硅胶压封试剂围栏\硅胶贴片
硅胶压封试剂围栏Press-to-Seal Silicone Isolators(Press-to-Seal gaskets),又称多样品芯片围栏、硅胶垫密片、试剂坝、硅胶片等。可用于同一芯片上的多样品反应,珍贵微量样品的检测等等。芯片围栏可使加样更准确,防止样品间的交叉反应,且与配套杂交反应盖片合用还可使加样更容易,反应和杂交更均匀,防止反应液挥发,避免空气中灰尘污染,是各种微阵列芯片进行杂交或免疫反应的理想辅助工具。试剂围栏可以压力粘贴,可干净去除。
硅胶属于惰性材料,对生物样品无不良影响,如果用来培养敏感性细胞,建议选用新型的无色透明的CultureWell “water-clear” silicone。
产品信息:
货号 |
深度 |
垫片类型 |
图片 |
70336-01 |
0.5mm |
S/S |
规格:单圆,25片/包 |
70336-31 |
0.5mm |
S/A |
70336-61 |
0.5mm |
A/A |
70336-02 |
1.0mm |
S/S |
70336-32 |
1.0mm |
S/A |
70336-62 |
1.0mm |
A/A |
70336-03 |
2.0mm |
S/S |
70336-33 |
2.0mm |
S/A |
70336-63 |
2.0mm |
A/A |
70336-04 |
2.5mm |
S/S |
70336-34 |
2.5mm |
S/A |
70336-64 |
2.5mm |
A/A |
70336-05 |
0.5mm |
S/S |
规格:单圆,25片/包 |
70336-40 |
0.5mm |
S/A |
70336-70 |
0.5mm |
A/A |
70336-10 |
1.0mm |
S/S |
70336-42 |
1.0mm |
S/A |
70336-72 |
1.0mm |
A/A |
70336-20 |
2.0mm |
S/S |
70336-44 |
2.0mm |
S/A |
70336-74 |
2.0mm |
A/A |
70336-25 |
2.5mm |
S/S |
70336-46 |
2.5mm |
S/A |
70336-76 |
2.5mm |
A/A |
70337-05 |
0.5mm |
S/S |
规格:单椭圆,25片/包 |
70337-40 |
0.5mm |
S/A |
70337-70 |
0.5mm |
A/A |
70337-10 |
1.0mm |
S/A |
70337-42 |
1.0mm |
S/A |
70337-72 |
1.0mm |
A/A |
70337-20 |
2.0mm |
S/S |
70337-44 |
2.0mm |
S/A |
70337-74 |
2.0mm |
A/A |
70337-25 |
2.5mm |
S/S |
70337-46 |
2.5mm |
S/A |
70337-76 |
2.5mm |
A/A |
70339-05 |
0.5mm |
S/S |
规格:8圆,25片/包 |
70339-40 |
0.5mm |
S/A |
70339-70 |
0.5mm |
A/A |
70339-10 |
1.0mm |
S/S |
70339-42 |
1.0mm |
S/A |
70339-72 |
1.0mm |
A/A |
70339-20 |
2.0mm |
S/S |
70339-44 |
2.0mm |
S/A |
70339-74 |
2.0mm |
A/A |
70339-25 |
2.5mm |
S/S |
70339-46 |
2.5mm |
S/A |
70339-76 |
2.5mm |
A/A |
70344-05 |
0.5mm |
S/S |
规格:12圆,25片/包 |
70344-38 |
0.5mm |
S/A |
70344-68 |
0.5mm |
A/A |
70344-10 |
1.0mm |
S/S |
70344-39 |
1.0mm |
S/A |
70344-69 |
1.0mm |
A/A |
70344-20 |
2.0mm |
S/S |
70344-40 |
2.0mm |
S/A |
70344-70 |
2.0mm |
A/A |
70345-05 |
0.5mm |
S/S |
规格:24圆,25片/包 |
70345-38 |
0.5mm |
S/A |
70345-68 |
0.5mm |
A/A |
70345-10 |
1.0mm |
S/S |
70345-39 |
1.0mm |
S/A |
70345-69 |
1.0mm |
A/A |
70345-20 |
2.0mm |
S/S |
70345-40 |
2.0mm |
S/A |
70345-70 |
2.0mm |
A/A |
70346-05 |
0.5mm |
S/S |
规格:8方,25片/包 |
70346-40 |
0.5mm |
S/A |
70346-70 |
0.5mm |
A/A |
70346-10 |
1.0mm |
S/S |
70346-42 |
1.0mm |
S/A |
70346-72 |
1.0mm |
A/A |
70346-20 |
2.0mm |
S/S |
70346-44 |
2.0mm |
S/A |
70346-74 |
2.0mm |
A/A |
70347-05 |
0.5mm |
S/S |
规格:10方,25片/包 |
70347-40 |
0.5mm |
S/A |
70347-70 |
0.5mm |
A/A |
70347-10 |
1.0mm |
S/S |
70347-42 |
1.0mm |
S/A |
70347-72 |
1.0mm |
A/A |
70347-20 |
2.0mm |
S/S |
70347-44 |
2.0mm |
S/A |
70347-74 |
2.0mm |
A/A |
70348-05 |
0.5mm |
S/S |
规格:16方,25片/包 |
70348-40 |
0.5mm |
S/A |
70348-70 |
0.5mm |
A/A |
70348-10 |
1.0mm |
S/S |
70348-42 |
1.0mm |
S/A |
70348-72 |
1.0mm |
A/A |
70348-20 |
2.0mm |
S/S |
70348-44 |
2.0mm |
S/A |
70348-74 |
2.0mm |
A/A |
70338-05 |
0.5mm |
S/S |
规格:红页,5张 |
70338-40 |
0.5mm |
S/A |
70338-70 |
0.5mm |
A/A |
70338-10 |
0.8mm |
S/S |
70338-42 |
0.8mm |
S/A |
70338-72 |
0.8mm |
A/A |
70338-20 |
1.6mm |
S/S |
70338-44 |
1.6mm |
S/A |
70338-74 |
1.6mm |
A/A |
70338-25 |
2.4mm |
S/S |
70338-46 |
2.4mm |
S/A |
70338-76 |
2,4mm |
A/A |
70338-29 |
0.25mm |
S/S |
规格:透明页,5张 |
70338-79 |
0.25mm |
A/A |
70338-30 |
0.5mm |
S/S |
70338-31 |
0.8mm |
S/S |
70338-32 |
1.6mm |
S/S |
70338-52 |
1.6mm |
S/A |
Cleaning Instructions:
We recommend rinsing chambers with distilled water immediately after each use followed by a brief, 5 minute soak in a solution of cell culture grade detergent, followed by repeated rinsing with diH2O. Do not use bleach as the silicone may absorb this solution.
After air-drying, chambers should be stored at room temperature.
Just before use, remove particulates from the chamber surface using scotch tape.
海德公司是Electron Microscopy Sciences 公司(简称 EMS )在中国的总代理,我们致力于将优秀的和符合中国客户的产品引入中国!精密的Dumont镊子和DiaTome钻石刀给电子显微镜用户带来便利。胶体金二抗来自荷兰的Aurion公司,这是一家专业的免疫金试剂的生产厂家,产品质量稳定,包括了光镜、电镜方面的免疫金试剂。提供美国EMS公司的镀膜仪(喷金仪)、辉光放电仪、低温灰化仪等等电子显微镜周边仪器,以及电镜铜网、支持膜、微珊、树脂包埋剂等等试剂耗材。来自英国的抗原修复锅和新型的免疫佐剂给更大病理研究和制药企业带来福音。海德生物代理国外产品的同时,也在某些领域进行着积极的探索和研究,我们将会不断的推出紧跟时代发展的优秀产品给广大的科研工作者。
单位名称: |
北京回龙观西大街115号龙冠大厦410
联系电话: |
Email: |
