蠕动泵/恒流泵
泵头
泵头
L/S® Rigid PTFE-Tubing Pump Head
进口
美国COLE-PARMER
Specifications
Product Type Masterflex L/S pump heads
Flow rate with 4-mm OD tubing at 1 to 300 rpm ml/min 0.06 to 17
Flow rate with 6-mm OD tubing at 1 to 300 rpm ml/min 0.25 to 65
Avg tubing life (100 rpm, 0 psi) 500 hours
Max pressure continuous bar 6.9
Body material Anodized aluminum, acetal
Rollers 6
Suction lift m 2.4
ft 8
Roller material Stainless steel
Optimum rpm range rpm 1 to 300
Max pressure continuous psi 100
Brand Masterflex
Dimensions 3-1/4"W x 5-1/8"H x 2-1/4"D, (8.3 cm x 13 cm x 5.7 cm)
Drive requirements Minimum 1/10 hp
深圳慧普德贸易有限公司主要代理世界名牌科学仪器,美国Cole-Parmer公司的各种实验室通用仪器,美国OMEGA公司和美国NASCO旗下Whirl-pak无菌取样袋产品,代理产品适用于化工、品检、生化及环保等范畴。
地址:深圳市罗湖区太白路布心村111号布心大厦6楼D1室
电话:0755-82380408*805
传真:0755-82380480
Email:jane@rightproducts.com.hk
www.rightproducts.cn
0755-82380408*805
