六硼化镧灯丝/denka
标准Denka M-3型六硼化镧灯丝Standard Denka Model 3 LaB6 Cathodes,在SEM、TEM、X-Ray、Electron Beam Lithography等领域应用,六硼化镧都是最佳的阴极材料。
特征:
标准尖Standard Tips | 平尖Flat Tips | 尖尖Sharp Tips | |
Brightness | About 10 times that of tungsten, 1x106 A/cm2· Str |
About 5 times that of tungsten, 2-5x105 A/cm2· Str |
Twice as bright as standard tips 2x106 A/cm2· Str |
Saturation | Mono spot at about 1,500°C. | Mono spot at about 1,400°C | Almost the same as standard tips |
Crossover | Small (7-10µ) | Large (11-13µ) | Small (7-10µ) |
Angular distribution | Sharp1.6 x10-2 rad | Broad, 3.3-4.2x10-2 rad | Sharp1.6 x10-2 rad |
Used Temperature | Low temperature | Low temperature | High temperature. |
Lifetime | Long life but shorter than flat tips. | Long life; usable at low temperatures and crystallized end changes slowly. | Short |
Operation | Not so difficult. | Easy; thanks to its large spot size and broad adjusting range. | Difficult; Point adjustment needed! |
Stability | High | High; vulnerable to thermal expansion or vibration. | Middle;. Vulnerable to the thermal expansion or vibration. Adjustment is sometimes necessary. |
Technology Needed | High | Ordinary | Very high |
货号 | 产品描述 | 规格 |
80900-05 | Denka M-3 LaB6 Standard for JEOL 60-5UM | 个 |
80900-10 | Denka M-3 LaB6 Standard for JEOL 60-10UM | 个 |
80900-11 | Denka M-3 LaB6 Standard for JEOL 90-20UM | 个 |
80900-20 | Denka M-3 LaB6 Standard for JEOL 60-20UM | 个 |
80900-21 | Denka M-3 LaB6 Standard for JEOL 90-21UM | 个 |
80900-40 | Denka M-3 LaB6 Standard for JEOL 60--40UM | 个 |
80900-41 | Denka M-3 LaB6 Standard for JEOL 90-41UM | 个 |
80900-60 | Denka M-3 LaB6 Standard for JEOL 60-60UM | 个 |
80900-61 | Denka M-3 LaB6 Standard for JEOL 90-60UM | 个 |
80900-80 | Denka M-3 LaB6 Standard for JEOL 60-80UM | 个 |
80900-100 | Denka M-3 LaB6 Standard for JEOL 60-100UM | 个 |
80900-101 | Denka M-3 LaB6 Standard for JEOL 90-100UM | 个 |
80900-05 | Denka M-3 LaB6 Standard for JEOL JEOL 60-5UM | 个 |
80904-5 | Denka M-3 LaB6 Standard for KF SHARP 60-5UM | 个 |
80904-10 | Denka M-3 LaB6 Standard for KF SHARP 60-10UM | 个 |
80904-20 | Denka M-3 LaB6 Standard for KF FLAT TIP 60-20UM | 个 |
80904-21 | Denka M-3 LaB6 Standard for KF FLAT TIP 90-20UM | 个 |
80904-40 | Denka M-3 LaB6 Standard for KF FLAT TIP 60-40UM | 个 |
80904-41 | Denka M-3 LaB6 Standard for KF FLAT TIP 90-40UM | 个 |
80904-60 | Denka M-3 LaB6 Standard for KF FLAT TIP 60-60UM | 个 |
80904-61 | Denka M-3 LaB6 Standard for KF FLAT TIP 90--60UM | 个 |
80904-80 | Denka M-3 LaB6 Standard for KF FLAT TIP 60-80UM | 个 |
80904-81 | Denka M-3 LaB6 Standard for KF FLAT TIP 90-80UM | 个 |
80904-100 | Denka M-3 LaB6 Standard for KF FLAT TIP 60-100UM | 个 |
80904-101 | Denka M-3 LaB6 Standard for KF FLAT TIP 90-100UM | 个 |
80906-5 | Denka M-3 LaB6 Standard for CAMBRIDGE 60-5UM | 个 |
80906-10 | Denka M-3 LaB6 Standard for CAMBRIDGE 60-10UM | 个 |
80906-11 | Denka M-3 LaB6 Standard for CAMBRIDGE 90-20UM | 个 |
80906-20 | Denka M-3 LaB6 Standard for CAMBRIDGE 60-20UM | 个 |
80906-21 | Denka M-3 LaB6 Standard for CAMBRIDGE 90-40UM | 个 |
80906-40 | Denka M-3 LaB6 Standard for CAMBRIDGE 60-40UM | 个 |
80906-41 | Denka M-3 LaB6 Standard for CAMBRIDGE 90-60UM | 个 |
80906-60 | Denka M-3 LaB6 Standard for CAMBRIDGE 60-60UM | 个 |
80906-61 | Denka M-3 LaB6 Standard for CAMBRIDGE 90-80UM | 个 |
80906-80 | Denka M-3 LaB6 Standard for CAMBRIDGE 60-80UM | 个 |
80906-81 | Denka M-3 LaB6 Standard for CAMBRIDGE 60-100UM | 个 |
80906-100 | Denka M-3 LaB6 Standard for CAMBRIDGE 60-100UM | 个 |
80908-5 | Denka M-3 LaB6 Standard for HITACHI 60-5UM | 个 |
80908-10 | DENKA M3-H2 LAB6 FOR HITACH 60-10UM | 个 |
80908-11 | DENKA M3-H2 LAB6 FOR HTIACHI 90-20UM | 个 |
80908-20 | DENKA M3-H2 LAB6 FOR HITACHI 60-20UM | 个 |
80908-21 | DENKA M3-H2 LAB6 FOR HITACHI 90-40UM | 个 |
809098-40 | DENKA M3-H2 LAB6 FOR HITACHI 60-40UM | 个 |
80908-41 | DENKA M3-H2 LAB6 FOR HITACHI 90-60UM | 个 |
80908-60 | DENKA M3-H6 LAB6 FOR HITACHI 60-60UM | 个 |
80908-61 | DENKA M3-H2 LAB 6 FOR HITACHI 90-60UM | 个 |
80908-80 | DENKA M3-H6 LAB6 FOR HITACHI 60-80UM | 个 |
80908-81 | DENKA M3-H2 LAB6 FOR HITACHI 90-100UM | 个 |
80908-100 | DENKA M3-H6 LAB6 FOR HITACHI 60-100UM | 个 |
海德公司是Electron Microscopy Sciences 公司(简称 EMS )在中国的总代理,我们致力于将优秀的和符合中国客户的产品引入中国!精密的Dumont镊子和DiaTome钻石刀给电子显微镜用户带来便利。胶体金二抗来自荷兰的Aurion公司,这是一家专业的免疫金试剂的生产厂家,产品质量稳定,包括了光镜、电镜方面的免疫金试剂。提供美国EMS公司的镀膜仪(喷金仪)、辉光放电仪、低温灰化仪等等电子显微镜周边仪器,以及电镜铜网、支持膜、微珊、树脂包埋剂等等试剂耗材。来自英国的抗原修复锅和新型的免疫佐剂给更大病理研究和制药企业带来福音。海德生物代理国外产品的同时,也在某些领域进行着积极的探索和研究,我们将会不断的推出紧跟时代发展的优秀产品给广大的科研工作者。
单位名称: |
北京回龙观西大街115号龙冠大厦410
联系电话: |
Email: |
