其他培养箱
广州研华PPC-L157T报价
广州研华PPC-L157T报价
中国台湾
标准
咨询电话:15302385015 吴先生
研华平板电脑
Introduction
The PPC-157T is an Intel Core 2 Duo based Panel PC with 15" color TFT LCD. It features multimedia devices, various connectors, and can be installed in virtually any application. In addition, its user-friendly interface makes it a great host for information appliances. Four serial ports and two Gigabit Ethernet ports give the PPC-157T advanced networking capabilities, and provide a great solution for versatile applications.
Specifications
Processor System
CPU
Supports mSocket 478 based Core 2 Duo up to 2.16 GHz
CPU FSB
533/667 MHz
Chipset
945GME + ICH7M
Disk Drive Housing
Room for 1 x 2.5" SATA HDD
Dimensions (W x H x D)
396.5 x 317.6 x 103.5 mm (15.6" x 12.5 x 4.08")
Weight
6 kg (13.22lb)
Front Panel Protection
IP65 compliant
HDD
SATA HDD interface (2.5" HDD bay)
DVD+/-RW Drive
Optional SATA 8X or above DVD+/-RW Drive, Optional optical drive bay
Memory
Supports up to 4 GB of 667 MHz DDR2 SODIMM system memory (socket x 2)
Network (LAN)
2 x Gigabit Ethernet ports, Wake on LAN, boot from LAN and LAN teaming supported
I/O Ports
- 4 x COM ports: 2 x RS-232, 1 x RS-232/422/485,
1 x RS-232/ GPIO (8 channels, TTL level)*
- 4 x USB 2.0 ports
- Mic in/ Line out / Line in, 1W speaker
- 2 x Gigabit Ethernet ports
- 1 x D-SUB VGA port
- 1 x PS/2 mouse and keyboard interface
* RS-232/422/485 - selecting by BIOS and supporting Auto-flow control,
RS-232/GPIO - by swapping pin header
Bus Expansion
1 x PCI-e Expansion Slot (PCI is available as an option), 1 x Mini PCI socket, 1 x Mini PCI-e socket
OS Support
OS support
Win XPE / Win XP Pro / WES7 32 & 64 bit / Windows 7 32 & 64 bit (64 bit only for T7400)
Environmental Specifications
Operating Temperature
0 ~ 50° C (32 ~ 122° F)
Relative Humidity
10 ~ 95% @ 40° C non-condensing
Shock
Operating 10 G peak acceleration (11 ms duration), follows IEC 60068-2-27
研华平板电脑
PPC-179TSee Full Selection
17" Intel 酷睿™2 双核 工业平板电脑
      Main Features
■17" TFT SXGA LCD
■基于Intel® 酷睿™2 双核 LGA775 socket的处理器,
最高可达3.0 GHz
■2个240针DDR31333/1066 DIMM,最高可达4 GB
■1个PCI和1个PCIe扩展插槽
■1个RS-232/422/485接口;(支持自动数据流控制,
可通过跳线设置)
17" Panel PC with
Intel® Core™2 Duo Processor
ƒƒ
17" TFT SXGA LCD
ƒ
Intel® Core™2 Duo LGA775 Socket-based processor
up to 3.0 GHz
ƒ
Supports 240-pin DDR3 1333/1066 DIMM x2 Up to 4
GB
ƒ
Rugged die-cast aluminum housing with removable
plastic front bezel
ƒ
Supports One Mini PCIe socket, Dual Gigabit
Ethernet
ƒ
One PCI and one PCIe expansion slot
ƒ
One RS-232/422/485; (supporting Auto-flow
control, jumper-selected)
广东广州市荷光路158号天逸商务大厦A座518房
