06480-30
Wave Biotech Hot Lips® Tube Sealer
Securely seal any thermoplastic tubing from 6.4 to 31.8mm OD
Works with liquid-filled tubing—no need to drain before use
Sealer only touches outside of tubing, while inside remains contamination-free
One-button control provides simple, error-free operation
Securely seal a broad range of tubing sizes and materials with this flexible tube sealer. Compatible with all thermoplastics, including Tygon®, C-Flex®, PharMed® and vinyl, it forms a half-inch wide seal that can only be opened when cut, preventing accidental leakage or contact with foreign materials. Compact, lightweight, and versatile, the flexible tube sealer is suitable for a broad range of applications, from sealing media bag inlet and outlet tubing to closing off fermentor or bioprocess vessel sampling ports. Works with Masterflex pump tubing as well as general purpose transfer tubing.
To seal tubing, simply select tubing material, ID, and OD from the pre-programmed LCD menu, insert tubing in the holder, and push start button. The sealer automatically applies the optimum temperature, pressure, and cooling cycle, then opens when seal is set. The display provides continuous feedback during operation, while a PC port allows you to update programs and download new tubing options. Programming lockout prevents unauthorized access
Flexible tubing sealer can be used in conjunction with sterile tubing fuser 06480-50 to join two liquid-filled sections of tubing. After sealing tubing, transfer to the sterile tubing fuser to connect aseptically without releasing fluid into the fuser or surrounding environment. Please specify voltage setting when ordering.
Specifications
Min tubing :OD 6.4mm
Max tubing :OD 31.8mm
Cycle time :3 minutes (max); includes heat-up and cool-down
Dimensions (L x W x H) 35.5 x 20.3 x 16.5 cm
Power (VAC) 230
