过滤耗材
Pallflex Tissuquartz™ (石英膜)
进口
美国PALL
Pallflex Tissuquart
询价
纯石英,没有粘合剂,最高化学纯度, 高流速,高过滤效率.  独特的设计适用用高温和热气体的监测应用。
  ●  滤材: 纯石英,没有粘合剂;
  ●  厚度: 432 µm (17 mils);
  ●  重量t: 5.8 mg/cm2
  ●  典型气溶胶截留:99.98% (按照标准 ASTM D 2986-95A, 0.3 µm DOP at 32 L/min/100 cm2滤材要求)
  ●  典型空气流速(0.7 bar (70 kPa, 10 psi): 73 L/min/cm2
  ●  典型水流速度(0.35 bar (35 kPa, 5 psi) : 220 mL/min/cm2
  ●  最大操作温度-空气: 1093 ºC (2000 ºF)
Pallflex Tissuquartz™ (石英膜)产品规格
Description
Tissuquartz Filters
Emfab Filters*
Fiberfilm Filters
Filter Media
Pure quartz, no binder
Borosilicate glass microfibers reinforced with woven glass cloth and bonded with PTFE
Heat resistant borosilicate glass fiber coated with fluorocarbon (TFE)
Diameter
25 - 142 mm and 8 x 10 in.
12 - 142 mm and 8 x 10 in.
25 - 100 mm and 8 x 10 in.
Typical Thickness
432 µm (17 mils)
178 µm (7 mils)
203 µm (8 mils)
Typical Filter Weight
5.8 mg/cm2
5.0 mg/cm2
3.4 mg/cm2
Typical Water Flow Rate
220 mL/min/cm2
32 mL/min/cm2
220 mL/min/cm2
Typical Air Flow Rate
73 L/min/cm2
68 L/min/cm2
180 L/min/cm2
Maximum Operating Temperature - Air
1093 ºC
(2000 ºF)
260 ºC
(500 ºF)
315.5 ºC
(600 ºF)
Typical Aerosol Retention**
99.90%
99.95%
96.40%
pH in Boiled Water Extract
6.5 - 7.5
* The TX40HI45 and TX40HI75 are made from the same materials but were developed in conjunction with the U.S. EPA (Method 26) when a need arose to sample the exhaust gases from the stacks at incinerator facilities. These two grades are made with higher levels of the PTFE binder resin than the TX40HI20WW to withstand the corrosive atmosphere. The TX40HI75 has a higher level of binder than the TX40HI45 and both have a higher level than the TX40HI20WW.
** Following ASTM D 2986-95A 0.3 μm (DOP) at 32 L/min/100 cm2 filter media
Pallflex Tissuquartz™ (石英膜)产品订购信息
Part Number
Description
Pkg
Tissuquartz™ Filters, 2500 QAT-UP
7200
25 mm
100/pkg
7201
37 mm
25/pkg
7202
47 mm
25/pkg
7199
54 mm
25/pkg
7191
60 mm
25/pkg
7197
63.5 mm
25/pkg
7196
64 mm
25/pkg
7205
82.6 mm
25/pkg
7190
83 mm
25/pkg
7206
85 mm
25/pkg
7187
87.5 mm
25/pkg
7203
90 mm
25/pkg
7195
100 mm
25/pkg
7207
102 mm
25/pkg
7250
110 mm
25/pkg
7249
115 mm
25/pkg
7208
125 mm
25/pkg
7251
142 mm
25/pkg
7204
8 x 10 in.
25/pkg
Non-Heat-treated Quartz, 2500 QAO-UP
7198
37 mm
25/pkg
7194
47 mm
25/pkg
7240
70 mm
25/pkg
7241
90 mm
25/pkg
7193
142 mm
25/pkg
Emfab™ Filters
7258
TX40HI20WW, 12 mm
100/pkg
7219
TX40HI20WW, 25 mm
100/pkg
7217
TX40HI20WW, 37 mm
100/pkg
7256
TX40HI20WW, 41 mm
100/pkg
7220
TX40HI20WW, 44 mm
100/pkg
7221
TX40HI20WW, 47 mm
100/pkg
7222
TX40HI20WW, 70 mm
100/pkg
7218
TX40HI20WW, 81 mm
100/pkg
7234
TX40HI20WW, 85 mm
100/pkg
7223
TX40HI20WW, 90 mm
100/pkg
7225
TX40HI20WW, 110 mm
100/pkg
7252
TX40HI20WW, 142 mm
100/pkg
7224
TX40HI20WW, 8 x 10 in.
100/pkg
7259
TX40HI45, 25 mm
100/pkg
7262
TX40HI45, 47 mm
100/pkg
7253
TX40HI45, 82.6 mm
100/pkg
7260
TX40HI45, 83 mm
100/pkg
7254
TX40HI45, 110 mm
100/pkg
7263
TX40HI75, 25 mm
100/pkg
7264
TX40HI75, 47 mm
100/pkg
7265
TX40HI75, 82.6 mm
100/pkg
7266
TX40HI75, 110 mm
100/pkg
Fiberfilm™ Filters
7210
T60A20, 25 mm
100/pkg
7211
T60A20, 37 mm
50/pkg
7212
T60A20, 47 mm
50/pkg
7216
T60A20, 55 mm
50/pkg
7213
T60A20, 70 mm
50/pkg
7209
T60A20-HT, 70 mm, heat treated
50/pkg
7214
T60A20, 90 mm
50/pkg
7257
T60A20, 100 mm
50/pkg
7215
T60A20, 8 x 10 in.
50/pkg
颇尔公司(Pall Corporation)(纽约证券交易所代码:PLL)是全球过滤、分离和纯化领域的领导者,为遍布生命科学和工业领域的众多客户提供满足关键流体控制所需的解决方案。颇尔公司致力于同客户并肩努力,提升关于健康、安全和环境保护的尖端技术。颇尔公司的产品始终引领工艺及产品创新,并能减少排放及废弃物。颇尔公司为标准普尔500入选公司,并被新闻周刊评为“最优绿色环保企业”。 欲知颇尔公司如何助力更绿色、更安全、更可持续发展的未来,请关注Twitter @PallCorporation或登录:www.pall.com。
颇尔(中国)有限公司于1993年底在北京成立,总部设在北京经济技术开发区,是颇尔公司在华独资企业。颇尔公司在上海、广州、成都、长春、石家庄、济南等地设立多个分公司及办事处,建立了全面的销售、技术服务网络,以更好更便捷地服务于全国各地的用户。
上海市华佗路1号GE中国科技园
