其他生物试剂
GE Silwet L-77 E表面活性剂
进口
GE
10ML
550元
简单介绍 GE 表面活性剂 Silwet 77 Silwet L-77
本产品为拟南芥、油菜等植物转化辅助试剂,是表面活性剂的一种,是NP40转化效率的40倍以上,本产品为GE公司的专利产品(注册商标)
详细介绍:
名称
品牌货号
型号包装
级别
价格
Silwet L-77 E表面活性剂
分装S5505-10ml
10ml
现货
350
分装S5505-35ml
35ml
现货
950
GE:SL77080596
10ML
现货
550
GE:SL77080596
35ML
现货
1550
SILWET L-77 is a unique surfactant designed to improve the spreading
and wetting properties of pesticide spray mixes. SILWET L-77 utilizes
unique organosilicone chemistry which provides the most complete
coverage possible. SILWET L-77 can improve cuticular penetration of
plant surfaces by the spray mix. Optimum application and resultant
effects can be influenced by many factors. Consequently, it is
recommended that careful observation of the spray deposit be made and
adjuvant rates adjusted accordingly. Applications should be made to
ensure thorough coverage without excessive run-off.
TYPICAL PROPERTIES
Physical appearance Clear, light amber liquid
Pounds per gallon 8.370
Specific gravity 1.0 - 1.01
pH (1.0%) 6.0 - 7.0
Freeze Point less than 35 degrees F
Surface Tension (0.125% v/v) less than 25 dynes/cm
Contact Angle (0.125% v/v) less than 5 degrees F
Draves Wet Time (0.125% v/v) less than 15.0 seconds
GENERAL PRODUCT INFORMATION
(1) SILWET L-77 contains organosilicone surfactants designed to
provide superior wetting and coverage.
(2) SILWET L-77 can improve water penetration of hard to wet soils
and provide more uniform distribution of applied moisture.
(3) SILWET L-77 is generally compatible with pesticides and
fertilizer solutions.
(4) SILWET L-77 may cause excessive foam if not properly added to the
spray tank. To minimize foam generation, add SILWET L-77 to the
tank after all other ingredients are added. If foaming is still
a concern, add an antifoaming agent, such as FOAMBUSTER or COMBAT
PLUS to the tank prior to adding SILWET L-77.
(5) Do not allow spray mixes containing SILWET L-77 to sit over 36hours.
GE Silwet L-77 E表面活性剂 Silwet 77
Kinetic是一种独特的非离子有机硅润湿剂/展着剂/渗透剂,用来加快农药吸收附着和营养物质渗透进植物的叶径。因其独特的功能,比普通的表面活性剂使用的比率低很多。主要的有效成分为Silwet
L-77,在技术上避免了Silwet
L-77在使用上的很多缺点,如农药有效成分的流失,对植物蒸发作用的影响,泡沫太多,在某些PH值条件下易水解,毒性太强等缺点。
有效成分:
聚环醚改性聚二甲基硅氧烷;聚氧乙烯聚氧丙烯共聚物
主要特点:
Ø     超级的展着扩散能力
Ø        迅速润湿叶面,润湿时间为14.2秒
Ø        将药液锁定在叶面上不滴落,并能抗雨水冲刷
Ø        能使药液向上扩散,增加扩散面积
Ø        符合环保要求
理化性质:
Ø        外观:               低粘性液体
Ø        气味:               微有助剂气味,无刺激性
Ø        有效成分含量(%):    ≥99%
Ø        PH(5%水溶液):       5.0-6.0
Ø        比重:               1.025g/ml
Ø        表面张力(0.1%水溶液):29达因/厘米
Ø        接触角(0.1%水溶液): 0
Ø        展着性(0.1%水溶液): 7.5
Ø        闪点:               93℃
应用范围:
Ø        大豆,稻谷和蔬菜除草剂
Ø        用于水性除草剂和芽后非选择性除草剂特别有效Ø        植物生长调节剂
使用方法:
本产品只能用做桶混助剂使用,可提高喷雾覆盖面,提高渗透性和降低喷雾量。在实际使用中,一定要在农药稀释后才可加入,并在配药完成后36小时内施药完毕。此外赤霉素用于柑橘属作物,柑橘新鲜上市时,本品慎用.具体的使用方法如下:
Ø        农作物:0.05%-0.1%v/v
Ø        草坪: 0.05%-0.125%v/v
Ø        树:    0.1%-0.2%v/v
北京智杰方远科技有限公司成立于2011年是一家进口胎牛血清专业供应商,专注细胞生物学试剂开发、销售、服务的高新技术企业。
主要代理产品如下: 1.进口胎牛血清:美国GIBCO、德国PAN-biotech、以色列BI、澳大利亚Ausgene-X、德国Cegrogen、美国GEMINI、美国Hyclone等。
2.MP Bio、日本同仁、TAKARA、Biolog微生物鉴定板、Borer清洗产品、台湾旭基。 3.Thermo、SIGMA、QIAGEN、MERCK、LEICA、Millipore、Whatman等。
好产品+好价格+好服务为经营理念,希望不断发展的智杰方远成为您最佳的选择!
北京市海淀区马连洼北路九号东居兴业写字楼
