过滤耗材
PriboFast黄曲霉毒素总量免疫亲和柱
Aflatoxin B1B2G1G2M1M2
进口
pribolab普瑞邦
3ML
销售商:
Aflatoxin (AFLA) is a mycotoxin which is produced by several Aspergillus species. Aflatoxin exposure produces an acute hepatic necrosis, resulting later in cirrhosis, and/or carcinoma of the liver. Acute hepatic failure is made manifest by hemorrhage, edema, alteration in digestion, and absorption and/or metabolism of nutrients and mental changes and/or coma. In line with various regulatory laws, it is required to control the AFLA content in food and feed.
Intended Use
Immunoaffinity columns are intended for use in a wide range of commodities including vegetable, fats, soy, vinegar etc. For this process, a representative sample of the commodity to be analysed is extracted with a mixture of solvent. The extract is filtered and then diluted with a buffer. The diluted extract can be run directly over the Immunoaffinity columns, in which the aflatoxins are bound and separated from the other substances of the extract. After a short rinsing phase isolated aflatoxins can be eluted using methanol. This eluate is suited for determining the concentration of aflatoxins directly with the HPLC.
----将免疫亲和柱连接于10.0mL玻璃注射器下。准确移取10.0mL样品提取液注入玻璃注射器;
----将空气压力泵与玻璃注射器连接,调节压力使溶液以约6mL/min流速缓慢通过免疫亲和柱,直至2~3mL空气通过柱体;
----用10.0mL 0.1%的吐温/PBS清洗,再以10.0mL水淋洗柱子2次,弃去全部流出液,并使2mL~3mL空气通过柱体;
----准确加入1.0mL色谱级甲醇洗脱,流速为1 mL/min ~2mL/min,收集全部洗脱液于玻璃试管中,供检测用。
注:如样品处理后仍然很粘稠,请加大离心力及离心时间,或者选择减少加入亲和柱中的样品量,避免出现亲和柱堵塞。
PriboLab作为面向全球提供霉菌毒素检测技术解决方案的主要服务商之一,凭借强大的研发团队和霉菌毒素检测技术的研究,为全球农业生产、食品加工与粮食、饲料工业等行业提供专业的真菌毒素检测技术产品与技术服务。积极为客户提供优质的霉菌毒素检测技术与产品服务,为客户提供适宜的霉菌毒素检测方案,帮助客户建立高效优质的霉菌毒素项目检测分析平台。
PriboLab is the major global facilitator of technical resolve project for mycotoxin detection.
PriboFast免疫亲和柱系列产品包括以下特点:
采用高特异性和高亲和力的的单克隆抗体。
柱容量高,有效提高纯化效率
达到真菌毒素检测的国内外限量标准
良好的稳定性和可靠性,回收率达到90%
可重复性(CV%)<5%
纯化后直接用于ELISA 法,高效液相色谱法,荧光光度法等。
稳定性:18个月
可以用于复杂样品检测,包括食品、饲料、调味品等多种复杂基质
可用于黄曲霉毒素B1B2G1G2M1M2,呕吐毒素,伏马毒素,赭曲霉毒素和玉米赤霉烯酮的检测
中国区客服热线: 400-688-5349
PriboFastR系列多功能净化柱采取的方法就是多重机制吸附杂质并快速萃取净化的方法,它将极性、非极性及离子交换等多类官能基团作为复合吸附填料作为填充剂填充到柱体中,这些填料可以选择性的吸附样品中的如脂类、蛋白类和色素等主要杂质吸附,同时将待测目标物(如中黄曲霉毒素 玉米赤霉烯酮等各种霉菌毒素)留在样液中,从而达到净化和富集的目的。多功能净化柱无需活化、上样、洗脱等步骤,能够将食品或饲料提取液中的杂质与真菌毒素进行一步分离,使用快捷、方便,减少萃取步骤,有效保证分析的更加准确可靠,降低检测成本,有效提高检测效率。
PriboFastR 系列多功能净化柱具以下特点:
采取多重机制填料吸附杂质并快速萃取净化
一步法快速净化,时间短(30s
独特设计原理—干扰物被截留在柱内填充物,待测毒素通过净化柱
可同时净化多种毒素:黄曲霉毒素、玉米赤霉烯酮和单端孢霉烯族毒素(包括呕吐毒素等)检测样品。
稳定性—30个月以上
回收率—90%以上
可以用于检测黄曲霉毒素、 玉米赤霉烯酮、呕吐毒素、雪腐镰刀菌烯醇T-2毒素、3-乙酰基脱氧雪腐镰刀菌烯醇、15-乙酰基脱氧雪腐镰刀菌烯醇等多种霉菌毒素。
适用于食品、粮食饲料、饮料、药材等样品的净化
PriboFast酶联免疫检测试剂盒系列:
采取直接竞争ELISA方法,检测时间段。
精确度与与HPLC方法接近,定量范围宽。
重复性好 ,不同实验室之间检测结果稳定性好
高灵敏度和高回收率
符合霉菌毒素相关标准和中国有关限量要求;
稳定性高,达到12个月
操作简单:简单培训即可独立操作
北京高新科技城总部基地
010-52453171 13811958057
