注射泵
超高压精密注射泵
超高压精密注射泵
Precision Syringe Pumps
Harvard
PHD 4400
询价
Harvard Apparatus的注射泵以其品种多、精度高和出色的可靠性而享誉世界。
Harvard注射泵的型号及附件众多,不能一一罗列。若要进一步了解相关产品
信息,请与美国自然基因有限公司联系。
Delivers >200 lbs (91 kg) linear pumping force across a wide flow rate range
Accurate and smooth flow
Ideally suited for stainless steel syringes
Easy-to-use interface
Control from your PC via serial interface
2 year warranty
The PHD 4400 Hpsi Programmable Syringe Pump is a single syringe infuse-withdraw pump equipped with all the functions of the PHD 22/2000 Programmable Model, but with a high-power stepper motor to provide up to 200 lbs. of linear force.
Pressure and Speed
The PHD 4400 Hpsi can deliver up to 220.82 ml/min with a single 140 ml syringe. Maximum pressure is dependent on syringe size. For stainless steel syringes, see page A70.
Flexibility and Easy Programmability
?Two standard infusion modes (continuous or volume dispense)
?Internal programmable pump control in all models
?In Program Mode, complex infuse and withdraw applications can be easily created, stored in the pumps nonvolatile memory and recalled for later use.
?Autofill Mode provides continuous delivery when the pump is used in conjunction with either a standard or high pressure valve box and a fluid reservoir.
Ease of Use
Setting the pump is quick and easy. Input the diameter of the syringe or use the internal Syringe Lookup Table to automatically input the syringe diameter based on the syringe manufacturer and size. Select a mode (continuous delivery or volume dispense) and a rate and you are ready to go.
Features
Universal Input Power Supply: No need to change AC line switches, fuses, or wires.
Nonvolatile Memory: Stores all operational data and program sequences.
Stall Detection: An optical detector verifies motor movement. Stalls due to jamming or excessive back pressure are reported.
Visual/Audible Alarms
Power-Up Options: Powers-up in Standby or Running Mode after power interruption.
RS-232 Connections: Allows daisy-chaining of multiple pumps for remote control. Also allows for scale and printer connections.
TTL Connections: Allows for synchronizing pump with external devices, controlling an external valve, changing direction of travel, etc.
Modes of Operation
Pump Runs continuously in the infuse or refill directions until stopped.
Volume Runs until specified volume has been pumped or refilled.
Program Pump operates according to specified sequence of instructions. (Note: All modes
interact with Autofill feature.
自然基因有限公司
NatureGene Corp.
CREATE, INVENT, INNOVATE
自然基因有限公司成立于1998年,是一家长期致力于研究,生产及销售生命科学仪器的一流企业。我们主要提供生化,医学,生物工程,分子生物学及其他科研项目如生物化学,农业,环保及质量控制等方面的产品。多年来,凭借强大的技术力量,完善的软硬件配置,自然基因有限公司为世界各地的大学,医院,科学研究机构提供世界最先进的科研仪器,满足各种研究领域的应用需求,并专业地提供完美的售后服务给客户。自然基因有限公司用户遍布全球,不少产品已在业界具有绝对的市场占有率,并享有很高的知名度。
自然基因有限公司于2005年进入中国市场,其北京代表处初期由原安莱公司北京代表处员工组成,为中国区域的管理机构。并先后在武汉、上海、成都、沈阳、西安、福州以及呼和浩特设立了分支机构。我们拥有经国外专业培训的有较好专业背景知识、熟悉市场的销售及技术服务人员,长期以来积累了丰富的经验和专业知识,为您提供完善周到的售前和售后服务,并提供全方位的产品及一体化的解决方案。我们还拥有一只经过专业培训的技术服务队伍,建立了一套十分完善的客户服务体系,能够确实帮助客户解决实际工作中的各种问题,并可以为客户提供各种需求的最佳解决方案。
我们在全国范围内诚征代理商,欢迎您们加入我们的队伍!详情请参见 http://www.naturegene.cn (中文)或致电0105150520/21
我们目前中国区域内的销售网络包括:
北京总部      马经理
上海联络处 徐经理
沈阳联络处 汪经理
大连联络处 孙经理
哈尔滨联络处 候经理
武汉联络处 李经理
成都联络处 王经理
昆明联络处 李经理
重庆联络处 周经理
北京市海淀区芙蓉里南街6号百环大厦1905
51650521
