咨询电话:15302385015 吴先生
研华平板电脑
ntroduction
PPC-179T is a top performing and highly
expandable panel PC. Equipped with a 17" Color
TFT LCD, it features high performance,
multimedia devices, connectors, and 2 expansion
sockets (PCI and PCIe) for high expansion
capacity. Because of its multifunctional design,
the PPC-179T meets demands from multimedia
applications and interactive kiosks that require
big displays and powerful computing performance.
Specifications
Processor System
CPU
Supports LGA775 Socket-based Intel Core 2 Duo
Processor up to 3.0 GHz
Dimensions (W x H x D)
446 x 382 x 149 mm (17.56" x 15.04" x 5.87")
Weight
10 kg (22 lb)
Front Panel Protection
IP65 compliant
HDD
One internal SATA interface - 2.5" Type
DVD+/-RW Drive
Equipped with one slim 8x SATA DVD +/- RW
(BLACK)
Memory
Supports 240-pin DDR3 1333/1066 DIMM x2 Up to 4
GB (only supports 64X8 and 128X8, not for 256X8)
Network (LAN)
2 x 10/100/1000 Mbps (RJ-45)
I/O ports
- 4 x serial ports: 3 x RS-232, 1 x RS-
232/422/485
- 6 x USB2.0 ports
- Mic-in, Line-in, Line-out, 1W speaker
- 1 x D-SUB VGA port
Bus Expansion
1 x PCI + 1 x PCIe (standard) , 2 x PCI (in the
accessory box), 1 x Mini PCI-e socket
Environmental Specifications
Operating Temperature
0 ~ 45° C (32 ~ 113° F)
Relative Humidity
10 ~ 95% @ 40° C, non-condensing
Shock
Operating 10 G peak acceleration (11 ms
duration), follows IEC 60068-2-27
Vibration
Operating Random Vibration Test 5~500Hz, 1Grms,
follows IEC 60068-2-64
EMC
BSMI, VCCI, CE, FCC Class B, CCC
Safety
CB, CE, UL
