全氟癸基磷酸
货号 | 中文名 | 英文名称 | CAS | 浓度 | 规格 |
WT-BE-C20776 | 全氟正癸酸 | Perfluoro-n-decanoic acid | [335-76-2] | 50ug/ml in methanol | 1.2ml |
WT-BE-C20777 | 全氟正十二酸 | Perfluoro-n-dodecanoic acid | [307-55-1] | 50ug/ml in methanol | 1.2ml |
WT-BE-C20778 | 全氟癸基磷酸 | Perfluorodecylphosphonic acid | [52299-26-0] | 50ug/ml in methanol | 1.2ml |
WT-BE-C20779 | 全氟正庚 酸 | Perfluoro-n-heptanoic acid | [375-85-9] | 50ug/ml in methanol | 1.2ml |
WT-BE-C20780 | 全氟正己酸 | Perfluoro-n-hexanoic acid | [307-24-4] | 50ug/ml in methanol | 1.2ml |
WT-BE-C20781 | 全氟正十六烷酸 | Perfluoro-n-hexadecanoic acid | [67905-19-5] | 50ug/ml in methanol | 1.2ml |
WT-BE-C20782 | 全氟己基磷酸 | Perfluorohexylphosphonic acid | [40143-76-8] | 50ug/ml in methanol | 1.2ml |
WT-BE-C20783 | 全氟正壬酸 | Perfluoro-n-nonanoic acid | [375-95-1] | 50ug/ml in methanol | 1.2ml |
WT-BE-C20784 | 全氟正辛酸 | Perfluoro-n-octanoic acid | [335-67-1] | 50ug/ml in methanol | 1.2ml |
WT-BE-C20785 | 全氟正十八酸 | Perfluoro-n-octadecanoic acid | [16517-11-6] | 50ug/ml in methanol | 1.2ml |
WT-BE-C20786 | 全氟辛基磷酸 | Perfluorooctylphosphonic acid | [40143-78-0] | 50ug/ml in methanol | 1.2ml |
WT-BE-C20787 | 全氟正戊 酸 | Perfluoro-n-pentanoic acid | [2706-90-3] | 50ug/ml in methanol | 1.2ml |
WT-BE-C20788 | PFAS混标 | Native PFAS Solution/Mixture | [N/A] | 2ug/ml in methanol | 1.2ml |
WT-BE-C20789 | 全氟正十四酸 | Perfluoro-n-tetradecanoic acid | [376-06-7] | 50ug/ml in methanol | 1.2ml |
WT-BE-C20790 | 全氟正十三酸 | Perfluoro-n-tridecanoic acid | [72629-94-8] | 50ug/ml in methanol | 1.2ml |
WT-BE-C20791 | 全氟正十一酸 | Perfluoro-n-undecanoic acid | [2058-94-8] | 50ug/ml in methanol | 1.2ml |
