血清/培养基
Formedium培养基
Formedium培养基
Formedium Medium
进口
英国/Formedium
Formedium Medium
优惠
Product Code Description & Weight
3AT010 3-Amino-1,2,4-Triazole, 3-AT - 10 gram
3AT025 3-Amino-1,2,4-Triazole, 3-AT - 25 gram
3AT100 3-Amino-1,2,4-Triazole, 3-AT - 100 gram
5ALA01 5-Aminolevulinic acid HCl - 1 gram
5ALA05 5-Aminolevulinic acid HCl - 5 gram
5ALA10 5-Aminolevulinic acid HCl - 10 gram
5ALA100 5-Aminolevulinic Acid HCl - 100 gram
5FOA01 5-Fluoro Orotic Acid - 1 gram
5FOA05 5-Fluoro Orotic Acid - 5 gram
5FOA10 5-Fluoro Orotic Acid - 10 gram
AGA01 Agar - 250 gram
AGA02 Agar - 500 gram
AGA03 Agar - 1000 gram
AGA04 Agar - 6 X 1000 gram
AGR02 Agar Granulated, Bacteriological grade - 250 gram
AGR05 Agar Granulated, Bacteriological grade - 500 gram
AGR10 Agar Granulated, Bacteriological grade - 1000 gram
AGR60 Agar Granulated, Bacteriological grade - 6 x 1 Kg
AIM2YT0101 AIM-2YT Broth base w/o Trace elements - 100 gram
AIM2YT0105 AIM-2YT Broth base w/o Trace elements - 500g
AIM2YT0110 AIM-2YT Broth base w/o Trace elements - 1000 gram
AIM2YT0160 AIM-2YT Broth base w/o Trace elements - 6 x 1000 gram
AIM2YT0201 AIM-2YT Broth base including Trace elements - 100 gram
AIM2YT0205 AIM-2YT Broth base including Trace elements - 500 gram
AIM2YT0210 AIM-2YT Broth base including Trace elements - 1000 gram
AIM2YT0260 AIM-2YT Broth base including Trace elements - 6 x 1000 gram
AIMLB0101 AIM-LB Broth base w/o Trace elements - 100 gram
AIMLB0105 AIM-LB Broth base w/o Trace elements - 500 gram
AIMLB0110 AIM-LB Broth base w/o Trace elements - 1000 gram
AIMLB0150 AIM-LB Broth base w/o Trace elements - 10 Kg
AIMLB0160 AIM-LB Broth base w/o Trace elements - 6 x 1000 gram
AIMLB0201 AIM-LB Broth base including Trace elements - 100 gram
AIMLB0205 AIM-LB Broth base including Trace elements - 500 gram
AIMLB0210 AIM-LB Broth base including Trace elements - 1000g
AIMLB0260 AIM-LB Broth base including Trace elements - 6 x 1000 gram
AIMLB10L AIM-LB Broth base including Trace Elements-10L pack (348.5g)
AIMLB1L AIM-LB Broth base including Trace elements-1L pack (34.8g)
AIMLB2L AIM-LB Broth base including Trace elements-2L pack (69.7g)
AIMLB5L AIM-LB-Broth base including Trace elements-5L pack (174.3g)
AIMSB0101 AIM-Super Broth base w/o Trace elements - 100 gram
AIMSB0105 AIM-Super Broth base w/o Trace elements - 500 gram
AIMSB0110 AIM-Super Broth base w/o Trace elements - 1000 gram
AIMSB0160 AIM-Super Broth base w/o Trace elements - 6 x 1000 gram
AIMSB0201 AIM-Super Broth base including Trace elements - 100 gram
AIMSB0205 AIM-Super Broth base including Trace elements - 500 gram
AIMSB0210 AIM-Super Broth base including Trace elements - 1000 gram
AIMSB025L AIM-Super Broth inc. Trace elements 5L - 374.3g
AIMSB0260 AIM-Super Broth base inc. Trace elements - 6 x 1000 gram
AIMTB0101 AIM-Terrific Broth Base w/o Trace elements - 100 gram
AIMTB0105 AIM-Terrific Broth Base w/o Trace elements - 500 gram
AIMTB0110 AIM-Terrific Broth Base w/o Trace elements - 1000g
AIMTB0150 AIM - Terrific Broth Base w/o Trace elements - 5 Kg
AIMTB0160 AIM-Terrific Broth Base w/o Trace elements - 6 x 1 Kg
AIMTB0201 AIM-Terrific Broth Base including Trace elements - 100 gram
AIMTB0205 AIM-Terrific Broth Base including Trace elements - 500 gram
AIMTB0210 AIM-Terrific Broth Base including Trace elements - 1000g
AIMTB024L AIM - Terrific Broth Base inc. Trace elements 4L - 223.5g
AIMTB0250 AIM-Terrific Broth Base including Trace elements - 10 Kg
AIMTB0260 AIM-Terrific Broth Base inc. Trace elements - 6 x 1 Kg
AIMTB0310 AIM-Terrific Broth inc. T/E w/o Glucose & Lactose - 1000g
AMD0101 A Medium - 250 gram
AMD0102 A Medium - 1000g
AMD0103 A Medium - 6 x 1 Kg
AMP01 Ampicillin Sodium - 1 gram
AMP05 Ampicillin Sodium - 5 gram
AMP10 Ampicillin Sodium - 10 gram
AMP100 Ampicillin Sodium - 100 gram
AMP25 Ampicillin Sodium - 25 gram
AMP50 Ampicillin Sodium - 50 gram
AMP500 Ampicillin Sodium - 500 gram
AMSM0100 Amino Mix 4 SeMet - 100g
ARA001 L-(+)-Arabinose - 100 gram
ARA005 L-(+)-Arabinose - 500 gram
ARA010 L-(+)-Arabinose - 1000g
AXM0101 AX Medium - 250 gram
AXM0102 AX Medium - 1000 gram
AXM0103 AX Medium - 6 x 1000 gram
BAB0105 Blood Agar Base - 500 gram
BAB0110 Blood Agar Base - 1000 gram
BAB0160 Blood Agar Base - 6 x 1000 gram
BBM01 3NBBM+V Medium - 648g
BYTA1000 BYTA Medium - 1000g
BYTA2X5L BYTA Medium - 250g (2 x 5L)
CAR0005 Carbenicillin Disodium - 5 gram
CAR0025 Carbenicillin Disodium - 25 gram
CAS01 Casamino acids - 250 gram
CAS02 Casamino acids - 500 gram
CAS03 Casamino acids - 1000 gram
CAS04 Casamino acids - 6 X 1000 gram
CCM0102 YPD Agar - 250 gram
CCM0105 YPD Agar - 500 gram
CCM0110 YPD Agar - 1000 gram
CCM0202 YPD Broth - 250 gram
CCM0205 YPD Broth - 500 gram
CCM0210 YPD Broth - 1000 gram
CCM0260 YPD Broth - 6 x 1 Kg
CCM0302 YEP Agar - 250 gram
CCM0305 YEP Agar - 500 gram
CCM0310 YEP Agar - 1000 gram
CCM0402 YEP Broth - 250 gram
CCM0405 YEP Broth - 500 gram
CCM0410 YEP Broth - 1000 gram
CCM0502 YPAD Agar - 250 gram
CCM0505 YPAD Agar - 500 gram
CCM0510 YPAD Agar - 1000 gram
CCM0602 MAL Indicator Medium - 250 gram
CCM0605 MAL Indicator Medium - 500g
CCM0610 MAL Indicator Medium - 1000 gram
CCM0702 GAL Indicator Medium - 250 gram
CCM0705 GAL Indicator Medium - 500 gram
CCM0710 GAL Indicator Medium - 1000 gram
CCM0802 Sporulation Medium - 250 gram
CCM0805 Sporulation Medium - 500 gram
CCM0810 Sporulation Medium - 1000 gram
CCM0902 Pre-Sporulation Medium - 250 gram
CCM0905 Pre-Sporulation Medium - 500 gram
CCM0910 Pre-Sporulation Medium - 1000 gram
CCM1002 YPAD Broth - 250 gram
CCM1005 YPAD Broth - 500 gram
CCM1010 YPAD Broth - 1000 gram
CCM1202 GAL Indicator Broth Medium - 250 gram
CCM1205 GAL Indicator Broth Medium - 500 gram
CCM1210 GAL Indicator Broth Medium - 1000 gram
CDA0102 Czapex Dox Agar - 250g
CDA0110 Czapex Dox Agar - 1000g
CDA0610 Czapex Dox Agar - 6 x 1 Kg
CDB0102 Czapex Dox Broth - 250g
CDB0110 Czapex Dox Broth - 1000g
CDB0610 Czapex Dox Broth - 6 x 1 Kg
CEFO001 Cefotaxime sodium salt - 1 gram
CEFO005 Cefotaxime sodium salt - 5 gram
CEFO025 Cefotaxime sodium salt - 25 gram
CFSVT01 CEFAS Vitamin mixture - 100 gram
CLA01 Chloramphenicol - 25g
CLA02 Chloramphenicol - 100g
CSC0101 SC Agar: 2% Glucose - 100 gram
CSC0102 SC Agar: 2% Glucose - 250 gram
CSC0105 SC Agar: 2% Glucose - 500 gram
CSC0110 SC Agar: 2% Glucose - 1000 gram
CSC0201 SC Broth: 2% Glucose - 100 gram
CSC0202 SC Broth: 2% Glucose - 250 gram
CSC0205 SC Broth: 2% Glucose - 500 gram
CSC0210 SC Broth: 2% Glucose - 1000 gram
CSC0301 SC Agar: 2% Galactose - 100 gram
CSC0302 SC Agar: 2% Galactose - 250 gram
CSC0305 SC Agar: 2% Galactose - 500 gram
CSC0310 SC Agar: 2% Galactose - 1000 gram
CSC0401 SC Broth: 2% Galactose - 100 gram
CSC0402 SC Broth: 2% Galactose - 250 gram
CSC0405 SC Broth: 2% Galactose - 500 gram
CSC0410 SC Broth: 2% Galactose - 1000 gram
CSC0418 SC Broth, 2% Glucose, -His - 500 gram
CSC0501 SC Agar: 2% Raffinose - 100 gram
CSC0502 SC Agar: 2% Raffinose - 250 gram
CSC0505 SC Agar: 2% Raffinose - 500 gram
CSC0510 SC Agar: 2% Raffinose - 1000 gram
CSC0601 SC Broth: 2% Raffinose - 100 gram
CSC0602 SC Broth: 2% Raffinose - 250 gram
CSC0605 SC Broth: 2% Raffinose - 500 gram
CSC0610 SC Broth: 2% Raffinose - 1000 gram
CSC0701 SC Agar: 3.3% Succinate - 100 gram
CSC0702 SC Agar: 3.3% Succinate - 250 gram
CSC0705 SC Agar: 3.3% Succinate - 500 gram
CSC0710 SC Agar: 3.3% Succinate - 1000 gram
CSC0801 SC Broth: 3.3% Succinate - 100 gram
CSC0802 SC Broth: 3.3% Succinate - 250 gram
CSC0805 SC Broth: 3.3% Succinate - 500 gram
CSC0810 SC Broth: 3.3% Succinate - 1000 gram
CSC0901 SC Agar: 2% Galactose / 1% Raffinose - 100 gram
CSC0902 SC Agar: 2% Galactose / 1% Raffinose - 250 gram
CSC0905 SC Agar: 2% Galactose / 1% Raffinose - 500 gram
CSC0910 SC Agar: 2% Galactose / 1% Raffinose - 1000 gram
CSC1001 SC Broth: 2% Galactose / 1% Raffinose - 100 gram
CSC1002 SC Broth: 2% Galactose / 1% Raffinose - 250 gram
CSC1005 SC Broth: 2% Galactose / 1% Raffinose - 500 gram
CSC1010 SC Broth: 2% Galactose / 1% Raffinose - 1000 gram
CSC4010 SC Broth, -Leu, -Trp, 2% Glucose - 1000 gram
CSC4011 SC Broth, -His, -Trp, Ura, 2% Glucose - 1000 gram
CSC4012 SC Broth, -His, -Leu, -Trp, -Ura, 2% Glucose - 1000 gram
CSC4013 SC Broth, -Leu, 2% Glucose - 1000 gram
CSC4014 SC Broth, -Ura, w/o Carbon Source - 1000 gram
CSC4015 SC Broth, -Ura, -His, -Trp, w/o Carbon Source - 1000 gram
CSC4016 SC Broth, 2% Raffinose, -His, -Trp, -Ura - 1000 gram
CSC4017 SC Broth, 2% Gal, 1% Raf, -His, -Trp, -Ura, - 1000 gram
CSM0101 SD Agar: 2% Glucose - 100 gram
CSM0102 SD Agar: 2% Glucose - 250 gram
CSM0105 SD Agar: 2% Glucose - 500 gram
CSM0110 SD Agar: 2% Glucose - 1000 gram
CSM0201 SD Broth: 2% Glucose - 100 gram
CSM0202 SD Broth: 2% Glucose - 250 gram
CSM0205 SD Broth: 2% Glucose - 500 gram
CSM0210 SD Broth: 2% Glucose - 1000 gram
CSM0301 SD Agar: 2% Galactose - 100 gram
CSM0302 SD Agar: 2% Galactose - 250 gram
CSM0305 SD Agar: 2% Galactose - 500 gram
CSM0310 SD Agar: 2% Galactose - 1000 gram
CSM0401 SD Broth: 2% Galactose - 100 gram
CSM0402 SD Broth: 2% Galactose - 250 gram
CSM0405 SD Broth: 2% Galactose - 500 gram
CSM0410 SD Broth: 2% Galactose - 1000 gram
CSM0501 SD Agar: 2% Raffinose - 100 gram
CSM0502 SD Agar: 2% Raffinose - 250 gram
CSM0505 SD Agar: 2% Raffinose - 500 gram
CSM0510 SD Agar: 2% Raffinose - 1000 gram
CSM0601 SD Broth: 2% Raffinose - 100 gram
CSM0602 SD Broth: 2% Raffinose - 250 gram
CSM0605 SD Broth: 2% Raffinose - 500 gram
CSM0610 SD Broth: 2% Raffinose - 1000 gram
CSM0701 SD Agar: 3.3% Succinate - 100 gram
CSM0702 SD Agar: 3.3% Succinate - 250 gram
CSM0705 SD Agar: 3.3% Succinate - 500 gram
CSM0710 SD Agar: 3.3% Succinate - 1000 gram
CSM0801 SD Broth: 3.3% Succinate - 100 gram
CSM0802 SD Broth: 3.3% Succinate - 250 gram
CSM0805 SD Broth: 3.3% Succinate - 500 gram
CSM0810 SD Broth: 3.3% Succinate - 1000 gram
CSM0901 SD Agar: 2% Galactose / 1% Raffinose - 100 gram
CSM0902 SD Agar: 2% Galactose / 1% Raffinose - 250 gram
CSM0905 SD Agar: 2% Galactose / 1% Raffinose - 500 gram
CSM0910 SD Agar: 2% Galactose / 1% Raffinose - 1000 gram
CSM1001 SD Broth: 2% Galactose / 1% Raffinose - 100 gram
CSM1002 SD Broth: 2% Galactose / 1% Raffinose - 250 gram
CSM1005 SD Broth: 2% Galactose / 1% Raffinose - 500 gram
CSM1010 SD Broth: 2% Galactose / 1% Raffinose - 1000 gram
CSM1101 SD Agar: 2% Glucose w/o Phosphate - 100 gram
CSM1102 SD Agar: 2% Glucose w/o Phosphate - 250 gram
CSM1103 SD Agar: 2% Glucose w/o Phosphate - 500 gram
CSM1104 SD Agar: 2% Glucose w/o Phosphate - 1000 gram
CSM1201 SD Broth: 2% Glucose w/o Phosphate - 100 gram
CSM1202 SD Broth: 2% Glucose w/o Phosphate - 250 gram
CSM1203 SD Broth: 2% Glucose w/o Phosphate - 500 gram
CSM1204 SD Broth: 2% Glucose w/o Phosphate - 1000 gram
CSM2010 SD Broth Trace Elements inc. Vitamins 2% Glucose - 1000g
CSM2210 SD Agar: 2% Galactose w/o Phosphate - 1000 gram
CSM9010 SD Broth 2% Galactose, wo Folic acid, wo Riboflavine - 1000g
CYN0101 Yeast Morphology Agar - 100 gram
CYN0102 Yeast Morphology Agar - 250 gram
CYN0105 Yeast Morphology Agar - 500 gram
CYN0110 Yeast Morphology Agar - 1000 gram
CYN0201 Yeast Nitrogen Base - 100g
CYN0202 Yeast Nitrogen Base - 250g
CYN0205 Yeast Nitrogen Base - 500g
CYN0210 Yeast Nitrogen Base - 1000 gram
CYN0301 Yeast Potassium Nitrate Nitrogen Base - 100 gram
CYN0302 Yeast Potassium Nitrate Nitrogen Base - 250 gram
CYN0305 Yeast Potassium Nitrate Nitrogen Base - 500 gram
CYN0310 Yeast Potassium Nitrate Nitrogen Base - 1000 gram
CYN0401 Yeast Nitrogen Base w/o Amino Acids - 100 gram
CYN0402 Yeast Nitrogen Base w/o Amino Acids - 250 gram
CYN0405 Yeast Nitrogen Base w/o Amino Acids - 500 gram
CYN0410 Yeast Nitrogen Base w/o Amino Acids - 1000 gram
CYN0501 Yeast Nitrogen Base w/o AA & w/o AS - 100 gram
CYN0502 Yeast Nitrogen Base w/o AA & w/o AS - 250 gram
CYN0505 Yeast Nitrogen Base w/o AA & w/o AS - 500 gram
CYN0510 Yeast Nitrogen Base w/o AA & w/o AS - 1000 gram
CYN0601 Yeast Carbon Base - 100 gram
CYN0602 Yeast Carbon Base - 250 gram
CYN0605 Yeast Carbon Base - 500 gram
CYN0610 Yeast Carbon Base - 1000 gram
CYN0701 Yeast Vitamin Free Base - 100 gram
CYN0702 Yeast Vitamin Free Base - 250 gram
CYN0705 Yeast Vitamin Free Base - 500 gram
CYN0710 Yeast Vitamin Free Base - 1000 gram
CYN0801 Yeast Nitrogen Base w/o AA & w/o Phosphate - 100 gram
CYN0802 Yeast Nitrogen Base w/o AA & w/o Phosphate - 250 gram
CYN0803 Yeast Nitrogen Base w/o AA & w/o Phosphate - 500 gram
CYN0804 Yeast Nitrogen Base w/o AA & w/o Phosphate - 1000 gram
CYN0901 Yeast Nitrogen Base w/o AA & w/o Copper - 100 gram
CYN0902 Yeast Nitrogen Base w/o AA & w/o Copper - 250 gram
CYN0905 Yeast Nitrogen Base w/o AA & w/o Copper - 500 gram
CYN0910 Yeast Nitrogen Base w/o AA & w/o Copper - 1000 gram
CYN10001 Translucent K+FreeMedium, YNB w/o AA,AS,Pot,Folic&Ribo-100g
CYN10005 Translucent K+FreeMedium, YNB w/o AA,AS,Pot,Folic&Ribo-500g
CYN1001 YNB w/o AA, AS & Copper - 100 gram
CYN10010 Translucent K+ Free Medium,YNB w/o AA,AS, Pot,Folic&Ribo-1Kg
CYN1002 YNB w/o AA, AS & Copper - 500 gram
CYN1010 YNB w/o AA, AS & Copper - 1000 gram
CYN10110 YNB w/o AA, AS, Calcium Chloride & Manganese - 1000g
CYN10210 YNB w/o AA, AS, Magnesium Sulphate & Trace Elements - 1000g
CYN10310 YNB w/o AA, Zinc & Iron - 1000g
CYN10410 Yeast Nitrogen Base w/o AA, AS, Biotin & Inositol - 1 Kg
CYN1101 Yeast Nitrogen Base w/o AA & w/o Iron - 100 gram
CYN1102 Yeast Nitrogen Base w/o AA & w/o Iron - 500 gram
CYN1110 Yeast Nitrogen Base w/o AA & w/o Iron - 1000 gram
CYN1201 YNB w/o AA & w/o AS & w/o Iron - 100 g
CYN1202 YNB w/o AA & w/o AS & w/o Iron - 500 g
CYN1210 YNB w/o AA & w/o AS & w/o Iron - 1000g
CYN1301 Yeast Nitrogen Base w/o AA & w/o Copper & w/o Iron - 100g
CYN1302 Yeast Nitrogen Base w/o AA & w/o Copper & w/o Iron - 500g
CYN1310 Yeast Nitrogen Base w/o AA & w/o Copper & w/o Iron - 1000g
CYN1501 Yeast Nitrogen Base w/o AA & w/o Boron - 100 gram
CYN1502 Yeast Nitrogen Base w/o AA & w/o Boron - 500 gram
CYN1510 Yeast Nitrogen Base w/o AA & w/o Boron - 1000g
CYN1601 YNB w/o AA & w/o AS & w/o Boron - 100 g
CYN1602 YNB w/o AA & w/o AS & w/o Boron - 500 g
CYN1610 YNB w/o AA & w/o AS & w/o Boron - 1000g
CYN167 YNB w/o AA, phosphates, vitamins, supplemented with KCI- 1Kg
CYN1701 YNB w/o AA & w/o AS & w/o Copper & w/o Iron - 100 gram
CYN1702 YNB w/o AA & w/o AS & w/o Copper & w/o Iron - 500 gram
CYN1710 YNB w/o AA & w/o AS & w/o Copper & w/o Iron - 1000g
CYN1801 YNB w/o AA & w/o AS & w/o Iodine - 100 g
CYN1802 YNB w/o AA & w/o AS & w/o Iodine - 500 g
CYN1810 YNB w/o AA & w/o AS & w/o Iodine - 1000g
CYN1901 Yeast Nitrogen Base w/o AA & w/o Manganese - 100 gram
CYN1902 Yeast Nitrogen Base w/o AA & w/o Manganese - 500 gram
CYN1910 Yeast Nitrogen Base w/o AA & w/o Manganese - 1000 gram
CYN2001 YNB w/o AA & w/o AS & w/o Manganese - 100g
CYN2002 YNB w/o AA & w/o AS & w/o Manganese - 500 g
CYN2010 YNB w/o AA & w/o AS & w/o Manganese - 1000g
CYN2101 Yeast Nitrogen Base w/o AA & w/o Molybdene - 100 gram
CYN2102 Yeast Nitrogen Base w/o AA & w/o Molybdene - 500 gram
CYN2110 Yeast Nitrogen Base w/o AA & w/o Molybdene - 1000 gram
CYN2201 YNB w/o AA & w/o AS & w/o Molybdene - 100g
CYN2202 YNB w/o AA & w/o AS & w/o Molybdene - 500 g
CYN2210 YNB w/o AA & w/o AS & w/o Molybdene - 1000g
CYN2301 Yeast Nitrogen Base w/o AA & w/o Zinc - 100 gram
CYN2302 Yeast Nitrogen Base w/o AA & w/o Zinc - 500 gram
CYN2310 Yeast Nitrogen Base w/o AA & w/o Zinc - 1000 gram
CYN2401 YNB w/o AA & w/o AS & w/o Zinc - 100g
CYN2402 YNB w/o AA & w/o AS & w/o Zinc - 500g
CYN2410 YNB w/o AA & w/o AS & w/o Zinc - 1000g
CYN2501 Yeast Nitrogen Base w/o AA & w/o Calcium - 100 gram
CYN2502 Yeast Nitrogen Base w/o AA & w/o Calcium - 500 gram
CYN2510 Yeast Nitrogen Base w/o AA & w/o Calcium - 1000 gram
CYN2601 YNB w/o AA & w/o AS & w/o Calcium - 100g
CYN2602 YNB w/o AA & w/o AS & w/o Calcium - 500g
CYN2610 YNB w/o AA & w/o AS & w/o Calcium - 1000g
CYN2701 Yeast Nitrogen Base w/o AA & w/o Magnesium - 100 gram
CYN2702 Yeast Nitrogen Base w/o AA & w/o Magnesium - 500 gram
CYN2710 Yeast Nitrogen Base w/o AA & w/o Magnesium - 1000 gram
CYN2801 YNB w/o AA & w/o AS & w/o Magnesium - 100g
CYN2802 YNB w/o AA & w/o AS & w/o Magnesium - 500g
CYN2810 YNB w/o AA & w/o AS & w/o Magnesium - 1000g
CYN2901 Yeast Nitrogen Base w/o AA & w/o Sodium - 100 gram
CYN2902 Yeast Nitrogen Base w/o AA & w/o Sodium - 500 gram
CYN2910 Yeast Nitrogen Base w/o AA & w/o Sodium - 1000 gram
CYN3001 YNB w/o AA & w/o AS & w/o Sodium - 100g
CYN3002 YNB w/o AA & w/o AS & w/o Sodium - 500g
CYN3010 YNB w/o AA & w/o AS & w/o Sodium - 1000g
CYN3101 Yeast Nitrogen Base w/o AA & w/o Biotin - 100 gram
CYN3102 Yeast Nitrogen Base w/o AA & w/o Biotin - 500 gram
CYN3110 Yeast Nitrogen Base w/o AA & w/o Biotin - 1000 gram
CYN3201 YNB w/o AA & w/o AS & w/o Biotin - 100g
CYN3202 YNB w/o AA & w/o AS & w/o Biotin - 500g
CYN3210 YNB w/o AA & w/o AS & w/o Biotin - 1000g
CYN3301 Yeast Nitrogen Base w/o AA & w/o Ca-Pantothenate - 100 gram
CYN3302 Yeast Nitrogen Base w/o AA & w/o Ca-Pantothenate - 500 gram
CYN3310 Yeast Nitrogen Base w/o AA & w/o Ca-Pantothenate - 1000 gram
CYN3401 YNB w/o AA, AS & Ca.Pantothenate - 100 g
CYN3402 YNB w/o AA, AS & Ca.Pantothenate - 500 g
CYN3410 YNB w/o AA, AS & Ca.Pantothenate - 1000g
CYN3501 Yeast Nitrogen Base w/o AA & w/o Folic acid - 100 gram
CYN3502 Yeast Nitrogen Base w/o AA & w/o Folic acid - 500 gram
CYN3510 Yeast Nitrogen Base w/o AA & w/o Folic acid - 1000 gram
CYN3601 YNB w/o AA & w/o AS & w/o Folic acid - 100g
CYN3602 YNB w/o AA & w/o AS & w/o Folic acid - 500g
CYN3610 YNB w/o AA & w/o AS & w/o Folic acid - 1000g
CYN3701 Yeast Nitrogen Base w/o AA & w/o Inositol - 100 gram
CYN3702 Yeast Nitrogen Base w/o AA & w/o Inositol - 500 gram
CYN3710 Yeast Nitrogen Base w/o AA & w/o Inositol - 1000 gram
CYN3801 YNB w/o AA & w/o AS & w/o Inositol - 100g
CYN3802 YNB w/o AA & w/o AS & w/o Inositol - 500g
CYN3810 YNB w/o AA & w/o AS & w/o Inositol - 1000g
CYN3901 Yeast Nitrogen Base w/o AA & w/o Nicotinic acid - 100 gram
CYN3902 Yeast Nitrogen Base w/o AA & w/o Nicotinic acid - 500 gram
CYN3910 Yeast Nitrogen Base w/o AA & w/o Nicotinic acid - 1000 gram
CYN4001 YNB w/o AA & w/o AS & w/o Nicotinic acid - 100g
CYN4002 YNB w/o AA & w/o AS & w/o Nicotinic acid - 500 g
CYN4010 YNB w/o AA & w/o AS & w/o Nicotinic acid - 1000g
CYN4101 Yeast Nitrogen Base w/o AA & w/o p-ABA - 100 gram
CYN4102 Yeast Nitrogen Base w/o AA & w/o p-ABA - 500 gram
CYN4110 Yeast Nitrogen Base w/o AA & w/o p-ABA - 1000g
CYN4201 YNB w/o AA & w/o AS & w/o p-ABA - 100 g
CYN4202 YNB w/o AA & w/o AS & w/o p-ABA - 500 g
CYN4210 YNB w/o AA & w/o AS & w/o p-ABA - 1000g
CYN4301 Yeast Nitrogen Base w/o AA & w/o Pyridoxine - 100 gram
CYN4302 Yeast Nitrogen Base w/o AA & w/o Pyridoxine - 500 gram
CYN4310 Yeast Nitrogen Base w/o AA & w/o Pyridoxine - 1000 gram
CYN4401 YNB w/o AA & w/o AS & w/o Pyridoxine - 100 g
CYN4402 YNB w/o AA & w/o AS & w/o Pyridoxine - 500 g
CYN4410 YNB w/o AA & w/o AS & w/o Pyridoxine - 1000g
CYN4501 Yeast Nitrogen Base w/o AA & w/o Riboflavine - 100 gram
CYN4502 Yeast Nitrogen Base w/o AA & w/o Riboflavine - 500 gram
CYN4510 Yeast Nitrogen Base w/o AA & w/o Riboflavine - 1000 gram
CYN4601 YNB w/o AA & w/o AS & w/o Riboflavin - 100 g
CYN4602 YNB w/o AA & w/o AS & w/o Riboflavin - 500 g
CYN4610 YNB w/o AA & w/o AS & w/o Riboflavin - 1000g
CYN4701 Yeast Nitrogen Base w/o AA & w/o Thiamine - 100 gram
CYN4702 Yeast Nitrogen Base w/o AA & w/o Thiamine - 500 gram
CYN4710 Yeast Nitrogen Base w/o AA & w/o Thiamine - 1000 gram
CYN4801 YNB w/o AA & w/o AS & w/o Thiamine - 100 g
CYN4802 YNB w/o AA & w/o AS & w/o Thiamine - 500 g
CYN4810 YNB w/o AA & w/o AS & w/o Thiamine - 1000g
CYN4901 Yeast Nitrogen Base w/o AA & w/o Iodine - 100 gram
CYN4902 Yeast Nitrogen Base w/o AA & w/o Iodine - 500 gram
CYN4910 Yeast Nitrogen Base w/o AA & w/o Iodine - 1000 gram
CYN5501 Yeast Nitrogen Base w/o AA, AS, Phosphate & Inositol - 1000g
CYN6201 Yeast Nitrogen Base w/o AA,AS,Folic Acid & Riboflavin -100g
CYN6202 Yeast Nitrogen Base w/o AA,AS,Folic Acid & Riboflavin - 250g
CYN6205 Yeast Nitrogen Base w/o AA,AS,Folic Acid & Riboflavin - 500g
CYN6210 Yeast Nitrogen Base w/o AA,AS,Folic Acid & Riboflavin -1000g
CYN6501 Yeast Nitrogen Base w/o AA, Folic Acid & Riboflavine - 100g
CYN6502 Yeast Nitrogen Base w/o AA, Folic acid & Riboflavine - 250 g
CYN6505 Yeast Nitrogen Base w/o AA, Folic Acid & Riboflavine - 500g
CYN6510 Yeast Nitrogen Base w/o AA, Folic acid & Riboflavine - 1000g
CYN6701 Yeast Nitrogen Base w/o AA & Phos supp with KCl - 100g
CYN6702 YNB w/o Amino Acids & Phosphate supp with KCl - 250g
CYN6703 YNB w/o Amino Acids & Phosphate supp with KCl - 500g
CYN6704 YNB w/o Amino Acids & Phosphate supp with KCl - 1000g
CYN6801 YNB w/o AA w/o AS & w/o Phosphate supp. with KCL - 100g
CYN6802 YNB w/o AA w/o AS & w/o Phosphate supp. with KCL -  250g
CYN6803 YNB w/o AA w/o AS & w/o Phosphate supp. with KCL -  500g
CYN6804 YNB w/o AA w/o AS & w/o Phos Supp KCL -  1 Kg
CYN7501 Translucent K+ Free Medium, YNB w/o AA, AS & Potassium-100g
CYN7502 Translucent K+ Free Medium, YNB w/o AA, AS & Potassium- 250g
CYN7505 Translucent K+ Free Medium, YNB w/o AA, AS & Potassium-500g
CYN7510 Translucent K+ Free Medium, YNB w/o AA, AS & Potassium-1 Kg
CYN8010 YNB w/o Amino Acids,Potassium Hydrogen Phos & Inositol -1 Kg
CYN8510 YNB w/o AA w/o AS w/o Inositol w/o Zinc - 1000 g
CYN8910 Yeast Nitrogen Base w/o AA, Folic Acid & p-ABA - 1 Kg
CYN9010 Yeast Nitrogen Base w/o AA, AS, Folic Acid & p-ABA - 1 Kg
CYN9401 Yeast Nitrogen Base w/o AA, AS, Iron & Zinc - 1000g
CYN9501 YNB w/o AA, Folic Acid, Riboflavin & Copper - 1 Kg
CYN9502 YNB w/o AA, Folic Acid, Riboflavin & Copper - 250g
CYN9601 YNB w/o AA, AS, Folic Acid, Riboflavin & Copper - 1 Kg
CYN9701 YNB w/o AA,Folic Acid,Riboflavin, Copper & CaCl2 - 1000g
CYN9801 YNB w/o AA,Folic Acid,Riboflavin, Copper & Phosphate - 1000g
CYN9901 YNB w/o AA,Folic Acid,Riboflavin & Phosphate - 1000g
DBSM012 BSM Complete - 25 gram
DBSM022 BSM Single Drop Out: -His. - 25 gram
DBSM032 BSM Single Drop Out: -Trp. - 25 gram
DBSM042 BSM Single Drop Out: -Ura. - 25 gram
DBSM052 BSM Double Drop Out: -His. -Ura. - 25 gram
DBSM062 BSM Double Drop Out: -Leu. -Trp. - 25 gram
DBSM072 BSM Double Drop Out: -Trp. -Ura. - 25 gram
DBSM082 BSM Triple Drop Out: -His. -Leu. -Ura. - 25 gram
DBSM092 BSM Triple Drop Out: -His. -Trp. -Ura. - 25 gram
DBSM102 BSM Triple Drop Out: -Leu. -Trp. -Ura. - 25 gram
DBSM112 BSM Quadruple Drop Out: -His. -Leu. -Trp. -Ura. - 25 gram
DBSM1122 BSM Double Drop Out: -Met, -Ura - 100 gram
DBSM122 BSM Double Drop Out: -Met, -Ura - 25 gram
DCS0011 CSM Complete - 10 gram
DCS0019 CSM Complete - 100 gram
DCS0021 CSM Complete: +20 Ade - 10 gram
DCS0029 CSM Complete: +20 Ade - 100 gram
DCS0031 CSM Complete: +40 Ade - 10 gram
DCS0039 CSM Complete: +40 Ade - 100 gram
DCS0041 CSM Single Drop Out: -Ade - 10 gram
DCS0049 CSM Single Drop Out: -Ade - 100 gram
DCS0051 CSM Single Drop Out: -Arg - 10 gram
DCS0059 CSM Single Drop Out: -Arg - 100 gram
DCS0061 CSM Single Drop Out: -Asp - 10 gram
DCS0069 CSM Single Drop Out: -Asp - 100 gram
DCS0071 CSM Single Drop Out: -His - 10 gram
DCS0071D CSM Single Drop Out: -His - 50 gram
DCS0079 CSM Single Drop Out: -His. - 100 gram
DCS0081 CSM Single Drop Out: -Ile - 10 gram
DCS0089 CSM Single Drop Out: -Ile - 100 gram
DCS0091 CSM Single Drop Out: -Leu. - 10 gram
DCS00912 CSM Single Drop-out: -Leu - 20 gram
DCS0099 CSM Single Drop Out: -Leu. - 100 gram
DCS0101 CSM Single Drop Out: -Lys. - 10 gram
DCS0109 CSM Single Drop Out: -Lys. - 100 gram
DCS0111 CSM Single Drop Out: -Met. - 10 gram
DCS0111D CSM Single Drop-out: -Met - 50 gram
DCS0119 CSM Single Drop Out: -Met. - 100 gram
DCS0121 CSM Single Drop Out: -Phe. - 10 gram
DCS0129 CSM Single Drop Out: -Phe. - 100 gram
DCS0131 CSM Single Drop Out: -Thr. - 10 gram
DCS0139 CSM Single Drop Out: -Thr. - 100 gram
DCS0141 CSM Single Drop Out: -Trp. - 10 gram
DCS0149 CSM Single Drop Out: -Trp. - 100 gram
DCS0151 CSM Single Drop Out: -Tyr. - 10 gram
DCS0159 CSM Single Drop Out: -Tyr. - 100 gram
DCS0161 CSM Single Drop Out: -Ura. - 10 gram
DCS0161D CSM Single Drop Out: - Ura. - 50 gram
DCS0169 CSM Single Drop Out: -Ura. - 100 gram
DCS0171 CSM Single Drop Out: -Val. - 10 gram
DCS0179 CSM Single Drop Out: -Val. - 100 gram
DCS0181 CSM Single Drop Out: -Arg. +40 Ade.- 10 gram
DCS0189 CSM Single Drop Out: -Arg. +40 Ade.- 100 gram
DCS0191 CSM Single Drop Out: -His. +20 Ade.- 10 gram
DCS0199 CSM Single Drop Out: -His. +20 Ade.- 100 gram
DCS0201 CSM Single Drop Out: -His. +40 Ade.- 10 gram
DCS0209 CSM Single Drop Out: -His. +40 Ade.- 100 gram
DCS0211 CSM Single Drop Out: -Leu. +5 Ade.- 10 gram
DCS0219 CSM Single Drop Out: -Leu. +5 Ade.- 100 gram
DCS0221 CSM Single Drop Out: -Leu. +20 Ade.- 10 gram
DCS0229 CSM Single Drop Out: -Leu. +20 Ade.- 100 gram
DCS0231 CSM Single Drop Out: -Leu. +40 Ade.- 10 gram
DCS0239 CSM Single Drop Out: -Leu. +40 Ade.- 100 gram
DCS0241 CSM Single Drop Out: -Lys. +40 Ade.- 10 gram
DCS0249 CSM Single Drop Out: -Lys. +40 Ade.- 100 gram
DCS0251 CSM Single Drop Out: -Trp. +5 Ade.- 10 gram
DCS0259 CSM Single Drop Out: -Trp. +5 Ade.- 100 gram
DCS0261 CSM Single Drop Out: -Trp. +20 Ade.- 10 gram
DCS0269 CSM Single Drop Out: -Trp. +20 Ade.- 100 gram
DCS0271 CSM Single Drop Out: -Ura. +20 Ade.- 10 gram
DCS0279 CSM Single Drop Out: -Ura. +20 Ade.- 100 gram
DCS0281 CSM Single Drop Out: -Ura. +40 Ade.- 10 gram
DCS0289 CSM Single Drop Out: -Ura. +40 Ade.- 100 gram
DCS0291 CSM Single Drop Out: -Trp. +10 Ala. - 10 gram
DCS0299 CSM Single Drop Out: -Trp. +10 Ala. - 100 gram
DCS0301 CSM Single Drop Out: -Trp. +25 Ala. - 10 gram
DCS0309 CSM Single Drop Out: -Trp. +25 Ala. - 100 gram
DCS0311 CSM Single Drop Out: -Trp. +50 Ala. - 10 gram
DCS0319 CSM Single Drop Out: -Trp. +50 Ala. - 100 gram
DCS0321 CSM Single Drop Out: -His. +10 Ala. - 10 gram
DCS0329 CSM Single Drop Out: -His. +10 Ala. - 100 gram
DCS0331 CSM Single Drop Out: -His. +25 Ala. - 10 gram
DCS0339 CSM Single Drop Out: -His. +25 Ala. - 100 gram
DCS0341 CSM Single Drop Out: -His. +50 Ala. - 10 gram
DCS0349 CSM Single Drop Out: -His. +50 Ala. - 100 gram
DCS0351 CSM Double Drop Out: -Ade. -Arg. - 10 gram
DCS0359 CSM Double Drop Out: -Ade. -Arg. - 100 gram
DCS0361 CSM Double Drop Out: -Ade. -His. - 10 gram
DCS0369 CSM Double Drop Out: -Ade. -His. - 100 gram
DCS0371 CSM Double Drop Out: -Ade. -Leu. - 10 gram
DCS0379 CSM Double Drop Out: -Ade. -Leu. - 100 gram
DCS0381 CSM Double Drop Out: -Ade. -Lys. - 10 gram
DCS0389 CSM Double Drop Out: -Ade. -Lys. - 100 gram
DCS0391 CSM Double Drop Out: -Ade. -Met. - 10 gram
DCS0399 CSM Double Drop Out: -Ade. -Met. - 100 gram
DCS0401 CSM Double Drop Out: -Ade. -Trp. - 10 gram
DCS0409 CSM Double Drop Out: -Ade. -Trp. - 100 gram
DCS0411 CSM Double Drop Out: -Ade. -Ura. - 10 gram
DCS0419 CSM Double Drop Out: -Ade. -Ura. - 100 gram
DCS0421 CSM Double Drop Out: -Arg. -His. - 10 gram
DCS0429 CSM Double Drop Out: -Arg. -His. - 100 gram
DCS0431 CSM Double Drop Out: -Arg. -Leu. - 10 gram
DCS0439 CSM Double Drop Out: -Arg. -Leu. - 100 gram
DCS0441 CSM Double Drop Out: -Arg. -Trp. - 10 gram
DCS0449 CSM Double Drop Out: -Arg. -Trp. - 100 gram
DCS0451 CSM Double Drop Out: -Arg. -Ura. - 10 gram
DCS0459 CSM Double Drop Out: -Arg. -Ura. - 100 gram
DCS0461 CSM Double Drop Out: -His. -Leu. - 10 gram
DCS0469 CSM Double Drop Out: -His. -Leu. - 100 gram
DCS0471 CSM Double Drop Out: -His. -Lys. - 10 gram
DCS0479 CSM Double Drop Out: -His. -Lys. - 100 gram
DCS0481 CSM Double Drop Out: -His. -Met. - 10 gram
DCS0489 CSM Double Drop Out: -His. -Met. - 100 gram
DCS0491 CSM Double Drop Out: -His. -Thr. - 10 gram
DCS0499 CSM Double Drop Out: -His. -Thr. - 100 gram
DCS0501 CSM Double Drop Out: -His. -Trp. - 10 gram
DCS0509 CSM Double Drop Out: -His. -Trp. - 100 gram
DCS0511 CSM Double Drop Out: -His. -Tyr. - 10 gram
DCS0519 CSM Double Drop Out: -His. -Tyr. - 100 gram
DCS0521 CSM Double Drop Out: -His. -Ura. - 10 gram
DCS0529 CSM Double Drop Out: -His. -Ura. - 100 gram
DCS0531 CSM Double Drop Out: -Leu. -Lys. - 10 gram
DCS0539 CSM Double Drop Out: -Leu. -Lys. - 100 gram
DCS0541 CSM Double Drop Out: -Leu. -Met. - 10 gram
DCS0549 CSM Double Drop Out: -Leu. -Met. - 100 gram
DCS0551 CSM Double Drop Out: -Leu. -Thr. - 10 gram
DCS0559 CSM Double Drop Out: -Leu. -Thr. - 100 gram
DCS0561 CSM Double Drop Out: -Leu. -Trp. - 10 gram
DCS0569 CSM Double Drop Out: -Leu. -Trp. - 100 gram
DCS0571 CSM Double Drop Out: -Leu. -Tyr. - 10 gram
DCS0579 CSM Double Drop Out: -Leu. -Tyr. - 100 gram
DCS0581 CSM Double Drop Out: -Leu. -Ura. - 10 gram
DCS0589 CSM Double Drop Out: -Leu. -Ura. - 100 gram
DCS0591 CSM Double Drop Out: -Lys. -Met. - 10 gram
DCS0599 CSM Double Drop Out: -Lys. -Met. - 100 gram
DCS0601 CSM Double Drop Out: -Lys. -Thr. - 10 gram
DCS0609 CSM Double Drop Out: -Lys. -Thr. - 100 gram
DCS0611 CSM Double Drop Out: -Lys. -Trp. - 10 gram
DCS0619 CSM Double Drop Out: -Lys. -Trp. - 100 gram
DCS0621 CSM Double Drop Out: -Lys. -Tyr. - 10 gram
DCS0629 CSM Double Drop Out: -Lys. -Tyr. - 100 gram
DCS0631 CSM Double Drop Out: -Lys. -Ura. - 10 gram
DCS0639 CSM Double Drop Out: -Lys. -Ura. - 100 gram
DCS0641 CSM Double Drop Out: -Met. -Trp. - 10 gram
DCS0649 CSM Double Drop Out: -Met. -Trp. - 100 gram
DCS0651 CSM Double Drop Out: -Met. -Ura. - 10 gram
DCS0659 CSM Double Drop Out: -Met. -Ura. - 100 gram
DCS0661 CSM Double Drop Out: -Thr. -Trp. - 10 gram
DCS0669 CSM Double Drop Out: -Thr. -Trp. - 100 gram
DCS0671 CSM Double Drop Out: -Thr. -Ura. - 10 gram
DCS0679 CSM Double Drop Out: -Thr. -Ura. - 100 gram
DCS0681 CSM Double Drop Out: -Trp. -Tyr. - 10 gram
DCS0689 CSM Double Drop Out: -Trp. -Tyr. - 100 gram
DCS0691 CSM Double Drop Out: -Trp. -Ura. - 10 gram
DCS0699 CSM Double Drop Out: -Trp. -Ura. - 100 gram
DCS0701 CSM Double Drop Out: -Tyr. -Ura. - 10 gram
DCS0709 CSM Double Drop Out: -Tyr. -Ura. - 100 gram
DCS0711 CSM Double Drop Out: -His. -Leu. +20 Ade.- 10 gram
DCS0719 CSM Double Drop Out: -His. -Leu. +20 Ade.- 100 gram
DCS0721 CSM Double Drop Out: -His. -Leu. +40 Ade.- 10 gram
DCS0729 CSM Double Drop Out: -His. -Leu. +40 Ade.- 100 gram
DCS0731 CSM Double Drop Out: -His. -Trp. +20 Ade. - 10 gram
DCS0739 CSM Double Drop Out: -His. -Trp. +20 Ade. - 100 gram
DCS0741 CSM Double Drop Out: -His. -Trp. +40 Ade. - 10 gram
DCS0749 CSM Double Drop Out: -His. -Trp. +40 Ade. - 100 gram
DCS0751 CSM Double Drop Out: -His. -Ura. +40 Ade.- 10 gram
DCS0759 CSM Double Drop Out: -His. -Ura. +40 Ade.- 100 gram
DCS0761 CSM Double Drop Out: -Leu. -Met. +40 Ade.- 10 gram
DCS0769 CSM Double Drop Out: -Leu. -Met. +40 Ade.- 100 gram
DCS0771 CSM Double Drop Out: -Leu. -Trp. +20 Ade.- 10 gram
DCS0779 CSM Double Drop Out: -Leu. -Trp. +20 Ade.- 100 gram
DCS0781 CSM Double Drop Out: -Leu. -Trp. +40 Ade.- 10 gram
DCS0789 CSM Double Drop Out: -Leu. -Trp. +40 Ade.- 100 gram
DCS0791 CSM Double Drop Out: -Leu. -Ura. +40 Ade.- 10 gram
DCS0799 CSM Double Drop Out: -Leu. -Ura. +40 Ade.- 100 gram
DCS0801 CSM Double Drop Out: -Trp. -Ura. +40 Ade.- 10 gram
DCS0809 CSM Double Drop Out: -Trp. -Ura. +40 Ade.- 100 gram
DCS0811 CSM Double Drop Out: -Leu. -Ura. +30 Ser. - 10 gram
DCS0819 CSM Double Drop Out: -Leu. -Ura. +30 Ser. - 100 gram
DCS0821 CSM Triple Drop Out: -Ade. -Arg. -Lys. - 10 gram
DCS0829 CSM Triple Drop Out: -Ade. -Arg. -Lys. - 100 gram
DCS0831 CSM Triple Drop Out: -Ade. -His. -Leu. - 10 gram
DCS0839 CSM Triple Drop Out: -Ade. -His. -Leu. - 100 gram
DCS0841 CSM Triple Drop Out: -Ade. -His. -Trp. - 10 gram
DCS0849 CSM Triple Drop Out: -Ade. -His. -Trp. - 100 gram
DCS0851 CSM Triple Drop Out: -Ade. -His. -Ura. - 10 gram
DCS0859 CSM Triple Drop Out: -Ade. -His. -Ura. - 100 gram
DCS0861 CSM Triple Drop Out: -Ade. -Leu. -Met. - 10 gram
DCS0869 CSM Triple Drop Out: -Ade. -Leu. -Met. - 100 gram
DCS0871 CSM Triple Drop Out: -Ade. -Leu. -Trp. - 10 gram
DCS0879 CSM Triple Drop Out: -Ade. -Leu. -Trp. - 100 gram
DCS0881 CSM Triple Drop Out: -Ade. -Leu. -Ura. - 10 gram
DCS0889 CSM Triple Drop Out: -Ade. -Leu. -Ura. - 100 gram
DCS0891 CSM Triple Drop Out: -Ade. -Met. -Trp. - 10 gram
DCS0899 CSM Triple Drop Out: -Ade. -Met. -Trp. - 100 gram
DCS0901 CSM Triple Drop Out: -Ade. -Met. -Ura. - 10 gram
DCS0909 CSM Triple Drop Out: -Ade. -Met. -Ura. - 100 gram
DCS0911 CSM Triple Drop Out: -Ade. -Trp. -Ura. - 10 gram
DCS0919 CSM Triple Drop Out: -Ade. -Trp. -Ura. - 100 gram
DCS0921 CSM Triple Drop Out: -Arg. -His. -Lys. - 10 gram
DCS0929 CSM Triple Drop Out: -Arg. -His. -Lys. - 100 gram
DCS0931 CSM Triple Drop Out: -Arg. -His. -Ura. - 10 gram
DCS0939 CSM Triple Drop Out: -Arg. -His. -Ura. - 100 gram
DCS0941 CSM Triple Drop Out: -Arg. -Leu. -Ura. - 10 gram
DCS0949 CSM Triple Drop Out: -Arg. -Leu. -Ura. - 100 gram
DCS0951 CSM Triple Drop Out: -Arg. -Trp. -Ura. - 10 gram
DCS0959 CSM Triple Drop Out: -Arg. -Trp. -Ura. - 100 gram
DCS0961 CSM Triple Drop Out: -His. -Leu. -Lys. - 10 gram
DCS0969 CSM Triple Drop Out: -His. -Leu. -Lys. - 100 gram
DCS0971 CSM Triple Drop Out: -His. -Leu. -Trp. - 10 gram
DCS0979 CSM Triple Drop Out: -His. -Leu. -Trp. - 100 gram
DCS0981 CSM Triple Drop Out: -His. -Leu. -Met. - 10 gram
DCS0989 CSM Triple Drop Out: -His. -Leu. -Met. - 100 gram
DCS0991 CSM Triple Drop Out: -His. -Leu. -Ura. - 10 gram
DCS0999 CSM Triple Drop Out: -His. -Leu. -Ura. - 100 gram
DCS1001 CSM Triple Drop Out: -His. -Lys. -Trp. - 10 gram
DCS1009 CSM Triple Drop Out: -His. -Lys. -Trp. - 100 gram
DCS1011 CSM Triple Drop Out: -His. -Lys. -Ura. - 10 gram
DCS1019 CSM Triple Drop Out: -His. -Lys. -Ura. - 100 gram
DCS1021 CSM Triple Drop Out: -His. -Met. -Trp. - 10 gram
DCS1029 CSM Triple Drop Out: -His. -Met. -Trp. - 100 gram
DCS1031 CSM Triple Drop Out: -His. -Met. -Ura. - 10 gram
DCS1039 CSM Triple Drop Out: -His. -Met. -Ura. - 100 gram
DCS1041 CSM Triple Drop Out: -His. -Trp. -Val. - 10 gram
DCS1049 CSM Triple Drop Out: -His. -Trp. -Val. - 100 gram
DCS1051 CSM Triple Drop Out: -His. -Trp. -Ura. - 10 gram
DCS1059 CSM Triple Drop Out: -His. -Trp. -Ura. - 100 gram
DCS1061 CSM Triple Drop Out: -Leu. -Lys. -Trp. - 10 gram
DCS1069 CSM Triple Drop Out: -Leu. -Lys. -Trp. - 100 gram
DCS1071 CSM Triple Drop Out: -Leu. -Lys. -Ura. - 10 gram
DCS1079 CSM Triple Drop Out: -Leu. -Lys. -Ura. - 100 gram
DCS1081 CSM Triple Drop Out: -Leu. -Met. -Trp. - 10 gram
DCS1089 CSM Triple Drop Out: -Leu. -Met. -Trp. - 100 gram
DCS1091 CSM Triple Drop Out: -Leu. -Met. -Ura. - 10 gram
DCS1099 CSM Triple Drop Out: -Leu. -Met. -Ura. - 100 gram
DCS1101 CSM Triple Drop Out: -Leu. -Trp. -Ura. - 10 gram
DCS1109 CSM Triple Drop Out: -Leu. -Trp. -Ura. - 100 gram
DCS1111 CSM Triple Drop Out: -Lys. -Trp. -Ura. - 10 gram
DCS1119 CSM Triple Drop Out: -Lys. -Trp. -Ura. - 100 gram
DCS1121 CSM Triple Drop Out: -Lys. -Tyr. -Ura. - 10 gram
DCS1129 CSM Triple Drop Out: -Lys. -Tyr. -Ura. - 100 gram
DCS1131 CSM Triple Drop Out: -Met. -Trp. -Ura. - 10 gram
DCS1139 CSM Triple Drop Out: -Met. -Trp. -Ura. - 100 gram
DCS1141 CSM Triple Drop Out: -Phe. -Trp. -Tyr. - 10 gram
DCS1149 CSM Triple Drop Out: -Phe. -Trp. -Tyr. - 100 gram
DCS1151 CSM Triple Drop Out: -His. -Leu. -Trp. +20 Ade.- 10 gram
DCS1159 CSM Triple Drop Out: -His. -Leu. -Trp. +20 Ade.- 100 gram
DCS1161 CSM Triple Drop Out: -His. -Leu. -Trp. +40 Ade.- 10 gram
DCS1169 CSM Triple Drop Out: -His. -Leu. -Trp. +40 Ade.- 100 gram
DCS1171 CSM Triple DO.-His. -Leu.-Ura.+20 Ser.+20 Pro.+20 Cys - 10 g
DCS1179 CSM Triple DO.-His.-Leu-Ura.+20 Ser.+20 Pro.+20 Cys - 100 g
DCS1181 CSM Triple DO.-His.-Leu.-Trp.+20 Ser.+20 Pro.+20 Cys - 10 g
DCS1189 CSM Triple DO.-His.-Leu.-Trp.+20 Ser.+20 Pro.+20 Cys - 100 g
DCS1191 CSM Quadruple Drop Out: -Ade. -Arg. -Leu. -Ura. - 10 gram
DCS1199 CSM Quadruple Drop Out: -Ade. -Arg. -Leu. -Ura. - 100 gram
DCS1201 CSM Quadruple Drop Out: -Ade. -Arg. -Met. -Tyr. - 10 gram
DCS1209 CSM Quadruple Drop Out: -Ade. -Arg. -Met. -Tyr. - 100 gram
DCS1211 CSM Quadruple Drop Out: -Ade. -His. -Leu. -Lys. - 10 gram
DCS1219 CSM Quadruple Drop Out: -Ade. -His. -Leu. -Lys. - 100 gram
DCS1221 CSM Quadruple Drop Out: -Ade. -His. -Leu. -Trp. - 10 gram
DCS1229 CSM Quadruple Drop Out: -Ade. -His. -Leu. -Trp. - 100 gram
DCS1231 CSM Quadruple Drop Out: -Ade. -His. -Leu. -Ura. - 10 gram
DCS1239 CSM Quadruple Drop Out: -Ade. -His. -Leu. -Ura. - 100 gram
DCS1241 CSM Quadruple Drop Out: -Ade. -His. -Met. -Ura. - 10 gram
DCS1249 CSM Quadruple Drop Out: -Ade. -His. -Met. -Ura. - 100 gram
DCS1251 CSM Quadruple Drop Out: -Ade. -His. -Trp. -Ura. - 10 gram
DCS1259 CSM Quadruple Drop Out: -Ade. -His. -Trp. -Ura. - 100 gram
DCS1261 CSM Quadruple Drop Out: -Ade. -Leu. -Lys. -Trp. - 10 gram
DCS1269 CSM Quadruple Drop Out: -Ade. -Leu. -Lys. -Trp. - 100 gram
DCS1271 CSM Quadruple Drop Out: -Ade. -Leu. -Met. -Ura. - 10 gram
DCS1279 CSM Quadruple Drop Out: -Ade. -Leu. -Met. -Ura. - 100 gram
DCS1281 CSM Quadruple Drop Out: -Ade. -Leu. -Trp. -Ura. - 10 gram
DCS1289 CSM Quadruple Drop Out: -Ade. -Leu. -Trp. -Ura. - 100 gram
DCS1291 CSM Quadruple Drop Out: -Ade. -Met. -Trp. -Ura. - 10 gram
DCS1299 CSM Quadruple Drop Out: -Ade. -Met. -Trp. -Ura. - 100 gram
DCS1301 CSM Quadruple Drop Out: -Arg. -His. -Lys. -Ura. - 10 gram
DCS1309 CSM Quadruple Drop Out: -Arg. -His. -Lys. -Ura. - 100 gram
DCS1311 CSM Quadruple Drop Out: -Arg. -Leu. -Lys. -Ura. - 10 gram
DCS1319 CSM Quadruple Drop Out: -Arg. -Leu. -Lys. -Ura. - 100 gram
DCS1321 CSM Quadruple Drop Out: -Arg. -Leu. -Trp. -Ura. - 10 gram
DCS1329 CSM Quadruple Drop Out: -Arg. -Leu. -Trp. -Ura. - 100 gram
DCS1331 CSM Quadruple Drop Out: -Arg. -Lys. -Trp. -Ura. - 10 gram
DCS1339 CSM Quadruple Drop Out: -Arg. -Lys. -Trp. -Ura. - 100 gram
DCS1341 CSM Quadruple Drop Out: -Asp. -His. -Leu. -Trp. - 10 gram
DCS1349 CSM Quadruple Drop Out: -Asp. -His. -Leu. -Trp. - 100 gram
DCS1351 CSM Quadruple Drop Out: -His. -Leu. -Lys. -Trp. - 10 gram
DCS1359 CSM Quadruple Drop Out: -His. -Leu. -Lys. -Trp. - 100 gram
DCS1361 CSM Quadruple Drop Out: -His. -Leu. -Met. -Trp. - 10 gram
DCS1369 CSM Quadruple Drop Out: -His. -Leu. -Met. -Trp. - 100 gram
DCS1371 CSM Quadruple Drop Out: -His. -Leu. -Lys. -Ura. - 10 gram
DCS1379 CSM Quadruple Drop Out: -His. -Leu. -Lys. -Ura. - 100 gram
DCS1381 CSM Quadruple Drop Out: -His. -Leu. -Trp. -Ura. - 10 gram
DCS1389 CSM Quadruple Drop Out: -His. -Leu. -Trp. -Ura. - 100 gram
DCS1391 CSM Quadruple Drop Out: -His. -Lys. -Trp. -Ura. - 10 gram
DCS1399 CSM Quadruple Drop Out: -His. -Lys. -Trp. -Ura. - 100 gram
DCS1401 CSM Quadruple Drop Out: -His. -Met. -Trp. -Ura. - 10 gram
DCS1409 CSM Quadruple Drop Out: -His. -Met. -Trp. -Ura. - 100 gram
DCS1411 CSM Quadruple Drop Out: -Leu. -Lys. -Trp. -Ura. - 10 gram
DCS1419 CSM Quadruple Drop Out: -Leu. -Lys. -Trp. -Ura. - 100 gram
DCS1421 CSM Quadruple Drop Out: -Leu. -Met. -Trp. -Ura. - 10 gram
DCS1429 CSM Quadruple Drop Out: -Leu. -Met. -Trp. -Ura. - 100 gram
DCS1431 CSM Quad.-Arg.-His.-Leu.-Trp +20Cys.+20Pro.+20Ser.+20Ura 10g
DCS1439 CSM Quad.-Arg.-His.-Leu.-Trp.+20Cys.+20Pro+20Ser.+20Ura 100g
DCS1441 CSM Quad DO.-His.-Leu.-Trp. +20Cys. +20Pro. +20Ser. - 10g
DCS1449 CSM Quad DO.-His.-Leu.-Trp.-Ura.+20Cys.+20Pro.+20Ser - 100g
DCS1451 CSM Multiple DO.-Ade.-Arg.-His.-Leu.-Met.-Thr.-Trp.-Ura -10g
DCS1459 CSM Multiple DO.-Ade.-Arg.-His.-Leu.-Met.-Thr.-Trp.-Ura-100g
DCS1461 CSM Mul DO.-Arg.-Asp.-Ile.-Met.-Phe.-Thr.-Tyr.-Ura.-Val -10g
DCS1469 CSM Mul DO.-Arg.-Asp.-Ile.-Met.-Phe.-Thr.-Tyr.-Ura.-Val-100g
DCS1471 CSM Mul DO.-Ade.-His.-Leu.-Lys.-Met.-Thr.-Trp.-Tyr.-Ura -10g
DCS1479 CSM Mul DO.-Ade.-His.-Leu.-Lys.-Met.-Thr.-Trp.-Tyr.-Ura-100g
DCS1481 CSM Multiple DO.-Ade.-His.-Leu.-Lys.-Trp.-Tyr.-Ura. - 10g
DCS1489 CSM Multiple DO.-Ade.-His.-Leu.-Lys.-Trp.-Tyr,-Ura. - 100g
DCS1491 CSM Multiple DO. -Ade. -His. -Leu. -Lys. -Trp. -Ura. - 10 gr
DCS1499 CSM Multiple DO. -Ade. -His. -Leu. -Lys. -Trp. -Ura. - 100 g
DCS1501 CSM Multiple DO. -Ade. -His. -Leu. -Met. -Trp. - 10 gram
DCS1509 CSM Multiple DO. -Ade. -His. -Leu. -Met. -Trp. - 100 gram
DCS1511 CSM Multiple DO. -Ade. -His. -Leu. -Met. -Trp. -Ura. - 10 gr
DCS1519 CSM Multiple DO. -Ade. -His. -Leu. -Met. -Trp. -Ura. - 100 g
DCS1521 CSM Multiple DO. -Ade.-His.-Leu.-Trp.-Ura. - 10 gram
DCS1529 CSM Multiple DO. -Ade.-His.-Leu.-Trp.-Ura. - 100 gram
DCS1531 CSM Multiple DO. -Ade. -His. -Lys. -Trp. -Ura. - 10 gram
DCS1539 CSM Multiple DO. -Ade. -His. -Lys. -Trp. -Ura. - 100 gram
DCS1541 CSM Multiple DO. -Ade. -Leu. -Lys. -Met. -Trp. -Ura. - 10 gr
DCS1549 CSM Multiple DO. -Ade. -Leu. -Lys. -Met. -Trp. -Ura. - 100 g
DCS1551 CSM Multiple DO. -Arg. -His. -Lys. -Trp. -Ura. - 10 gram
DCS1559 CSM Multiple DO. -Arg. -His. -Lys. -Trp. -Ura. - 100 gram
DCS1561 CSM Multiple DO.-His.-Leu.-Lys.-Met.-Thr.-Trp.-Ura. - 10g
DCS1569 CSM Multiple DO.-His.-Leu.-Lys.-Met.-Thr.-Trp.-Ura. - 100g
DCS1571 CSM Multiple DO. -His. -Leu. -Lys. -Trp. -Ura. - 10 gram
DCS1579 CSM Multiple DO. -His. -Leu. -Lys. -Trp. -Ura. - 100 gram
DCS1581 CSM Multiple DO. -His. -Leu. -Met. -Trp. -Ura. - 10 gram
DCS1589 CSM Multiple DO. -His. -Leu. -Met. -Trp. -Ura. - 100 gram
DCS1591 CSM Triple Drop-Out: -His, -Lys, -Met +40 Ade. - 10g
DCS1599 CSM Triple Drop-Out: -His, -Lys, -Met +40 Ade. - 100g
DCS1601 CSM Triple Drop Out: -Arg, -His, -Met - 10g
DCS1609 CSM Triple Drop Out: -Arg, -His, -Met - 100g
DCS1611 CSM Triple Drop Out: -Arg, -Lys, -Met - 10g
DCS1619 CSM Triple Drop Out: -Arg, -Lys, -Met - 100g
DCS1621 CSM Triple Drop Out: -Leu, -Lys, -Met - 10g
DCS1629 CSM Triple Drop Out: -Leu, -Lys, -Met - 100g
DCS1631 CSM Multiple Drop Out: -Arg, -His, -Leu, -Lys, -Met - 10g
DCS1639 CSM Multiple Drop Out: -Arg, -His, -Leu, -Lys, -Met - 100g
DCS1641 CSM Multiple Drop Out: -Ade,-His,-Leu,-Lys,-Met,-Ura - 10g
DCS1649 CSM Multiple Drop Out: -Ade,-His,-Leu,-Lys,-Met,-Ura - 100g
DCS1651 CSM Quadruple Drop Out: -Arg, -His, -Leu, -Lys - 10g
DCS1659 CSM Quadruple Drop Out: -Arg, -His, -Leu, -Lys - 100g
DCS1661 CSM Multiple DO: -Arg,-His,-Leu,-Lys,-Trp,-Ura - 10g
DCS1669 CSM Multiple DO: -Arg,-His,-Leu,-Lys,-Trp,-Ura - 100g
DCS1671 CSM Quadruple Drop Out: -His, -Leu, -Met, -Ura - 10g
DCS1679 CSM Quadruple Drop Out: -His, -Leu, -Met, -Ura - 100g
DCS1681 CSM Multiple Drop Out: -His,-Leu,-Phe,-Trp,-Tyr,-Ura - 10g
DCS1689 CSM Multiple Drop Out: -His,-Leu,-Phe,-Trp,-Tyr,-Ura - 100g
DCS1691 CSM Multiple Drop Out: -Asp,-Ile,-Leu,-Lys,-Val - 10g
DCS1699 CSM Multiple Drop Out: -Asp,-Ile,-Leu,-Lys,-Val - 100g
DCS1701 CSM Quadruple Drop Out: -Ile,-Leu,-Ura,-Val - 10g
DCS1709 CSM Quadruple Drop Out: -Ile,-Leu,-Ura,-Val - 100g
DCS1711 CSM Double Drop Out: -Ile, -Val - 10g
DCS1719 CSM Double Drop Out: -Ile, -Val - 100g
DCS1721 CSM Multiple Drop-Out: -Leu,-Phe,-Trp,-Tyr,-Ura - 10g
DCS1729 CSM Multiple Drop-Out: -Leu,-Phe,-Trp,-Tyr,-Ura - 100g
DCS1731 CSM Multiple Drop Out: -Arg,-Leu,-Lys,-Met,-Ura - 10g
DCS1739 CSM Multiple Drop Out: -Arg,-Leu,-Lys,-Met,-Ura - 100g
DCS1741 CSM Triple Drop Out: -His, -Lys, -Met - 10g
DCS1749 CSM Triple Drop Out: -His, -Lys, -Met - 100g
DCS5023 CSM Single Drop Out: -Trp +20 Ade - 500g
DHSM015 HSM Single Drop Out: -His. - 50 gram
DHSM025 HSM Single Drop Out: -Leu. - 50 gram
DHSM035 HSM Single Drop Out: -Lys. - 50 gram
DHSM045 HSM Single Drop Out: -Trp. - 50 gram
DHSM055 HSM Single Drop Out: -Ura. - 50 gram
DHSM065 HSM Double Drop Out: -Leu. -Trp. - 50 gram
DHSM075 HSM Double Drop Out: -Trp. -Ura. - 50 gram
DHSM085 HSM Double Drop Out: -Leu. -Ura. - 50 gram
DHSM095 HSM Triple Drop Out: -His. -Leu. -Trp. - 50 gram
DHSM105 HSM Triple Drop Out: -His. -Leu. -Ura. - 50 gram
DHSM115 HSM Triple Drop Out: -His. -Lys. -Ura. - 50 gram
DHSM125 HSM Triple Drop Out: -His. -Trp. -Ura. - 50 gram
DHSM135 HSM Triple Drop Out: -Met. -Trp. -Ura. - 50 gram
DHSM145 HSM Triple Drop Out: -Leu. -Trp. -Ura. - 50 gram
DHSM155 HSM Quadruple Drop Out: -His. -Leu. -Trp. -Ura. - 50 gram
DHSM165 HSM Quadruple Drop Out: -His. -Lys. -Trp. -Ura. - 50 gram
DHSM175 HSM Multiple Drop Out: -His. -Leu. -Lys. -Trp. -Ura. - 50 gr
DHSM185 HSM Multiple D/O:-Ade. -His. -Leu.-Lys. -Met. -Trp.-Ura- 50g
DOC0102 L-Alanine - 5 gram
DOC0103 L-Alanine - 10 gram
DOC0104 L-Alanine - 25 gram
DOC0105 L-Alanine - 100 gram
DOC0106 L-Arginine- 5 gram
DOC0107 L-Arginine- 10 gram
DOC0108 L-Arginine- 25 gram
DOC0109 L-Arginine- 100 gram
DOC0114 L-Asparagine Monohydrate - 5 gram
DOC0115 L-Asparagine Monohydrate - 10 gram
DOC0116 L-Asparagine Monohydrate - 25 gram
DOC0117 L-Asparagine Monohydrate - 100 gram
DOC0118 L-Aspartic acid - 5 gram
DOC0119 L-Aspartic acid - 10 gram
DOC0120 L-Aspartic acid - 25 gram
DOC0121 L-Aspartic acid - 100 gram
DOC0122 L-Cysteine - 5 gram
DOC0123 L-Cysteine - 10 gram
DOC0124 L-Cysteine - 25 gram
DOC0125 L-Cysteine - 100 gram
DOC0130 L-Glutamine - 5 gram
DOC0131 L-Glutamine - 10 gram
DOC0132 L-Glutamine - 25 gram
DOC0133 L-Glutamine - 100 gram
DOC0134 L-Glutamic acid - 5 gram
DOC0135 L-Glutamic acid - 10 gram
DOC0136 L-Glutamic acid - 25 gram
DOC0137 L-Glutamic acid - 100 gram
DOC0138 Glycine - 5 gram
DOC0139 Glycine - 10 gram
DOC0140 Glycine - 25 gram
DOC0141 Glycine - 100 gram
DOC0141C Glycine - 1 Kg
DOC0142 L-Histidine - 5 gram
DOC0143 L-Histidine - 10 gram
DOC0144 L-Histidine - 25 gram
DOC0145 L-Histidine - 100 gram
DOC0150 L-IsoLeucine - 5 gram
DOC0151 L-IsoLeucine - 10 gram
DOC0152 L-IsoLeucine - 25 gram
DOC0153 L-IsoLeucine - 100 gram
DOC0154 L-Leucine - 5 gram
DOC0155 L-Leucine - 10 gram
DOC0156 L-Leucine - 25 gram
DOC0157 L-Leucine - 100 gram
DOC0158 L-Lysine - 5 gram
DOC0159 L-Lysine - 10 gram
DOC0160 L-Lysine - 25 gram
DOC0161 L-Lysine - 100 gram
DOC0166 L-Methionine - 5 gram
DOC0167 L-Methionine - 10 gram
DOC0168 L-Methionine - 25 gram
DOC0169 L-Methionine - 100 gram
DOC0170 L-Phenylalanine - 5 gram
DOC0171 L-Phenylalanine - 10 gram
DOC0172 L-Phenylalanine - 25 gram
DOC0173 L-Phenylalanine - 100 gram
DOC0174 L-Proline - 5 gram
DOC0175 L-Proline - 10 gram
DOC0176 L-Proline - 25 gram
DOC0177 L-Proline - 100 gram
DOC0178 L-Serine - 5 gram
DOC0179 L-Serine - 10 gram
DOC0180 L-Serine - 25 gram
DOC0181 L-Serine - 100 gram
DOC0182 L-Threonine - 5 gram
DOC0183 L-Threonine - 10 gram
DOC0184 L-Threonine - 25 gram
DOC0185 L-Threonine - 100 gram
DOC01850 L-Serine - 500g
DOC0186 L-Tryptophan - 5 gram
DOC0187 L-Tryptophan - 10 gram
DOC0188 L-Tryptophan - 25 gram
DOC0189 L-Tryptophan - 100 gram
DOC0190 L-Tyrosine - 5 gram
DOC0191 L-Tyrosine - 10 gram
DOC0192 L-Tyrosine - 25 gram
DOC0193 L-Tyrosine - 100 gram
DOC0194 L-Valine - 5 gram
DOC0195 L-Valine - 10 gram
DOC0196 L-Valine - 25 gram
DOC0197 L-Valine - 100 gram
DOC0198 Inositol - 5 gram
DOC0199 Inositol - 10 gram
DOC0200 Inositol - 25 gram
DOC0201 Inositol - 100 gram
DOC0202 D(+)-Biotin - 1 gram
DOC0203 D(+)-Biotin - 5 gram
DOC0204 para-Aminobenzoic acid - 5 gram
DOC0205 para-Aminobenzoic acid - 10 gram
DOC0206 para-Aminobenzoic acid - 25 gram
DOC0207 para-Aminobenzoic acid - 100 gram
DOC0210 L-Threonine 250 gram
DOC0212 Uracil - 5 gram
DOC0213 Uracil - 25 gram
DOC0214 Uracil - 100 gram
DOC0215 Uracil - 250 gram
DOC0220 L-Arginine - 500 gram
DOC0225 L-Leucine - 500 gram
DOC0228 Adenine Sulphate - 5 gram
DOC0229 Adenine Sulphate - 25 gram
DOC0230 Adenine Sulphate - 100 gram
DOX01 Doxycycline Hyclate - 1 gram
DOX05 Doxycycline Hyclate - 5 gram
DOX10 Doxycycline Hyclate - 10 gram
DOX100 Doxycycline Hyclate - 100 gram
DOX25 Doxycycline Hyclate - 25 gram
DSA0110 Saubaurad Dextrose Agar - 1000g
DSCK012 SC Complete - 20 gram
DSCK022 SC Single Drop Out: -Ade.- 20 gram
DSCK032 SC Single Drop Out: -Cys - 20 gram
DSCK042 SC Single Drop Out: -His. - 20 gram
DSCK04C SC Multiple Drop Out: -Arg, -His, -Leu, -Trp, -Ura - 100g
DSCK052 SC Single Drop Out: -Leu. - 20 gram
DSCK062 SC Single Drop Out: -Lys. - 20 gram
DSCK072 SC Single Drop Out: -Met. - 20 gram
DSCK082 SC Single Drop Out: -Pro - 20 gram
DSCK092 SC Single Drop Out: -Trp. - 20 gram
DSCK1000 SC Complete - 100 gram
DSCK1001 SC Single Drop Out: -Ade - 100 gram
DSCK1002 SC Single Drop Out: -Cys - 100 gram
DSCK1003 SC Single Drop Out: -His. - 100 gram
DSCK1004 SC Single Drop Out: -Leu. - 100 gram
DSCK1005 SC Single Drop Out: -Lys. - 100 gram
DSCK1006 SC Single Drop Out: -Met. - 100 gram
DSCK1007 SC Single Drop Out: -Pro. - 100 gram
DSCK1008 SC Single Drop Out: -Trp - 100 gram
DSCK1009 SC Single Drop Out: -Ura - 100 gram
DSCK1010 SC Double Drop Out: -Ade. -Leu. - 100 gram
DSCK1011 SC Double Drop Out: -Ade. -Lys. - 100 gram
DSCK1012 SC Double Drop Out: -Ade. -Trp. - 100 gram
DSCK1013 SC Double Drop Out: -Cys. -Met. - 100 gram
DSCK1014 SC Double Drop Out: -His. -Leu. - 100 gram
DSCK1015 SC Double Drop Out: -His. -Ura. - 100 gram
DSCK1016 SC Double Drop Out: -Leu. -Trp. - 100 gram
DSCK1017 SC Double Drop Out: -Leu. -Ura. - 100 gram
DSCK1018 SC Double Drop Out: -Met. -Ura. - 100 gram
DSCK1019 SC Double Drop Out: -Trp. -Ura - 100 gram
DSCK102 SC Single Drop Out: -Ura. - 20 gram
DSCK1020 SC Double Drop Out: -Ura. -Inositol - 100 gram
DSCK1021 SC Triple Drop Out: -Cys. -His. -Met. - 100 gram
DSCK1022 SC Triple Drop Out: -Cys, -Met, -Ura. - 100 gram
DSCK1023 SC Triple Drop Out: -His. -Leu. -Trp. - 100 gram
DSCK1024 SC Triple Drop Out: -His. -Leu. -Ura. - 100 gram
DSCK1025 SC Triple Drop Out: -His. -Trp. -Ura. - 100 gram
DSCK1026 SC Quadruple Drop Out: -Ade, -His, -Leu, -Trp. - 100 gram
DSCK1027 SC Quadruple Drop Out: -His, -Leu, -Trp, -Ura. - 100 gram
DSCK1028 SC Multiple D/O: -Ade -His -Leu -Lys -Trp -Ura - 100g
DSCK1029 SC Multiple Drop Out: -Cys, -Leu, -Lys, -Met, -Ura. - 100g
DSCK1030 SC Multiple D/O:-Ade.-Arg.-His.-Leu.-Met.-Thr.-Trp.-Ura 100g
DSCK1031 SC Multiple Drop Out: -Ade. -His. -Leu. -Trp. -Ura - 100gram
DSCK1032 SC Multiple Drop Out: -Arg. -His. -Lys. -Met. -Ura.-100 gram
DSCK1033 SC Single Drop Out: -Arg. - 100 gram
DSCK1034 SC Triple Drop Out: -Leu, -Lys, -Trp. - 100 gram
DSCK1035 SC Triple Drop Out: -Leu. -Trp. -Ura. - 100 gram
DSCK1036 SC Single Drop Out: -Ura. +40mg/L Ade. - 100 gram
DSCK1037 SC Multiple Drop Out: -Cys.-Leu.-Lys.-Met.-Trp.-Ura - 100 g
DSCK1038 SC Single Drop-out: -Thr - 100g
DSCK1039 SC Multiple Drop Out: -His,-Leu,-Met,-Trp,-Ura. - 100 gram
DSCK1044 SC Triple Drop-out: -Arg, -Lys, -Met. - 100 gram
DSCK1051 SC Double Drop Out: -His. -Trp. - 100 gram
DSCK1052 SC Double Drop Out: -Met. -Trp. - 100 gram
DSCK1053 SC Double Drop Out: -Ade. -Ura. - 100 gram
DSCK1054 SC Triple Drop-out: -Arg, -Lys, -Ura. - 100 gram
DSCK1055 SC Triple Drop Out: -His, -Leu, -Met. - 100 gram
DSCK1056 SC Triple Drop Out: -Ade, -Leu, -Trp. - 100 gram
DSCK1057 SC Triple Drop Out: -Leu, -Met, -Ura - 100 gram
DSCK1058 SC Multiple D/O: -His, -Leu, -Lys, -Met, -Trp, -Ura - 100g
DSCK1059 SC Triple Drop Out: -Ade, -Arg, -Lys - 100 gram
DSCK1060 SC Triple Drop Out: -Arg, -His, -Ura - 100 gram
DSCK1070 SC Drop Out: - Ura + 20 Ade - 100 gram
DSCK1080 SC Single Drop Out: -Ser - 100g
DSCK1090 SC Drop Out: -His,-Ile,-Leu,-Trp,-Ura,-Val - 100g
DSCK1100 SC Drop Out: -His,-Leu,-Lys,-Met,-Ura - 100 gram
DSCK1110 SC Multiple Drop Out: -Arg,-Leu,-Lys,-Trp,-Ura - 100g
DSCK112 SC Double Drop Out: -Ade. -Leu. - 20 gram
DSCK1120 SC Multiple Drop Out: -His, -Lys, -Met, -Trp, -Ura - 100g
DSCK1130 SC Triple Drop Out: -Ade, -Met, -Ura - 100g
DSCK1140 SC Triple Drop Out: -Arg, -Lys, -Trp - 100g
DSCK1150 SC Drop Out: -Gly - 100g
DSCK1160 SC Multiple Drop Out: -Arg,-Leu,-Lys,-Met,-Ura - 100g
DSCK1170 SC Quadruple Drop Out: -Ade, -Leu, -Trp, -Ura - 100g
DSCK1180 SC Triple Drop Out: -Ade, -Trp, -Ura. - 100g
DSCK122 SC Double Drop Out: -Ade. -Lys. - 20 gram
DSCK132 SC Double Drop Out: -Ade. -Trp. - 20 gram
DSCK142 SC Double Drop Out: -Cys. -Met. - 20 gram
DSCK152 SC Double Drop Out: -His. -Leu. - 20 gram
DSCK162 SC Double Drop Out: -His. -Ura. - 20 gram
DSCK172 SC Double Drop Out: -Leu. -Trp. - 20 gram
DSCK182 SC Double Drop Out: -Leu. -Ura. - 20 gram
DSCK192 SC Double Drop Out: -Met. -Ura. - 20 gram
DSCK202 SC Double Drop Out: -Trp. -Ura. - 20 gram
DSCK2032 SC Triple Drop Out: -His, -Leu, -Met. - 250 gram
DSCK212 SC Double Drop Out: -Ura. -Inositol - 20 gram
DSCK222 SC Triple Drop Out: -Cys. -His. -Met. - 20 gram
DSCK232 SC Triple Drop Out: -Cys. -Met. -Ura. - 20 gram
DSCK242 SC Triple Drop Out: -His. -Leu. -Trp. - 20 gram
DSCK2500 SC Complete - 250 gram
DSCK2501 SC Single Drop Out: -Ade. - 250 gram
DSCK2502 SC Single Drop Out: -Cys. - 250 gram
DSCK2503 SC Single Drop Out: -His. - 250 gram
DSCK2504 SC Single Drop-Out: -Leu. - 250 gram
DSCK2505 SC Single Drop Out: -Lys. - 250 gram
DSCK2506 SC Single Drop Out: -Met. - 250 gram
DSCK2507 SC Single Drop Out: - Pro. - 250 gram
DSCK2508 SC Single Drop Out: -Trp - 250 gram
DSCK2509 SC Single Drop Out: -Ura - 250 gram
DSCK2510 SC Double Drop Out: -Ade, -Leu - 250g
DSCK2511 SC Double Drop Out: -Ade, -Lys - 250g
DSCK2512 SC Double Drop Out: -Ade, -Trp - 250g
DSCK2513 SC Double Drop Out: -Cys, -Met  - 250g
DSCK2514 SC Double Drop Out: -His, -Leu - 250g
DSCK2515 SC Double Drop Out: -His, -Ura - 250g
DSCK2516 SC Double Drop Out: -Leu. -Trp - 250 gram
DSCK2517 SC Double Drop Out: -Leu. -Ura. - 250 gram
DSCK2518 SC Double Drop Out: -Met, -Ura  - 250g
DSCK2519 SC Double Drop Out: -Trp. -Ura. - 250 gram
DSCK252 SC Triple Drop Out: -His. -Leu. -Ura. - 20 gram
DSCK2520 SC Double Drop Out: -Ura, -Inositol  - 250g
DSCK2521 SC Triple Drop Out: -Cys, -His, -Met - 250g
DSCK2522 SC Triple Drop out: -Cys, -Met, -Ura - 250 gram
DSCK2523 SC Triple Drop Out: -His, -Leu, -Trp - 250g
DSCK2524 SC Triple Drop Out: -His, -Leu, -Ura - 250g
DSCK2525 SC Triple Drop Out: -His, -Trp, -Ura  - 250g
DSCK2526 SC Quadruple Drop Out: -Ade, -His, -Leu, -Trp - 250g
DSCK2527 SC Quadruple Drop Out: -His, -Leu, -Trp, -Ura - 250g
DSCK2528 SC Multi Drop Out: -Ade,-His,-Leu,-Lys,-Trp,-Ura - 250g
DSCK2529 SC Multiple Drop Out: -Cys,-Leu,-Lys,-Met,-Trp,-Ura - 250g
DSCK2530 SC Multi D/O: -Ade,-Arg,-His,-Leu,-Met,-Thr,-Trp,-Ura - 250g
DSCK262 SC Triple Drop Out: -His. -Trp. -Ura. - 20 gram
DSCK265 SC Triple Drop Out: -Leu. -Trp. -Ura. - 20 gram
DSCK265C SC Triple Drop Out: -Leu. -Trp. -Ura - 250 gram
DSCK267 SC Triple Drop Out: -Ade, -Leu, -Ura - 20 gram
DSCK272 SC Quadruple Drop Out: -Ade, -His, -Leu, -Trp. - 20 gram
DSCK282 SC Quadruple Drop Out: -His, -Leu, -Trp, -Ura. - 20 gram
DSCK292 SC Multiple D/O: -Ade. -His. -Leu. -Lys. -Trp. -Ura.- 20g
DSCK302 SC Multiple Drop Out:-Cys,-Leu. -Lys. -Met. -Trp. -Ura. 20g
DSCK312 SC Multi D/O:-Ade.-Arg.-His.-Leu.-Met.-Thr.-Trp.-Ura - 20g
DSCK3202C SC Quadruple Drop-out: -Arg, -Leu, -Lys, -Ura - 100 gram
DSCK322 SC Multiple Drop Out:-Ade. -His. -Leu. -Trp. -Ura. - 20 gram
DSCK3256C SC Quadruple Drop-out: -Arg, -His, -Lys, -Ura - 100 gram
DSCK422 SC Multiple Drop Out: -Arg. -His. -Lys. -Met. -Ura - 20 gram
DSCK491C SC Triple Drop Out:  -Arg, -His, -Lys - 100 gram
DSCK5000 Kaiser SC Complete, - 500g
DSCK5009 SC Single Drop Out: -Ura. - 500g
DSCK5020 SC Multiple Drop Out:-His -Leu -Lys -Met -Trp -Ura - 500g
DSCK5024 SC Triple Drop Out: -His. -Leu. -Ura. - 500g
DSCK5027 SC Quadruple Drop Out: -His, -Leu, -Trp, -Ura - 500 gram
DSCK522 SC Double Drop Out: -His. -Trp. - 20g
DSCK532 SC Double Drop Out: -Met, -Trp. - 20g
DSCK542 SC Double Drop Out: -Leu, -Lys. - 20g
DSCK552 SC Double Drop Out: -Ade, -Ura. - 20g
DSCK562 SC Double Drop Out: -Lys, -Met - 20g
DSCK572 SC Double Drop Out: -Arg, -Lys - 20g
DSCK582 SC Double Drop Out: -His, -Met - 20g
DSCK592 SC Double Drop Out: -Leu, -Met - 20g
DSCK602 SC Double Drop Out: -Lys, -Ura - 20g
DSCK612 SC Double Drop Out: -Ura, -Val - 20g
DSCK622 SC Triple Drop Out: -Arg, -His, -Lys - 20 gram
DSCK632 SC Triple Drop Out: -Leu, -Lys, -Trp. - 20 gram
DSCK642 SC Triple Drop Out: -His, -Leu, -Met. - 20 gram
DSCK652 SC Triple Drop Out: -Arg, -Leu, -Lys - 20 gram
DSCK662 SC Triple Drop Out: -Arg, -Lys, -Pro. - 20 gram
DSCK672 SC Triple Drop Out: -Arg, -Lys, -Met. - 20 gram
DSCK682 SC Triple Drop Out: -Arg, -Lys, -Ura. - 20 gram
DSCK692 SC Quadruple Drop Out: -Arg, -Leu, -Lys, -Ura. -  20 gram
DSCK702 SC Quadruple Drop Out: -Arg, -His, -Lys, -Ura. - 20 gram
DSCK712 SC Quadruple Drop Out: -His, -Leu, -Met, -Trp. - 20 gram
DSCK722 SC Quadruple Drop Out: -His, -Leu, -Ser, -Ura.- 20 gram
DSCK732 SC Quadruple Drop Out: -His, -Leu, -Met, -Ura. - 20 gram
DSCK742 SC Quadruple Drop Out: -Leu, -Lys, -Trp, -Ura. - 20 gram
DSCK752 SC Multiple Drop Out: -Arg, -His, -Leu, -Trp, -Ura. - 20g
DSCK772 SC Multi D/O: -Ade,-Arg,-his,-Leu,-Lys,-Met,-Trp,-Ura. - 20g
DSCK782 SC Multiple Drop Out: -His,-Leu,-Met,-Trp,-Ura. - 20 gram
DSCK792 SC Multi Drop-out: -Arg, -His, -Leu, -Lys, -Met, -Ura - 20g
DSCK812 SC Triple Drop Out: -Leu, -Met, -Ura - 20 gram
DSCK822 SC Triple Drop Out: -Ade, -Arg, -Lys - 20 gram
DSCK832 SC Triple Drop Out: -Arg, -His, -Ura - 20 gram
DSCK842 SC Drop Out: - Ura + 20 Ade - 20 gram
DSCK852 SC Single Drop Out: -Ser - 20 gram
DSCK8588 SC Multi D/O: -Ade.-Arg.-His.-Leu.-Lys.-Met.-Trp.-Ura. 100g
DSCK8589 SC Multi Drop-out: -Arg, -His, -Leu, -Lys, -Met, -Ura - 100g
DSCK8590 SC Quadruple Drop Out: -Leu, -Lys, -Trp, -Ura. - 100 gram
DSCK8591 SC Double Drop Out: -Lys, -Ura - 100g
DSCK862 SC Drop Out: -His,-Ile,-Leu,-Trp,-Ura,-Val - 20 gram
DSCK8692 SC Double Drop Out: -Ura, -Val - 100g
DSCK872 SC Multiple Drop Out: -His,-Leu,-Lys,-Met,-Ura - 20 gram
DSCK8793 SC Double Drop Out: -Ile, - Leu. - 100g
DSCK8794 SC Double Drop Out: -Ile, - Leu. - 250 gram
DSCK882 SC Multiple Drop Out: -Arg,-Leu,-Lys,-Trp,-Ura - 20g
DSCK892 SC Multople Drop Out: -His, -Lys, -Met, -Trp, -Ura - 20g
DSCK902 SC Triple Drop Out: -Ade, -Met, -Ura - 20g
DSCK912 SC Triple Drop Out: -Arg, -Lys, -Trp - 20g
DSCK9120 SC Multiple Drop Out:-His, Leu,-Lys,-Met,-Trp,-Ura -250 gram
DSCK914C SC Double Drop Out: -Leu, -Met - 100g
DSCK922 SC Drop Out: -Gly - 20g
DSCK932 SC Multiple Drop Out: -Arg,-Leu,-Lys,-Met,-Ura - 20g
DSCK942 SC Quadruple Drop Out: -Ade, -Leu, -Trp, -Ura - 20g
DSCK952 SC Triple Drop Out: -Ade, -Trp, -Ura. - 20g
DSCK9590 SC Quadruple Drop Out: -His, -Leu, -Met, -Trp. - 100 gram
DSCK9591 SC Quadruple Drop Out: -His, -Leu, -Ser, -Ura. - 100 gram
DSCK9592 SC Quadruple Drop Out: -His, -Leu, -Met, -Ura. - 100 gram
DSCK977C SC Triple Drop Out: -Arg, -Leu, -Lys -100 gram
DSCK9911C SC Triple Drop-Out: -Arg, -Lys, -Pro. - 100 gram
DSCK9912C SC Double Drop-Out: -Arg, -Lys - 100g
DSCK9914 SC Triple Drop Out: -Ade. -Leu. -Ura. - 100g
DSCK9915C SC Double Drop Out: -Lys, -Met - 100g
DSCK9916C SC Double Drop Out: -His, -Met - 100g
DSCK9925 SC Triple Drop Out: -His, -Leu, -Met - 1000g
DSCK9927 SC Multiple Drop Out: -His,-Leu,-Met,-Trp,-Ura. - 250 gram
DSCS011 SCSM Complete. Hopkins Mixture - 30 gram
DSCS021 SCSM Single Drop Out: -Ade.- 30 gram
DSCS031 SCSM Single Drop Out: -Cys - 30 gram
DSCS041 SCSM Single Drop Out: -His. - 30 gram
DSCS051 SCSM Single Drop Out: -Leu. - 30 gram
DSCS061 SCSM Single Drop Out: -Lys. - 30 gram
DSCS071 SCSM Single Drop Out: -Met. - 30 gram
DSCS081 SCSM Single Drop Out: -Pro - 30 gram
DSCS091 SCSM Single Drop Out: -Trp. - 30 gram
DSCS101 SCSM Single Drop Out: -Ura. - 30 gram
DSCS1021 SCSM Single Drop Out -Ade. - 100 gram
DSCS1041 SCSM Single Drop Out: -His. - 100 gram
DSCS1051 SCSM Single Drop Out: -Leu - 100 gram
DSCS1091 SCSM Single Drop Out: -Trp - 100 gram
DSCS1101 SCSM Single Drop Out: -Ura. - 100 gram
DSCS111 SCSM Double Drop Out: -Ade. -Leu. - 30 gram
DSCS121 SCSM Double Drop Out: -Ade. -Lys. - 30 gram
DSCS1281 SCSM Quadruple Drop-Out: -His, -Leu, -Trp, -Ura - 100 gram
DSCS131 SCSM Double Drop Out: -Ade. -Trp. - 30 gram
DSCS141 SCSM Double Drop Out: -Cys. -Met. - 30 gram
DSCS151 SCSM Double Drop Out: -His. -Leu. - 30 gram
DSCS161 SCSM Double Drop Out: -His. -Ura. - 30 gram
DSCS171 SCSM Double Drop Out: -Leu. -Trp. - 30 gram
DSCS181 SCSM Double Drop Out: -Leu. -Ura. - 30 gram
DSCS191 SCSM Double Drop Out: -Met. -Ura. - 30 gram
DSCS201 SCSM Double Drop Out: -Trp. -Ura. - 30 gram
DSCS211 SCSM Double Drop Out: -Ura. -Inositol - 30 gram
DSCS221 SCSM Triple Drop Out: -Cys. -His. -Met. - 30 gram
DSCS231 SCSM Triple Drop Out: -Cys. -Met. -Ura. - 30 gram
DSCS241 SCSM Triple Drop Out: -His. -Leu. -Trp. - 30 gram
DSCS251 SCSM Triple Drop Out: -His. -Leu. -Ura. - 30 gram
DSCS261 SCSM Triple Drop Out: -His. -Trp. -Ura. - 30 gram
DSCS271 SCSM Quadruple Drop Out: -Ade. -His. -Leu. -Trp. - 30 gram
DSCS281 SCSM Quadruple Drop Out: -His. -Leu. -Trp. -Ura. - 30 gram
DSCS291 SCSM Multi Drop Out: -Ade. -His. -Leu. -Lys. -Trp. -Ura.30g
DSCS301 SCSM Mult Drop Out: -Cys. -Leu. -Lys. -Met. -Trp. -Ura.30g
DSCS311 SCSM Multi D/O:-Ade.-Arg.-His.-Leu.-Met.-Thr.-Trp.-Ura - 30g
DSCS401 Hopkins Special: -Ade,-His,-Leu,-Met,-Ura - 100gram
DTT005 DTT Dithiothreitol - 5 gram
DTT010 DTT Dithiothreitol - 10 gram
DTT025 DTT Dithiothreitol - 25 gram
DTT100 DTT Dithiothreitol - 100 gram
EDTA1000 EDTA disodium salt - 1000 gram
EDTA250 EDTA disodium salt - 250 gram
EDTA500 EDTA disodium salt - 500 gram
EDTA6000 EDTA Disodium Salt - 6 x 1000 gram
ERYT005 Erythromycin - 5 gram
ERYT100 Erythromycin - 100 gram
FM3501 FM Minimal Medium without Cyanocobalamin - 1000g
FMA02 Complete FM Amino acid mixture - 100 gram
FMA03 Complete FM Amino acid mixture - 250 gram
FMA05 FM Drop-out mixture, minus Cysteine - 100 gram
FMA06 FM Drop-out mixture, minus Cysteine - 250 gram
FMA08 FM Drop-out mixture, minus Glutamic acid - 100 gram
FMA09 FM Drop-out mixture, minus Glutamic acid - 250 gram
FMA11 FM Drop-out mixture, minus Lysine - 100 gram
FMA12 FM Drop-out mixture, minus Lysine - 250 gram
FMA14 FM Drop-out mixture, minus Methionine - 100 gram
FMA15 FM Drop-out mixture, minus Methionine - 250 gram
FMA17 FM drop-out mixture, minus Arginine & Cysteine - 100 g
FMA18 FM drop-out mixture, minus Arginine & Cysteine - 250 gram
FMA20 FM Drop-out mixture, minus Arginine & Glutamic acid - 100 g
FMA21 FM Drop-out mixture, minus Arginine & Glutamic acid - 250 g
FMA23 FM Drop-out mixture, minus Arginine & Lysine - 100 g
FMA24 FM Drop-out mixture, minus Arginine & Lysine - 250 g
FMA26 FM Drop-out mixture, minus Arginine & Methionine, 100 g
FMA27 FM Drop-out mixture, minus Arginine & Methionine - 250 g
FMA29 FM Drop-out mixture, minus Cysteine & Glutamic acid 100 g
FMA30 FM Drop-out mixture, minus Cysteine & Glutamic acid - 250 g
FMA32 FM Drop-out mixture, minus Cysteine & Lysine, 100 g
FMA33 FM Drop-out mixture, minus Cysteine & Lysine - 250 g
FMA35 FM Drop-out mixture, minus Cysteine & Methionine, 100 g
FMA36 FM Drop-out mixture, minus Cysteine & Methionine - 250 g
FMA38 FM Drop-out mixture, minus Glutamic acid & Lysine - 100 g
FMA39 FM Drop-out mixture, minus Glutamic acid & Lysine - 250 g
FMA41 FM Drop-out mixture, minus Glutamic acid & Methionine -100 g
FMA42 FM Drop-out mixture, minus Glutamic acid & Methionine -250 g
FMA44 FM Drop-out mixture, minus Lysine & Methionine - 100 g
FMA45 FM Drop-out mixture, minus Lysine & Methionine - 250 g
FMA47 FM Drop-out mixture, minus Arginine - 100 gram
FMA48 FM Drop-out mixture, minus Arginine - 250 gram
FMM0101 FM Minimal Medium - 250 gram
FMM0102 FM Minimal Medium - 1000 gram
FMM0103 FM Minimal Medium - 6 X 1000 gram
FMM0201 FM Minimal Medium w/o NH4Cl - 250g
FMM0202 FM Minimal Medium w/o NH4Cl - 1000g
FMM0203 FM Minimal Medium w/o NH4Cl - 6 X 1000g
FMM0301 FM Minimal Medium w/o Methionine - 250 gram
FMM0302 FM Minimal Medium w/o Methionine - 1000 gram
FMM0303 FM Minimal Medium w/o Methionine - 6 X 1000 gram
FMM0401 FM Minimal Medium w/o Arginine & w/o Lysine - 250 gram
FMM0402 FM Minimal Medium w/o Arginine & w/o Lysine - 1000 gram
FMM0403 FM Minimal Medium w/o Arginine & w/o Lysine - 6 x 1000 gram
FMM0501 FM Minimal medium w/o Amino acids - 250 gram
FMM0502 FM Minimal medium w/o Amino acids - 1000 gram
FMM0503 FM Minimal medium w/o Amino acids 6 x 1000 gram
FMM0601 FM Minimal Medium w/o Amino acids & w/o NH4Cl - 250g
FMM0602 FM Minimal medium w/o Amino acids & w/o NH4Cl - 1000g
FMM0603 FM Minimal medium w/o Amino acids & w/o NH4Cl - 6 x 1000g
FMM0701 FM Minimal Medium w/o Cysteine & w/o Methionine - 250 gram
FMM0702 FM Minimal Medium w/o Cysteine & w/o Methionine - 1000 gram
FMM0703 FM Minimal Medium w/o Cysteine & w/o Methionine 6 x 1000g
FMM0801 FM Minimal Medium w/o Glutamic acid & w/o Lysine - 250 gram
FMM0802 FM Minimal Medium w/o Glutamic acid & w/o Lysine - 1000 gram
FMM0803 FM Minimal Medium w/o Glutamic acid & w/o Lysine - 6 x 1 Kg
FMM0910 FM Minimal Medium w/o Phosphates - 1000g
FMM1002 FM Minimal Medium w/o Iron - 1000g
FRU02 D-Fructose - 250g
FRU03 D-Fructose - 1 Kg
G4181 G-418 Disulphate - 1 gram
G4185 G-418 Disulphate - 5 gram
G4185S G-418 Disulphate Solution 5 x 20ml
G418S G-418 Disulphate Solution 1 x 20ml
GAL01 D (+) -Galactose - 100 gram
GAL02 D (+) -Galactose - 500 gram
GAL03 D (+) -Galactose - 1000 gram
GAL04 D (+) -Galactose - 6 X 1000 gram
GAL05 D (+) Galactose - 250 gram
GEN05 Gentamicin sulphate - 5 gram
GEN25 Gentamicin sulphate - 25 gram
GLU01 Glucose Anhydrous - 250 gram
GLU02 Glucose Anhydrous - 500 gram
GLU03 Glucose Anhydrous - 1000 gram
GLU04 Glucose Anhydrous - 6 X 1000 gram
GUA01 Guanidine Thiocyanate, Molecular Biology Grade >99% -100g
GUA05 Guanidine Thiocyanate, Molecular Biology Grade >99% -500g
GUA10 Guanidine Thiocyanate, Molecular Biology Grade >99% - 1 Kg
GUA25 Guanidine Thiocyanate, Molecular Biology Grade >99% - 250g
GUA50 Guanidine Thiocyanate, Molecular Biology Grade >99% - 5 Kg
HDU0001 Hydroxyurea -  1 gram
HDU0005 Hydroxyurea - 5 gram
HDU0025 Hydroxyurea - 25 gram
HDU0100 Hydroxyurea - 100 gram
HDU0250 Hydroxyurea - 250 gram
HEPES01 HEPES - 100 gram
HEPES03 HEPES - 250 gram
HEPES05 HEPES - 500 gram
HEPES10 HEPES - 1000 gram
HEPES60 HEPES - 6 x 1000 gram
HLB0101 HL5 Medium without glucose - 250 gram
HLB0102 HL5 Medium without glucose - 1000 gram
HLB0103 HL5 Medium without glucose - 6 x 1000 gram
HLC0101 HL5-C Medium including Glucose - 250 gram
HLC0102 HL5-C Medium including Glucose - 1000 gram
HLC0103 HL5-C Medium including Glucose - 6 X 1000 gram
HLD0101 HL5-C Medium without Glucose - 250 gram
HLD0102 HL5-C Medium without Glucose - 1000 gram
HLD0103 HL5-C Medium without Glucose - 6 X 1000 gram
HLE1 HL5 medium inc. Glucose and supp with Vit & Micro - 250 gram
HLE2 HL5 medium inc. Glucose and supp with Vit & Mic - 1000 gram
HLE3 HL5 medium inc. Glucose and supp with Vit & Micro- 6 x 1 Kg
HLF1 HL5 Medium w/o Gluc, supp with Vit & Micro - 250 gram
HLF2 HL5 Medium w/o Gluc. supp with Vit & Micro - 1000 gram
HLF3 HL5 Medium w/o Gluc supp with Vit & Micro - 6 x 1 Kg
HLG0101 HL5 Medium including Glucose - 250 gram
HLG0102 HL5 Medium including Glucose - 1000 gram
HLG0103 HL5 Medium including Glucose - 6 X 1000 gram
HLH1 HL5-C medium inc. Glucose, supp with Vit & Micro - 250 gram
HLH2 HL5-C medium inc. Glucose, supp with Vit & Micro - 1 Kg
HLH3 HL5-C medium inc. Glucose, supp with Vit & Micro - 6 x 1 Kg
HLI1 HL5-C medium w/o Glucose, supp with Vit&Micro - 250 gram
HLI2 HL5-C medium w/o Glucose, supp with Vit & Micro - 1 Kg
HLI3 HL5-C medium inc. Glucose, supp with Vit & Micro - 6 x 1 Kg
HNB9703 St Andrews HNB - 500 gram
HYG0500 Hygromycin  B - 500 mg
HYG1000 Hygromycin B - 1 gram
HYG5000 Hygromycin B - 5 gram
IPTG001 IPTG - 1 gram
IPTG005 IPTG - 5 gram
IPTG010 IPTG - 10 gram
IPTG025 IPTG - 25 gram
IPTG100 IPTG - 100 gram
IPTG250 IPTG - 250 gram
IST0110 IST Medium - 1 Kg
KAN0005 Kanamycin Monosulphate - 5 gram
KAN0025 Kanamycin Monosulphate - 25 gram
KAN0150 Kanamycin Monosulphate - 150 gram
KAN0250 Kanamycin Monosulphate - 250 gram
KNM0005 Kanamycin Disulphate Salt - 5 gram
KNM0025 Kanamycin Disulphate Salt - 25 gram
KNM0100 Kanamycin Disulphate Salt - 100 gram
LAC02 D (+) -Lactose - 1000 gram
LAC03 D (+) -Lactose - 6 X 1000 gram
LBD0101 2X LB-Broth - 250 gram
LBD0102 2X LB-Broth - 1000 gram
LBD0103 2X LB-Broth - 6 X 1000 gram
LBD0201 2X LB-Agar - 250 gram
LBD0202 2X LB-Agar - 1000 gram
LBD0203 2X LB-Agar - 6 X 1000 gram
LBL0101 L-Broth - 250 gram
LBL0102 L-Broth - 1000 gram
LBL0103 L-Broth - 6 X 1000 gram
LBL0201 L-Broth Agar - 250 gram
LBL0202 L-Broth Agar - 1000 gram
LBL0203 L-Broth Agar - 6 X 1000 gram
LBL0301 L-Broth Top Agar - 250 gram
LBL0302 L-Broth Top Agar - 1000 gram
LBO0101 LB-Broth w/o NaCl - 250 gram
LBO0102 LB-Broth w/o NaCl - 1000 gram
LBO0103 LB-Broth w/o NaCl - 6 X 1000 gram
LBO0201 LB-Agar w/o NaCl - 250 gram
LBO0202 LB-Agar w/o NaCl - 1000 gram
LBO0203 LB-Agar w/o NaCl - 6 X 1000 gram
LBX0101 LB-Broth Lennox - 250 gram
LBX0102 LB-Broth Lennox - 1000 gram
LBX0103 LB-Broth Lennox - 6 X 1000 gram
LBX0104 LB-Broth Lennox - 500 gram
LBX0201 LB-Agar Lennox - 250 gram
LBX0202 LB-Agar Lennox - 1000 gram
LBX0203 LB-Agar Lennox - 6 X 1000 gram
LBX0204 LB-Agar Lennox - 500 gram
LBX0301 LB-Top Agar Lennox - 250 gram
LBX0302 LB-Top Agar Lennox - 1000 gram
LBX0303 LB-Top Agar Lennox - 6 X 1000 gram
LBX10L LB-Broth Lennox - 10L pack (200g)
LBX1L LB-Broth Lennox - 1L pack (20g)
LBX20L LB-Broth Lennox - 20L pack (400g)
LBX2L LB-Broth Lennox - 2L pack (40g)
LBX5L LB-Broth Lennox - 5L pack (100g)
LBXA10L LB-Agar Lennox - 10L Pack (350g)
LBXA1L LB-Agar Lennox - 1L pack (35g)
LBXA20L LB-Agar Lennox - 20L pack (700g)
LBXA2L LB-Agar Lennox - 2L pack (70g)
LBXA5L LB-Agar Lennox - 5L pack (175g)
LBXG1000 LB-Broth Lennox + Glucose - 1000g
LBXG10L LB-Broth Lennox + Glucose 1 g/l -10L pack - 210g
LBXG1L LB-Broth Lennox + Glucose 1g/l - 1L pack - 21g
LBXG2L LB-Broth Lennox + Glucose 1 g/l - 2L pack - 42g
LBXG500 LB-Broth Lennox + Glucose - 500g
LBXG5L LB-Broth Lennox + Glucose 1 g/l - 5L pack - 105g
LEES0500 Lee's Medium - 500g
LEES1000 Lee's Medium - 1000g
LF0501 LoFlo Medium - 500 gram
LF1001 LoFlo Medium - 1 Kg
LF6001 LoFlo Medium - 6 x 1 Kg
LFG0501 LoFlo Medium inc. Yeast Extract - 500 gram
LFG1001 LoFlo Medium inc. Yeast Extract - 1 Kg
LFG6001 LoFlo Medium inc. Yeast Extract - 6 x 1 Kg
LMG0101 LBM-Broth Miller - 250 gram
LMG0102 LBM-Broth Miller - 1000 gram
LMG0103 LBM-Broth Miller - 6 X 1000 gram
LMG0201 LBM-Agar Miller - 250 gram
LMG0202 LBM-Agar Miller - 1000 gram
LMG0203 LBM-Agar Miller - 6 X 1000 gram
LMM0101 LB-Broth Miller - 250 gram
LMM0102 LB-Broth Miller - 1000 gram
LMM0103 LB-Broth Miller - 6 X 1000 gram
LMM0104 LB-Broth Miller - 500 gram
LMM0105 LB-Broth Miller - 1500 gram
LMM0201 LB-Agar Miller - 250 gram
LMM0202 LB-Agar Miller - 1000 gram
LMM0203 LB-Agar Miller - 6 X 1000 gram
LMM0204 LB-Agar Miller 500 gram
LMM02-10L LB-Agar Miller - 10L pack - 400g
LMM02-1L LB-Agar Miller - 1L pack - 40g
LMM02-20L LB-Agar Miller - 20L pack - 800g
LMM02-2L LB-Agar Miller - 2L pack - 80g
LMM02-5L LB-Agar Miller - 5L pack - 200g
LMM0301 LB-Top Agar Miller - 250 gram
LMM0302 LB-Top Agar Miller - 1000 gram
LMM10L LB-Broth Miller - 10L pack - 250g
LMM1L LB-Broth Miller - 1L pack - 25g
LMM20L LB-Broth Miller - 20L pack - 500g
LMM2L LB-Broth Miller - 2L pack - 50g
LMM5L LB-Broth Miller - 5L pack - 125g
M170110 M17 Broth - 1 Kg
M170160 M17 Broth - 6 x 1000 gram
MAB05 MacConkey Agar Base - 500 gram
MAB10 MacConkey Agar Base - 1000 gram
MAB60 MacConkey Agar Base - 6 x 1000 gram
MAL03 Malt Extract - 1 Kg
MEA0102 Malt Extract Agar - 250 gram
MEA0110 Malt Extract Agar - 1000 gram
MEA0160 Malt Extract Agar - 6 x 1000 gram
MES01 MES Monohydrate - 100 gram
MES02 MES Monohydrate - 250 gram
MES03 MES Monohydrate - 500 gram
MES04 MES Monohydrate - 1000 gram
MES05 MES Monohydrate - 6 x 1 Kg
MES-SDS0500 MES SDS Running Buffer 20X - 500mL
MES-SDS1000 MES SDS Running Buffer 20X - 1L
MES-SDS5000 MES SDS Running Buffer 20X - 5L
MHB0100 Mueller Hinton Broth - 250 gram
MHB0101 Mueller Hinton Broth - 1000 gram
MHB0102 Mueller Hinton Broth - 6 x 1000 g
MMS0101 M9 Minimal Salts Base 5X - 250 gram
MMS0102 M9 Minimal Salts Base 5X - 1000 gram
MMS0103 M9 Minimal Salts Base 5X - 6 X 1000 gram
MMS0202 M9 Minimal Salts w/o Ammonium Chloride 5X - 1 Kg
MOPS01 MOPS - 100 gram
MOPS02 MOPS - 250 gram
MOPS03 MOPS - 500 gram
MOPS04 MOPS - 1000 gram
MOPS05 MOPS - 6 x 1000 gram
MOPS-SDS0500 MOPS SDS Running Buffer 20X - 500mL
MOPS-SDS1000 MOPS SDS Running Buffer 20X - 1L
MOPS-SDS5000 MOPS SDS Running Buffer 20X - 5L
MRSA0500 MRS Agar - 500g
MRSA1000 MRS Agar - 1 Kg
MRSA5000 MRS Agar - 5 Kg
MRSB0500 MRS Broth - 500g
MRSB1000 MRS Broth - 1 Kg
MRSB5000 MRS Broth - 5 Kg
NAC02 Sodium chloride - 1000 gram
NAC03 Sodium chloride - 6 X 1000 gram
NAO01 Nutrient Agar - 500 gram
NAO02 Nutrient Agar - 1000 gram
NAO03 Nutrient Agar - 6 x 1000 gram
NBO01 Nutrient Broth - 500 gram
NBO02 Nutrient Broth - 1000 gram
NBO03 Nutrient Broth - 6 x 1000 gram
NBS01 Neidhardt Basal Salt Mixture (10L) - 329g
NBS02 Neidhardt Basal Salt Mixture (20L) - 658g
NBS03 Neidhardt Basal Salt Mixture (30L) - 987g
NSM01 Neidhardt Supplement Mixture (10L) - 31g
NSM02 Neidhardt Supplement Mixture (20L) - 62g
NSM03 Neidhardt Supplement Mixture (30L) - 93g
NZA0101 NZ Agar (NZM Agar) - 250 gram
NZA0102 NZ Agar (NZM Agar) - 1000 gram
NZB0101 NZ Broth (NZM Broth) - 250 gram
NZB0102 NZ Broth (NZM Broth) - 1000 gram
NZC0101 NZCYM Broth - 250 gram
NZC0102 NZCYM Broth - 1000 gram
NZC0103 NZCYM Broth - 6 X 1000 gram
NZC0201 NZCYM Agar - 250 gram
NZC0202 NZCYM Agar - 1000 gram
NZC0203 NZCYM Agar - 6 X 1000 gram
NZC0301 NZCYM Top Agar - 250 gram
NZC0302 NZCYM Top Agar - 1000 gram
NZD0101 NZYDT Broth - 500 gram
NZD0201 NZYDT Agar - 500 gram
NZM0101 NZYM Broth (NZY Broth) - 250 gram
NZM0102 NZYM Broth (NZY Broth) - 1000 gram
NZM0103 NZYM Broth (NZY Broth) - 6 X 1000 gram
NZM0201 NZYM Agar (NZY Agar) - 250 gram
NZM0202 NZYM Agar (NZY Agar) - 1000 gram
NZM0203 NZYM Agar (NZY Agar) - 6 X 1000 gram
NZM0301 NZYM Top Agar (NZY Top Agar) - 250 gram
NZM0302 NZYM Top Agar (NZY Top Agar) - 1000 gram
NZT0301 NZ Top Agar (NZM Top Agar) - 250 gram
NZT0302 NZ Top Agar (NZM Top Agar) - 1000 gram
NZY0101 NZY Broth - 250 gram
NZY0102 NZY Broth - 1000 gram
NZY0201 NZY Agar - 250 gram
NZY0202 NZY Agar - 1000 gram
NZY0302 NZY+ (Broth) Medium - 1 Kg
PBS100L PBS 100L Pack - 993g
PBS10L PBS 10L Pack - 99.3g
PBS20L PBS 20L Pack - 198.6g
PCM0102 YE Broth - 250 gram
PCM0105 YE Broth - 500 gram
PCM0110 YE Broth - 1000 gram
PCM0150 YE Broth - 5000 gram
PCM0155 YE Broth - 15000 gram
PCM0202 YE Agar - 250 gram
PCM0205 YE Agar - 500 gram
PCM0210 YE Agar - 1000 gram
PCM0250 YE Agar - 5000 gram
PCM0255 YE Agar - 15000 gram
PCM0302 YES Broth - 250 gram
PCM0305 YES Broth - 500 gram
PCM0310 YES Broth - 1000 gram
PCM0350 YES Broth - 5000 gram
PCM0355 YES Broth - 15000 gram
PCM0402 YES Agar - 250 gram
PCM0405 YES Agar - 500 gram
PCM0410 YES Agar - 1000 gram
PCM0450 YES Agar - 5000 gram
PCM0502 YSO Broth - 250 gram
PCM0505 YSO Broth - 500 gram
PCM0510 YSO Broth - 1000 gram
PCM0550 YSO Broth - 5000 gram
PCM0602 YSO Agar - 250 gram
PCM0605 YSO Agar - 500 gram
PCM0610 YSO Agar - 1000 gram
PCM0650 YSO Agar - 5000 gram
PCM0702 ME Broth - 250 gram
PCM0705 ME Broth - 500 gram
PCM0710 ME Broth - 1000 gram
PCM0802 ME Agar - 250 gram
PCM0805 ME Agar - 500 gram
PCM0810 ME Agar - 1000 gram
PDA0101 PDA  Potato Dextrose Agar - 100 gram
PDA0102 PDA  Potato Dextrose Agar - 1 Kg
PDA0103 PDA  Potato Dextrose Agar - 5 x 1 Kg
PDA0104 PDA  Potato Dextrose Agar - 500g
PDB0101 PDB  Potato Dextrose Broth - 100 gram
PDB0102 PDB  Potato Dextrose Broth - 1 Kg
PDB0103 PDB  Potato Dextrose Broth - 5 x 1 Kg
PEP01 Peptone - 250 gram
PEP02 Peptone - 500 gram
PEP03 Peptone - 1000 gram
PEP04 Peptone - 6 X 1000 gram
PMD0101 EMM Agar - 100 gram
PMD0102 EMM Agar - 250 gram
PMD0105 EMM Agar - 500 gram
PMD0110 EMM Agar - 1000 gram
PMD0150 EMM Agar - 5000 gram
PMD0155 EMM Agar - 15000 gram
PMD0201 EMM Broth - 100 gram
PMD0202 EMM Broth - 250 gram
PMD0205 EMM Broth - 500 gram
PMD0210 EMM Broth - 1000 gram
PMD0250 EMM Broth - 5000 gram
PMD0255 EMM Broth - 15000 gram
PMD0301 EMM Agar w/o Dextrose (Glucose) - 100 gram
PMD0302 EMM Agar w/o Dextrose (Glucose) - 250 gram
PMD0305 EMM Agar w/o Dextrose (Glucose) - 500 gram
PMD0310 EMM Agar w/o Dextrose (Glucose) - 1000 gram
PMD0401 EMM Broth w/o Dextrose (Glucose) - 100 gram
PMD0402 EMM Broth w/o Dextrose (Glucose) - 250 gram
PMD0405 EMM Broth w/o Dextrose (Glucose) - 500 gram
PMD0410 EMM Broth w/o Dextrose (Glucose) - 1000 gram
PMD0501 EMM Agar Low Dextrose: 5 g/l - 100 gram
PMD0502 EMM Agar Low Dextrose: 5 g/l - 250 gram
PMD0505 EMM Agar Low Dextrose: 5 g/l - 500 gram
PMD0510 EMM Agar Low Dextrose: 5 g/l - 1000 gram
PMD0601 EMM Broth Low Dextrose: 5 g/l - 100 gram
PMD0602 EMM Broth Low Dextrose: 5 g/l - 250 gram
PMD0605 EMM Broth Low Dextrose: 5 g/l - 500 gram
PMD0610 EMM Broth Low Dextrose: 5 g/l - 1000 gram
PMD0701 EMM Agar plus 1 x SP Supplements: -Leu. -Ura. - 100 gram
PMD0702 EMM Agar plus 1 x SP Supplements: -Leu. -Ura. - 250 gram
PMD0705 EMM Agar plus 1 x SP Supplements: -Leu. -Ura. - 500 gram
PMD0710 EMM Agar plus 1 x SP Supplements: -Leu. -Ura. - 1000 gram
PMD0801 EMM Broth plus 1 x SP Supplements: -Leu. -Ura. - 100 gram
PMD0802 EMM Broth plus 1 x SP Supplements: -Leu. -Ura. - 250 gram
PMD0805 EMM Broth plus 1 x SP Supplements: -Leu. -Ura. - 500 gram
PMD0810 EMM Broth plus 1 x SP Supplements: -Leu. -Ura. - 1000 gram
PMD0901 EMMS - 100 gram
PMD0910 EMMS - 1000 gram
PMD1001 EMM Agar w/o Phosphate - 100 gram
PMD1002 EMM Agar w/o Phosphate - 250 gram
PMD1005 EMM Agar w/o Phosphate - 500 gram
PMD1010 EMM Agar w/o Phosphate - 1000 gram
PMD1101 EMM Broth w/o Phosphate - 100 gram
PMD1102 EMM Broth w/o Phosphate - 250 gram
PMD1105 EMM Broth w/o Phosphate - 500 gram
PMD1110 EMM Broth w/o Phosphate - 1000 gram
PMD1201 EMM Agar w/o Nitrogen - 100 gram
PMD1202 EMM Agar w/o Nitrogen - 250 gram
PMD1205 EMM Agar w/o Nitrogen - 500 gram
PMD1210 EMM Agar w/o Nitrogen - 1000 gram
PMD1301 EMM Broth w/o Nitrogen - 100 gram
PMD1302 EMM Broth w/o Nitrogen - 250 gram
PMD1305 EMM Broth w/o Nitrogen - 500 gram
PMD1310 EMM Broth w/o Nitrogen - 1000 gram
PMD1401 MB Agar - 100 gram
PMD1402 MB Agar - 250 gram
PMD1405 MB Agar - 500 gram
PMD1410 MB Agar - 1000 gram
PMD1501 MB Broth - 100 gram
PMD1502 MB Broth - 250 gram
PMD1505 MB Broth - 500 gram
PMD1510 MB Broth - 1000 gram
PMD1601 MMA Agar Medium - 100 gram
PMD1602 MMA Agar Medium - 250 gram
PMD1605 MMA Agar Medium - 500 gram
PMD1610 MMA Agar Medium - 1000 gram
PMD1701 MB Broth  w/o Amino Acids - 100 gram
PMD1702 MB Broth  w/o Amino Acids - 250 gram
PMD1705 MB Broth  w/o Amino Acids - 500 gram
PMD1710 MB Broth  w/o Amino Acids - 1 Kg
PMD1801 EMM Glutamate Broth - 100 gram
PMD1802 EMM Glutamate Broth - 250 gram
PMD1805 EMM Glutamate Broth - 500 gram
PMD1810 EMM Glutamate Broth - 1 Kg
PMD1850 EMM Glutamate Broth - 5 Kg
PMD1855 EMM Glutamate Broth - 15 Kg
PMD1910 EMM Broth with complete SP supplements - 1000 gram
PMD2010 EMM Broth with complete SP supplements, -Leu, - 1000 gram
PMD2101 EMM Glutamate Agar - 100 gram
PMD2102 EMM Glutamate Agar - 250 gram
PMD2105 EMM Glutamate Agar - 500 gram
PMD2110 EMM Glutamate Agar - 1000 gram
PMD2150 EMM Glutamate Agar - 5 Kg
PMD2155 EMM Glutamate Agar - 15 Kg
PMD2510 EMM Broth w/o Dextrose & Ammonium Chloride - 1 Kg
PPC0110 Peptone + Potassium Chloride Medium - 1 Kg
PSU0101 SP Supplements - 10 gram
PSU0110 SP Supplements - 100 gram
PSU0201 SP Supplements: -Leu. -Ura. - 10 gram
PSU0210 SP Supplements: -Leu. -Ura. - 100 gram
PSU0301 SP Supplements: -Lys. - 10 gram
PSU0310 SP Supplements: -Lys. - 100 gram
PSU0510 SP Supplements, -His - 100 gram
PSU0710 SP Supplements, -Ura - 100 gram (Special)
PSU0910 SP Supplements, -His, -Ura - 100 gram
PTE01 Potato extract - 250 gram
PTE02 Potato extract - 500 gram
PTE03 Potato extract - 1000 gram
PTE04 Potato extract - 6 X 1000 gram
PYG0110 PYG Medium - 1 Kg
RAF01 D (+) - Raffinose Pentahydrate - 100 gram
RAF02 D (+) - Raffinose Pentahydrate - 250 gram
RAF03 D (+) - Raffinose Pentahydrate - 500 gram
RAF04 D (+) - Raffinose Pentahydrate - 1000 gram
RZ500 RNaseZero - 500ml
SAB0102 Sabouraud Agar - 250 gram
SAB0105 Sabouraud Agar - 500 gram
SAB0110 Sabouraud Agar - 1000 gram
SAB0202 Sabouraud Broth - 250 gram
SAB0205 Sabouraud Broth - 500 gram
SAB0210 Sabouraud Broth - 1000 gram
SCAA0101 2xSCCA Amino Acid Supplement - 500g
SDS0100 SDS Micro-Pellets - 100g
SDS0500 SDS Micro-Pellets - 500g
SDS1000 SDS Micro-Pellets - 1 Kg
SHA02 Complete SIH Amino acid mixture - 100 gram
SHA03 Complete SIH Amino Acid Mixture - 250 gram
SHA05 SIH Drop-out mixture, minus Arginine - 100 gram
SHA06 SIH Drop-out mixture, minus Arginine - 250 gram
SHA08 SIH Drop-out mixture, minus Cysteine - 100 gram
SHA09 SIH Drop-out mixture, minus Cysteine - 250 gram
SHA11 SIH Drop-out mixture, minus Glutamic acid - 100 gram
SHA12 SIH Drop-out mixture, minus Glutamic acid - 250 gram
SHA14 SIH Drop-out mixture, minus Lysine - 100 gram
SHA15 SIH Drop-out mixture, minus Lysine - 250 gram
SHA17 SIH Drop-out mixture minus Methionine - 100 gram
SHA18 SIH Drop-out mixture, minus Methionine - 250 gram
SHA20 SIH Drop-out mixture, minus Methionine & Cysteine - 100 gram
SHA21 SIH Drop-out mixture, minus Methionine & Cysteine - 250 gram
SHA23 SIH Drop-out mixture, minus Arginine & Glutamic acid -100g
SHA24 SIH Drop-out mixture, minus Arginine & Glutamic acid - 250 g
SHA26 SIH Drop-out mixture, minus Arginine & Lysine - 100 gram
SHA27 SIH Drop-out mixture, minus Arginine & Lysine - 250 gram
SHA29 SIH drop-out mixture, minus Arginine & Methionine - 100 gram
SHA30 SIH Drop-out mixture, minus Arginine & Methionine - 250 gram
SHA32 SIH Drop-out mixture, minus Cysteine & Glutamic acid - 100 g
SHA33 SIH Drop-out mixture, minus Cysteine & Glutamic acid - 250 g
SHA35 SHI Drop-out mixture, minus Cysteine & Lysine - 100 gram
SHA36 SIH Drop-out mixture, minus Cysteine & Lysine - 250 gram
SHA38 SIH Drop-out mixture, minus Cysteine & Methionine - 100 gram
SHA39 SIH Drop-out mixture, minus Cysteine & Methionine - 250 gram
SHA41 SIH Drop-out mixture, minus Glutamic acid & Lysine - 100 g
SHA42 SIH Drop-out mixture, minus Glutamic acid & Lysine - 250 g
SHA44 SIH Drop-out mixture, minus Glutamic acid & Methionine -100g
SHA45 SIH Drop-out mixture, minus Glutamic acid & Methionine -250g
SHA47 SIH Drop-out mixture, minus Lysine & Methionine - 100 gram
SHA48 SIH Drop-out mixture, minus Lysine & Methionine - 250 gram
SHA49 SIH Drop-out mixture, -Arg, -Lys, -Glu - 1 Kg
SHA50 SIH Drop-out mixture, -Arg, -Lys, -Glu - 250g
SHA51 SIH Medium, minus Magnesium Chloride - 1 Kg
SHA52 SIH Medium, minus Magnesium Chloride - 250g
SIH0101 SIH  Medium - 250 gram
SIH0102 SIH Medium - 1000 gram
SIH0103 SIH Medium - 6 X 1000 gram
SIH0501 SIH Medium w/o Ammonium Chloride - 250 g
SIH0502 SIH Medium w/o Ammonium Chloride - 1 Kg
SIH0503 SIH Medium w/o Ammonium Chloride - 6 x 1000 gram
SIH0601 SIH Medium w/o Amino acids - 250 g
SIH0602 SIH Medium w/o Amino acids - 1000 gram
SIH0603 SIH Medium w/o Amino acids - 6 x 1000 gram
SIH0701 SIH Medium w/o Amino acids and w/o NH4Cl - 250g
SIH0702 SIH Medium w/o Amino acids and w/o NH4Cl - 1000g
SIH0703 SIH Medium w/o Amino acids and w/o NH4Cl -  6 x 1000g
SIH0801 SIH Medium w/o Cysteine & w/o Methionine - 250 gram
SIH0802 SIH Medium w/o Cysteine & w/o Methionine - 1000 gram
SIH0803 SIH Medium w/o Cysteine & w/o Methionine - 6 x 1000 gram
SIH0901 SIH Medium w/o Glutamic acid & w/o Lysine - 250 gram
SIH0902 SIH Medium w/o Glutamic acid & w/o Lysine - 1000 gram
SIH0903 SIH Medium w/o Glutamic acid & w/o Lysine - 6 x 1000 gram
SIH1001 SIH Medium w/o Arginine & w/o Lysine - 250 gram
SIH1002 SIH Medium w/o Arginine & w/o Lysine - 1000 gram
SIH1003 SIH Medium w/o Arginine & w/o Lysine - 6 x 1000 gram
SIH1004 SIH Medium including 100 mg/l Glucose - 1000 gram
SIH114 SIH Drop-out Mixture, minus Folate - 1000g
SIH115 SIH Medium without Cyanocobalamin - 1000g
SIM0101 SIH Medium w/o Methionine - 250 gram
SIM0102 SIH Medium w/o Methionine - 1000 gram
SIM0103 SIH Medium w/o Methionine - 6 X 1000 gram
SMA0101 SM Agar - 250 gram
SMA0102 SM Agar - 1000 gram
SMA0103 SM Agar - 6 X 1000 gram
SMA50101 SM Agar/5 - 250 gram
SMA50102 SM Agar/5 - 1000 gram
SMA50103 SM Agar/5 - 6 x 1000 gram
SMB0101 SM Broth - 250 gram
SMB0102 SM Broth - 1000 gram
SMB0103 SM Broth - 6 X 1000 gram
SMB50101 SM Broth/5 - 250 gram
SMB50102 SM Broth/5 - 1000 gram
SMB50103 SM Broth/5 - 6 x 1000 gram
SOA0101 SOA - 250 gram
SOA0102 SOA - 1000 gram
SOA0201 SOA: Hanahan's Agar - 250 gram
SOA0202 SOA: Hanahan's Agar - 1000 gram
SOB0101 SOB - 250 gram
SOB0102 SOB - 1000 gram
SOB0201 SOB Hanahan's Broth - 250 gram
SOB0202 SOB Hanahan's Broth - 1000 gram
SOC0101 SOC Agar - 250 gram
SOC0102 SOC Agar - 1000 gram
SOC0201 SOC Broth - 250 gram
SOC0202 SOC Broth - 1000 gram
SOC0205 SOC Broth - 500 gram
SOR02 D(+) - Sorbitol - 1000g
SOR03 D(+) - Sorbitol - 5 x 1 Kg
SPA0101 Super Broth Agar - 250 gram
SPA0102 Super Broth Agar - 1000 gram
SPA0103 Super Broth Agar - 6 X 1000 gram
SPB0101 Super Broth - 250 gram
SPB0102 Super Broth - 1000 gram
SPB0103 Super Broth - 6 X 1000 gram
SPT0101 Super Broth Top Agar - 250 gram
SPT0102 Super Broth Top Agar - 1000 gram
STDA0105 STD Agar - 500g
STDA0110 STD Agar - 1000g
SUC01 D-(+)-Sucrose - 1000g
SUC06 D-(+)Sucrose - 6 x 1 Kg
TAE0500 TAE Buffer 50X - 500ml
TAE1000 TAE Buffer 50X - 1L
TAE5000 TAE Buffer 50X - 5L
TAP0101 Terrific Agar: Phosphate Buffered - 250 gram
TAP0102 Terrific Agar: Phosphate Buffered - 1000 gram
TAP0103 Terrific Agar: Phosphate Buffered - 6 X 1000 gram
TBE0500 TBE Buffer 10x - 500 mL
TBE1000 TBE Buffer 10X - 1 Litre
TBE5000 TBE Buffer 10X - 5 litre
TBP0101 Terrific Broth: Phosphate Buffered - 250 gram
TBP0102 Terrific Broth: Phosphate Buffered - 1000 gram
TBP0103 Terrific Broth: Phosphate Buffered - 6 X 1000 gram
TBP0105 Terrific Broth: Phosphate Buffered - 5 Kg
TBSL0500-7.4 TBS Buffer pH 7.4 10x 500ml
TBSL0500-7.6 TBS Buffer pH 7.6 10X 500ml
TBSL0500-7.8 TBS Buffer pH 7.8 10X 500ml
TBSL0500-8.0 TBS Buffer pH 8.0 10X 500ml
TBSL1000-7.4 TBS Buffer pH 7.4 10X 1L
TBSL1000-7.6 TBS Buffer pH 7.6 10X 1L
TBSL1000-7.8 TBS Buffer pH 7.8 10X 1L
TBSL1000-8.0 TBS Buffer pH 8.0 10X 1L
TBSL5000-7.4 TBS Buffer pH 7.4 10X 5L
TBSL5000-7.6 TBS Buffer pH 7.6 10X 5L
TBSL5000-7.8 TBS Buffer pH 7.8 10X 5L
TBSL5000-8.0 TBS Buffer pH 8.0 10X 5L
TET02 Tetracycline HCl - 25 gram
TET03 Tetracycline HCl - 100 gram
TGS0500 Tris Glycine SDS Transfer Buffer 10X - 500mL
TGS1000 Tris Glycine SDS Transfer Buffer 10X - 1L
TGS5000 Tris Glycine SDS Transfer Buffer 10X - 5L
THM077 Thermus Media - 770 gram
TMP0105 Tryptone Phosphate Broth - 960 gram
TMP0106 Tryptone Phosphate Broth - 480 gram
TMP0107 Tryptone Phosphate Broth - 1920 gram
TPA0101 Tryptone Agar - 250 gram
TPA0102 Tryptone Agar - 1000 gram
TPA0103 Tryptone Agar - 6 X 1000 gram
TPB0101 Tryptone Broth - 250 gram
TPB0102 Tryptone Broth - 1000 gram
TPB0103 Tryptone Broth - 6 X 1000 gram
TPT0101 Tryptone Top Agar - 250 gram
TPT0102 Tryptone Top Agar - 1000 gram
TRA0101 Terrific Agar - 250 gram
TRA0102 Terrific Agar - 1000 gram
TRA0103 Terrific Agar - 6 X 1000 gram
TRB0101 Terrific Broth - 250 gram
TRB0102 Terrific Broth - 1000 gram
TRB0103 Terrific Broth - 6 X 1000 gram
TRB0104 Terrific Broth - 500 gram
TRE250 D-(+)-Trehalose Dihydrate - 250g
TRIS01 Tris Ultra Pure - 1000 gram
TRIS05 Tris Ultra Pure - 500 gram
TRIS06 Tris Ultra Pure - 6 x 1000 gram
TRP01 Tryptone - 250 gram
TRP02 Tryptone - 500 gram
TRP03 Tryptone - 1000 gram
TRP04 Tryptone - 6 X 1000 gram
TRT0105 Tryptone Soya Broth - 500 gram
TSA0105 Tryptic Soy Agar - 500g
TSA0110 Tryptic Soy Agar - 1000g
TSB0105 Tryptic Soy Broth - 500g
TSB0110 Tryptic Soy Broth - 1000g
TSBT01 Trypton Soy Broth w/o Glucose - 1000 gram
TYE0101 TYE Broth - 1000g
TYEA09L TYE Agar - 350gram
VL60101 VL6 Medium Including Glucose - 250 gram
VL60102 VL6 Medium Including Glucose - 1000 gram
VL60103 VL6 Medium Including Glucose - 6 X 1000 gram
VL60201 VL6 Medium without Glucose - 250 gram
VL60202 VL6 Medium without Glucose - 1000 gram
VL60203 VL6 Medium without Glucose - 6 X 1000 gram
VLBAL0250 VLB-Agar Lennox - 250g
VLBAL0500 VLB-Agar Lennox - 500g
VLBAL1000 VLB-Agar Lennox - 1000g
VLBAL10L VLB-Agar Lennox - 10  Litre Pack
VLBAL1L VLB-Agar Lennox - 1 Litre Pack
VLBAL20L VLB-Agar Lennox - 20  Litre Pack
VLBAL2L VLB-Agar Lennox - 2  Litre Pack
VLBAL5L VLB-Agar Lennox - 5  Litre Pack
VLBAL6000 VLB-Agar Lennox - 6 x 1 Kg
VLBAM0250 VLB-Agar Miller - 250g
VLBAM0500 VLB-Agar Miller - 500g
VLBAM1000 VLB-Agar Miller - 1000g
VLBAM10L VLB-Agar Miller - 10 Litre Pack
VLBAM1L VLB-Agar Miller - 1 Litre Pack
VLBAM20L VLB-Agar Miller - 20 Litre Pack
VLBAM2L VLB-Agar Miller - 2 Litre Pack
VLBAM5L VLB-Agar Miller - 5 Litre Pack
VLBAM6000 VLB-Agar Miller - 6 x 1 Kg
VLBBL0250 VLB-Broth  Lennox - 250g
VLBBL0500 VLB-Broth  Lennox - 500g
VLBBL1000 VLB-Broth  Lennox - 1000g
VLBBL10L VLB-Broth Lennox - 10  Litre Pack
VLBBL1L VLB-Broth Lennox - 1 Litre Pack
VLBBL20L VLB-Broth Lennox - 20 Litre Pack
VLBBL2L VLB-Broth Lennox - 2  Litre Pack
VLBBL5L VLB-Broth Lennox - 5  Litre Pack
VLBBL6000 VLB-Broth  Lennox - 6 x 1 Kg
VLBBM0250 VLB-Broth Miller - 250g
VLBBM0500 VLB-Broth Miller - 500g
VLBBM1000 VLB-Broth Miller - 1000g
VLBBM10L VLB-Broth Miller - 10 Litre Pack
VLBBM1500 VLB-Broth Miller - 1500g
VLBBM1L VLB-Broth Miller - 1 Litre Pack
VLBBM20L VLB-Broth Miller - 20 Litre Pack
VLBBM2L VLB-Broth Miller - 2 Litre Pack
VLBBM5L VLB-Broth Miller - 5 Litre Pack
VLBBM6000 VLB-Broth Miller - 6 x 1 Kg
VPEP01 Soya Peptone - 250g
VPEP02 Soya Peptone - 500g
VPEP03 Soya Peptone - 1000g
VPEP04 Soya Peptone - 6 x 1000g
VYTA0250 2X VYT Agar - 250g
VYTA0500 2X VYT Agar - 500g
VYTA1000 2X VYT Agar - 1000g
VYTA10L 2X VYT Agar - 10 Litre Pack
VYTA1L 2X VYT Agar - 1 Litre Pack
VYTA20L 2X VYT Agar - 20 Litre Pack
VYTA2L 2X VYT Agar - 2 Litre Pack
VYTA5L 2X VYT Agar - 5 Litre Pack
VYTA6000 2X VYT Agar - 6 x 1 Kg
VYTB01000 2X VYT Broth - 1000g
VYTB0250 2X VYT Broth - 250g
VYTB0500 2X VYT Broth - 500g
VYTB10L 2X VYT Broth - 10 Litre Pack (310g)
VYTB1L 2X VYT Broth - 1 Litre Pack (31g)
VYTB20L 2X VYT Broth - 20 Litre Pack (620g)
VYTB2L 2X VYT Broth - 2 Litre Pack (62g)
VYTB5L 2X VYT Broth - 5 Litre Pack (155g)
VYTB6000 2X VYT Broth - 6 x 1 Kg
WSA0105 Wallerstein Agar - 500g
WSA0110 Wallerstein Agar - 1000g
XGAL001 X-Gal - 1 gram
XGAL005 X-Gal - 5 gram
XGAL010 X-Gal - 10 gram
YDA0201 2X YT Agar - 250 gram
YDA0202 2X YT Agar - 1000 gram
YDA0203 2X YT Agar - 6 X 1000 gram
YDA10L 2X YT Agar - 10L pack - 460g
YDA1L 2X YT Agar - 1L pack
YDA20L 2X YT Agar - 20L pack
YDA2L 2X YT Agar - 2L pack
YDA5L 2X YT Agar - 5L pack
YDB0101 2X YT Broth - 250 gram
YDB0102 2X YT Broth - 1000 gram
YDB0103 2X YT Broth - 6 X 1000 gram
YDB0104 2X YT Broth - 500 gram
YDB10L 2X YT Broth - 10 L pack - 310g
YDB1L 2X YT Broth - 1L pack - 31 gram
YDB20L 2X YT Broth - 20L pack
YDB24L 2X YT Broth - 24L pack (744g)
YDB2L 2X YT Broth - 2L pack - 62g
YDB5L 2X YT Broth - 5L pack
YEA01 Yeast Extract, Powder - 250 gram
YEA02 Yeast Extract, Powder - 500 gram
YEA03 Yeast Extract, Powder - 1000 gram
YEA04 Yeast Extract, Powder - 6 X 1000 gram
YEA06 Yeast Extract, Powder - 2 Kg
YEB0102 YEB Broth - 250g
YEB0105 YEB Broth - 500g
YEB0110 YEB Broth - 1000g
YGC01 YGC Agar - 1000g
YGC02 YGC Agar - 500 gram
YMAG0110 Yeast Mold Agar - 1000g
YMBR0110 Yeast Mold Broth - 1000g
YP01 YP Medium - 1650g
YP0111 YP Medium - 1000g
YP0115 YP Medium - 1.5 Kg
YPLA01 YPL Agar with Lactose - 250 gram
YPLA02 YPL Agar with Lactose - 500 gram
YPLA03 YPL Agar with Lactose - 1000 gram
YPLB01 YPL Broth with Lactose - 250 gram
YPLB02 YPL Broth with Lactose - 500 gram
YPLB03 YPL Broth with Lactose - 1000 gram
YTA0201 YT Agar - 250 gram
YTA0202 YT Agar - 1000 gram
YTA0203 YT Agar - 6 X 1000 gram
YTB0101 YT Broth - 250 gram
YTB0102 YT Broth - 1000 gram
YTB0103 YT Broth - 6 X 1000 gram
YTT0301 YT Top Agar - 250 gram
YTT0302 YT Top Agar - 1000 gram
我们提供世界著名品牌的百万种优质产品:
部分仪器>
三维细胞组织培养系统
微囊发生器
微量注射器、助吸器
转定子式均质器、碾槌式匀质器、混涡混合器、旋转器、细胞破碎器、振荡器、搅拌器
加热套
吸入暴露系统/气溶胶发生器
所售仪器类商品,保修一年,终身维修。
上海市徐汇区云锦路500号绿地汇中心A座809,在中国主要城市有销售支持,见www.equl.cn
2380088352, 390113670
上海:021-64280805
22817530
