45240-100 kimble石油尖底刻度离心管100ml
KIMBLE & CHASE 45246-100大容量石油测试用尖底刻度离心管 (Centrifuge Tubes) Centrifuge Tube, Oil Test, 8”, Screw Cap
* KG-33硼矽酸玻璃制成
* 主要用於测试液化石油气(Liquified Petroleum gases)中之残馀物
* 刻度标示量等於内容量
* 刻度为珐琅材质
* 尺寸37x203mm,8寸长
* 附PTFE垫片螺旋盖
产品介绍:离心管旋盖盖为有PTFE膜的胶垫黑色酚醛塑料盖,管身有可持久保存的白色瓷釉刻度和标签区,有精细刻度,刻度0-1ml之间最小刻度是0.05ml;1-3ml最小刻度是0.01ml;3-6ml最小刻度是0.2ml;6-10ml最小刻度是0.5ml;10-100ml最小刻度是1ml.
订货信息:
货号 |
品名 |
规格 |
包装 |
售价 |
库存 |
45246-100 |
大容量石油测试用尖底刻度离心管 |
8956.60 |
现货 |
KIMBLE & CHASE 45240-100油水分离离心管可重复利用石油测试用离心管-适合卡盖-Centrifuge Tube, Oil Test
* KG-33硼矽酸玻璃制成
* 刻度清晰,刻度标示量等於内容量
* 刻度为珐琅材质
* 尺寸37x203/mm,8寸长
用途:用于水或沉淀物与原有的离心分离。 |
货号 |
容量(mL) |
分刻度(mL) |
外径×长度(mm) |
包装(个/件) |
单价(RMB) |
45240-100 |
100 |
0-0.5 in 0.05 |
37×203 |
12 |
7642.00 |
美国kimble 原油测试用离心管100ml 45243-100
原油测试用离心管 Centrifuge Tube, Oil Test
* KG-33硼矽酸玻璃制成
* 用於原油中水和沉淀物测试
* 刻度标示量等於内容量
* 刻度为珐琅材质
* 尺寸45x165/mm,6寸长
厂牌: KIMBLE & CHASE
Part Number |
45243-100 |
Name |
6" Short Cone Oil Centrifuge Tubes |
Capacity (mL) |
100 |
OD (mm) |
45 |
Length (mm) |
165 |
Max RCF |
800 |
Shelf-Pack Qty |
6 |
Case Qty |
12 |
OIL CENTRIFUGE TUBES
KIMAX® tube designed for field use in testing petroleum.
Calibrated to contain
Scale and legend are durable white ceramic enamel
45243-200 is graduated in %. 100 mL equals 200%
Top is tooled to accept snap cap 28150R-6
Referenced in ASTM D4007
Manufactured from 33 expansion, low extractable borosilicate glass conforming to USP Type I and ASTM E438, Type I, Class A requirements
KIMBLE & CHASE 73750-16100圆底螺盖试管 抛弃式 Tube, Culture, Disposable, Screw Cap
* N-51A硼矽酸玻璃制成
* 白色标示区供使用者书写
* 适用於组织微生物与一般 菌之培养
* 附橡胶垫片螺盖
* 13mm试管搭配13-415螺盖
* 16mm试管搭配15-415螺盖
* 20mm试管搭配18-415螺盖
厂牌: KIMBLE & CHASE
Culture, Screw Thread, Borosilicate Glass Tubes
简介:73750 73802
Tubes are suitable for tissue culture work and general bacteriological use. Tubes are made from KIMAX-51 borosilicate glass in compliance with ASTM Specification E438, Type I, Class A or B glass requirements. Each tube has a chevron marking area. Trays are shrink wrapped in plastic film in modular trays. Supplied without caps. 73800, 73802 and 73805 for caps.
货号 |
容量(mL) |
外径(mm) |
长度(mm) |
包装(个/件) |
单价(RMB) |
73750-13100 |
8 |
13 |
100 |
1000 |
5938.00 |
73750-16100 |
12 |
16 |
100 |
1000 |
6995.00 |
73750-16125 |
16 |
16 |
125 |
1000 |
7014.00 |
73750-16150 |
20 |
16 |
150 |
1000 |
7382.00 |
73750-20125 |
25 |
20 |
125 |
500 |
5147.00 |
73750-20150 |
30 |
20 |
150 |
500 |
6164.00 |
73802-13415 |
GPI Thread Finish 13-415 |
500 |
1738.00 |
73802-15415 |
GPI Thread Finish 15-415 |
500 |
1913.00 |
73750-13100 |
13 ×100 |
500/1000 |
8 |
73750-16100 |
16 ×100 |
250/1000 |
12 |
73750-16125 |
16 ×125 |
250/1000 |
16 |
73750-16150 |
16 ×150 |
250/1000 |
20 |
73750-20125 |
18 ×150 |
250/500 |
25 |
73750-20150 |
20 ×150 |
250/500 |
30 |
45066-13100 |
13 ×100 |
72/288 |
8 |
45066-16100 |
16 ×100 |
72/288 |
12 |
45066-16125 |
16 ×125 |
72/288 |
16 |
45066-16150 |
16 ×150 |
72/288 |
20 |
45066-20125 |
20 ×125 |
48/192 |
25 |
45066-20150 |
20 ×150 |
48/192 |
30 |
45066-25150 |
25 ×150 |
36/144 |
50 |
45066-25200 |
25 ×200 |
36/144 |
70 |
45066-38200 |
38 ×200 |
24 |
160 |
美国Kimble、Kimax、Konte
KIMBLE CHASE 73785-5抛弃式玻璃尖底螺盖离心管 Centrifuge Tube, Disposable
˙N-51A硼矽酸玻璃制成 ˙
容量5,10,15mL之管身呈圆柱体,底部为尖状 ˙
容量50ML之管身呈圆柱体,底部为弹头状 ˙可承受离心力2980RCFxg ˙附盖、塑胶垫片
5ml离心管搭配13-415螺盖 ˙
10-15ml离心管搭配15-415螺盖 ˙
50ml离心管搭配24-400螺盖
Centrifuge Tubes, Disposable, Plain, Screw Thread Finish
用途:离心。玻璃材质
简介:73785 73800
Tubes are made from borosilicate glass in compliance with ASTM Specification E438, Type I, Class A or B glass requirements. With conical shaped bottoms on the 5, 10, and 15 mL sizes and a bullet nosed shape on the 50 mL size to withstand centrifugation up to 2980 RCF. Tubes are plastic shrink wrapped in modular trays for cleanliness and safety. Closures are not supplied.
货号 |
容量(mL) |
外径(mm) |
长度(mm) |
包装(个/件) |
单价(RMB) |
73785-5 |
5 |
13 |
110 |
125 |
询价 |
73785-10 |
10 |
16 |
114 |
125 |
询价 |
73785-15 |
15 |
17 |
126 |
125 |
询价 |
73785-50 |
50 |
29 |
137 |
72 |
1748.00 |
Accessory Closures |
73800-13415 |
Closures, Screw Thread, Rubber Lined, 13-415 |
1000 |
2065.00 |
73800-15415 |
Closures, Screw Thread, Rubber Lined, 15-415 |
1000 |
2361.00 |
73802-13415 |
Closures, Screw Thread, PTFE Lined, 13-415 |
500 |
1738.00 |
73802-15415 |
Closures, Screw Thread, PTFE Lined, 15-415 |
500 |
1913.00 |
73802-24400 |
Closures, Screw Thread, PTFE Lined, 24-400 |
144 |
2326.00 |
KIMBLE 37010-25胖肚移液管 球型吸管A级 Class A, Serialized And Certified *KG-33硼矽酸玻璃制成 *精度A级 *管身细长,中间部分突出 *可高压灭菌,吸管印有序号,并附有证书 *具高精准度,高品质之产品 厂牌: KIMBLE & CHASE
Volumetric Pipets, Reusable, To Deliver, Class A, Color-Coded, Serialized and Certified 用途:精确转移液体。可重复使用。 简介:37010All volumetric pipets are calibrated to deliver. Sizes 1 mL and larger are marked with large numerals on the bulb, indicating capacity. Color-coded (ASTM E1273) for ease in sorting and selecting the correct pipet. With a legend of permanent brown stain.
KIMBLE & CHASE自动归零滴定管17051F-50 Automatic, with Three-Way PTFE Stopcock
厂牌: KIMBLE & CHASE
* KG-33硼矽酸玻璃制成
* 精度B级
* PTFE三斜孔活栓
* 滴管上方有溢流管,下方活栓有注入孔,皆可外接外径1/4英寸之软管
* 由活栓注入口注入滴定液体,液体过量时会由上方的溢流管排出
* 此滴定管具自动归零功能,刻度为黑色珐琅材质,耐久清晰
货号 |
名称 |
容量 |
规格 |
价格 |
自动归零滴定管 |
容量10ml |
刻度0.05ml/误差±0.04ml / L515mm |
2865.80 |
自动归零滴定管 |
容量25ml |
刻度0.1ml/误差±0.06ml / L577mm |
2695.67 |
自动归零滴定管 |
容量50ml |
刻度0.1ml/误差±0.10ml / L735mm |
2695.67 |
自动归零滴定管 |
容量100ml |
刻度0.2ml/误差±0.20ml / L765mm |
3278.65 |
KIMBLE & CHASE17052F-100自动滴定管A级 Buret, Class A, with Three-Way PTFE Stopcock, with Certificate of GraduationAccuracy
* KG-33硼矽酸玻璃制成
* 精度A级
* 刻度精准,管身印有序号,附校正书
* 下方活栓有注入孔,可外接外径1/4英寸之软管
* 附PTFE活栓,刻度为白色珐琅材质,耐久清晰
厂牌: KIMBLE & CHASE
17052F-100 |
BURET,CLASSA,3WAY PTFE STPK,100ML |
3423.51 |
17052F-25 |
BURET,CLASSA,3WAY PTFE STPK,25ML |
2535.51 |
17052F-50 |
BURET,CLASSA,3WAY PTFE STPK,50ML |
2672.54 |
17054F-10 |
BURET,CLASSA,AUTO ZERO,PTFE STPK,10ML |
3172.24 |
17054F-100 |
BURET,CLASSA,AUTO ZERO,PTFE STPK,100ML |
3890.11 |
17054F-25 |
BURET,CLASSA,AUTO ZERO,PTFE STPK,25ML |
3174.37 |
17054F-50 |
BURET,CLASSA,AUTO ZERO,PTFE STPK,50ML |
3279.72 |
平口取样瓶 内塞式塑胶 Vail, Shell, Open Bottom Titeseal Closure
* 高品质硼矽酸玻璃制成
* 附PE材质可插针盖
* 使用耐化学性佳,低溶出物的硼矽酸玻璃制成
厂牌: KIMBLE & CHASE
货号 |
容量ml |
数量 |
介绍 |
60831D-830 |
0.75 |
2000 |
透明玻璃,适合Perkin-Elmer自动取样瓶机 |
60831D-843 |
1 |
2000 |
透明玻璃 |
60831D-1231 |
2 |
1000 |
透明玻璃, 适合Waters自动取样瓶机 |
60831D-1544 |
4 |
200 |
透明玻璃 |
60835D-843 |
1 |
2000 |
茶色玻璃 |
60835D-1231 |
2 |
2000 |
茶色玻璃, 适合Waters自动取样瓶机 |
60835D-1544 |
4 |
200 |
茶色玻璃, 适合Waters, 48-Pos自动取样瓶机 |
北京优尼康生物科技有限公司
联系人:张真
电话:13911868362
传真:010-52086511-808
Email:13911868362@163.com
QQ:2856009800
邮政编码:100107
地址:北京市朝阳区北苑路13号领地A座1204室
公司网页:http://www.bjunique.com
北京优尼康生物科技有限公司是最早经营进口、国产生物科研仪器、试剂及耗材,提供技术服务的生物公司之一。现经营的品牌及相关产品如下:
德国Griner培养板、培养皿、离心管、冻存管、培养瓶、接种环、接种针等;
美国Wheaton 匀浆器、组织研磨器、双侧壁细胞培养瓶、悬浮细胞培养瓶、细胞专用搅拌器、安培瓶等玻璃仪器。
美国kimble 蓝盖瓶、匀浆器、离心管,巴氏吸管等玻璃仪器;
加拿大Labplas 的无菌采样袋、均值袋;
美国Nalgene 过滤装置、塑料广口瓶、放水桶、低温冰盒、低温标签、记号笔、离心管、冻存管、便携液氮罐、无菌培养基瓶、手动真空泵等
美国ABI PCR板、PCR管、PCR盖子、八连拍管、膜等
德国Brand 移液器,电动移液器,瓶口分配等
德国艾本德eppendorf 移液器、分配器等
法国Hyphen Biomed 的出血、凝血类试剂 ;
美国BioProducts MD 的PEDF(人眼色素上皮衍生因子);
德国IBL international 新蝶呤试剂盒、儿茶酚胺试剂盒;
美国TYLER 的筛分仪;
BD公司的基质胶,细胞筛网等;
法国Interscience 均质器、重量稀释器、自动螺旋接种仪、均值袋、均值夹、开袋器、架子等
德国Wiggens 搅拌器、培养箱、振荡器、蒸发器(氮吹仪)菌落计数器本生灯、均质器等
德国Chemvck 防腐隔膜泵、无油泵、真空泵、蠕动泵等
瑞士Keller 小型快速玻璃珠灭菌器、玻璃珠等
美国Millpore 细胞电阻仪、超滤管、膜、针头滤器等
美国 BioSpec研磨珠均质器、手持匀浆机等
自产镍洛合金接种环、接种针、核酸染料等
| 单位名称: |
北京市朝阳区双营路11号美立方3号楼2单元2108室3单元2101室
| 联系电话: |
| Email: |
