Orbit 16 TC - 高通量脂双层工作站
Nanion公司的Orbit 16 TC 平台可轻松高效的进行脂双层涂抹与记录,该设备能自动一次性形成16个脂双层并对其进行完全平行记录,所以能快速地生成有效的数据。 Orbit 16 TC 主要特点有:
Orbit 16 TC 内置专业的低噪16通道放大器(Elements s.r.l.),支持使用最高带宽同时记录16个脂双层。此外,Orbit 16 TC 还兼容绝大多数在售的放大器,包括Tecella公司的16通道Triton放大器、EPC-10或Axopatch等单通道放大器等。Orbit内置多路转接器,可以自动在记录位点之间切换从而实现用单通道放大器记录多个脂双层位点。
Orbit 16 TC 脂双层工作站完整的Orbit 16 TC 系统包括主记录站、内置的Elements e16脂双层专用放大器和支持Ionera公司的MECA 16 TC 16记录芯片的记录模块。
Orbit 16 TC EDR4 Software
The intuative and easy to learn EDR4 software for the Orbit 16 TC was developed by our partner Elements S.R.L.(Italy). Further detailed information can be found at https://elements-ic.com/
MECA 16 TC chips
The MECA 16 TC recording substrate contains an array of 16 circular microcavities in a highly inert polymer. Each cavity contains an individual integrated Ag/AgCl-microelectrode. The bilayer is automatically formed by remotely actuated painting (Ionera1-SPREAD), thus roofing the liquid-filled cavity. The bilayers can be easily and repeatedly zapped and re-formed in an automated fashion. After bilayer formation, ion channels or nanopores are reconstituted via self-insertion, proteoliposome fusion or dilution from detergent micelles.
The MECA 16 TC recording chips are produced and quality assured by our partner Ionera Technologies GmbH in Freiburg Germany and shipped from Munich to our international customers. Different types of MECA 16 chips will be available depending on the sample.
数据与应用:
Alpha-Hemolysin - Parallel Recordings of monoPEG-28 Block
Orbit 16 data and applications:
Data courtesy of Dr. Gerhard Baaken et. al., University of Freiburg / Ionera.
Event-averaged histograms (black) and overlaid current traces (blue) of parallel and simultaneous recordings on a MECA chip of monoPEG-28-mediated blockages of hemolysin nanopore(s). The current traces were recorded with a multichannel amplifier (Tecella Jet 16). Histograms were derived from the mean current levels of at least 2000 visits of blocked stated per cavity (20 kHz sample frequency).
Read the full paper. (Am. Chem. Soc Nano, 5(10), 8080-8088, 2011)
Alpha-Hemolysin - Block by Mono- and Poly PEGs
Data courtesy of Dr. Gerhard Baaken et.al, University of Freiburg / Ionera.
Current traces and histograms derived from recordings of αHL pores blocked by monoPEG-28 and polyPEG-1500 on an Ionera MECA chip (AxoPatch 200B, filter freq: 20kHz, digitized at 200 kHz).
Read the full paper: (Am. Chem. Soc Nano, 5(10), 8080-8088, 2011)
Alamethicin - Parallel recordings
Data courtesy of Dr. Gerhard Baaken, University of Freiburg / Ionera.
The data image shows parallel recordings from reconstituted alamethicin channels. See also the paper: "Alamethicin Supramolecular Organization in Lipid Membranes from 19F Solid-State NMR", Salnikov et al. (2016) Biophysical Journal 111(11): 2450-2459.
Alpha-Hemolysin - Automated Formation of Membranes from Polyoxazoline based Triblock Copolymers
Orbit 16 and applications:
Data were kindly provided by Ionera.
Automated formation of membranes from polyoxazoline based triblock popolymers. Screenshot of a recording of Alpha-Hemolysine in a polyoxazoline based triblock copolymer membrane on the Orbit 16.
Alpha-Hemolysin is capable of insertion into triblock copolymer membranes.
(A) Current-voltage relationship of Alpha-Hemolysin pore in Poly(2-methyloxazoline-b-dimethylsiloxane-b-2-methyloxazoline) membrane. Average of two channels. Conditions: 25 mM Tris, 4 M KCl, pH 8.0.
(B+C) Representative recordings of Alpha-Hemolysin with PEG-28 at 40 mV and -40 mM. Conditions: 25 mM Tris, 4 M KCl, pH 8.0. Note different time scale at positive (B) and negative (C) potentials.
KcsA - Single Channel Recordings
Single channel currents of tetrameric potassium channel KcsA E71A recorded from 5 selected bilayers in parallel.
KcsA was expressed in vitro with its co-translational integration into liposoms containing asolectin lipids. The proteoliposomes were subsecuently fused with bilayer array containing POPE/POPG on the Orbit 16.
Conditions: Current traces were recorded in 20 mM MES pH 4.0 on the cis-side and 10 mM MOPS, pH 7.0 on the trans-side of the bilayer; containing 200 mM KCl symmetric solutions with membrane potential held at +150 mV
Ryanodine Receptor - Application of Na-ATP and Ryanodine
Traces illustrating RYR single channel activity in the planar lipid bilayer recorded on the Orbit 16.
The RYR channel was reconstituted via fusion of sarcoplasmic reticulum vesicles with preformed asolectin bilayer.
(A) Activity after vesicle fusion and buffer exchange on cis-side. (B) 120 s after addition of 1 mM Na-ATP to the cis-side. (C) 120 s after addition of 5 µM Ryanodine to the cis-side.
Conditions: Trans-side: 53 mM Ba(OH)2, 1 mM Ca2+; Cis-side: 150 nM Ca2+, VHold: 0 mV in all case
Screenshot of the recording window showing simultaneous and parallel assay of channel-forming activity and single-channel conductance of recombinant MspA mutant porin in a diphytanoyl phosphatidylcholine bilayer derived in 1 experimental run with the Orbit 16.
Traces from a single experiment recorded in parallel from 16 lipid bilayers. Grids X: 1 s; Y: 100 pA. Addition of MspA in OPOE detergent micelles resulted in insertion of 97 pores in 12 bilayers.
Conditions: 20 mM HEPES, 350 mM KCl, pH 7,5, rMspA final concentration 20 ng/ml; holding potential +40 mV
Alpha-Hemolysin - PEG Detection
Screenshot of the recording window showing simultaneous and parallel PEG detection with single aHL-nanopores. Channels 1-5,7,12-14 contain a single aHL-nanopore. Channels 10 and 11 have two and Channel 9 has three aHL-nanopores. In Channels 8 and 14 single aHL-nanopores are assembled as hexamer. Channels 6 and 16 are switched off.
Conditons: 3 M KCl, 20 mM TRIS, pH 8, +40 mV
Gramicidin - Ion Channel Forming Antibiotic
Screenshots of a recording window of a typical Gramicidin ion channel forming activity assay on the Orbit 16.
Conditions: symmetrical 0,1 HCl, +150 mV.
发表文献:
2021 - Design, assembly, and characterization of membrane-spanning DNA nanopores
耐尼恩公司简介:
耐尼恩技术(北京)有限公司是德国Nanion技术有限公司的在中国的子公司。德国Nanion技术有限公司是致力于生命科学领域的技术开发、技术服务和设备生产的高新技术公司。德国Nanion技术公司开发制造了科研级和工业级全自动膜片钳工作站系统,在学术和药物工业领域享有盛誉,与世界知名学术机构和药业公司有着紧密的合作。总部设在德国慕尼黑,在中国、美国和日本设有多个子公司和分支机构。
