Sampling Standard Solution
货号 | 中文名 | 英文名称 | CAS | 浓度 | 规格 |
WT-BE-C20526 | European Method EN-1948 Standard Solution CS1 | European Method EN-1948 Standard Solution CS1 | [N/A] | in nonane | 500ul |
WT-BE-C20527 | European Method EN-1948 Standard Solution CS2 | European Method EN-1948 Standard Solution CS2 | [N/A] | in nonane | 500ul |
WT-BE-C20528 | European Method EN-1948 Standard Solution CS3 | European Method EN-1948 Standard Solution CS3 | [N/A] | in nonane | 500ul |
WT-BE-C20529 | European Method EN-1948 Standard Solution CS4 | European Method EN-1948 Standard Solution CS4 | [N/A] | in nonane | 500ul |
WT-BE-C20530 | European Method EN-1948 Standard Solution CS5 | European Method EN-1948 Standard Solution CS5 | [N/A] | in nonane | 500ul |
WT-BE-C20531 | European Method EN-1948 Standard Solution CS6 | European Method EN-1948 Standard Solution CS6 | [N/A] | in nonane | 500ul |
WT-BE-C20532 | Extended Calibration/Low Level Solution | Extended Calibration/Low Level Solution | [N/A] | in nonane | 500ul |
WT-BE-C20533 | European Method EN-1948 Calibration Kit (CS1-CS6) | European Method EN-1948 Calibration Kit (CS1-CS6) | [N/A] | in nonane | 1kit(6x500ul ampoules) |
WT-BE-C20534 | Extraction Standard Solution | Extraction Standard Solution | [N/A] | in nonane | 1.2ml |
WT-BE-C20535 | Syringe Standard Solution | Syringe Standard Solution | [N/A] | in nonane | 1.2ml |
WT-BE-C20536 | Sampling Standard Solution | Sampling Standard Solution | [N/A] | in nonane | 1.2ml |
WT-BE-C20537 | PCDD/PCDF Solution/Mixture | PCDD/PCDF Solution/Mixture | [N/A] | in nonane | 1.2ml |
WT-BE-C20538 | Extended Calibration/Low Level Solution ((CS1)/2) | Extended Calibration/Low Level Solution ((CS1)/2) | [N/A] | in nonane | 500ul |
