Deuterated PAH Solution/Mixture
货号 | 中文名 | 英文名称 | CAS | 浓度 | 规格 |
WT-BE-C20587 | Matrix Spiking Solution | Matrix Spiking Solution | [N/A] | in nonane | 1.2ml |
WT-BE-C20588 | Recovery Standard Solution | Recovery Standard Solution | [N/A] | in nonane | 1.2ml |
WT-BE-C20589 | Sample Fortification Solution | Sample Fortification Solution | [N/A] | in nonane | 1.2ml |
WT-BE-C20590 | Native Stock PC DDs and PCD Fs | Native Stock PC DDs and PCD Fs | [N/A] | in nonane | 1.2ml |
WT-BE-C20591 | Deuterated PAH Solution/Mixture | Deuterated PAH Solution/Mixture | [N/A] | N/A | 1.2ml |
WT-BE-C20592 | Deuterated PAH Solution/Mixture | Deuterated PAH Solution/Mixture | [N/A] | N/A | 1.2ml |
WT-BE-C20593 | Native PAH Solution/Mixture | Native PAH Solution/Mixture | [N/A] | N/A | 1.2ml |
WT-BE-C20594 | eta-1,2,5,6,9,10-Hexabromocyclododecane | eta-1,2,5,6,9,10-Hexabromocyclododecane | [3194-55-6] | 50ug/ml in Tolu ene | 1.2ml |
WT-BE-C20595 | Deuterated PAH Solution/Mixture | Deuterated PAH Solution/Mixture | [N/A] | N/A | 1.2ml |
WT-BE-C20596 | Native PAH Solution/Mixture | Native PAH Solution/Mixture | [N/A] | N/A | 1.2ml |
