2,2',4,5,5'-五溴-4'-甲氧基二苯醚
货号 | 中文名 | 英文名称 | CAS | 浓度 | 规格 |
WT-BE-C20064 | 2,2',3,3',4,5,5',6,6'-九氯-4'-甲氧基联 苯 | 2,2',3,3',4,5,5',6,6'-Nonachloro-4'-methoxybiphenyl | [N/A] | 50ug/ml in nonane | 1.2ml |
WT-BE-C20065 | 3,3',4',5-四氯-4-甲氧基联 苯 | 3,3',4',5-Tetrachloro-4-methoxybiphenyl | [N/A] | 50ug/ml in nonane | 1.2ml |
WT-BE-C20066 | 2,2',3,4',5'-五氯-4-甲氧基联 苯 | 2,2',3,4',5'-Pentachloro-4-methoxybiphenyl | [N/A] | 50ug/ml in nonane | 1.2ml |
WT-BE-C20067 | 2,2',4,5,5'-五溴-4'-甲氧基二苯 醚 | 2,2′,4,5,5′-Pentabromo-4′-methoxydiphenyl ether | [1185773-72-1] | 50ug/ml in nonane | 1.2ml |
WT-BE-C20068 | 2,2',4',5,6'-五溴-4-甲氧基二苯 醚 | 2,2′,4′,5,6′-Pentabromo-4-methoxydiphenyl ether | [1185773-71-0] | 50ug/ml in nonane | 1.2ml |
WT-BE-C20069 | 2,2',4',5-四溴-4-甲氧基二苯 醚 | 2,2′,4′,5-Tetrabromo-4-methoxydiphenyl ether | [602326-26-1] | 50ug/ml in nonane | 1.2ml |
WT-BE-C20070 | 4,5-二氯-2-(2,4-二氯苯氧)苯酚 | 4,5-Dichloro-2-(2,4-dichlorophenoxy)phenol(4-Chlorotriclosan) | [3380-44-7] | 50ug/ml in nonane | 1.2ml |
WT-BE-C20071 | 1-全氟戊基乙醇(5:2) | 1-Perfluoropentyl ethanol(5:2 secondary) | [914637-05-1] | N/A | 1.2ml |
WT-BE-C20072 | EPA方法513标准溶液CS0.25 | Custom Calibration Solution | [N/A] | in nonane | 500ul |
WT-BE-C20073 | Window Defining Mixture for DB5/BP5/HP2/Rtx-5/SPB-5 | Window Defining Mixture for DB5/BP5/HP2/Rtx-5/SPB-5 | [N/A] | in nonane | 1.2ml |
WT-BE-C20074 | 2,2',4,4'-四溴-5-甲氧基二苯 醚 | 2,2′,4,4′-Tetrabromo-5-methoxydiphenyl ether | [602326-19-2] | 50ug/ml in nonane | 1.2ml |
WT-BE-C20075 | 2,2',4,4',6'-五溴-5-甲氧基二苯 醚 | 2,2′,4,4′,6′-Pentabromo-5-methoxydiphenyl ether | [1185773-70-9] | 50ug/ml in nonane | 1.2ml |
WT-BE-C20076 | 2,2',4,4',5-五溴-5'-甲氧基二苯 醚 | 2,2′,4,4′,5-Pentabromo-5′-methoxydiphenyl ether | [1013432-29-5] | 50ug/ml in nonane | 1.2ml |
WT-BE-C20077 | 2378-TCDD Specificity Mix for DB5/BP5/HP2/Rtx-5/SPB-5 | 2378-TCDD Specificity Mix for DB5/BP5/HP2/Rtx-5/SPB-5 | [N/A] | in nonane | 1.2ml |
WT-BE-C20078 | Combined Window Defining/TCDD Resolution Mix | Combined Window Defining/TCDD Resolution Mix | [N/A] | in nonane | 1.2ml |
