PCDD & PCDF Calibration Solution CS3
货号 | 中文名 | 英文名称 | CAS | 浓度 | 规格 |
WT-BE-C20475 | PCDD & PCDF Calibration Solution CS1 | PCDD & PCDF Calibration Solution CS1 | [N/A] | in nonane | 200ul |
WT-BE-C20476 | PCDD & PCDF Calibration Solution CS2 | PCDD & PCDF Calibration Solution CS2 | [N/A] | in nonane | 200ul |
WT-BE-C20477 | PCDD & PCDF Calibration Solution CS3 | PCDD & PCDF Calibration Solution CS3 | [N/A] | in nonane | 200ul |
WT-BE-C20478 | PCDD & PCDF Calibration Solution CS4 | PCDD & PCDF Calibration Solution CS4 | [N/A] | in nonane | 200ul |
WT-BE-C20479 | PCDD & PCDF Calibration Solution CS5 | PCDD & PCDF Calibration Solution CS5 | [N/A] | in nonane | 200ul |
WT-BE-C20480 | PCDD & PCDF Calibration Solution CS6 | PCDD & PCDF Calibration Solution CS6 | [N/A] | in nonane | 200ul |
WT-BE-C20481 | PCDD & PCDF Calibration Solution CS7 | PCDD & PCDF Calibration Solution CS7 | [N/A] | in nonane | 200ul |
WT-BE-C20482 | PCDD & PCDF Calibration Solutions (CS1-CS7) | PCDD & PCDF Calibration Solutions (CS1-CS7) | [N/A] | in nonane | 1kit(7x200ul ampoules) |
WT-BE-C20483 | PCDD/PCDF/PCB Calibration Solution CS1 | PCDD/PCDF/PCB Calibration Solution CS1 | [N/A] | in nonane | 200ul |
WT-BE-C20484 | PCDD/PCDF/PCB Calibration Solution CS2 | PCDD/PCDF/PCB Calibration Solution CS2 | [N/A] | in nonane | 200ul |
WT-BE-C20485 | PCDD/PCDF/PCB Calibration Solution CS3 | PCDD/PCDF/PCB Calibration Solution CS3 | [N/A] | in nonane | 200ul |
WT-BE-C20486 | PCDD/PCDF/PCB Calibration Solution CS4 | PCDD/PCDF/PCB Calibration Solution CS4 | [N/A] | in nonane | 200ul |
WT-BE-C20487 | PCDD/PCDF/PCB Calibration Solution CS5 | PCDD/PCDF/PCB Calibration Solution CS5 | [N/A] | in nonane | 200ul |
WT-BE-C20488 | PCDD/PCDF/PCB Calibration Solution CS6 | PCDD/PCDF/PCB Calibration Solution CS6 | [N/A] | in nonane | 200ul |
WT-BE-C20489 | PCDD/PCDF/PCB Calibration Solution CS7 | PCDD/PCDF/PCB Calibration Solution CS7 | [N/A] | in nonane | 200ul |
WT-BE-C20490 | PCDD/PCDF/PCB Calibration Kit (CS1-CS7) | PCDD/PCDF/PCB Calibration Kit (CS1-CS7) | [N/A] | in nonane | 1kit(7x200ul ampoules) |
