真空泵
真空泵油
真空泵油
进口
阿尔卡特 莱宝 贝克 普旭
各种型号都有
供应 ALCATEL ECKER BUSCH  EDWARDS KINNEY PFEIFFER LEYBOLD RIETSCHLE  ULVAC VARIAN STOKES WELCH 真空泵油
ALCATEL ADIXEN
真空泵油
A100 A102 A111 A113 A119 A120 A121 A200 A300 A214 A-100 A-102 A-111 A-113 A-119
A-120 A-121 A-200 A-300 A-214 ALCATEL100 ALCATEL102 ALCATEL111 ALCATEL113
ALCATEL119 ALCATEL120 ALCATEL121 ALCATEL200 ALCATEL300 ALCATEL214
ALCATEL-100 ALCATEL-102 ALCATEL-111 ALCATEL-113 ALCATEL-119 ALCATEL-120
ALCATEL-121 ALCATEL-200 ALCATEL-300 ALCATEL-214 ALCATEL 100 ALCATEL 102
ALCATEL 111 ALCATEL 113 ALCATEL 119 ALCATEL 120 ALCATEL 121 ALCATEL 200
ALCATEL 300 ALCATEL 214 ALCATEL100 OIL ALCATEL102 OIL ALCATEL111 OIL
ALCATEL113 OIL ALCATEL119 OIL ALCATEL120 OIL ALCATEL121 OIL
ALCATEL200 OIL ALCATEL300 OIL ALCATEL214 OIL
EDWARDS 真空泵油
Ultra grade 15 Ultra grade 19 Ultra grade 20 Ultra grade 70
Ultragrade 15 Ultragrade 19 Ultragrade 20 Ultragrade 70 Ultragrade-15 Ultragrade-19 Ultragrade-20 Ultragrade-70 Ultragrade15 Ultragrade19 Ultragrade20 Ultragrade70 Mechanical Pump Oils Edwards TW Super Vac fluid 15 Super Vac fluid 19 Super Vac fluid 20 Super Vac fluid15 Super Vac fluid19 Super Vac fluid20 SuperVac fluid15 SuperVac fluid19 SuperVac fluid20 Super A ED15 ED16 ED20 ED TW ED 15 ED 16 ED 20
TW Oil Mechanical Pump Fluids Hydrocarbon Edwards No 45 Oil Edwards Q45 Edwards No45 Oil Edwards 45 Edwards45 Mechanical Pump Oil-45 Mechanical Pump Oil45 Mechanical Pump Fluids Hydrocarbon Ultragrade 15 Ultragrade 19 Ultragrade 20 Ultragrade 70 Edwards TW BOC Edwards 45
Fluid Fomblin MFY25/6 Fomblin MFY06/6 Fomblin MFY06/6 Fomblin MFY 14/6 Fomblin 25/6 Fomblin 14/6 Inert Fluids Alcatel 113 Edwards 1506 Krytox 1506 Krytox 1514 Krytox 1525
PFPE YVAC 06/6 16/6 25/6 Drynert 25/6 Krytox1506 Krytox1514 Krytox1525 Diffusion Pump Fluids AP201 Silicone 702 Silicone 704EU Silicone 705 L9 Santovac Hydrocarbon Krytox 1506 Krytox 1514 Krytox 1525 Silicone702 Silicone704EU Silicone705 Silicone704
BECKER真空泵油
FO 100 SS 100 M 100 FO100 SS100 M100
BUSCH真空泵油
VM032 VM068 VM32 VM68 VM100 VMH100 VSL032 VSL068 VSL100 VM 32 VM 68 VM 032 VM 068 VM 100    VMH 100 VSL 032 VSL 068 VSL 100 300SD 300 SD VS600 VS 600 R580 R590 R568 R540 R530  R130 R605 R610 R-580 R-590 R-568 R-540 R-530  R-130 R-605 R-610
KINNEY
真空泵油
Halovac60 OILS 01LS Halovac100 OILS Halovac125 OILS Halovac190 OILS Halovac-60 OILS 01LS Halovac-100 OILS Halovac-125 OILS Halovac-190 OILS Halovac 60 OILS 01LS Halovac 100 OILS Halovac 125 OILS Halovac 190 OILS
KINNEY 真空泵油
TYPE A  KV100 oil LT oil KV-100 Mechanical Vacuum Pump Oil KV100 Mechanical Vacuum Pump Oil LR Oil Liquid Ring Pump Sealant LT Mechanical Vacuum Pump Oil Tuthill S500 Mechanical Vacuum Pump Oil     KINNEY A KINNEY AX   KINNEY SUPER X
AX OIL -4/1GL HYD KV 100-4/1GL HYD KV100 4/1GL HYD KV100-4/1GL HYD KV 100-4/1GL HYD KV-100 4/1GL KV-100 KV100 KV 100 LR-5GL PL LR5GL PL LR 5GL PL LR OIL 5GL PL LT-BLK LT BLK LT OIL BLK SUPER X SUPER-X
LEYBOLD 真空泵油
GS 32 GS 555 GS 77 N 62 N 62H N62H GS32 GS555
HE100 HE125 HE175 HE200 HE400 HE500 HE700 HE1200 HE1400 HE1600 HE2500 HE2700 GS77 N62 HE-100 HE-125 HE-175 HE-200 HE-400 HE-500 HE-700 HE-1200 HE-1400 HE-1600 HE-2500 HE-2700 GS-77 N-62 N-62H HE 100 HE 175 HE 200 HE 400 HE 500 HE 700 HE 1200 HE 1400 HE 1600 HE 2500 HE 2700 SCH224 NC1/4 NC10 SCH 224 NC 1/4 NC 10
PFEIFFER真空泵油
TL 011 P-3 F5 TL 011 P3 F3 F4 F5 D1 TL011 TL-011 P-3 F-3 F-4 F-5 D-1 OIL TL 011 OIL P-3 OIL F5 OIL TL 011 OIL P3 OIL F3 OIL F4 OIL F5 OIL D1 OIL TL011 OIL TL-011 OIL P-3 OIL F-3 OIL F-4 OIL F-5 OIL D-1 Berliner Strasse 43 D-35614 Asslar Lubricant/ Operating Fluid Lubricant Operating Fluid PK 001 107 –T PK001 107 -T PK001107 -T PK001107-T Germany D-35614
RIETSCHLE  WELCH真空泵油
MULTI-LUBE 46 MULTI-LUBE 100 MULTI-LUBE46 MULTI-LUBE100 SUPER LUBE 46
SUPER LUBE 100 SUPERLUBE 46 SUPERLUBE 100 SUPER LUBE46
SUPER LUBE100 PGY193 PGY 193
CAT. NO. 8995G-11 8995G-15 8995G-20 SIZE Liter Gallon 5 Gallon Premium Vacuum Pump Oil CAT. NO. 8995P-11 8995P-15 8995P-20 DUOSEAL Vacuum Oil CAT. NO. 1407K-11 1407K-15 1407K-20 Gold Vacuum Pump Oil CAT. NO. 8995G 11 8995G 15 8995G 20 SIZE Liter Gallon 5 Gallon Premium Vacuum Pump Oil CAT. NO. 8995P 11 8995P 15 8995P 20 DUOSEAL Vacuum Oil CAT. NO. 1407K 11 1407K 15 1407K 20 Gold Vacuum Pump Oil CAT. NO. 8995G11 8995G15 8995G20 SIZE Liter Gallon 5 Gallon Premium Vacuum Pump Oil CAT. NO. 8995P11 8995P15 8995P20 DUOSEAL Vacuum Oil CAT. NO. 1407K11 1407K15 1407K20 DIRECTORR 8995P PREMIUM VACUUM PUMP OIL DIRECTORR-8995P PREMIUM VACUUM PUMP OIL DIRECTORR8995P PREMIUM VACUUM PUMP OIL DIRECTORR 8995G GOLD VACUUM PUMP OIL DIRECTORR8995G GOLD VACUUM PUMP OIL DIRECTORR-8995G GOLD VACUUM PUMP OIL DuoSeal DUO SEAL GOLD 8995C PUMPING/TRAPPING FLUID 1407K DUOSEAL VACUUM PUMP OIL Gold Vacuum Pump Oil
ULVAC真空泵油
ULVOIL R7 ULVOIL R4 ULVOIL R2 ULVOIL R -7 ULVOIL R-4 ULVOIL R-2 ULVOIL R-2000
ULVOIL R-4000 ULVOIL R-7000 R7 R4 R2 R-7 R-4 R-2 SMR100 SMR 100 MR-100 MR-200 MR100 MR200 NEOVAC SX NEOVAC SY NEOVAC-SX NEOVAC-SY DIFFUSION OIL SO-M SO-H SA-H SOM SOH SAH
STOKES真空泵油
V-LUBE A V-LUBE B V-LUBE C V-LUBE D V-LUBE F V-LUBE G V-LUBE H V-LUBE J VLUBE A VLUBE B VLUBE C VLUBE D VLUBE F VLUBE G VLUBE H VLUBE J V-LUBE-A V-LUBE-B V-LUBE-C V-LUBE-D V-LUBE-F V-LUBE-G V-LUBE-H V-LUBE-J V LUBE A V LUBE B V LUBE C V LUBE D V LUBE F V LUBE G V LUBE H V LUBE J
VARIAN真空泵油
GP CS Varian Oil GP Type Mechanical Pump Fluid Varian GP Type Fluid Varian CS Type Fluid
Varian   ELITE Z
CMP KINLYVAC 真空泵油
CMP 19 CMP 20 ULTRA HT   CMP 19, In Europe CMP 67 CMP ELITE Z    CMP 41     CMP 57 / 51 CMP ELITE A   CMP 70 ULTRA HT   CMP 97
本司是专业真空泵配件及真空油供应商,提供售前售后服务。主营欧美日等进口真空泵ALCATEL阿尔卡特ADIXEN阿迪森BECKER贝克BUSCH普旭博士BOCEDWARDS爱德EBARA任原GAST嘉仕达ORION好利旺OERIKON欧瑞康LEYBOLD莱宝PFEIFFER普发PVR普威乐TOMAS托马斯RIETSCHLE里其乐ULVAC爱发科MITSUVAC三津海VARIAN瓦里安WELCH韦尔等等耗材及维修服务。
我们有一支热情周到的客服队伍,丰富行业经验的工程师,为您提供诚信,专业,高效,优质的服务。为此本司也获得了国际国内市场的认可。
嘉定宝钱公路5000弄262
