免疫学/诊断检测试剂
支原体检测试剂盒
支原体检测试剂盒
MYCOALERT DETECTION KIT
进口
美国lonza
咨询电话010-88865677
咨询电话010-88865677
支原体检测试剂盒 25次 现货 更多产品请咨询 Tel: 咨询电话010-88865677 13466618207
Email: atcclines@163.com (24小时服务)联系人:王少伟
MycoAlert™ Mycoplasma Detection Kit产品介绍: Lonza MycoAlert Mycoplasma Detection Kit支原体检测试剂盒是专门检测细胞培养过程中是否被支原体污染的经典试剂盒,它包含检测所用到的各种试剂和产品操作手册。MycoAlert™支原体检测试剂盒检测原理主要是:细胞培养中存活的支原体被溶解,然后释放出来的酶与支原体检测试剂盒中提供的底物发生催化反应,将ADP转化成ATP。通过测量样品中添加底物前后ATP的含量,可以得到一个比率,该比率指示支原体是否存在。如果这些酶不存在,第二次读数相对于第一次读数就没有增加;如果酶与底物进行特异性反应,就会导致ATP含量上升。最后通过分光光度计读数,由于发出光的强度与ATP的浓度成线性关系,因此可检测支原体的污染问题。同时,该支原体检测试剂盒具有操作简单、快速高效、结果稳定可靠、灵敏度极高等优点,让您在支原体检测时轻松容易,并确保您的培养洁净无污染。 MycoAlert™ Mycoplasma Detection Kit产品特性: » 快速检测:20分钟内即可诊断出你的细胞培养是否健康无污染,而其它方法一般要几个小时到一周的时间 » 应用方便:只需把你的细胞培养物与两种试剂混合配成100µl,在分光光度计上读2次数 » 通用性强:可以检测所有支原体在细胞培养过程中的污染,如支原体属、无胆甾原体属、虫原体属、脲原体属、螺原体属等 » 检测灵敏:可检测<50 cfu/ml的支原体,避免出现像PCR和荧光染色方法出现的阴性结果 » 成分完备:该支原体检测试剂盒包含实验所需的所有试剂,而不像商业PCR检测方法中需要你提供PCR酶、核酸、限制性内切酶和琼脂糖电泳所需的其它试剂 MycoAlert™ Mycoplasma Detection Kit英文简述: The MycoAlert™ Mycoplasma Detection Kit is a selective biochemical test that exploits the activity of mycoplasmal enzymes which are found in all six of the main mycoplasma cell culture contaminants and the vast majority of 180 mycoplasma species, but are not present in eukaryotic cells. Viable mycoplasma in a test sample (cell supernatant) are lysed and the enzymes react with the MycoAlert™ Substrate, catalyzing the conversion of ADP to ATP. The ATP is then transferred into a light signal via the luciferase enzyme in the MycoAlert™ Reagent. By measuring the level of ATP in a sample both before (read A) and after the addition of the MycoAlert™ Substrate (read B), a ratio can be obtained which is indicative of the presence or absence of mycoplasma. Convenient & fast • Simply add two reagents to the culture supernatant • Perform two luminescence readings • Easy interpretation of results • Results in < 20 min Universal • Detects all common mollicute contaminations (Mycoplasma, Acholeplasma, Entomoplasma and Spiroplasma; except Ureaplasma)
LAL试剂
动态显色法鲎试剂
LAL试剂
细菌内毒素检查、LAL检测(检测)
LAL试剂
细菌内毒素检查、LAL检测(检测)
LAL试剂
细菌内毒素检查、LAL检测(稀释)
LAL试剂
细菌内毒素工作标准品
LAL试剂
细菌内毒素检查、LAL检测(稀释)
LAL试剂
细菌内毒素检查用水、试剂配制
LAL试剂
细菌内毒素检查用水、试剂配制
LAL试剂
细菌内毒素检查用水、试剂配制
LAL试剂
细菌内毒素检查、LAL检测缓冲液
LAL试剂
烘箱除热原程度的检测
LT07-118 MycoAlert® Mycoplasma Detection Kit, 10 Tests
LT07-218 MycoAlert® Mycoplasma Detection Kit, 25 Tests
LT07-418 MycoAlert® Mycoplasma Detection Kit, 50 Tests
LT07-318 MycoAlert® Mycoplasma Detection Kit, 100 Tests
订购电话: 010-88865677 Email: atcclines@163.com
ATCC细胞株(系) \菌种(株)\动植物病毒\噬菌体(细菌)
我们公司专业代理美国ATCC以下产品:
1.细胞系(3000种);
2.细菌和噬菌体(15000种);
3.动植物病毒(2500种);
4.原生动物(1200种)
5.以及重组物品等等。
美国菌种保藏中心,又称美国模式菌种收集中心(ATCC),是位于马里兰洲洛克菲勒的一家私营的,非赢利性组织。目前它可以提供以下物品:细胞系(3000种);细菌和噬菌体(15000种);动植物病毒(2500种);原生动物 1200种以及重组物品等。
ATCC细胞株菌种病毒质粒藻类
ATCC 细胞、细菌、菌株、噬菌体、细胞株
ATCC细胞、细胞株、菌种, 菌株、动植物病毒、噬菌体
地址:北京市海淀区紫竹院路31号华澳中心3号楼6G 邮编:100089
美国菌种保藏中心,又称美国模式菌种收集中心(ATCC), 是位于马里兰洲洛克菲勒的一家私营的,非赢利性组织。目前它可以提供以下物品 : 细胞系(3000种);细菌和噬菌体(15000种);动植物病毒(2500种);原生动物 1200种以及重组物品等。
编号 名称 价格 编号 名称 价格
CCL-1 NCTC clone 929 179 CCL-70 CV-1 179
CCL-1.2 L-M 290 CCL-71 CAR 290
CCL-1.3 L-M(TK-) 224 CCL-72 Detroit 510 290
CCL-1.4 A9 290 CCL-73 Ch 1 Es(NBL-8) 290
CCL-2 HeLa 179 CCL-74 P1 1Ut(NBL-9) 290
CCL-2.1 HeLa 229 224 CCL-75 WI 38 179
CCL-2.2 HeLa S3 179 CCL-75.1 WI-38 VA-13 subline 2RA 224
CCL-5 L-132 290 CCL-76 citrullinemia 290
CCL-15 HaK 290 CCL-88 Tb 1 Lu 290
CCL-16 Don 290 CCL-89 AtT-20 224
CCL-17 KB 224 CCL-90 Cri du Chat 290
CCL-20.2 Clone 1-5c-4 290 CCL-91 BF-2 290
CCL-21 AV3 290 CCL-92 3T3-Swiss albino 179
CCL-22 MDBK(NBL-1) 179 CCL-93 V79-4 224
CCL-23 Hep-2 179 CCL-94 CRFK 224
CCL-25 WISH 224 CCL-95.1 WI-26VA4 290
CCL-26 BS-C-1 179 CCL-96 3T6-Swiss albino 179
CCL-28 Dempsey 29 CCL-97 R2C 290
CCL-30 RPMI 2650 290 CCL-98 BeWo 179
CCL-32 MB lll (de Bruyn-Gey) 290 CCL-100 GeLu 260
CCL-33 PK(15) 224 CCL-102 A6 224
CCL-34 MDCK(NBL-2) 179 CCL-104 E.H.IV 290
CCL-34.1 DoCIl(S+L-) 290 CCL-105 SW-13 224
CCL-35 PtK1(NBL-3) 290 CCL-106 LLC-RK1 290
CCL-37 RK13 224 CCL-107 C6 179
CCL-38 LLC-WRC 256 290 CCL-108 lgh-2 290
CCL-39 Dede 290 CCL-110 Detroit 551 179
CCL-41 FT 290 CCL-111 Gekko lung-1 290
CCL-42 FHM 290 CCL-113 RPMI 6666 290
CCL-43 LC-540 290 CCL-114 RPMI 7666 290
CCL-44 EBTr(NBL-4) 290 CCL-116 Detroit548 290
CCL-45 Jensen Sarcoma 290 CCL-117 Detroit 573 290
CCL-46 P388D1 224 CCL-119 CCRF-CEM 179
CCL-46.1 NCTC 3749 290 CCL-120 CCRF-SB 224
CCL-47 RR1022 290 CCL-120.1 CCRF-HSB-2 224
CCL-49 RPMI 1846 290 CCL-121 HT-1080 179
CCL-50 TH-1,Subline B1 290 CCL-122 HG-261 290
CCL-51 MMT 060562 290 CCL-123 C211 290
CCL-53.1 Clone M-3 224 CCL-124 Amdur ll 290
CCL-54 Detroit 532 290 CCL-125 Aedes aegypti 290
CCL-55 RTG-2 290 CCL-126 Aedes albopictus 290
CCL-56 PtK2(NBL-5) 290 CCL-127 IMR-32 179
CCL-57 E.Derm(NBL-6) 290 CCL-128 ICR 134 290
CCL-58 Grunt Fin 290 CCL-129 VSW 290
CCL-59 BB 290 CCL-130 MOPC-31C 290
CCL-60 SIRC(Statens Seruminstitut Rabbit Cornea) 224 CCL-131 Neuro-2a 179
CCL-61 CHO-K1 179 CCL-132 CHP3(M.W.) 290
CCL-62 FL 290 CCL-133 CHP 4 290
CCL-63 NCTC 4093 290 CCL-134 LL29(AnHa) 290
CCL-64 Mv 1Lu(NBL-7) 179 CCL-135 LL47(MaDo) 290
CCL-64.1 MiCI1(S+L-) 290 CCL-136 RD 179
CCL-65 Detroit 525 290 CCL-137 HEL 299 224
CCL-66 Detroit 529 290 CCL-138 Detroit 562 224
CL-68 Sf 1Ep(NBL-11) 290 CCL-139 TCMK-1 290
CCL-140 VH 2 290 CCL-227 SW620 179
CCL-141 Duck embryo 290 CCL-228 SW480 179
CCL-142 RAG 290 CCL-229 LoVo 179
CCL-144 MH1C1 290 CCL-230 SW403 224
CCL-145 ICR-2A 290 CCL-231 SW48 224
CCL-146 IMR-33 290 CCL-233 SW1116 224
CCL-147 NB41A3 290 CCL-234 SW1463 290
CCL-148 HSDM1C1 290 CCL-235 SW837 224
CCL-149 L2 224 CCL-237 SW948 224
CCL-150 AK-D 290 CCL-238 SW1417 290
CCL-151 LL 24 290 CCL-240 HL-60 179
CCL-153 HFL1 224 CCL-241 FHs 74Int 179
CCL-155 RPMI 8226 179 CCL-242 GPC-16 290
CCL-156 RPMI 1788 290 CCL-243 K-562 179
CCL-157 Indian Muntjac 290 CCL-244 HCT-8(HRT-18) 224
CCL-158 JH4 clone 1 290 CCL-245 Mo-B 290
CCL-159 IM-9 224 CCL-246 KG-1 179
CCL-161 DBS-FCL-1 290 CCL-246.1 KG-1a 224
CCL-162 DBS-FCL-2 290 CCL-247 HCT 116 179
CCL-163 BALB/3T3 clone A31 179 CCL-248 T84 179
CCL-163.1 SV-T2 290 CCL-249 NCI-H548 290
CCL-163.2 M-MSV-BALB/3T3 290 CCL-250 SNU-C2B 290
CCL-163.3 K-BALB(K-234) 290 CCL-250.1 XMI-C2A 290
CCL-164 BALB/3T12-3 290 CCL-251 NCI-H716 290
CCL-165 XC 290 CCL-252 NCI-H747 290
CCL-166 MPK 290 CCL-253 NCI-H508 290
CCL-167 MPC-11 290 CCL-254 NCI-H498 290
CCL-168 FoLu 290 CCL-255 LS123 290
CCL-169 CGBQ 290 CCL-256 NCI-H2126 290
CCL-171 MRC-5 179 CCL-256.1 NCI-BL2126 290
CCL-176 Fc3Tg 290 CCL-257 NCI-H1688 290
CCL-183 D-17 290 CL-48 WRL 68 290
CCL-185 A549 179 CL-101 LLC-PK 179
CCL-186 IMR-90 179 CL-101.1 LLC-PK1A 290
CCL-189 HK-PEG-1 290 CL-160 DBS-FRhL-2 290
CCL-190 LL86(LeSa) 290 CL-173 3T3-L1 179
CCL-191 LL97A(AlMY) 290 CL-177 XB-2 290
CCL-192 RFL-6 224 CL-184 ESK-4 290
CCL-193 R9ab 290 CL-187 LA 180 224
CCL-194 DPSO 114/74 290 CRL-188 LS 174T 179
CCL-195 AHL-1 290 CRL-1098 Lei Cap 290
CCL-196 LA-4 224 CRL-1107 Per Sel 290
CCL-197 NOR-10 290 CRL-1110 Sal Mat 290
CCL-198 BLO-11 290 CRL-1129 Am Ric 290
CCL-199 HLF-a 290 CRL-1130 Lo Ren 290
CCL-200 CCD-13Lu 290 CRL-1131 Ron Har 290
CCL-201 CCD-8Lu 290 CRL-1138 Mar Vin 290
CCL-202 CCD-11Lu 290 CRL-1140 Be Sal 290
CCL-204 CCD-16Lu 290 CRL-1144 Lu Vin 290
CCL-205 CCD-18Lu 290 CRL-1148 Ma San 290
CCL-206 MLg 290 CRL-1149 EI Don 290
CCL-208 4MBr-5 290 CRL-1150 Su Mor 290
CCL-209 CPAE 224 CRL-1159 Lo Wen 290
CCL-210 CCD-19Lu 290 CRL-1165 Ce Ar 290
CCL-211 Hs888Lu 290 CRL-1167 Be Ar 290
CCL-212 MRC-9 290 CRL-1168 Em Ar 290
CCL-213 Daudi 179 CRL-1172 Win Mec 290
CCL-214 NC-37 290 CRL-1173 Ce Geg 290
CCL-215 CCD-25Lu 290 CRL-1176 Ja Bos 290
CCL-216 4/4R.M.-4 290 CRL-1177 Fe Bos 290
CCL-217 Fc2Lu 290 CRL-1179 La Bel 290
CCL-218 WiDr 224 CRL-1180 Bo Gin 290
CCL-219 L1210 224 CRL-1192 Le Ana 290
CCL-220 COLO320DM 240 CRL-1193 Mel Neg 290
CCL-220.1 COLO 320HSR 290 CRL-1195 La Bel ll 290
CCL-221 DLD-1 179 CRL-1205 Ne Loc 290
CCL-222 COLO 205 179 CRL-1213 FR 290
CCL-223 CMT-93 224 CRL-1215 Jay Sen 290
CCL-224 COLO 201 224 CRL-1219 Bi Fin 290
CCL-225 HCT-15 179 CRL-1226 Ray Hot 290
CCL-226 C3H/10T1/2,Clone 8 179 CRL-1227 Ad Hot 290
CRL-1231 Sar Nis 290 CRL-1446 H9c2(2-1) 179
CRL-1247 WoJo 290 CRL-1447 G-7 290
CRL-1248 Ro Bon 290 CRL-1453 KLN205 290
CRL-1249 De Te 290 CRL-1456 G-8 290
CRL-1250 May Roy 290 CRL-1458 L6 179
CRL-1251 Da Bon 290 CRL-1459 CCD-18Co 224
CRL-1252 Mar Ton 290 CRL-1468 FRTL 290
CRL-1254 Be Tim 290 CRL-1469 PANC-1 179
CRL-1257 Mar Nol 290 CRL-1472 HT-1376 224
CRL-1262 Os Te 290 CRL-1473 HT-1197 290
CRL-1265 Ra Bot 290 CRL-1474 CCD-25Sk 290
CRL-1266 An Zan 290 CRL-1475 CCD-27Sk 290
CRL1267 Tal Jo 290 CRL-1476 A-10` 179
CRL-1271 Wa Fen 290 CRL-1478 CCD-29Lu 290
CRL-1273 Wo Fel 290 CRL-1484 HS-Sultan 224
CRL-1280 Ba Pot 290 CRL-1485 CCD-32Lu 290
CRL-1286 Am Coo 290 CRL-1486 HEPM 290
CRL-1287 Ran De 290 CRL-1489 CCD-32Sk 224
CRL-1288 Me Jon 290 CRL-1490 CCD-33Lu 290
CRL-1289 Ra Lot 290 CRL-1491 CCD-34Lu 290
CRL-1294 Ja Coo 290 CRL-1492 AR42J 179
CRL-1298 Tu To 290 CRL-1494 Bge 290
CRL-1308 RoVid 290 CRL-1495 26CB-1 290
CRL-1310 Ro Shi 290 CRL-1497 CCD-34Sk 290
CRL-1315 Ru Ra 290 CRL-1598 CCD-39Lu 290
CRL-1324 Ar Ke-2 290 CRL-1500 ZR-75-1 179
CRL-1325 Al Ke 290 CRL-1501 CCD-39Sk 290
CRL-1326 Gam Per 290 CRL-1502 WS1 224
CRL-1327 No Per 290 CRL-1503 STO 179
CRL-1332 Jo Per 290 CRL-1504 ZR-75-30 290
CRL-1335 Gap Per 290 CRL-1509 CCD-43Sk 290
CRL-1336 Tep Be 290 CRL-1513 CCD-42Sk 290
CRL-1337 Ro Dow 290 CRL-1520 A2B5 clone 105 224
CRL-1338 He We 290 CRL-1532 182-PF SK 290
CRL-1341 Pa Kel-1 290 CRL-1533 166-ME SK 290
CRL-1342 Me Mon 290 CRL-1538 SCC-PSA1 290
CRL-1344 Pa Kel-2 290 CRL-1539 CCD-33Co 290
CRL-1351 Ce Wal 290 CRL-1541 CCD-112CoN 224
CRL-1360 XP17BE 290 CRL-1542 A-72 290
CRL-1361 HTZ17XP 290 CRL-1543 HOS 224
CRL-1365 EB 290 CRL-1544 KHOS/NP(R-970-5) 290
CRL-1366 Or De 290 CRL-1545 KHOS-240S 290
CRL-1378 RBL-1 224 CRL-1546 KHOS-321H 290
CRL-1379 Da Hol 290 CRL-1547 MNNG/HOS(C1#5) 290
CRL-1381 Go Je 290 CRL-1548 H-4-11-E 179
CRL-1383 Da Mo 290 CRL-1550 Ca Ski 179
CRL-1388 Da Cav 290 CRL-1552 MOLT-3 224
CRL-1390 BT 179 CRL-1554 BUD-8 290
CRL-1394 Ga Va 290 CRL-1555 A-431 179
CRL-1395 FBHE 290 CRL-1556 OMK(637-69) 290
CRL-1396 HAFE 290 CRL-1563 CCD-186Sk 290
CRL-1397 Lu Rob 290 CRL-1566 NULL1-SCC1 290
CRL-1404 SC-1 290 CRL-1569 3197-3 290
CRL-1405 104C1 290 CRL-1570 KNRK 290
CRL-1411 C3H/MCA clone 15 290 CRL-1571 NRK-49F 224
CRL-1412 C3H/MCA clone 16 290 CRL-1572 NRK-52E 224
CRL-1414 RAB-9 290 CRL-1573 PA-1 224
CRL-1419 RSOL 290 CRL-1576 293 179
CRL-1420 MIA PaCa-2 179 CRL-1578 12MBr6 290
CRL-1423 G-292,clone A141B1 290 CRL-1579 H4TG 290
CRL-1424 G-361 224 CRL-1580 C32TG 290
CRL-1427 MG-63 179 CRL-1581 P3X63Ag8.653 179
CRL-1430 Cf2Th 290 CRL-1582 Sp2/0-Ag14 179
CRL-1432 NAMALWA 224 CRL-1583 MOLT-4 179
CRL-1435 PC-3 179 CRL-1584 3A(Tpa-30-1) 290
CRL-1439 Clone9 224 CRL-1585 3A-sub E [post crisis of 3A(Tpa-30-1)] 290
CRL-1440 G-402 290 CRL-1586 C32 224
CRL-1441 G-401 290 CRL-1587 VERO C1008 179
CRL-1442 BRL3A 290 CRL-1588 VERO 76 224
CRL-1443 BC3H1 290 CRL-1676 BW5147.G.1.4.OUAR.1 290
CRL-1444 BC3H1 290 CRL-1589 IEC-18 224
CRL-1590 SL-29 224 CRL-1677 IA-XsSBR 290
CRL-1591 TRA-171 290 CRL-1679 WEH1-274.1 290
CRL-1592 IEC-6 179 CRL-1680 CHH-1 290
CRL-1593.2 U-937 179 CRL-1681 CHSE-214 290
CRL-1594 C-4I 290 CRL-1682 AsPC-1 179
CRL-1595 C-411 290 CRL-1687 BxPC-3 179
CRL-1596 Ramos(RA 1) 179 CRL-1688 FRhK-4 224
CRL-1597 P3X63Ag8U.1 290 CRL-1689 2D12 290
CRL-1598 A-673 224 CRL-1690 T98G 179
CRL-1600 H4-II-E-C3 224 CRL-1691 C7 290
CRL-1601 McA-RH7777 224 CRL-1693 NFS-5C-1 290
CRL-1602 McA-RH8994 290 CRL-1694 NFS-70C-10 290
CRL-1603 N1--S1 Fudr 290 CRL-1695 NFS-25C-3 290
CRL-1604 N1-S1 290 CRL-1696 NcCoy 224
CRL-1605 HFN 36.3 290 CRL-1698 7D4 290
CRL-1606 HFN 7.1 290 CRL-1700 SCP 290
CRL-1607 6-23(Clone 6) 290 CRL-1701 DDT MF-2 290
CRL-1608 45.6.TG1.7 290 CRL-1702 WEH1-231 224
CRL-1610 GS-109-V-20 290 CRL-1703 9D9 290
CRL-1611 ACHN 224 CRL-1704 WEHI-279 290
CRL-1613 GS-109-V-34 290 CRL-1707 123-I0 290
CRL-1614 GS-109-V-63 290 CRL-1708 QT6 290
CRL-1615 CL-S1 290 CRL-1709 MOP-8 290
CRL-1616 C127I 290 CRL-1710 RTH-149 290
CRL-1619 A-375 179 CRL-1711 Sf9 179
CRL-1620 A172 179 CRL-1712 68-1-2 290
CRL-1621 ARH-77 224 CRL-1713 123-28 290
CRL-1622 KLE 224 CRL-1714 TM3 224
CRL-1623 SCC-15 224 CRL-1715 TM4 224
CRL-1624 SCC-4 224 CRL-1716 CF4-C4 290
CRL-1628 SCC-25 224 CRL-1718 CC-STTG1 224
CRL-1629 SCC-9 224 CRL-1720 F9 224
CRL-1631 Y3-Ag1.2.3 290 CRL-1721 PC-12 179
CRL-1632 tk-ts13 224 CRL-1722 L5178-R(LY-R) 290
CRL-1633 MDOK 290 CRL-1723 L5178-S(LY-S) 290
CRL-1634 Hs27 179 CRL-1724 MYB 2-7.77 290
CRL-1635 Hs28 179 CRL-1725 MYC CT9-B7.3 290
CRL-1636 NMuMG 224 CRL-1726 MYB 3-37.63 290
CRL-1637 Mm5MT 290 CRL-1727 MYC CT 14-G4.3 290
CRL-1638 NMuLi 290 CRL-1728 MYB 2-3.76 290
CRL-1640 SJK-132-20 290 CRL-1729 MYC 1-9E10.2 224
CRL-1642 LL/2(LLC1) 179 CRL-1730 HUV-EC-C 179
CRL-1643 GS-109-V-21 290 CRL-1732 FOX-NY 290
CRL-1644 SJK-287-38 290 CRL-1733 CPA 47 290
CRL-1645 SJK-237-71 290 CRL-1734 SCA-9 clone 15 290
CRL-1646 FO 224 CRL-1735 Lec1 290
CRL-1647 ST486 290 CRL-1736 Lec2 290
CRL-1648 CA46 290 CRL-1737 Lec8 290
CRL-1649 MC116 290 CRL-1739 AGS 179
CRL-1650 COS-1 179 CRL-1740 LNCaP clone FGC 179
CRL-1651 COS-7 179 CRL-1741 Y13-238 290
CRL-1652 STK1 290 CRL-1742 Y13-259 290
CRL-1653 F32VIIIC4 290 CRL-1743 NMU 290
CRL-1655 NBT-II 290 CRL-1745 3C9-D11-H11 290
CRL-1656 Mpf 290 CRL-1746 ST 224
CRL-1657 R1610 290 CRL-1747 RBA 290
CRL-1658 NIH/3T3 179 CRL-1749 UM-UC-3 224
CRL-1660 Aedes albopictus clone C6/36 224 CRL-1751 WEHI164 224
CRL-1661 UMR-106 224 CRL-1752 HP6014 290
CRL-1662 YB2/0 290 CRL-1753 HP6017 290
CRL-1663 UMR-108 290 CRL-1754 HP6000 290
CRL-1666 13762MAT B III 224 CRL-1755 HP6001 290
CRL-1667 CA3-F4 290 CRL-1756 HP6003 290
CRL-1668 SHM-D33 290 CRL-1757 HP6045 290
CRL-1669 CW13.20-3B3(clone of BCL1) 290 CRL-1758 HP6053 290
CRL-1670 BC9-E5 290 CRL-1759 TFTB1 290
CRL-1671 RL95-2 224 CRL-1760 2C4 290
CRL-1672 GS-109-IV-8 290 CRL-1761 9AE10 290
CRL-1674 ARIP 290 CRL-1762 KEL F1B 290
CRL-1675 WM-115 224 CRL-1763 HP6054 290
CRL-1676 WM-266-4 224 CRL-1764 Rat2 224
CRL-1765 Lp1 MAB 1 290 CRL-1862 UV20 290
CRL-1766 MLH1 290 CRL-1863 RF-48 224
CRL-1767 Lp1 MAB 3 290 CRL-1864 RF-1 224
CRL-1768 HP6050 290 CRL-1865 UV5 290
CRL-1769 L8 290 CRL-1866 UV24 290
CRL-1770 Lp1MAB2 290 CRL-1867 UV135 290
CRL-1771 TFTA1 290 CRL-1869 6F4C5 290
CRL-1772 C2C12 179 CRL-1870 IL-A42 290
CRL-1774 HP6047 290 CRL-1871 IL-A51 290
CRL-1775 HP6025 290 CRL-1872 A375.S2 290
CRL-1776 HP6023 290 CRL-1873 RS4;11 290
CRL-1777 HIT-T15 179 CRL-1874 IL-A29 290
CRL-1778 LBRM TG6 290 CRL-1875 8A3B.6 290
CRL-1779 MLH2 290 CRL-1877 8B1B.1 290
CRL-1780 RF/6A 290 CRL-1878 YN1/1.7.4 290
CRL-1781 Pro-5 290 CRL-1879 IL-A11 290
CRL-1783 MA1-6 290 CRL-1882 PDL-1 290
CRL-1786 HP6058 290 CRL-1886 7D3A.2 290
CRL-1787 HP6016 290 CRL-1887 B104-1-1 290
CRL-1788 HP6002 290 CRL-1888 EJ-6-2-Bam-6a 290
CRL-1789 HP6020 290 CRL-1889 34 290
CRL-1790 CCD 841 CoN 290 CRL-1890 548 290
CRL-1793 CHO-1C6 290 CRL-1891 FB2 290
CRL-1794 13C4 290 CRL-1893 372 290
CRL-1795 AtT-20/D16v-F2 224 CRL-1894 IL-A30 290
CRL-1796 SBAC 290 CRL-1895 RK3E 290
CRL-1797 PS 67 290 CRL-1896 KM703 290
CRL-1798 PS 45 290 CRL-1897 UACC-812 290
CRL-1799 PS 41 290 CRL-1898 lgG-4A4 290
CRL-1800 PS 60 290 CRL-1899 lgG-B16 290
CRL-1802 J26 290 CRL-1902 UACC-893 224
CRL-1803 TT 179 CRL-1903 RC-4B/C 290
CRL-1804 C127:LT 290 CRL-1907 11E 10 290
CRL-1805 LCL 8664 290 CRL-1908 11F11 290
CRL-1806 MTC-M 290 CRL-1909 M/K-2.7 290
CRL-1807 CCD 841 CoTr 290 CRL-1910 M/K-1.9 290
CRL-1808 Psi2 12S6 290 CRL-1911 PS/2 290
CRL-1809 Pisi2 13s1 290 CRL-1912 R187 290
CRL-1811 A9 290 CRL-1913 48 290
CRL-1812 2E10-H2 290 CRL-1914 514 290
CRL-1813 4H1-A7 290 CRL-1915 DHFR-G8 290
CRL-1814 3G5 290 CRL-1917 Raszip 6 290
CRL-1817 Wgd5 290 CRL-1918 CFPAC-1 224
CRL-1818 4D9D4 290 CRL-1921 NZP-12 290
CRL-1821 ES-E14TG2a 224 CRL-1922 NZP-36 290
CRL-1823 K6H6/B5 290 CRL-1923 Ramos.2G6.4C10 224
CRL-1825 P19 179 CRL-1924 NZP-60 290
CRL-1826 CCD-919SK 290 CRL-1925 NZP-29 290
CRL-1827 D11 33.1 290 CRL-1926 NZP-46 290
CRL-1830 Hepa 1-6 179 CRL-1927 SV40 MES13 224
CRL-1831 FHC 224 CRL-1928 4A6 290
CRL-1832 HIG-82 224 CRL-1929 SUP-B15 179
CRL-1834 GK-5 290 CRL-1932 786-O 179
CRL-1836 CCD-944Sk 290 CRL-1933 769-P 224
CRL-1837 SU.86.86 224 CRL-1934 ES-D3 179
CRL-1838 M-NFS-60 224 CRL-1935 CHL/IU 290
CRL-1839 NRbM 290 CRL-1936 IgG-11H4 290
CRL-1840 OK 224 CRL-1937 IgG-1B3 290
CRL-1841 HT-2 clone A5E 224 CRL-1938 IgG-5D7 290
CRL-1842 6D8MB4 290 CRL-1942 SUP-T1 224
CRL-1843 3G9F3 290 CRL-1943 C44 290
CRL-1844 9-A5 290 CRL-1945 7-34-1 290
CRL-1845 9-B1 290 CRL-1947 CCD-986SK 290
CRL-1846 A2E11 290 CRL-1949 Psi2 DAP 290
CRL-1848 NCL-H292 179 CRL-1950 PS 38 290
CRL-1852 1B8-F11 290 CRL-1951 mSXL5 290
CRL-1853 2H6-C2 290 CRL-1952 mSXL 18 290
CRL-1858 CRE BAG2 290 CRL-1953 mSXL 104 290
CRL-1859 AA8 290 CRL-1954 mSXL 114 290
CRL-1860 UV41 290 CRL-1955 P-tyr-1 290
CRL-1861 EM9 290 CRL-1958 H1HeLa 290
CRL-1959 3C7.2 290 CRL-2047 N2.261 290
CRL-1960 2B5.3 290 CRL-2048 BCE C/D -1b 290
CRL-1961 1A3.1 290 CRL-2049 DMS 79 290
CRL-1962 QM7 290 CRL-2050 ZF4 290
CRL-1963 Schneider’s Drosophila Line2 179 CRL-2051 TBM-54 290
CRL-1964 Clone 15 HL-60 179 CRL-2052 SA22 290
CRL-1965 1B2A3 290 CRL-2053 GC-1 spg 224
CRL-1967 88B 290 CRL-2054 CCD-1037Sk 290
CRL-1968 UC8-1B9 290 CRL-2055 NIT-1 224
CRL-1969 5C6 Clone 1 290 CRL-2057 RIN-m 224
CRL-1970 l43-4-2 290 CRL-2058 RIN-5F 224
CRL-1971 83-I2-5 290 CRL-2059 RIN-14B 290
CRL-1972 M2-10B4 224 CRL-2060 PFSK-1 224
CRL-1973 NTERA-2 cl.D1 179 CRL-2061 SJRH 30 224
CRL-1974 COLO 829 290 CRL-2062 DMS 53 290
CRL-1975 145-2C11 224 CRL-2063 J.CaM1.6 224
CRL-1976 MES-SA 224 CRL-2064 DMS 153 290
CRL-1977 MES-SA/Dx5 224 CRL-2065 MLTC-1 224
CRL-1978 ES-2 224 CRL-2066 DMS 114 290
CRL-1980 COLO 8298BL 290 CRL-2067 MAb104 290
CRL-1981 M3WT4 290 CRL-2068 CCD-1056Sk 290
CRL-1982 M3WT5 290 CRL-2069 NFPE 290
CRL-1983 M3WT8 290 CRL-2070 NE 290
CRL-1984 M1WT2 290 CRL-2071 CCD-1058Sk 290
CRL-1985 M1WT3 290 CRL-2072 CCD-1059Sk 290
CRL-1986 M1WT5 290 CRL-2073 NCCIT 224
CRL-1988 UC3-10A6 290 CRL-2075 NF-1 290
CRL-1989 UC7-13D5 290 CRL-2076 CCD-1064Sk 290
CRL-1990 J45.01 224 CRL-2077 CCD-1065Sk 290
CRL-1991 T1(174x CEM.T1) 290 CRL-2078 HBE-E6/E7 290
CRL-1992 T2(174x CEM.T2) 224 CRL-2079 HBE4-E6/E7-C1 290
CRL-1993 HMy2.CIR 290 CRL-2081 MSTO-211H 290
CRL-1995 H2.35 224 CRL-2082 VCH-17 290
CRL-1996 KL295 290 CRL-2086 CCD-1068Sk 290
CRL-1997 HPAF-II 224 CRL-2087 vEPT 290
CRL-1999 T/G HA-VSMC 179 CRL-2088 CCD-1072Sk 290
CRL-2002 RT101 290 CRL-2089 CCD-1069Sk 290
CRL-2003 TF-1 179 CRL-2090 CCD-1074Sk 290
CRL-2005 DI TNC 224 CRL-2091 CCD-1070Sk 224
CRL-2006 CTX TNA2 290 CRL-2092 CHO-CD36 290
CRL-2007 JB6 Cl 30-7b 290 CRL-2093 CHO-ICAM-1 290
CRL-2010 JB6 Cl41-5a 290 CRL-2094 CCD-1077Sk 290
CRL-2012 T36274 290 CRL-2095 CAL 27 290
CRL-2013 GR-96 290 CRL-2096 CCD-1076Sk 290
CRL-2014 HGF-1 224 CRL-2097 CCD-1079Sk 290
CRL-2016 Sp2/mlL-6 290 CRL-2098 SJSA-1 290
CRL-2017 M.dunni(Clone III8C) 290 CRL-2099 KU812 224
CRL-2018 SV40LT-SMC Clone HEP-SA) 224 CRL-2100 KU812E 290
CRL-2019 MH-S 224 CRL-2101 KU812F 290
CRL-2020 DBTRG-05MG 224 CRL-2102 C2BBe1 179
CRL-2021 MEG-01 179 CRL-2103 CCD-1086SK 290
CRL-2024 GR-20 290 CRL-2104 CCD-1087Sk 290
CRL-2025 2D7F10 290 CRL-2105 HH 224
CRL-2026 Hepa-1c1c7 224 CRL-2106 CCD-1090Sk 290
CRL-2027 KL304 290 CRL-2107 bcd mab23 290
CRL-2028 SR-4987 290 CRL-2108 EHS 290
CRL-2029 WSS-1 290 CRL-2109 FAT 7 290
CRL-2030 KL277 290 CRL-2110 MLE 12 224
CRL-2031 anti -SC35 290 CRL-2111 DT40 224
CRL-2032 PG-4(S+L-) 224 CRL-2112 DT95 290
CRL-2033 G355-5 290 CRL-2113 E.G7-OVA 224
CRL-2034 10P2 290 CRL-2114 CCD-1092Sk 290
CRL-2036 10P12 290 CRL-2115 CCD-1093Sk 290
CRL-2037 11P0-1 290 CRL-2116 JC 290
CRL-2038 M-1 224 CRL-2117 LMH 290
CRL-2039 F1.652 290 CRL-2118 LMH/2A 290
CRL-2040 N1.551 290 CRL-2119 HPAC 224
CRL-2041 A4.74 290 CRL-2120 CCD-1094SK 290
CRL-2042 N3.36 290 CRL-2121 lgG-2A4 290
CRL-2043 A4.840 290 CRL-2122 CCD-1095Sk 290
CRL-2046 A4.951 290 CRL-2123 MlMCD-3 224
CRL-2124 CCD-1097Sk 290 CRL-2211 CCD-1100Sk 224
CRL-2127 CCD-1098Sk 290 CRL-2212 KMC8.8 290
CRL-2128 NCI-H29SR 290 CRL-2213 lgG-11H9 290
CRL-2129 CCD-1096Sk 290 CRL-2214 MEF-1 290
CRL-2130 DAN 290 CRL-2215 PEA 10 290
CRL-2131 DSDh 290 CRL-2216 PEA 13 290
CRL-2132 DSL-6A/C1 290 CRL-2217 BpRcl 290
CRL-2133 DSL-6B/C2 290 CRL-2218 tao BpRcl 290
CRL-2134 LS513 290 CRL-2220 CA-HPV-10 290
CRL-2135 TGP61 290 CRL-2221 PZ-HPV-7 224
CRL-2136 TGP49 290 CRL-2222 YPEN-1 224
CRL-2137 SK-N-AS 224 CRL-2223 1G10 290
CRL-2138 VA-ES-BJ 290 CRL-2224 lgG-1C6 290
CRL-2139 SK-PN-DW 290 CRL-2226 2D10 290
CRL-2140 TGP52 290 CRL-2227 AP.6 290
CRL-2141 TGP47 290 CRL-2228 X22 290
CRL-2142 SK-N-F1 224 CRL-2229 CON.1 290
CRL-2143 MC2/3 290 CRL-2230 BC-1 290
CRL-2147 ZEM2S 290 CRL-2231 BC-2 290
CRL-2148 WEHI-13VAR 179 CRL-2232 TD.1 290
CRL-2149 SK-N-DZ 224 CRL-2233 SNU-398 290
CRL-2150 TGP55 290 CRL-2234 SNU-449 290
CRL-2151 266-6 290 CRL-2235 SNU-182 290
CRL-2153 55-36 290 CRL-2236 SNU-475 290
CRL-2155 55-2. 290 CRL-2237 SNU-387 290
CRL-2156 55-6. 290 CRL-2238 SNU-423 290
CRL-2158 LS1034 290 CRL-2240 RPE-J 290
CRL-2159 LS411N 290 CRL-2241 pgsB-618 290
CRL-2160 3B-11 290 CRL-2242 pgsA-745 224
CRL-2161 SVEC4-10EHR1 290 CRL-2243 pgsB-650 290
CRL-2162 IP-1B 290 CRL-2244 pgsD-677 290
CRL-2163 2H-11 290 CRL-2245 pgsC-605 290
CRL-2167 SVEC4-10EE2 290 CRL-2246 pgsE-606 290
CRL-2168 2F-2B 290 CRL-2247 WU E-4 290
CRL-2169 SW 780 290 CRL-2248 B1B6 290
CRL-2170 SW 1573 290 CRL-2249 B1B3 290
CRL-2171 IP2-E4 290 CRL-2252 G-3-5 290
CRL-2172 SW1990 290 CRL-2253 J1-31 290
CRL-2173 FIGR 290 CRL-2254 AML12 179
CRL-2174 SoI8 290 CRL-2255 WU E-14 290
CRL-2175 SW 156 290 CRL-2256 RBL-2H3 179
CRL-2177 SW 1271 290 CRL-2257 HL-60/MX2 290
CRL-2178 46-4 290 CRL-2258 HL-60/MX1 290
CRL-2179 KM16 290 CRL-2260 HT 290
CRL-2180 L2-RYC 290 CRL-2261 RL 224
CRL-2181 SVEC4-10 224 CRL-2262 SR 290
CRL-2184 46-5 290 CRL-2263 NIE-115 179
CRL-2185 55-83 290 CRL-2264 CEM/C2 290
CRL-2186 46-2 290 CRL-2265 CEM/C1 290
CRL-2187 PA 317 cyclin E-L 290 CRL-2266 SH-SY5Y 179
CRL-2188 PA317 cyclin E-S 290 CRL-2267 BE(2)-M17 290
CRL-2189 WR21 290 CRL-2268 BE(2)-C 224
CRL-2190 HK-2 179 CRL-2270 MC-IXC 290
CRL-2192 NR8383 179 CRL-2271 SK-N-BE(2) 224
CRL-2193 As4.1 290 CRL-2273 CHP-212 290
CRL-2194 EH7a 290 CRL-2274 MES-SA/MX2 290
CRL-2195 SHP-77 290 CRL-2275 A5.4 290
CRL-2196 GC-2spd(ts) 290 CRL-2276 Dubca 290
CRL-2197 lgG-6A6 290 CRL-2277 BC-3 290
CRL-2198 lgG-7D4 290 CRL-2278 RAW 264.7rNO(-) 179
CRL-2199 C6/LacZ 290 CRL-2279 MS1 224
CRL-2200 9L/lacZ 290 CRL-2280 SVR 224
CRL-2201 CCD-1099Sk 290 CRL-2281 CCD-1101SK 290
CRL-2202 PA317 LXSN 290 CRL-2282 807.3l 290
CRL-2203 PA317 LXSN 16E6E7 290 CRL-2283 LA7 290
CRL-2204 PA317 LXSN 16E6 290 CRL-2284 3C5.1 290
CRL-2205 PA 317 LXSN 16E7 290 CRL-2285 Super Tube 290
CRL-2206 PA 317 LXSN 6E6 290 CRL-2286 Super Dome 290
CRL-2207 PA317 LXSN 6E7 290 CRL-2287 807.l5 290
CRL-2209 EH17a 290 CRL-2288 DAL K20 290
CRL-2210 Rat1-R12 290 CRL-2289 DB 290
CRL-2290 807.33 290 CRL-2374 J27-B7 290
CRL-2291 DAL K29 290 CRL-2375 AT3B-1 290
CRL-2292 DAL K45 290 CRL-2376 MAT-Ly-Lu-b-2 290
CRL-2294 BCP-1 290 CRL-2378.1 MA-104 Clone 1 224
CRL-2295 MC57G 290 CRL-2379 RmcB 290
CRL-2296 SJD.1 290 CRL-2381 JAA-F11 290
CRL-2298 AB.9 290 CRL-2382 20C2 290
CRL-2299 bEnd.3 179 CRL-2383 anti-SR 290
CRL-2300 RLE-6TN 290 CRL-2384 anti-SRp20 290
CRL-2301 SOB-15 290 CRL-2385 16h3 290
CRL-2302 ARPE-19 179 CRL-2386 SVR A 221a 290
CRL-2303 C6/lacZ7 290 CRL-2387 SVR bag4 290
CRL-2304 CCD 1103 KIDTr 290 CRL-2389 LTPA 290
CRL-2305 CCD 1105 KIDTr 290 CRL-2390 FL83B 290
CRL-2306 bl3.1 290 CRL-2392 GA-10 290
CRL-2307 MB16tsA,clone 1B5 290 CRL-2393 GA-10(Clone4) 290
CRL-2308 MB19tsA,clone 2B2 290 CRL-2394 GA-10(Clone 20) 290
CRL-2309 CCD 1106 KERTr 290 CRL-2395 803-15.6 290
CRL-2310 CCD 1102KERTr 290 CRL-2396 TK-1 290
CRL-2311 SML,clone 4D8 290 CRL-2397 F98 290
CRL-2312 OML,clone 13C 290 CRL-2398 BEND 290
CRL-2314 HCC38 290 CRL-2401 anti-130-kDaMesothelial-Ciliated Cells 290
CRL-2315 HCC70 290 CRL-2404 HEK001 290
CRL-2316 HCC202 290 CRL-2405 SH-34 290
CRL-2319 HCC1007BL 290 CRL-2406 PLHC-1 290
CRL-2320 HCC1008 390 CRL-2407 NK-92 179
CRL-2321 HCC1143 290 CRL-2408 NK-92MI 224
CRL-2322 HCC1187 290 CRL-2409 NK-92CI 290
CRL-2323 HCC1187 BL 290 CRL-2417 MYA-1 290
CRL-2324 HCC1395 224 CRL-2418 lgG-1B7 290
CRL-2325 HCC1395BL 290 CRL-2419 lgG-2F1 290
CRL-2326 HCC1419 290 CRL-2420 LADMAC 224
CRL-2327 HCC1428 290 CRL-2422 MDA Pca 2b 179
CRL-2328 HCC1428 BL 290 CRL-2423 PFHR 9 290
CRL-2329 HCC1500 224 CRL-2424 C305 290
CRL-2330 HCC1569 290 CRL-2429 CCD-1112Sk 224
CRL-2331 HCC1599 290 CRL-2430 10C7 290
CRL-2332 HCC1599BL 290 CRL-2431 15C6 290
CRL-2334 HCC1739BL 290 CRL-2433 RG2 290
CRL-2335 HCC1806 290 CRL-2434 1G3 290
CRL-2336 HCC1937 224 CRL-2435 2G3 290
CRL-2337 HCC1937BL 290 CRL-2437 4C9 290
CRL-2338 HCC1954 290 CRL-2438 CT6-1D7 290
CRL-2339 HCC1954BL 290 CRL-2439 CCD-1113Sk 290
CRL-2340 HCC2157 290 CRL-2440 3A5 290
CRL-2341 HCC2157BL 290 CRL-2441 LC3 290
CRL-2343 HCC2218 290 CRL-2442 2A11 290
CRL-2345 LK-4 290 CRL-2443 2B7 290
CRL-2346 HCC38 BL 290 CRL-2444 2A5 290
CRL-2347 lgG-9D5 290 CRL-2445 H36.12a 290
CRL-2348 xrs5 290 CRL-2446 H36.12b 290
CRL-2349 XR-V15B 290 CRL-2447 H36.12d 290
CRL-2350 αTCLClone 9 290 CRL-2448 H36.12e 290
CRL-2351 AU565 224 CRL-2449 H36.12j 290
CRL-2352 CCD 1108Sk 290 CRL-2450 CCD-1114Sk 290
CRL-2357 R2-9A5 290 CRL-2451 TF-1a 290
CRL-2358 R2-10F6 290 CRL-2452 SI/SI4 hsCF248 290
CRL-2359 HIL 12R1.2B10 290 CRL-2453 SI/SI4 hSCF220 290
CRL-2360 R1-5D9 290 CRL-2454 SI/SI4 hSCF248 290
CRL-2361 CCD-1109Sk 290 CRL-2455 AMJ2-C8 290
CRL-2362 HCC1143 BL 290 CRL-2456 AMJ2-C11 290
CRL-2363 HCC2218BL 290 CRL-2457 PMJ2-PC 290
CRL-2364 NIT-2 290 CRL-2458 PMJ2-R 290
CRL-2365 M059K 179 CRL-2459 SYF 224
CRL-2366 M059J 224 CRL-2460 MS1 VEGF 290
CRL-2367 TUR 224 CRL-2461 SV7tert 290
CRL-2368 293/CHE-Fc 290 CRL-2462 IE-10 290
CRL-2369 C1R-neo 290 CRL-2463 IE-3 290
CRL-2370 C1R-sB7 290 CRL-2564 M1.4 290
CRL-2371 C1R-B7 290 CRL-2465 CCD-1117Sk 290
CRL-2372 J27-neo 290 CRL-2466 CCD-1118Sk 290
CRL-2467 EOC2 290 CRL-2573 RMC 224
CRL-2468 EOC 13.31 290 CRL-2575 CCD-1129Sk 224
CRL-2469 EOC 20 290 CRL-2576 OLGA-PH-J/9 224
CRL-2470 1-11.15 290 CRL-2577 RKO 224
CRL-2471 1-13.35 290 CRL-2578 RKO-E6 224
CRL-2472 HAAE-1 224 CRL-2579 RKO-AS45-1 224
CRL-2473 HAAE-2 290 CRL-2580 MR1 224
CRL-2474 HFAE-2 290 CRL-2581 C166 224
CRL-2475 HIAE-78 290 CRL-2583 C166-GFP 224
CRL-2476 HIVE-78 290 CRL-2586 EOMA 224
CRL-2478 HIAE-101 290 CRL-2587 EOMA-GFP 224
CRL-2480 HUVE-12 290 CRL-2588 P-1 224
CRL-2481 HUVS-112D 290 CRL-2591 PI-11 224
CRL-2482 HIVS-125 290 CRL-2592 A431NS 224
CRL-2496 HS-27A 290 CRL-2593 MC3T3-E1 Subclone 4 224
CRL-2497 Src++ 290 CRL-2594 MC3T3-E1 Subclone 14 224
CRL-2498 SYF+C-Src 290 CRL-2595 MC3T3-E1 Subclone 24 224
CRL-2500 A7 290 CRL-2596 MC3T3 -E1 Subclone 30 224
CRL-2501 mAb BB7 290 CRL-2597 glomote 224
CRL-2502 ARPE-19/HPV-16 290 CRL-2598 HPAE-26 224
CRL-2503 NL20 290 CRL-2599 HIAE-38 224
CRL-2504 NL20-TA 290 CRL-2603 HIVE-26 224
CRL-2505 22Rv1 179 CRL-2605 HIVE-65 224
CRL-2506 HP75 224 CRL-2606 HIAE-65 224
CRL-2507 MARCS5 290 CRL-2607 HPVE-26 224
CRL-2508 MARC 29F8 290 CRL-2608 HIAE-55 224
CRL-2509 MARC 2B7 290 CRL-2609 HIVE-55 224
CRL-2510 CCD-1120Sk 290 CRL-2610 LN-18 224
CRL-2511 CCD-1121Sk 290 CRL-2611 LN-229 224
CRL-2512 TF-1.CN5a.1 290 CRL-2613 Cyt c-/- 224
CRL-2513 CCD-1122Sk 290 CRL-2614 Ect1/E6E7 224
CRL-2514 CL2 290 CRL-2615 End1/E6E7 224
CRL-2515 CL3 290 CRL-2616 VK2/E6E7 224
CRL-2516 CL37 290 CRL-2617 CCD-1131SK 224
CRL-2518 CL18/6 290 CRL-2618 15P-1 224
CRL-2522 BJ 179 CRL-2619 p53NiS1 224
CRL-2523 Rtgill-W1 290 CRL-2620 tsc2 ang1 224
CRL-2524 CCD-1123Sk 290 CRL-2622 CCD-1132SK 224
CRL-2526 H19-7/IGF-1R 290 CRL-2623 W-20-17 224
CRL-2527 XLK-WG 290 CRL-2627 GDM-1 224
CRL-2528 PT-K75 290 CRL-2629 Loucy 224
CRL-2529 CCD-1124Sk 290 CRL-2630 Farage 224
CRL-2531 Clone C 290 CRL-2631 Toledo 224
CRL-2532 QNR/D 290 CRL-2632 Pfeiffer 224
CRL-2533 QNR/K2 290 CRL-2633 5G5 224
CRL-2534 C8-D30 290 CRL-2634 B3D 224
CRL-2535 C8-S 290 CRL-2635 5E4. 224
CRL-2536 G1B 290 CRL-2638 CT26.WT 224
CRL-2538 4C5G 290 CRL-2639 CT26.CL25 224
CRL-2539 4T1 179 CRL-2640 MG38 224
CRL-2540 C8-B4 290 CRL-2643 ZFL 224
CRL-2541 C8-D1A 224 CRL-2644 FAK-/- 224
CRL-2542 56B3 290 CRL-2645 FAK+/+ 224
CRL-2543 Sal 290 CRL-2646 5H8 224
CRL-2545 lgG-1D2 290 CRL-2647 L Wnt-3A 179
CRL-2547 Panc 10.05 224 CRL-2648 LCells 224
CRL-2549 Panc 03.27 290 CRL-2649 142-24E5 224
CRL-2551 Panc 08.13 290 CRL-2650 146-03E04 224
CRL-2553 Panc 02.03 290 CRL-2651 203-7D10 224
CRL-2554 Panc 02.13 290 CRL-2653 413-15D12 224
CRL-2558 PL45 224 CRL-2654 147-67C6 224
CRL-2559 32B11 290 CRL-2655 20.3 224
CRL-2564 CCE-1126Sk 290 CRL-2656 310-29F7 224
CRL-2565 CCD-1127Sk 290 CRL-2657 311-3D4 224
CRL-2566 CCD-1128Sk 290 CRL-2658 312-13E8 224
CRL-2567 H1.6 290 CRL-2659 173-1C11 224
CRL-2568 H2.8 290 CRL-2660 172-12A4 224
CRL-2569 H3.1 290 CRL-2661 171-11B9 224
CRL-2570 A3 224 CRL-2663 411-14E10 224
CRL-2571 19.2 224 CRL-2667 260-33C4 224
CRL-2572 12.1 224 CRL-2669 202-11A8 224
CRL-2670 201-45E9 224 CRL-2796 CCD-1141Sk 224
CRL-2672 240-13D10 224 CRL-2827 1G12 224
CRL-2673 CCD-1134Sk 224 CRL-5800 HCI-H23 179
CRL-2674 GMMe[EPI] 224 CRL-5803 HCI-H1299 179
CRL-2675 GMMs{str} 224 CRL-5804 HCI-H187 224
CRL-2676 p116 224 CRL-5807 HCI-H358 224
CRL-2677 p116.c139 224 CRL-5808 HCI-H378 290
CRL-2678 J.γ1 224 CRL-5810 HCI-H522 224
CRL-2679 J.γ1.WT 224 CRL-5811 HCI-H526 224
CRL-2680 TSHRT5-51 224 CRL-5813 HCI-H660 290
CRL-2681 TSHR-R5T-44 224 CRL-5815 HCI-H727 290
CRL-2682 TSHR-T5U-317 224 CRL-5816 HCI-H810 290
CRL-2683 TSHR-R5T-34 224 CRL-5817 HCI-H889 290
CRL-2684 TSHR-T3-365 224 CRL-5818 HCI-H1155 290
CRL-2685 LHR-29 224 CRL-5819 HCI-H1404 290
CRL-2686 LHR-74 224 CRL-5820 HCI-H28 290
CRL-2687 LHR-1055 224 CRL-5822 HCI-H87 224
CRL-2688 FSHR-18 224 CRL-5823 HCI-H196 290
CRL-2689 FSHR-323 224 CRL-5824 HCI-H211 290
CRL-2690 EGC/PK060399egfr 224 CRL-5825 HCI-H220 290
CRL-2691 CCD-1135SK 224 CRL-5826 HCI-H226 224
CRL-2692 Het-1a 224 CRL-5828 HCI-H250 290
CRL-2693 lgG-3B2 224 CRL-5831 NCI-H524 290
CRL-2695 4l-2 224 CRL-5833 NCI-H630 290
CRL-2696 50- 224 CRL-5834 NCI-H647 290
CRL-2697 CCD-1136SK 224 CRL-5835 NCI-H650 290
CRL-2699 GSML 224 CRL-5836 NCI-H711 390
CRL-2700 L1-Hybridoma 224 CRL-5837 NCI-H719 390
CRL-2701 D24 224 CRL-5838 NCI-H720 290
CRL-2702 5A1 224 CRL-5840 NCI-H740 290
CRL-2703 CCD-1137SK 224 CRL-5841 NCI-H748 390
CRL-2704 C13589 224 CRL-5842 NCI-H774 290
CRL-2706 THLE-2 224 CRL-5843 NCI-H835 290
CRL-2707 CCD-1138SK 224 CRL-5844 NCI-H838 290
CRL-2708 CCD-1139SK 224 CRL-5845 NCI-H841 290
CRL-2709 mh 224 CRL-5846 NCI-H847 290
CRL-2710 c12(B15ECiii2) 224 CRL-5849 NCI-H865 290
CRL-2711 c37(B71Fil) 224 CRL-5850 NCI-H920 290
CRL-2712 vT{2} 224 CRL-5852 NCI-H969 290
CRL-2713 MDA-kb2 224 CRL-5853 NCI-H1048 290
CRL-2714 CCD-1140Sk 224 CRL-5855 NCI-H1092 290
CRL-2715 c35(B16GBil c3) 224 CRL-5856 NCI-H1105 290
CRL-2716 cl(B6NLxv1c2) 224 CRL-5858 NCI-H1184 290
CRL-2717 c4(B13NBiil) 224 CRL-5859 NCI-H1238 290
CRL-2724 Kasumi-1 224 CRL-5861 NCI-H1284 290
CRL-2725 Kasumi-3 224 CRL-5862 NCI-H1304 290
CRL-2730 TRAMP-C1 224 CRL-5864 NCI-H1341 290
CRL-2731 TRAMP-C2 224 CRL-5865 NCI-H1355 290
CRL-2732 TRAMP-C3 224 CRL-5866 NCI-H1373 290
CRL-2733 F19 224 CRL-5867 NCI-H1385 290
CRL-2737 132-1C8 224 CRL-5868 NCI-H1395 290
CRL-2738 133-10F6 224 CRL-5869 NCI-H1417 290
CRL-2739 131-94H4 224 CRL-5870 NCI-H1435 290
CRL-2742 1A6 224 CRL-5871 NCI-H1436 290
CRL-2743 6A8.6F10.1A6 224 CRL-5872 NCI-H1437 290
CRL-2744 4C2.4A7.5H11 224 CRL-5874 NCI-H1522 390
CRL-2746 2C1H7 224 CRL-5875 NCI-H1563 290
CRL-2747 ASK 224 CRL-5876 NCI-H1568 290
CRL-2749 OP9 224 CRL-5877 NCI-H1573 290
CRL-2750 PHL 224 CRL-5878 NCI-H1581 290
CRL-2751 23ScCr 224 CRL-5879 NCI-H1618 290
CRL-2754 B35 224 CRL-5881 NCI-H1623 290
CRL-2755 EMT6 224 CRL-5882 NCI-H1648 290
CRL-2756 1G8 224 CRL-5883 NCI-H1650 290
CRL-2757 3B11 224 CRL-5884 NCI-H1651 290
CRL-2758 28S.3 224 CRL-5885 NCI-H1666 290
CRL-2761 BSC40 224 CRL-5886 NCI-H1672 290
CRL-2762 SQMK-FP 224 CRL-5887 NCI-H1693 290
CRL-2769 FSC-1 224 CRL-5888 NCI-H1694 290
CRL-2772 CCO 224 CRL-5889 NCI-H1703 290
CRL-2780 ATRFLOX 224 CRL-5891 NCI-H1734 290
CRL-5892 NCI-H1755 290 CRL-5971 SNU-1 290
CRL-5893 NCI-H1770 290 CRL-5972 SNU-C1 290
CRL-5894 NCI-H1781 290 CRL-5973 SNU-5 290
CRL-5895 NCI-H1792 290 CRL-5974 SNU-16 290
CRL-5896 NCI-H1793 290 CRL-5975 UMC-11 290
CRL-5897 NCI-H1819 290 CRL-5978 NCI-H735 290
CRL-5898 NCI-H1836 290 CRL-5982 NCI-H1963 290
CRL-5899 NCI-H1838 290 CRL-5983 NCI-H2107 390
CRL-5900 NCI-H1869 290 CRL-5984 NCI-H2018 390
CRL-5901 NCI-H1870 290 CRL-5985 NCI-H2122 390
CRL-5902 NCI-H1876 290 CRL-6001 TAM.T 390
CRL-5903 NCI-H1882 290 CRL-6009 DFNI.Tr 390
CRL-5904 NCI-H1915 290 CRL-6012 Mvi/IT 390
CRL-5905 NCI-H1926 290 CRL-6016 BBm 390
CRL-5906 NCI-H1930 290 CRL-6017 BLn 390
CRL-5907 NCI-H1944 290 CRL-6019 BSp 390
CRL-5908 NCI-H1975 290 CRL-6020 BThy 390
CRL-5909 NCI-H1993 290 CRL-6022 B2.Ln 390
CRL-5910 NCI-H1994 290 CRL-6023 B2.Sp 390
CRL-5911 NCI-H2009 290 CRL-6024 B2.Sp/Thy 390
CRL-5912 NCI-H2023 290 CRL-6033 FB2.K 390
CRL-5913 NCI-H2029 290 CRL-6034 FB2.Ln 390
CRL-5914 NCI-H2030 290 CRL-6036 FB2.Thy 390
CRL-5915 NCI-H2052 290 CRL-6038 FB3.Ln 390
CRL-5916 NCI-H2059 290 CRL-6039 FB3.Thy 390
CRL-5917 NCI-H2066 290 CRL-6041 FB4.Ln 390
CRL-5918 NCI-H2073 290 CRL-6042 FB4.SP/Thy 390
CRL-5920 NCI-H2081 290 CRL-6043 FB5.Bm 390
CRL-5921 NCI-H2085 290 CRL-6044 FB5.Ln 390
CRL-5922 NCI-H2087 290 CRL-6045 FB10.Ln 390
CRL-5923 NCI-H2106 290 CRL-6046 LBLN 390
CRL-5924 NCI-H2110 290 CRL-6047 2LBLN 390
CRL-5926 NCI-H2135 290 CRL-6048 3LBLN 390
CRL-5927 NCI-H2141 290 CRL-6049 5LBLN 390
CRL-5928 NCI-H2170 290 CRL-6050 6LBLN 390
CRL-5929 NCI-H2171 290 CRL-6052 LB9.Sp/Thy/Bm 390
CRL-5930 NCI-H2172 290 CRL-6053 LB9.Bm 390
CRL-5931 NCI-H2195 290 CRL-6054 LB9.D 390
CRL-5932 NCI-H2196 290 CRL-6057 LB9.Ln 390
CRL-5933 NCI-H2198 290 CRL-6058 LB9.Sp 390
CRL-5934 NCI-H2227 290 CRL-6059 LB9.Thy 390
CRL-5935 NCI-H2228 290 CRL-6060 LB10Bm 390
CRL-5938 NCI-H2286 290 CRL-6061 LB10.K 390
CRL-5939 NCI-H2291 290 CRL-6062 LB10.Ln 390
CRL-5940 NCI-H2330 290 CRL-6063 LB10.Sp 390
CRL-5941 NCI-H2342 290 CRL-6064 LB10.Thy 390
CRL-5942 NCI-H2347 290 CRL-6066 LB11.Ln 390
CRL-5944 NCI-H2405 290 CRL-6067 LB11.Sp 390
CRL-5945 NCI-H2444 290 CRL-6068 LB11.Thy 390
CRL-5946 NCI-H2452 290 CRL-6069 MBC(5) 390
CRL-5947 NCI-BL128 290 CRL-6070 R2LBLN 390
CRL-5948 NCI-BL209 290 CRL-6074 F8 390
CRL-5949 NCI-BL1184 290 CRL-6078 FC5.K 390
CRL-5950 NCI-BL1339 290 CRL-6081 FC6.Bm 390
CRL-5951 NCI-BL1450 290 CRL-6082 FC6.K 390
CRL-5952 NCI-BL1514 290 CRL-6088 FC11.BM 390
CRL-5953 NCI-BL1607 290 CRL-6094 FC47 390
CRL-5955 NCI-BL2141 290 CRL-6098 FC60(B).We 390
CRL-5956 NCI-BL2195 290 CRL-6099 FC61 390
CRL-5957 NCI-BL1395 290 CRL-6102 FC70.We 390
CRL-5958 NCI-BL1437 290 CRL-6105 FC77.T 390
CRL-5959 NCI-BL1672 290 CRL-6106 FC79.We 390
CRL-5960 NCI-BL1770 290 CRL-6107 FC81.Sp 390
CRL-5961 NCI-BL2009 290 CRL-6108 FC81.T 390
CRL-5962 NCI-BL2028 290 CRL-6109 FC81.Thy 390
CRL-5963 NCI-BL2052 290 CRL-6110 FC83.Sp 390
CRL-5965 NCI-BL2087 290 CRL-6113 FC94.T 390
CRL-5966 NCI-BL2107 290 CRL-6114 FC95.Thy 390
CRL-5967 NCI-BL2122 290 CRL-6115 FC100.T 390
CRL-5969 NCI-BL2171 290 CRL-6116 FC100.Sp 390
CRL-5970 NCI-BL2347 290 CRL-6117 FC100.Ln 390
CRL-6118 FC101 390 CRL-6274 HJ1.Ov 390
CRL-6119 FC102 390 CRL-6277 HJ2.Lu 390
CRL-6120 FC112 390 CRL-6295 A.P. 390
CRL-6121 FC113 390 CRL-6399 CMMT 390
CRL-6122 FC115.K 390 CRL-6300 CMMT 110/C1 390
CRL-6124 FC118 390 CRL-6309 MT1.K 390
CRL-6125 FC119 390 CRL-6319 A-9 390
CRL-6126 FC2.K 390 CRL-6320 AKR/JA.Sp 390
CRL-6130 FC28.Lu 390 CRL-6322 B16-F0 224
CRL-6134 FC56.Thy 390 CRL-6323 B16-F1 179
CRL-6136 FC57.Thy 390 CRL-6327 B/C3T3.We 390
CRL-6137 FC58.Thy 390 CRL-6331 B/CMBA.Ov 390
CRL-6139 FC59.Thy 390 CRL-6334 B/CWE 390
CRL-6140 FC60A.We 390 CRL-6336 C57L/J.We 390
CRL-6141 FC60B.We 390 CRL-6338 CFZT(A) 390
CRL-6143 FC63.Res 390 CRL-6339 CFZT(B) 390
CRL-6145 FC71A.We 390 CRL-6340 DBAC.Sp 290
CRL-6150 FC87.Sk 390 CRL-6342 DBAC.Sp 390
CRL-6152 FC104.We 390 CRL-6345 DV68F 390
CRL-6154 FC106.We 390 CRL-6347 HR/+A.Sp 390
CRL-6155 FC107.We 390 CRL-6348 HR/+B.Sp 390
CRL-6156 FC108.We 390 CRL-6349 HR/+C.Sp 390
CRL-6157 FC109.We 390 CRL-6350 HR/+D.Sp 390
CRL-6158 FC110.We 390 CRL-6351 HR/+E.Sp 390
CRL-6167 FC114E.Tr 390 CRL-6352 HR/+F.Sp 390
CRL-6168 F1B 390 CRL-6353 HR/+G.Sp 390
CRL-6170 FNS 390 CRL-6354 HR/HR1.Sp 390
CRL-6171 FO-4 390 CRL-6355 HR/HR2.Sp 390
CRL-6173 LFC16.Ln 390 CRL-6356 HR/HR3.Sp 390
CRL-6174 FC16.Sp 390 CRL-6357 hr/hr(WE)A 390
CRL-6175 NEF26.Ov 390 CRL-6358 hr/hr(WE)B 390
CRL-6176 NEF36.Sg 390 CRL-6359 JLS-V5 390
CRL-6178 OSU1 390 CRL-6360 JLS-V9 390
CRL-6180 Gd1T 390 CRL-6361 K:Molv NIH/3T3 290
CRL-6181 Gd1WE 390 CRL-6370 MBA C57.We 390
CRL-6182 RGDd2WE 390 CRL-6371 ME 390
CRL-6183 RGDd3WE 390 CRL-6373 MM2MT 390
CRL-6184 RGDd4WE 390 CRL-6374 MM2MTC 390
CRL-6185 RGDd5WE 390 CRL-6375 MM2SCT 390
CRL-6190 RFGd10WE 390 CRL-6376 MM3MG 290
CRL-6191 RFGd11WE 390 CRL-6377 MM4.We 390
CRL-6192 RFGd12WE 390 CRL-6378 MM5MTC 390
CRL-6193 OHH1.k 390 CRL-6379 MM5MTM 390
CRL-6194 OHH1.Li 390 CRL-6380 MM5.1 390
CRL-6195 OHH1.Lu 390 CRL-6381 MM7-11.Sp 390
CRL-6211 CF8.Thy 390 CRL-6382 MM14.Lu 390
CRL-6217 CF11.T 390 CRL-6383 MM14.Ov 390
CRL-6219 CF17.T 390 CRL-6384 MM14.OT 390
CRL-6220 CF21.T 290 CRL-6388 MM15.Sp/Thy 390
CRL-6221 CF24.T 390 CRL-6390 MM16.Ov 390
CRL-6223 CF28 390 CRL-6396 MM19.Lu 390
CRL-6225 CF30.Mg 390 CRL-6400 MM22.We 390
CRL-6227 CF33.MT 390 CRL-6401 MM23.We 390
CRL-6228 CF34.Mg 390 CRL-6402 MM27.We 390
CRL-6229 CF35.Mg 390 CRL-6403 MM29.We 390
CRL-6230 CF37.Mg 390 CRL-6405 MM31.We 390
CRL-6231 CF38.Mg 390 CRL-6408 MM34.We 390
CRL-6232 CF41.Mg 290 CRL-6411 MM36T(C.) 390
CRL-6234 CF43.Mg 390 CRL-6413 MM36We 390
CRL-6235 CF44.Mg 390 CRL-6414 MM37T 390
CRL-6237 CF45B.Mg 390 CRL-6416 MM41We 390
CRL-6238 CF46.Tr 390 CRL-6418 MM43T 390
CRL-6239 CF47.Mg 390 CRL-6419 MM44.Sp 390
CRL-6240 CF48.Mg 390 CRL-6420 MM45T.BI 390
CRL-6241 CF49.Mg 390 CRL-6421 MM45T.Li 390
CRL-6244 CF52.Tr 390 CRL-6422 MM45T.Sp 390
CRL-6245 CLN 390 CRL-6423 MM46T 390
CRL-6247 DK 390 CRL-6424 MM47T 390
CRL-6248 D17 390 CRL-6425 MM48T 390
CRL-6250 D22 390 CRL-6426 MM49T 390
CRL-6270 Ch2.D 390 CRL-6427 MM51.Sp 390
CRL-6428 MM52.Sp 390 CRL-7003 Hs2.We 390
CRL-6429 MM52.T 390 CRL-7005 Hs3.T 390
CRL-6430 MM53.Sp 390 CRL-7006 Hs3.Sk 390
CRL-6433 MM54.K 390 CRL-7011 Hs13.Sk 390
CRL-6434 MM54.Sp/Thy 390 CRL-7014 Hs18.Fs 390
CRL-6436 MM55.K 390 CRL-7015 Hs21.Fs 390
CRL-6437 MM55.Sp/Thy 390 CRL-7016 Hs24.FS 390
CRL-6438 MM15OT 390 CRL-7023 Hs39.T 390
CRL-6440 Mouse 390 CRL-7024 Hs44.Fs 390
CRL-6444 MM5/C1 390 CRL-7025 Hs45.Fs 390
CRL-6447 NMu3Li 290 CRL-7026 Hs46.Fs 390
CRL-6449 RIIIMT 390 CRL-7027 Hs48.Fs 390
CRL-6450 SC-1 390 CRL-7028 Hs49.Fs 390
CRL-6452 SJL/JB 390 CRL-7030 Hs51.T 390
CRL-6453 SJL/JC 390 CRL-7031 Hs52.sk 390
CRL-6458 SWR/J.We 390 CRL-7032 Hs52.Th 390
CRL-6460 UC1BC1 390 CRL-7033 Hs53.T 390
CRL-6461 UC1BC2 390 CRL-7035 Hs55.Fs 390
CRL-6462 UC1BC3 390 CRL-7036 Hs56.Fs 390
CRL-6463 UC1BC4 390 CRL-7037 Hs57.T 390
CRL-6464 UC1BC5 390 CRL-7038 Hs58.Fs 390
CRL-6465 UC18 390 CRL-7040 Hs60.Fs 390
CRL-6466 WM1043 390 CRL-7041 Hs61.Fs 390
CRL-6467 .+/+Li 390 CRL-7042 Hs62.Fs 390
CRL-6468 .+/+MGT 390 CRL-7043 Hs63.T 390
CRL-6469 .+/+SCT 390 CRL-7047 Hs69.Fs 390
CRL-6470 .+/+(A) 390 CRL-7048 Hs70.Fs 390
CRL-6471 .+/+(B) 390 CRL-7049 Hs72.Fs 390
CRL-6475 B16-F10 179 CRL-7055 Hs77.Fs 390
CRL-6476 12-A-3 390 CRL-7058 Hs80.Fs 390
CRL-6485 MU14.K 390 CRL-7059 Hs86.Fs 390
CRL-6488 Peccary.K 390 CRL-7060 Hs88.T 390
CRL-6489 PK13 390 CRL-7062 Hs93.T 390
CRL-6490 PK(D1) 390 CRL-7064 Hs94.Fs 390
CRL-6492 PK-2a/CL 13 390 CRL-7065 Hs97.Fs 390
CRL-6493 PtK1 290 CRL-7068 Hs103.Sp/Th 390
CRL-6496 CTPS 390 CRL-7070 Hs104.Sp/Th 390
CRL-6497 DRS 390 CRL-7074 Hs112.Sk 390
CRL-6502 Sf1Ep 390 CRL-7077 Hs115.Lu 390
CRL-6504 VX7 290 CRL-7081 Hs127.T 390
CRL-6506 AL/N 390 CRL-7085 Hs132.T 390
CRL-6507 AVE-115 390 CRL-7087 Hs137.Fs 390
CRL-6509 NRK 224 CRL-7090 Hs142.Sp 390
CRL-6510 RATV-NRK 390 CRL-7091 Hs142.Th 390
CRL-6511 Rn3T 390 CRL-7092 Hs143.We 390
CRL-6512 Rn4T 390 CRL-7093 Hs144.We 390
CRL-6513 Rn 5TES 390 CRL-7098 Hs154.Fs 390
CRL-6514 T-AL/N 390 CRL-7102 Hs156.T 390
CRL-6515 OVE-10 390 CRL-7118 Hs165.Fs 390
CRL-6538 OA1 390 CRL-7122 Hs168.Fs 390
CRL-6546 OA3.Ts 390 CRL-7123 Hs173.Sp 390
CRL-6547 OA4.Bm 290 CRL-7124 Hs174.We 390
CRL-6549 OA4.K/S1 290 CRL-7129 Hs181.Sk 390
CRL-6564 Tb1.Lu 390 CRL-7131 Hs181.Tes 390
CRL-6566 F25 390 CRL-7133 Hs184.Sp 390
CRL-6567 FC83.Res 390 CRL-7134 Hs184.T 390
CRL-6569 FC2.Lu 390 CRL-7138 Hs186.sk 390
CRL-6571 FC60(A).We 390 CRL-7140 Hs188.T 390
CRL-6575 CF3.Th 390 CRL-7145 Hs190.T 390
CRL-6581 Ch1.Es 390 CRL-7148 Hs193.Sp 390
CRL-6583 Horse 390 CRL-7150 Hs195.T 390
CRL-6589 HPME 390 CRL-7156 Hs198.Tom 390
CRL-6590 MM5MT 390 CRL-7159 Hs200.T 390
CRL-6598 Rn1T 390 CRL-7161 Hs201.Sk 390
CRL-6599 Rn2T 390 CRL-7162 Hs202.Sp 390
CRL-6600 Rn2Nod 390 CRL-7163 Hs202.Th 390
CRL-6601 Rn6T 390 CRL-7164 Hs203.Sp 390
CRL-6602 SMT/2A LNM 390 CRL-7165 Hs203.Th 390
CRL-7000 Hs1.Lu 390 CRL-7166 Hs204.Sp 390
CRL-7001 Hs1.Sk/Mu 390 CRL-7168 Hs207.T 390
CRL-7002 Hs1.Tes 390 CRL-7169 Hs208.Sp 390
CRL-7170 Hs208.Th 390 CRL-7306 Hs505.T 390
CRL-7171 Hs209.Sp 390 CRL-7307 Hs507.Sk 390
CRL-7173 Hs212.m 390 CRL-7311 Hs517.Sk 390
CRL-7175 Hs215.Ln 390 CRL-7313 Hs518.T 390
CRL-7176 Hs215.Sp 390 CRL-7314 Hs523.Sk; 390
CRL-7177 Hs215.Th 390 CRL-7315 Hs531.SK 390
CRL-7178 Hs216.We 390 CRL-7316 Hs540.T 390
CRL-7180 Hs218.Lu 390 CRL-7317 Hs544.Sk 390
CRL-7184 Hs219.T 390 CRL-7318 Hs545.Sk 390
CRL-7187 Hs221.Sp 390 CRL-7320 Hs548.Sk 390
CRL-7188 Hs221.Th 390 CRL-7321 Hs556.Sk 390
CRL-7189 Hs222.Sp 390 CRL-7323 Hs559.Sk 390
CRL-7191 Hs225.Th 390 CRL-7329 Hs564(E).Mg 390
CRL-7193 Hs228.T 390 CRL-7330 Hs565(A).Mg 390
CRL-7194 Hs229.T 390 CRL-7333 Hs565(D).Mg 390
CRL-7195 Hs230.Th 390 CRL-7336 Hs566(b).T 390
CRL-7196 Hs230.Sp 390 CRL-7340 Hs568.We 390
CRL-7197 Hs232.Th 390 CRL-7343 Hs573.T 390
CRL-7198 Hs232.Sp 390 CRL-7344 Hs573.Lu 390
CRL-7200 Hs234.Th 390 CRL-7345 Hs574.T 390
CRL-7201 Hs235.Sk 390 CRL-7346 Hs574.Sk 390
CRL-7203 Hs238.Sk 390 CRL-7347 Hs579.Mg 390
CRL-7213 Hs255.T 390 CRL-7352 Hs587.lnt 390
CRL-7214 Hs257.T 390 CRL-7353 Hs590.We 390
CRL-7218 Hs268.T 390 CRL-7358 Hs598.Af 390
CRL-7222 Hs274.T 390 CRL-7360 Hs600.T 390
CRL-7223 Hs275.Sk 390 CRL-7362 Hs604.T 390
CRL-7225 Hs277.T 390 CRL-7364 Hs605.Sk 390
CRL-7226 Hs280.T 390 CRL-7365 Hs605.T 390
CRL-7227 Hs281.T 390 CRL-7367 Hs606.Sk 390
CRL-7228 Hs284.Pe 390 CRL-7368 Hs606. 390
CRL-7232 Hs295.Sk 390 CRL-7372 Hs610.Sk 390
CRL-7233 Hs295.T 390 CRL-7373 Hs611.T 390
CRL-7235 Hs313.T 390 CRL-7375 Hs613.Sk 390
CRL-7236 Hs319.T 390 CRL-7378 Hs616.T 390
CRL-7239 Hs324.T 390 CRL-7379 Hs617.Mg 390
CRL-7240 Hs325.Ln 390 CRL-7380 Hs618.T 390
CRL-7242 Hs329.T 390 CRL-7383 Hs621.Sk 390
CRL-7245 Hs343.T 390 CRL-7385 Hs622.Sk 390
CRL-7246 Hs344.T 390 CRL-7397 Hs674.Sk 390
CRL-7248 Hs350.T 390 CRL-7400 Hs675.T 390
CRL-7252 Hs357.T 390 CRL-7406 Hs677.Sk 390
CRL-7253 Hs362.T 390 CRL-7408 Hs677.Tg 390
CRL-7254 Hs364.Ct 390 CRL-7418 Hs680.Rec 390
CRL-7255 Hs365.Ct 390 CRL-7419 Hs680.Sk 390
CRL-7256 Hs371.T 390 CRL-7421 Hs680.Tg 390
CRL-7257 Hs372.Sk 390 CRL-7422 Hs680.Tr 390
CRL-7263 Hs387.T 390 CRL-7424 Hs687.Sk 390
CRL-7265 Hs389(A).Lu 390 CRL-7425 Hs688(A).T 390
CRL-7266 Hs389(B).LU 390 CRL-7426 Hs688(B).T 390
CRL-7267 Hs391.We 390 CRL-7428 Hs692(A).T 390
CRL-7268 Hs392.Sk 390 CRL-7431 Hs696.Sk 390
CRL-7269 Hs394.Lu 390 CRL-7433 Hs697.Sp 390
CRL-7270 Hs394.Sk 390 CRL-7434 Hs697.Ln 390
CRL-7271 Hs395.We 390 CRL-7435 Hs698.T 390
CRL-7272 Hs397.Lu 390 CRL-7439 Hs700.Sk 390
CRL-7274 Hs399.Li 390 CRL-7440 Hs701.T 390
CRL-7275 Hs401.Lu 390 CRL-7443 Hs704.sk 390
CRL-7276 Hs402.Sk 390 CRL-7444 Hs704.T 390
CRL-7278 Hs404.Sk 390 CRL-7446 Hs706.sk 390
CRL-7279 Hs405.Sk 390 CRL-7447 Hs706.T 390
CRL-7281 Hs409.We 390 CRL-7448 Hs707(A).T 390
CRL-7282 Hs410.We 390 CRL-7449 Hs707(B).Ep 390
CRL-7285 Hs412.Lu 390 CRL-7452 Hs709.Sk 390
CRL-7286 Hs413.We 390 CRL-7453 Hs709.T 390
CRL-7287 Hs414.T 390 CRL-7456 Hs722.T 390
CRL-7288 Hs415.Sk 390 CRL-7460 Hs726.PI 390
CRL-7289 Hs416.T 390 CRL-7462 Hs728.Sk/Mu 390
CRL-7291 Hs417.Lu 390 CRL-7463 Hs728.Sp 390
CRL-7299 Hs432.T 390 CRL-7464 Hs730.pl 390
CRL-7300 Hs443.T 390 CRL-7465 Hs731.Sk 390
CRL-7469 Hs733.sk 390 CRL-7594 Hs859.T 390
CRL-7470 Hs734.sk 390 CRL-7595 Hs860.T 390
CRL-7471 Hs735.T 390 CRL-7596 Hs861.T 390
CRL-7473 Hs737.T 390 CRL-7598 Hs863.T 390
CRL-7476 Hs739.sk 390 CRL-7599 Hs864.Sk 390
CRL-7477 Hs739.T 390 CRL-7600 Hs864.T 390
CRL-7478 Hs740.sk 390 CRL-7601 Hs865.Sk 390
CRL-7479 Hs741.Sk 390 CRL-7602 Hs866.T 390
CRL-7480 Hs741.T 390 CRL-7603 Hs867.SK 390
CRL-7481 Hs742.sk 390 CRL-7604 Hs868.T 390
CRL-7482 Hs742.T 390 CRL-7606 Hs870.T 390
CRL-7486 Hs924.SK 390 CRL-7608 Hs871.Sk 390
CRL-7487 Hs925.Sk 390 CRL-7609 Hs871.T 390
CRL-7488 Hs925.T 390 CRL-7610 Hs873.T 390
CRL-7489 Hs926.T 390 CRL-7611 Hs874.T 390
CRL-7490 Hs929.Sk 390 CRL-7612 Hs875.T 390
CRL-7492 Hs933.T 390 CRL-7613 Hs877.T 390
CRL-7494 Hs764.Mu 390 CRL-7615 Hs879(B).T 390
CRL-7502 Hs774.Pl 390 CRL-7616 Hs880.T 390
CRL-7507 Hs777.T 390 CRL-7617 Hs883.T 390
CRL-7508 Hs778(A).T 390 CRL-7618 Hs885.T 390
CRL-7509 Hs778(B).T 390 CRL-7622 Hs888.T 390
CRL-7510 Hs781.SK 390 CRL-7623 Hs888.Sk 390
CRL-7511 Hs781.T 390 CRL-7624 Hs888.Lu 390
CRL-7512 Hs782.T 390 CRL-7625 Hs889.Sk 390
CRL-7513 Hs782.Sk 390 CRL-7626 Hs889.T 390
CRL-7516 Hs788.Sk 390 CRL-7627 Hs890.Sk 390
CRL-7518 Hs789.Sk 390 CRL-7628 Hs890.T 390
CRL-7519 Hs791.Sk 390 CRL-7629 Hs891.T 390
CRL-7520 Hs792(A).T 390 CRL-7630 Hs892.T 390
CRL-7521 Hs792(B).T 390 CRL-7631 Hs894(A).T 390
CRL-7522 Hs792(c).m 390 CRL-7632 Hs894(B).T 390
CRL-7523 Hs793.Sk 390 CRL-7633 Hs894©.T 390
CRL-7524 Hs793.T 390 CRL-7634 Hs894(D).T 390
CRL-7526 Hs795.pl 390 CRL-7635 Hs894(E).Lu 390
CRL-7529 Hs798.Pl 390 CRL-7636 Hs895.Sk 390
CRL-7530 Hs799.pl 390 CRL-7637 Hs895.T 390
CRL-7533 Hs803.Sk 390 CRL-7640 Hs898.Sk 390
CRL-7534 Hs803.T 390 CRL-7641 Hs898.T 390
CRL-7537 Hs805.T 390 CRL-7642 Hs899(A).T 390
CRL-7543 Hs811.T 390 CRL-7643 Hs899(B).T 390
CRL-7545 Hs813.Sk 390 CRL-7644 Hs899(C).T 390
CRL-7546 Hs814.Sk 390 CRL-7645 Hs899(D).Lu 390
CRL-7547 Hs814.T 390 CRL-7646 Hs900.T 390
CRL-7548 Hs815.pl 390 CRL-7648 Hs903.Sk 390
CRL-7551 Hs820.Sk 390 CRL-7649 Hs903.T 390
CRL-7552 Hs820.T 390 CRL-7650 Hs904.Sk 390
CRL-7553 Hs821.Sk 390 CRL-7651 Hs904.T 390
CRL-7554 Hs821.T 390 CRL-7652 Hs905.T 390
CRL-7556 Hs822.T 390 CRL-7653 Hs906(A).T 390
CRL-7558 Hs824.Sk 390 CRL-7654 Hs906(B).T 390
CRL-7564 Hs828.Sk 390 CRL-7657 Hs907.Lu 390
CRL-7566 Hs832(C.).T 390 CRL-7658 Hs908.Sk 390
CRL-7567 Hs833(C.).Sk 390 CRL-7660 Hs910.Thm 390
CRL-7568 Hs834.T 390 CRL-7661 Hs912.T 390
CRL-7569 Hs835.T 390 CRL-7664 Hs913(B).T 390
CRL-7570 Hs836.Sk 390 CRL-7665 Hs913(C).T 390
CRL-7572 Hs839.T 390 CRL-7666 Hs913(D).T 390
CRL-7573 Hs840.T 390 CRL-7668 Hs913(F).T 390
CRL-7574 Hs841.T 390 CRL-7669 Hs917.T 390
CRL-7576 Hs844.Sk 390 CRL-7671 Hs919.Sk 390
CRL-7577 Hs845.T 390 CRL-7672 Hs919.T 390
CRL-7578 Hs846.Sk 390 CRL-7674 Hs924.Sk 390
CRL-7579 Hs846.T 390 CRL-7676 Hs925.Sk 390
CRL-7583 Hs849.T 390 CRL-7677 Hs925.T 390
CRL-7584 Hs851.T 390 CRL-7678 Hs926.T 390
CRL-7585 Hs852.T 390 CRL-7681 Hs929.Sk 390
CRL-7589 Hs854.Sk 390 CRL-7683 Hs933.T 390
CRL-7591 Hs855.SK 390 CRL-7684 Hs934.T 390
CRL-7592 Hs855.T 390 CRL-7685 Hs935.T 390
CRL-7593 Hs856.T 390 CRL-7686 Hs936.T 390
CRL-7687 Hs939.T 390 CRL-7855 Hs695.Sk 390
CRL-7688 Hs940.T 390 CRL-7862 Hs729.T 390
CRL-7690 Hs941.T 390 CRL-7868 Hs738.Lu 390
CRL-7691 HS944.T 390 CRL-7869 Hs738.St/Int 390
CRL-7692 HF282.Sp 390 CRL-7870 Hs740.T 390
CRL-7693 HF322.Sk 390 CRL-7882 Hs769.T 390
CRL-7701 HF333.We 390 CRL-7886 Hs789.T 390
CRL-7703 HF345.We 390 CRL-7888 Hs801.PI 390
CRL-7706 HF 358.We 390 CRL-7891 Hs819.T 390
CRL-7708 A68177 390 CRL-7894 Hs910.Sk 390
CRL-7709 HE-LU(Rifkin) 390 CRL-7895 Hs914 390
CRL-7714 HE-SK 390 CRL-7896 Hs915 390
CRL-7717 LS3-10 390 CRL-7897 Hs916 390
CRL-7718 MB157 390 CRL-7898 A101D 390
CRL-7720 LS3-10 390 CRL-7901 80T 390
CRL-7721 MB157 390 CRL-7902 A253 390
CRL-7722 Murphy 390 CRL-7905 A388 390
CRL-7723 R-970-5 390 CRL-7911 A704 390
CRL-7724 SH-4 390 CRL-7920 DoTc2 4510 390
CRL-7729 HB 390 CRL-7940 SW527 390
CRL-7732 TE76.T 390 CRL-7943 T1-73 390
CRL-7739 TE90.Sk 390 CRL-7944 TE84.T 390
CRL-7740 TE91.Sk 390 CRL-7945 TE125.T 390
CRL-7741 TE98.T 390 CRL-8000 OKT 1 290
CRL-7744 TE115.T 390 CRL-8001 OKT 3 224
CRL-7746 TE130.T 390 CRL-8002 OKT4 290
CRL-7751 TE149.T 390 CRL-8003 IZD-MB-0503 290
CRL-7752 TE159.T 390 CRL-8006 Sp2/01-Ag 290
CRL-7753 TE161.T 390 CRL-8012 FL74-UCD-1 290
CRL-7754 TE170.M 390 CRL-8013 OKT 5 290
CRL-7755 TE175.T 390 CRL-8014 OKT 8 290
CRL-7757 TE199.T 390 CRL-8015 TK6 290
CRL-7758 TE206.T 390 CRL-8016 OKT 5 290
CRL-7761 TE353.Sk 390 CRL-8017 H25B10 290
CRL-7762 TE354.T 390 CRL-8017A H25B10 290
CRL-7763 TE381.T 390 CRL-8018 H21F8-1 290
CRL-7765 TE417.T 390 CRL-8019 1116NS-3d 290
CRL-7766 TE418.T 390 CRL-8020 OKT 6 290
CRL-7767 TE441.T 390 CRL-8021 OKT 9 290
CRL-7774 TE617.T 390 CRL-8022 OKT 1O 290
CRL-7776 TO166.M 390 CRL-8024 PLC/PRF/5 224
CRL-7779 TO175.T 390 CRL-8026 OKM1 290
CRL-7780 TO203.T 390 CRL-8027 OKT 11 290
CRL-7782 HT297.T 390 CRL-8031 KG-1 290
CRL-7783 HT728.T 390 CRL-8033-1 SKO-007 290
CRL-7789 HT762.T 390 CRL-8033-2 SKO-007 290
CRL-7790 HT768.M 390 CRL-8034 B3/25 290
CRL-7797 HT1417 390 CRL-8037 BL-3 290
CRL-7801 Hs446.SK 390 CRL-8062 WI-L2-729HF2 290
CRL-7802 Hs454.T 390 CRL-8066 Mo 290
CRL-7804 Hs456.Sk 390 CRL-8079 LBRM-33-1A5 290
CRL-7805 Hs456.Bt 390 CRL-8080 LBRM-33-5A4 290
CRL-7807 Hs466.Sk 390 CRL-8083 MC/CAR 290
CRL-7808 Hs467.Sk 390 CRL-8085 B2-1 290
CRL-7810 Hs468.Lu 390 CRL-8119 1A2 290
CRL-7811 Hs469.Sk 390 CRL-8130 J-A1886 290
CRL-7813 Hs479.T 390 CRL-8131 J-99 290
CRL-7814 Hs483.T 390 CRL-8135 MDTC-RP19 290
CRL-7815 Hs483.Sk 390 CRL-8146 AHH-1 290
CRL-7818 Hs491.T 390 CRL-8147 MC/CAR-Z2 290
CRL-7820 Hs1.int 390 CRL-8155 WIL2-NS 290
CRL-7822 Hs5.T 390 CRL-8163 H33HJ-JA1 290
CRL-7823 Hs14.T 390 CRL-8164 BF-11 290
CRL-7824 Hs15.T 390 CRL-8179 CI.Ly1+2-/9 290
CRL-7826 Hs38.T 390 CRL-8192 A6 290
CRL-7828 Hs67.Th 390 CRL-8193 36 290
CRL-7833 Hs172.T 390 CRL-8199 AGR-ON 290
CRL-7834 HS173.We 390 CRL-8200 HIIF-D 290
CRL-7842 Hs383.Sk 390 CRL-8286 Reh 224
CRL-7846 Hs571.T 390 CRL-8287 Sp2/0-Ag14 290
CRL-7850 Hs588.T 390 CRL-8293 C5/MJ 290
CRL-8294 MJ 290 CRL-10314 BHK570 290
CRL-8295 6T-CEM20 290 CRL-10317 MCF 10A 179
CRL-8296 6T-CEM 290 CRL-10318 MCF 10F 290
CRL-8303 143B 224 CRL-10354 BL-65 290
CRL-8304 143B PML BKTK 290 CRL-10389 DH82 290
CRL-8306 MC/9 179 CRL-10390 DH82ECOK 290
CRL-8399 CHM1a 290 CRL-10422 LtK-11 179
CRL-8400 CSMαβ6C 290 CRL-10423 JM1 290
CRL-8401 CSMαβ1H 290 CRL-10442 HCN-1A 290
CRL-8468 D17 390 CRL-10463 A-HER2 290
CRL-8543 H9/HTLV-IIIB 290 CRL-10478 CV-1/EBNA-1 290
CRL-8544 2254-62.2 290 CRL-10575 MCL-5 290
CRL-8621 SVG p12 290 CRL-10609 MMQ 290
CRL-8644 HuNS1 290 CRL-10624 CO 88BV59-1 290
CRL-8658 KR-12 290 CRL-10632 TAC-1 290
CRL-8659 EJG 290 CRL-10685 PG13/LN c8 290
CRL-8727 NCE-F161 290 CRL-10686 PG13/LN c8 290
CRL-8752 9D10 290 CRL-10741 C3A 179
CRL-8753 C5B7 290 CRL-10742 HCN-2 179
CRL-8756 SC-1 290 CRL-10762 CTLA4 lg-24 290
CRL-8761 TP-3 290 CRL-10781 MCF-10-2A 290
CRL-8795 8E7 290 CRL-10782 MCF-12A 224
CRL-8798 184A1 224 CRL-10783 MCF-12F 290
CRL-8799 184B5 290 CRL-10852 293 c18 290
CRL-8885 WIL2-5 290 CRL-10860 BTI-TN-MG1 290
CRL-8910 BM-N 290 CRL-10907 2018 290
CRL-8985 MTKP97-12 290 CRL-10915 D1.1 290
CRL-8993 8E5 290 CRL-10998 L.N.4159 290
CRL-9010 CUKX B1 290 CRL-11005 FL 62891 224
CRL-9068 NCI-H929 224 CRL-13001 BHK21-pcDNA3.1-HC 224
CRL-9078 PA317 224 CRL-13002 GH329 224
CRL-9096 CHO/dhFr 179 CRL-13003 GH354 224
CRL-9116 FeLV-3281 290 CRL-13007 IMM002.69.47.4 224
CRL-9300 20H11 290 CRL-13011 Hela NR1 224
CRL-9391 Swiss SFME 290 CRL-11102 DS-1 290
CRL-9392 BALB SFME 290 CRL-11115 59B5 290
CRL-9444 MeT-5A 224 CRL-11116 36.5(CD8+) 290
CRL-9446 CHL-1 290 CRL-11135 HCE-2 290
CRL-9482 BBM 290 CRL-11138 L-ALPHA-1AL-CELLS 290
CRL-9483 BZR 290 CRL-11139 L-alpha-1b 290
CRL-9518 CRL-11351 290 CRL-11147 A2058 224
CRL-9519 MC-SV-HUCT-2 290 CRL-11171 PSP-36 290
CRL-9520 SV-HUC-1 290 CRL-11177 022HU-NSO 290
CRL-9560 Psi 2 BAG α 290 CRL-11179 CATH.a 224
CRL-9589 AML-193 240 CRL-11180 L-α-2AL-CELLS 290
CRL-9591 MV-4-11 240 CRL-11181 L-α-2CL-CELLS 290
CRL-9595 MCB3901 290 CRL-11226 143.98.2 290
CRL-9606 CHO 1-15500 290 CRL-11233 THLE-3 224
CRL-9607 HMCB(Human Melanoma Cell Bowes) 290 CRL-11268 293T/17 179
CRL-9609 BEAS-2B 179 CRL-11269 ANJOU 65 290
CRL-9618 CHO-K1 290 CRL-11270 BOSC 23 224
CRL-9641 GP+envAM-12 290 CRL-11285 AtT-20ins(CGT-6) 290
CRL-9642 GP+E-86 290 CRL-11346 32D Clone 3 224
CRL-9850 MD 290 CRL-11351 H69AR 290
CRL-9852 PMC2 290 CRL-11372 Hfob 1.19 179
CRL-9853 91196B 290 CRL-11379 9TR#1 290
CRL-9854 EL 1 290 CRL-11383 TK#1 290
CRL-9855 SC 290 CRL-11386 TALL-104 390
CRL-9856 KMA 290 CRL-11397 B13-24 290
CRL-9939 DSN 290 CRL-11398 6E6 290
CRL-9995 CRL-11611 290 CRL-11421 B-3 290
CRL-10052 35.6 290 CRL-11422 MPRO Cell Line,Clone 2.1 290
CRL-10101 LA3-5 290 CRL-11506 Β-TC-6 224
CRL-10154 5/9m a3-18 290 CRL-11515 10.014 pRSV-T 290
CRL-10191 L-2/M Δ2-3 290 CRL-11516 2.040 pRSV-T 290
CRL-10225 A9 L Hd2s.c.18 290 CRL-11538 Co88BV59H21-2 290
CRL-10237 2F7 290 CRL-11539 Co88BV59H21-2V67-66 290
CRL-10275 L-NGC-α2BL-CELLS 290 CRL-11543 LNZTA3WT4 290
CRL-10287 L-NGC-5HT2 290 CRL-11544 LNZTA3WT11 290
CRL-10296 NCI-H295 290 CRL-11554 Bing 290
CRL-10302 SW756 290 CRL-11605 RIN-m5F 224
CRL-11609 RWPE-1 179 HB-51 28-8-6S 290
CRL-11610 RWPE-2 224 HB-53 15-1-5P 290
CRL-11611 RER-1E 290 HB-54 MA2.1 290
CRL-11622 RH9/CB 290 HB-55 L243 290
CRL-11632 ES-D3 224 HB-56 BB7.1 290
CRL-11663 HRT-18G 290 HB-57 DA4-4 290
CRL-11691 EML Cell Line, Clone 1 290 HB-58 187.1 290
CRL-11730 TOV-112D 224 HB-59 MB40.2 290
CRL-11731 TOV-112D 224 HB-60 C3-124 290
CRL-11732 OV-90 224 HB-61 TB 28-2 290
CRL-11882 HS-5 224 HB-64 M2-1C6-4R3 290
CRL-11904 JAWSII 179 HB-65 H16-L10-4R5 290
CRL-11967 FeT-J 290 HB-66 73/1. 290
CRL-11968 Fet-1C 290 HB-67 46/4. 290
CRL-11997 HEP G2/2.2.1 290 HB-68 VD-10 290
CRL-12006 ProPakA.6 290 HB-69 MRSS-1(D2D4) 290
CRL-12007 ProPak-X.36 290 HB-70 ᇫTA4-1 290
CRL-12011 HX 290 HB-72 AE-1 290
CRL-12012 HP 290 HB-73 AE-2 290
CRL-12013 2A 290 HB-75 34-4-20S 290
CRL-12051 DDT1-MF-2 290 HB-76 34-4-21S 290
CRL-12103 FDC-P1 224 HB-77 31-34S 290
CRL-12135 Con A-C1-VICK 290 HB-78 MMA 290
CRL-12203 UMNSAH/DF-1 179 HB-79 34-5-2S 290
CRL-12284 PT67 290 HB-80 ACT 1 290
CRL-12357 ConA-B1-VICK 290 HB-81 ACT IV 290
CRL-12424 D1 ORL UVA 224 HB-82 BB7.2 290
CRL-12479 ProPak-A.52 Clone #52 290 HB-84 L5.1 290
CRL-12557 7F2 290 HB-85 34-5-3S 290
CRL-12568 HKB11 290 HB-86 HD2-4 290
CRL-12569 2B8 290 HB-87 34-2-12S 290
CRL-12582 20B8 290 HB-88 Bet-2 290
HB-2 T3-3A1 290 HB-90 ED1-19-1-6-5 290
HB-3 MK-D6 290 HB-91 PNP/PFn 290
HB-4 MK-S4 290 HB-92 7D2-1.4.1.5 290
HB-5 16-3-22S 290 HB-94 BB7.7 290
HB-6 17-3-3S 290 HB-95 W6/32 224
HB-11 20-8-4S 290 HB-96 L227 290
HB-12 GAP 8.3 290 HB-97 LS102.9 290
HB-13 15-3-1S 290 HB-98 LK 35.2 290
HB-14 16-1-11N 290 HB-99 LB27.4 290
HB-15 26-7-11S 290 HB-100 Bet-1 290
HB-16 16-1-11N 290 HB-101 34-7-23S 290
HB-19 28-11-5S 290 HB-102 34-5-8S 290
HB-20 3-83P 290 HB-103 Genox3.53 290
HB-21 5E9C11 290 HB-104 Antibody 2.06 290
HB-22 4F2C13 290 HB-105 MB 40.3 290
HB-23 20-10-5S 290 HB-109 G2b.2 290
HB-24 15-5-5S 290 HB-110 G2a.5 290
HB-25 16-3-1N 290 HB-112 D1-4G2-4-15 290
HB-26 25-9-17S11 290 HB-114 D3-2H2-9-21 290
HB-27 28-l4-8S 290 HB-116 MB40.5 290
HB-28 BBM.1 290 HB-115 BB7.6 290
HB-31 30-5-7S 290 HB-117 PA2.1 290
HB-32 14-4-4S 290 HB-118 PA2.6 290
HB-33 AB1-2 290 HB-119 ME 1 290
HB-34 15-79-2 290 HB-120 BB7.5 290
HB-35 28-16-8S 290 HB-121 E5BB3IIA2 290
HB-36 23A-5-21S 290 HB-122 GAP A3 290
HB-37 25-5-16S 290 HB-123 CC9C10 290
HB-38 25-9-3S 290 HB-124 DB9G8 290
HB-41 28-13-3S 290 HB-125 AE9D6 290
HB-42 26-8-16S 290 HB-126 CG7C7 290
HB-43 1410KG7 290 HB-127 CE9H9 290
HB-44 63D3 290 HB-128 2E.3 290
HB-45 141PF11 290 HB-129 116-13.1 290
HB-46 3H5-1 290 HB-130 41-3.48 290
HB-47 15F3-1 290 HB-131 I(TL.Mp) 290
HB-48 1H10-6 290 HB-132 CEL-14 290
HB-49 5D4-11 290 HB-133 BE3F9 290
HB-50 12-2-2S(clone 5F11) 290 HB-134 OM3-1.1 290
HB-135 THB-5 290 HB-210 TE16 290
HB-136 THB-7 290 HB-211 TE19 290
HB-137 SE-1.3 290 HB-212 TE8 290
HB-138 M-2E6 290 HB-213 CDR1 290
HB-139 74-11-10 290 HB-214 CDR2 290
HB-140 76-7-4 290 HB-215 E13 161-7 290
HB-141 76-6-7 290 HB-216 CDC 1C42H11 290
HB-142 74-22-15 290 HB-217 IV.3 290
HB-142.1 74-22-15A 290 HB-218 H57-597 290
HB-143 76-2-11 290 HB-219 TR310 290
HB-144 IVD12 290 HB-220 MB23G2 290
HB-145 IVA12 290 HB-221 K204 290
HB-146 Lg(4a)10.9 290 HB-222 35.1 290
HB-147 74-12-4 290 HB-223 MB4B4 290
HB-149 L368 290 HB-224 N418 290
HB-151 SFR3-DR5 290 HB-225 N22 290
HB-152 SFR8-B6 290 HB-226 2E6. 290
Hb-153 76-5-28 290 HB-227 R1-2 290
HB-155 Ep-16 290 HB-228 12.1 290
HB-156 74-9-3 290 HB-229 Md2 290
HB-157 B27m1 290 HB-230 51.1 290
HB-158 Af6-88.5.3 290 HB-231 38.1 290
HB-159 Sf1-1.1.10 290 HB-232 LP4.4 290
HB-160 Af3-12.1.3 290 HB-233 BE29G1 290
HB-161 Ams 9.1.1.1 290 HB-235 CLA-E-4.15 290
HB-162 Af6-78.25.4 290 HB-236 CLA-E-7.12 290
HB-163 Af6-120.1.2 290 HB-240 4D11 290
HB-164 A11.1 M 290 HB-241 162-21.2 290
HB-165 B27M2 290 HB-242 AP-3 290
HB-166 2.28 M1 290 HB-243 TS2/16.2.1 290
HB-167 9BG5 290 HB-244 TS2/4.1.1 290
HB-168 72A1 290 HB-245 TS2/7.1.1 290
HB-169 TM1 290 HB-246 26ic 290
HB-170 R4-6A2 224 HB-247 60bca 290
HB-171 L203 290 HB-248 17aba 290
HB-172 10B9 290 HB-249 44aacb 290
HB-174 14E5 290 HB-250 11-26C 290
HB-175 anti-IR-1 290 HB-251 1/24.D6 290
HB-176 Y-3 290 HB-252 HD168 290
HB-177 A1G3 290 HB-253 GL1 290
HB-178 4d12 290 HB-254 GL7 290
HB-179 y-17 290 HB-255 Hs-21(subclone 1H3) 290
HB-180 9.3F10 290 HB-256 FW11-9-2 290
HB-181 356-I. 290 HB-257 FW11-10-3 290
HB-182 38-l 290 HB-258 FW11-24-17-36 290
HB-183 Y-3P 290 HB-261 FW3-218-1 290
HB-184 GAD-1 290 HB-262 17D 290
HB-185 204-4. 290 HB-263 DU1-29 290
HB-186 339-l 290 HB-264 CC63 290
HB-187 162-46.2 290 HB-265 CC15 290
HB-188 11B11 290 HB-266 CC38 290
HB-189 mAb 270 290 HB-267 CC20 290
HB-191 PK136 224 HB-268 CC57 290
HB-192 F1-3G8-1 290 HB-269 CC29 290
HB-193 MBL-Sm-4B1 290 HB-270 CC30 290
HB-194 MBL-Sm-1A6 290 HB-271 CC51 290
HB-195 TS2/18.1.1 290 HB-272 CC42 290
HB-196 4B2 290 HB-273 CC56 290
HB-197 2.4G2 224 HB-274 CC39 290
HB-198 F4/80 290 HB-275 CC58 290
HB-199 AF6-122.2.5 290 HB-276 BA-G5 290
HB-200 CH-EB6 290 HB-277 SC-71 290
HB-201 AF6-122.2.5 290 HB-278 BF-45 290
HB-202 TS1/22.1.1.13 290 HB-280 CC8 290
HB-203 TS1/18.1.2.11 290 HB-281 CC17 290
HB-204 LM2/1.6.11 290 HB-282 CC55 290
HB-205 TS2/9.1.4.3 290 HB-283 BF-F3 290
HB-206 TE15 290 HB-284 1H3 290
HB-207 TE4 290 HB-285 36F-18C 290
HB-208 TE7 290 HB-286 86D 290
HB-209 TE3 290 HB-287 BA-D5 290
HB-288 CC21 290 HB-8214 CBL-1 290
HB-289 FW4-101-1-1 290 HB-8240 CLT 85 290
HB-290 DEC-205 290 HB-8244 CLT 152 290
HB-292 MECA-89 290 HB-8247 HT 29/26 290
HB-293 FIB504.64 290 HB-8248 HT 29/36 290
HB-294 DATK32 290 HB-8291 IFGCP-F1BA10 290
HB-295 FIB21 290 HB-8297 J5-1 290
HB-296 171-4 290 HB-8298 J5-2 290
HB-298 LB3.1 290 GB-8301 703D4 290
HB-299 WAPS 12.2 290 HB-8307 CLN H11.4 290
HB-300 DREG56 290 HB-8311 4C 290
HB-301 16-10A1 290 HB-8322 151-5-G2-12 290
HB-302 DREG200 290 HB-8323 151-5-G3-5 290
HB-304 UC10-4F10-11 290 HB-8324 151-6-A7-9 290
HB-305 ID3 290 HB-8325 143-2-A6-11 290
HB-306 LYK-1 290 HB-8326 130-3-F7-5 290
HB-310 LYK-5 290 HB-8327 4A4B11 290
HB-311 LYK-7 290 HB-8328 12A5B7 290
HB-312 LYK-8 290 HB-8329 CH26-1352 290
HB-313 LYK-9 290 HB-8331 S3D3 290
HB-316 LYK-12 290 HB-8332 S1E4 290
HB-319 LYK-16 290 HB-8337 13.90.2 290
HB-321 19F8 290 HB-8363 16M3F10 290
HB-322 15F7 290 HB-8371 5C9 290
HB-323 20H2 290 HB-8372 B11 290
HB-326 15C6 290 HB-8377 HB-8653 290
HB-327 4C4 290 HB-8389 2.03.7 290
HB-8049 14IA2E2E10D5 290 HB-8411 MF 116 290
HB-8051 F5-A-1/22.8.13 290 HB-8412 MH55 290
HB-8059 1116-NS-19-9 290 HB-8431 ME195 290
HB-8064 Hep 3B2.1-7 179 HB-8437 LI27 290
HB-8065 Hep G2 179 HB-8438 M 111 290
HB-8067 3E1 290 HB-8439 D 14 290
HB-8068 1D4 290 HB-8440 M 144 290
HB-8086 132D4A/4 290 HB-8441 AL 1-27 290
HB-8087 129A3/1 290 HB-8442 LI66 290
HB-8088 130D3/2B/8 290 HB-8443 E 20 290
HB-8090 1A8 290 HB-8444 K 114 290
HB-8106 B6.2 290 HB-8445 R24 290
HB-8107 B25.2 290 HB-8446 L235 290
HB-8108 B72.3 290 HB-8447 L101 290
HB-8110 B38.1 290 HB-8448 L230 290
HB-8116 HY3-11.27 290 HB-8449 M-24(M138) 290
HB-8117 2Hx-2 290 HB-8450 L368 290
HB-8133 1939-3G5 290 HB-8451 A123 290
HB-8134 1939-8G2 290 HB-8452 A124 290
HB-8136 3Pt12B8 290 HB-8453 B5 290
HB-8144 1B2E12 290 HB-8465 7C8 290
HB-8152 30/15 290 HB-8466 158.2 290
HB-8153 17/14 290 HB-8472 LP3IIG2 290
HB-8154 61/7. 290 HB-8473 NN-4 290
HB-8156 WFL4F12.3 290 HB-8474 NN-3 290
HB-8157 WFL3C6.1 290 HB-8476 NN-5 290
HB-8159 6A7M 290 HB-8483 Anti-My-10 clone 28/8/8/14/4 290
HB-8161 8A2N 290 HB-8484 454C11 290
HB-8162 10F7MN 290 HB-8500 T4 Clone 5(10-0101,0062-83) 290
HB-8172 E6(2)2 290 HB-8501 Sa13 290
HB-8177 9F12 290 HB-8502 Ltr228 290
HB-8178 2BD4E4K99 290 HB-8506 579 290
HB-8180 39-S 290 HB-8507 455 290
HB-8181 52-S 290 HB-8508 225 290
HB-8182 53-S 290 HB-8509 538 290
HB-8183 58-S 290 HB-8510 15b2 290
HB-8190 2G8.D6 290 HB-8511 3c11 290
HB-8191 a-ACE3.1.1 290 HB-8512 3f6 290
HB-8206 CLNH5.5 290 HB-8513 10e5 290
HB-8207 F1A3-23 290 HB-8516 3g3 290
HB-8208 18AF1 290 HB-8521 23b6 290
HB-8209 5F12AD3 290 HB-8523 RLTM02 290
HB-8210 2AB1-1A10 290 HB-8525 RLSD09 290
HB-8213 2T8-3E10 290 HB-8526 RLTM01 290
HB-8527 RLSD06 290 HB-9018 FHCR-1-2813/FDC-6 290
HB-8530 VM-2 290 HB-9070 12/44 290
HB-8534 HAA1 290 HB-9071 12/49 290
HB-8553 K117 290 HB-9081 XMMEN-OE5 290
HB-8554 L-14 290 HB-9094 HB-9909 290
HB-8555 2A3A1H 290 HB-9097 171-19B10 290
HB-8563 1A3 290 HB-9101 3D8 290
HB-8568 Mab 126 290 HB-9102 3G12 290
HB-8573 Ch13 290 HB-9110 G28-5 224
HB-8575 Gr431 290 HB-9119 P25.48 290
HB-8577 Te39 290 HB-9147 OVB-3 290
HB-8587 HM2 290 HB-9148 Mab 5.2 290
HB-8592 Mab 543 290 HB-9158 MX 290
HB-8609 La1 290 HB-9168 P3 6D4(SCRF 43.1) 290
HB-8612 Lym-1 290 HB-9169 P3 8D2(SCRF 43.1) 290
HB-8613 Lym-2 290 HB-9173 XMMCO-791 290
HB-8619 LO-22 290 HB-9255 S5 290
HB-8627 L5 290 HB-9257 F24 290
HB-8628 L18 290 HB-9259 4E11. 290
HB-8633 VLN6H2 290 HB-9282 W4F.5B 290
HB-8636 VLN3G2 290 HB-9283 (BF1)8A3.31 290
HB-8638 JO1-1 290 HB-9303 C273 290
HB-8651 DS-3 290 HB-9306 YI328-18 290
HB-8652 DS-6 290 HB-9311 40.10.09 290
HB-8653 DS-5 290 HB-9312 37.04.12 290
HB-8654 3B18 290 HB-9313 42.08.07 290
HB-8669 C5 290 HB-9326 ME361S2a 290
HB-8672 WI-MN-1 290 HB-9361 52 290
HB-8678 7C2C5C12 290 HB-9367 116 290
HB-8691 317G5.C1D3 290 HB-9371 219 290
HB-8693 UCD/AB6.01 290 HB-9372 232 290
HB-8694 UCD/PR 10.11 290 HB-9397 7E12H12 290
HB-8696 520C9 290 HB-9401 Hy bridoma 231 290
HB-8700 γ3-11.1 290 HB-9402 Hybridoma 234 s.2a 290
HB-8704 TA 99 290 HB-9403 Hybridoma 234 s.2a 290
HB-8705 L21-6 290 HB-9419 CKMM14.15 290
HB-8709 KC-4G3 290 HB-9420 CKMM14.5 290
HB-8710 KC-4M1 290 HB-9421 CKMM14.52 290
HB-8730 S9.6 290 HB-9437 B69 290
HB-8737 200-3-G6-4 290 HB-9459 CC49 290
HB-8747 T84.66A3.1A.1F2 290 HB-9463 F21-1D3G7C8 290
HB-8759 XMMME-001 290 HB-9469 32.2 290
HB-8760 XMMME-002 290 HB-9478 MECA-367 290
HB-8766 SV63 290 HB-9479 MECA-79 290
HB-8767 K66 290 HB-9480 Hermes-3 290
HB-8770 FHCR-1-2075/FH5 290 HB-9490 R63 290
HB-8775 FHCR-1-2075/FH4 290 HB-9496 XVI E6E6G10 290
HB-8779 AS33 290 HB-9500 QPN1 12D99SCRF 43.2) 290
HB-8783 D8/17 290 HB-9509 QPN1 22F5(SCRF 43.2) 290
HB-8784 7G7B6 290 HB-9510 MY904 290
HB-8785 F3B6 290 HB-9515 C171 290
HB-8786 CCK061 290 HB-9516 C129 290
HB-8794 S4B6 290 HB-9517 C180 290
HB-8832 7E3. 290 HB-9568 BVD2-23B6.4 290
HB-8857 mAb35 290 HB-9569 BVD2-21C11.3 290
HB-8861 FHCR-1-2516/FH7 290 HB-9571 18C2.8.3 290
HB-8870 MH-SVM23 290 HB-9572 5D6.10.4 290
HB-8871 MH-SVM25 290 HB-9573 6D3.2.2 290
HB-8872 MH-SVM26 290 HB-9574 7C6.5.4 290
HB-8873 HB-9667 290 HB-9579 S6F1 290
HB-8902 WBC264-9C 290 HB-9580 R6.5.D6.E9.B2 290
HB-8906 DS-1 290 HB-9596 A717 290
HB-8917 EIAV 12E8.1 290 HB-9645 1F5 290
HB-8934 13-5-9-6-2 290 HB-9647 EL-NC-1S 290
HB-8935 9-4-3. 290 HB-9667 2D-7 290
HB-8963 2B5 290 HB-9689 BD5-2d 224
HB-8964 C11C1 290 HB-9706 G253 290
HB-8975 MH-SVM33C9 290 HB-9725 31-90-25 290
HB-8984 110-5 290 HB-9726 31-42-19 290
HB-8987 mAb64 290 HB-9739 MH1 290
HB-8995 2C5-6 290 HB-9743 DD-4 290
HB-9746 B29 290 HB-11917 SM27-1045 290
HB-9753 Uc7 290 HB-11945 7F2-6D4-8E7 290
HB-9763 Mab 96 290 HB-11946 Mab 24-2 290
HB-9764 Mab 108 290 HB-11947 Mab 24-1 290
HB-9771 B6h12.2 290 HB-12000 B505 290
HB-9849 1D11.16.8 290 HB-12024 3A8 290
HB-9893 G26.4.1C3//86 290 HB-12029 #490 290
HB-9907 αΑbl5c2.870005 290 HB-12055 Hcd40L-M90 290
HB-9908 αΑbl5c2.870009 290 HB-12056 Hcd40l-m91 290
HB-9909 αΑbl5c2.870016 290 HB-12061 hlL-15-M110 290
HB-10135 7A9 290 HB-12062 hlL-15-M110 290
HB-10164 IB4 290 HB-12314 PCA 31.1 290
HB-10166 BC3 290 HB-12315 PCA33.28 290
HB-10179 E-8 290 HB-12317 NG108-15 290
HB-10183 AA224 290 HB-12318 A3.6B10 290
HB-10204 OD-3 224 HB-12319 A3.4H2 290
HB-10219 ILB1-H6 290 HB-12330 1C6 290
HB-10220 ILBI-H21 290 HB-12346 AC133.1 290
HB-10221 ILB1-H34 290 HB-12352 PV1 290
HB-10222 ILBI-H67 290 HB-12465 2A2-6E10-1D8 290
HB-10306 M195 290 HB-12466 4B2-6C3-1C9 290
HB-10452 4E8C12 290 HB-12497 TS 106 290
HB-10487 JES3-19F1.1.1 290 HB-12549 LS132.1D9 290
HB-10494 7E11C5 290 HB-12558 SWLA3 290
HB-10500 T529-15D3-18-1A3-1B7 290 HB-12559 SWLA1 290
HB-10501 T529-15D3-2E5-4G12-1A7 290 HB-12560 SWLA2 290
HB-10508 9.4 290 HB-12592 226H 290
HB-10519 VIII-6G10 290 HB-12593 236L 290
HB-10558 CAB 117-12D10 290 HB-12624 1G1 290
HB-10565 mAb 13-1 290 HB-12644 LS-125-2D4-11-10-1 290
HB-10569 B5 NIH 290 HB-12681 MAb 26-7-5 290
HB-10596 HGH 290 HB-12682 MAb 151-45-4 290
HB-10611 1H11 290 HB-12683 MAb 1812-4-8 290
HB-10714 MAC 2-48 290 HB-12684 Mab 951-5-1 290
HB-10716 BA7.3C.9 290 HTB-1 J82 290
HB-10743 SH2 290 HTB-2 RT4 224
HB-10744 SH3 290 HTB-3 SCaBER 290
HB-10745 SH4 290 HTB-4 T24 179
HB-10812 650E2-2B12 290 HTB-5 TCCSUP 290
HB-10830 FRAN4 290 HTB-9 5637 224
HB-10893 559/64-D 100,10,1 290 HTB-10 SK-N-MC 179
HB-10894 558-D 100,10,1 290 HTB-11 SK-N-SH 179
HB-10895 448-D 100,10,1 290 HTB-12 SW 1088 290
HB-10916 5c8 290 HTB-13 SW 1783 290
HB-10968 S4B6-1 290 HTB-14 U-87 MG 179
HB-11029 10C4.1.3 290 HTB-15 U-118MG 179
HB-11052 31E9 290 HTB-16 U-138MG 224
HB-11103 10D2F6 290 HTB-18 Y79 179
HB-11124 Αm346c7c1 290 HTB-19 BT-20 179
HB-11129 P3D 290 HTB-20 BT-474 179
HB-11300 89MS30 290 HTB-21 CAMA-1 290
HB-11301 91MS441 290 HTB-22 MC7 179
HB-11341 b7-24-e1g4 290 HTB-23 MDA-MB-134-VI 290
HB-11342 443-15d3-2f12 290 HTB-24 MDA-MB-157 224
HB-11426 Prost 410 290 HTB-25 MDA-MB-175-VII 290
HB-11465 huFasM38 290 HTB-26 MDA-MB-231 179
HB-11485 HECA-452 290 HTB-27 MDA-MB-361 179
HB-11490 Mab 1E8 290 HTB-30 SK-BR-3 179
HB-11491 Mab 2B5 290 HTB-31 C-33 A 179
HB-11494 10H2.12.1 290 HTB-32 HT-3 224
HB-11495 4D1.5.7 290 HTB-33 ME-180 224
HB-11534 DC101 290 HTB-34 MS751 290
HB-11601 Ab 21.1 290 HTB-35 SiHa 179
HB-11602 Ab 23.1 290 HTB-36 JEG-3 179
HB-11642 ER4.7G11 290 HTB-37 Caco-2 179
HB-11684 H18/7 290 HTB-38 HT-29 179
HB-11726 huFasM3 290 HTB-39 SK-CO-1 290
HB-11765 QCRL-1 290 HTB-40 HuTu 80 290
HB-11766 QCRL-3 290 HTB-41 a-253 290
HB-11894 1A3.3.13 290 HTB-43 FaDu 224
HB-11911 127H 290 HTB-44 a-498 224
HTB-45 A-704 290 HTB-135 Hs 746T 224
HTB-46 Caki-1 179 HTB-137 Hs 695 T 290
HTB-47 Caki-2 224 HTB-138 Hs 683 224
HTB-48 SK-NEP-1 290 HTB-140 Hs 294T 290
HTB-49 SW 839 290 HTB-142 Hs 602 290
HTB-52 SK-HEP-1 224 HTB-144 JAR 179
HTB-53 A-427 224 HTB-146 Hs 445 290
HTB-54 Calu-1 224 HTB-147 Hs 700T 290
HTB-55 Calu-3 179 HTB-148 H4 224
HTB-56 Calu-6 224 HTB-151 Hs 696 290
HTB-57 SK-LU-1 290 HTB-152 Hs 913T 290
HTB-58 SK-MES-1 224 HTB-153 Hs 729 290
HTB-59 SW 900 224 HTB-157 FHs 738Lu 290
HTB-60 EB1 290 HTB-158 FHs 173We 290
HTB-61 EB2 290 HTB-161 NIH:OVCAR-3 179
HTB-62 P3HR-1 290 HTB-163 Hs 67 290
HTB-63 HT-144 290 HTB-166 RD-ES 290
HTB-64 Malme-3M 290 HTB-168 ChaGo-k-1 290
HTB-65 MeMo 224 HTB-169 WERI-Rb-1 224
HTB-66 Rpmi 7951 290 HTB-171 NCI-H446 290
HTB-67 SK-MEL-1 290 HTB-172 NCI-H209 224
HTB-68 SK-MEL-2 224 HTB-173 NCI-H146 224
HTB-69 SK-MEL-3 290 HTB-174 NCI-H441 179
HTB-70 SK-MEL-5 224 HTB-175 NCI-H82 224
HTB-71 SK-MEL-24 290 HTB-176 H9 179
HTB-72 SK-MEL-28 179 HTB-177 NCI-H460 179
HTB-73 SK-MEL-31 290 HTB-178 NCI-H596 224
HTB-75 Caov-3 224 HTB-179 NCI-H676B 290
HTB-76 Caov-4 290 HTB-180 NCI-H345 224
HTB-77 SK-OV-3 179 HTB-181 NCI-H820 290
HTB-78 SW 626 224 HTB-182 NCI-H520 224
HTB-79 Capan-1 179 HTB-183 NCI-H661 290
HTB-80 Capan-2 224 HTB-184 NCI-H510A 224
HTB-81 DU 145 179 HTB-185 D283 Med 224
HTB-82 A-204 290 HTB-186 Daoy 224
HTB-85 Saos-2 179 HTB-187 D341 Med 224
HTB-86 SK-ES-1 224 JHU-1 TC-1 224
HTB-88 SK-LMS-1 290 JHU-3 R3327-G 224
HTB-91 SW 684 290 JHU-4 MAT-Lu 224
HTB-92 SW 872 224 JHU-29 R-3327-AT-1 224
HTB-93 SW 982 224 JHU-30 R-3327-AT-2.1 224
HTB-94 SW 1353 224 JHU-31 R-3327-AT-3.1 224
HTB-96 U-2 OS 179 JHU-32 JSC-1 224
HTB-102 Malme-3 290 JHU-52 IB3-1 224
HTB-103 KATO III 224 JHU-53 S9 224
HTB-104 Cates-1b 290 JHU-54 C38 224
HTB-105 Tera-1 290 JHU-56 p53R 224
HTB-106 Tera-2 290 JHU-64 293 EcR Shh 224
HTB-107 SW579 290 JHU-67 2v6.11 224
HTB-111 AN3 CA 290 JHU-68 Shh Light II 224
HTB-112 HEC-1-A 224 SCRC-1002 ES-C57BL/6 450
HTB-113 HEC-1-B 224 SCRC-1003 ES-D3GL 450
HTB-114 SK-UT-1 290 SCRC-1029 AINV 15 250
HTB-115 SK-UT-1B 290 SCRC-1036 R1/E 450
HTB-117 SW 954 290 TIB-6 J558 290
HTB-118 SW 962 290 TIB-8 P3.6.2.8.1 290
HTB-119 NCI-H69 179 TIB-9 P3X63Ag8 290
HTB-120 NCI-H128 290 TIB-10 P1.17 290
HTB-121 BT-483 224 TIB-11 C1.18.4 290
HTB-122 BT-549 224 TIB-12 RPC5.4 290
HTB-123 DU4475 224 TIB-13 HOPC 1F/12 290
HTB-125 Hs 578Bst 179 TIB-15 MPC 11 OUAr 290
HTB-126 Hs 578T 179 TIB-16 XC1.5/51 290
HTB-127 MDA-MB-330 290 TIB-17 XS63 290
HTB-128 MDA-MB-415 290 TIB-18 P3/NSI/1-Ag-1(NS-1) 224
HTB-129 MDA-MB-435S 179 TIB-19 S194/5.XXO.BU.1 290
HTB-130 MDA-MB-436 224 TIB-20 MOPC 315 290
HTB-131 MDA-MB-453 179 TIB-23 MOPC 315 290
HTB-132 MDA-MB-468 179 TIB-27 S1A.TB.4.8.2 290
HTB-133 T-47D 179 TIB-28 S49.1 290
HTB-134 Hs 766T 224 TIB-29 S49.1H.1AG.6 290
TIB-30 S49.1TB.2 290 TIB-119 RAN-2 290
TIB-33 S49.1TB.4 DEX R.63 290 TIB-120 M5/114.15.2 290
TIB-34 S49.1G.3 290 TIB-121 M1/22.25.8HL 290
TIB-35 S49001G3 PHA.100/0 290 TIB-122 M1/9.3.4.HL.2 290
TIB-36 S49(Thy-1-a) 290 TIB-123 M1/97.27.7.HLK 290
TIB-37 Timi.4 290 TIB-124 M1/89.18.7.HK 290
TIB-38 Timi.4g.1.3 290 TIB-125 N1/69.16.11.HL 290
TIB-39 El1 179 TIB-126 M1/42.3.9.8.HLK 290
TIB-40 El4.BU 290 TIB-127 M1/75.16.47.HLK 290
TIB-41 EL4.BU.1.OUAr.1.1 290 TIB-128 M1/70.15.11.5.HL 290
TIB-42 R1.1 290 TIB-129 331.12 290
TIB-43 R1E/TL8x.1 290 TIB-131 α Intermediate filament 290
TIB-44 R1.G1 290 TIB-132 80V 5B4 290
TIB-45 R1E/TL8x.1.G1.OUAr.1 290 TIB-135 CVC.1 290
TIB-47 BW5147.3 224 TIB-137 CVC.4 290
TIB-48 BW5147.G.1.4 290 TIB-138 CVC.7 290
TIB-49 C1498 290 TIB-139 B8-24-3 290
TIB-50 RAW 8.1 290 TIB-141 IGEL b4 290
TIB-51 RAW 309F.1.1 290 TIB-142 IGEL a2 290
TIB-52 WR19L 290 TIB-145 RA3-2C2/1 290
TIB-53 WEHI 7.1 290 TIB-146 RA3-3A1/6.1 290
TIB-54 WEHI 22.1 290 TIB-147 71A7 290
TIB-55 BB88 290 TIB-148 lg(1a)803 290
TIB-56 D1B 290 TIB-149 lg(5a)7.2 290
TIB-57 T27A 290 TIB-150 HO-2.2 290
TIB-58 D2N 290 TIB-152 Jurkat,Clone E6-1 290
TIB-59 BC16A 290 TIB-153 J.RT3-T3.5 290
TIB-60 BC3A 290 TIB-154 P107.2.2 290
TIB-61 PU5-1.8(PU5-1R) 290 TIB-155 LBRM-33 Clone 4A2 290
TIB-63 P388D1 ?(IL-1) 224 TIB-157 LS-136 290
TIB-64 P815 179 TIB-158 70Z/3 224
TIB-66 Sarcoma 180 290 TIB-160 YAC-1 179
TIB-67 J774A.1 179 TIB-161 Hut 78 179
TIB-68 WEHI-3 179 TIB-162 Hut 102 224
TIB-69 RAW 309.Cr.1 290 TIB-163 Cy34.1.2 290
TIB-70 WR19M.1 290 TIB-164 14.8 290
TIB-71 RAW 264.7 179 TIB-165 10-1.D.2 290
TIB-73 BNL CL.2 290 TIB-166 M3/38.1.2.8 HL.2 290
TIB-74 BNL SV A.8.8 290 TIB-167 RG9/6.13 HLK 290
TIB-75 BNL 1ME A.7R.1 290 TIB-168 M3/84.6.34 290
TIB-76 BNL 1NG A.2 290 TIB-169 RG7/9.1 HLK 290
TIB-80 BALB/c CL.7 290 TIB-170 RG11/39.4 290
TIB-81 BLK CL.4 290 TIB-172 RG7/7.6.HL 290
TIB-84 BALB/B0.75BAEA.1R.1 HD A0.8 290 TIB-173 RG7/1.30 290
TIB-85 BALB/c 10ME HD A.5R.1 290 TIB-174 RG7/11.1 290
TIB-86 BALB/c 10CrMC A.2R.1 290 TIB-175 mAb35 290
TIB-87 BALB/c AMuLV A.3R.1 290 TIB-180 HEL 92.1.7 224
TIB-88 BLK SV HD.2 A.5R.1A.3R.1 290 TIB-181 EL4.IL-2 224
TIB-90 BALB/c AMuLV A.6R.1 290 TIB-182 BE2 290
TIB-92 10-3.6.2 290 TIB-183 J11d.2 290
TIB-93 10-2.16 290 TIB-184 J1j.10 290
TIB-94 11-5.2.1.9 290 TIB-185 2D4 290
TIB-95 11-4.1 290 TIB-186 IC-21 224
TIB-96 Lg(5b)6.3 290 TIB-188 L11/135 290
TIB-98 RDP 45/20 290 TIB-189 1B2-1B7 290
TIB-99 HO-13-4 290 TIB-190 CESS 290
TIB-100 HO-22-1 290 TIB-191 1B7.11 290
TIB-103 T11D7e2 290 TIB-192 M1 224
TIB-104 53-7.313 290 TIB-194 2F.11.15 290
TIB-105 53-6.72 224 TIB-195 CEM-CM3 290
TIB-106 30-C7 290 TIB-196 U266B1 179
TIB-107 30-H12 290 TIB-197 BCL clone 5Bb 224
TIB-108 N-S.2.1 290 TIB-198 PI 153/3 290
TIB-109 N-S.8.1 290 TIB-200 HNK-1 290
TIB-110 N-S.4.1 290 TIB-202 THP-1 179
TIB-111 S-S.1 290 TIB-203 SRL-3 290
TIB-112 S-S.3 290 TIB-204 WEHI-265.1 290
TIB-114 S-S.7 290 TIB-205 ABE-8.1/2 290
TIB-115 Pab 100 290 TIB-206 DAKIKI 290
TIB-116 Pab 122 290 TIB-207 GK1.5 179
TIB-117 Pab 101 290
TIB-208 A20 179 TIB-227 33D1 290
TIB-209 X16C8.5 290 TIB-228 3C10 290
TIB-210 2.43 224 TIB-229 B21-2 290
TIB-211 3.155 290 TIB-230 PAb108 290
TIB-213 FD441.8 290 TIB-231 S1A(Thy-1-b) 290
TIB-214 CTLL-2 179 TIB-232 AKR1.G.1.OVAR.1.26 290
TIB-215 SKW 6.4 224 TIB-233 BW5147(T200-a)5.2 290
TIB-216 MAR 18.5 290 TIB-234 BWS147.3(Thy-1-e).10 290
TIB-217 M17/4.4.11.9 290 TIB-235 Im7.8.1 290
TIB-218 M18/2.a.12.7 290 TIB-236 C58(NT)D.1.G.OVAR.1 290
TIB-219 R17 217.1.3 290 TIB-237 M17/5.2 290
TIB-220 R17 208.2 290 TIB-238 M5/49.4.1 290
TIB-221 CJ1 290 TIB-239 2EB 290
TIB-222 PC61 5.3 224 TIB-240 KM201 290
TIB-223 GCT 290 TIB-241 KM81 290
TIB-224 D10.G4.1 224 TIB-242 KM114 290
更多产品请咨询010-88865677
咨询电话 010-88865677转801 Email: atcclines@163.com
北京市海淀区紫竹院路81号院十号名邸A306
