测序/基因分析
MassARRAY® DNA质谱阵列基因分析系统
MassARRAY Analyzer 4 system
进口
美国
MassARRAY
【性能参数】
MassARRAY® DNA质谱阵列基因分析系统——全球独创核酸质谱高精度定性定量平台
MassARRAY® DNA质谱阵列基因分析系统是一个功能强大的核酸质谱定性定量平台,它完美地结合了质谱检测的高分辨率、PCR扩增的高敏感度,以及生物芯片技术的高通量,同时无需杂交及荧光染料等二级标记物,直接以分子量为标记对样本进行多方位分析。
MassARRAY® DNA质谱阵列基因分析系统主要应用包含:
• 中高通量SNP基因型分析
• GWAS及二代测序验证
• 肿瘤体细胞基因突变谱分析
• 基因表达定量及目标基因CNV分析
• DNA甲基化定位定量
• 病原体分子分型
• MassARRAY®
DNA质谱阵列基因分析系统以其通量高、自动化、灵活、结果准确、实验成本低廉等诸多优势成为了全球著名大学、医学生物学研究所、生物技术公司、制药企业、疾控中心等机构所推崇的研究工具。应用领域涵盖:医学及转化医学、分子生物学、基因组学、表观遗传学、农业遗传育种及转基因技术等相关领域。
MassARRAY® Analyzer 4: Setting new standards in speed, performance, and flexibility With its exquisite sensitivity and accuracy, mass spectrometry is ideally suited for the analysis of nucleic acids. The new MassARRAY® Analyzer 4 system brings the power of mass spectrometry,  robust molecular biology, and advanced data analysis software to meet the needs of high and  low-throughput.
It provides increased throughput,  faster time-to-results, and the ability to cost-efectively run from tens to thousands of samples – making this an ideal genetic analysis system for use in basic and translational research laboratories.
With the new MassARRAY Analyzer 4 system you can:
• Conduct rapid, accurate, and cost-efective analyses with a highly sensitive and specifc mass spectrometry-based detection system
• Run a variety of applications, from genotyping and  somatic mutation analysis to methylation and comparative sequencing
• Save research time and maximize efciency with easy-to-use multiplexed assay design and optimization software
• Fit experiments into your schedule with fast experimental set-up and rapid data acquisition and analysis
• Save money with simple, robust, label-free primer extension Chemistries for detection on the MassARRAY Analyzer 4 system
High Performance Maximum Flexibility
Highly accurate MALDI-TOF-based detection provides unparalleled specificity and sensitivity for studies of Genetic variation including somatic mutation    detection in heterogeneous samples.  The  increased chip  scan speed coupled with the robust detection system gets you to results faster with minimal system down time. The MAssARRAY Analyzer 4 system has a small footprint, and is a highly scalable platform with the fexibility to analyze any combination of SNPs and  samples for low to high-throughput applications, making it ideally suited for fne mapping studies, and candidate gene analysis downstream of whole genome association studies
Easy-to-Use Versatility
Robust assay design software automates primer design and optimization to maximize efciency and minimize experimental variability. New data acquisition software streamlines your workfow to ensure fast, direct identifcation of genetic targets The benchtop MassARRAY Analyzer  4 system is ideally suited for targeted genetic analyses across a variety of applications including SNP genotyping, somatic mutation detection, methylation analysis, quantitative gene expression analysis, copy number variation, and comparative sequence analysis.
Comparison of MassARRAY Analyzer 4 system formats
  96-well 384-well
Multiplexing Up    to     36-plex Up    to     36-plex
Genotypes/day < 30,000 Up    to     138,000
Ideal # of markers Fewer       than 500 Up    to     3,000
The MassARRAY Analyzer 4 system is ofered in several confgurations to meet your throughput needs. A 384-well system is intended for higher-throughput laboratories with a capacity of up to 138,000 genotypes per day.  The 96-well system is specifcally designed to address the needs of low to mid-throughput labs, and  is ideally suited for experiments involving  fewer than 30,000 genotypes per day (see  table).  For ordering information please contact your local ofce below.
Agena Bioscience公司(原Sequenom Bioscience )多年专一致力于研发、生产和销售MassARRAY®基因质谱分析系统及其配套试剂。该设备可一次性精确检测几个至几百个靶向SNP/CNV/Indel基因标记物,具有一天检测几个乃至几千个样本的通量高度灵活优势;其设计和分析软件更可根据客户需求独立设计并使检测利于自主知识产权的保护,为客户提供了一种高性价比的技术平台。目前该设备系统已经在全球37个国家应用,应用范围覆盖生物学的各个领域,如癌症分析实体瘤和液体活检,遗传病检测,遗传药理学、农业基因组学、临床转化医学研究和法医学研究等。
Agena Bioscience (Shanghai) Co., Ltd.
基纳生物技术(上海)有限公司
地址:上海市徐汇区枫林路380号枫林国际中心A座1609-1613室
电话:+86 21 6427 0566
传真:+86 21 6427 0511
网址:www.agenabio.com.cn
