注射泵
大剂量高压注射泵
大剂量高压注射泵
Precision Syringe Pumps
进口
Harvard
PHD 22/2000
Harvard Apparatus的注射泵以其品种多、精度高和出色的可靠性而享誉世界
由于Harvard注射泵的型号及附件众多,不能一一罗列。
若要进一步了解相关产品信息,请与美国自然基因有限公司联系。
大注射能力 – 用四个200 ml注射器可以达到800 ml。
超高注射压力 – 可以提供超过400 lbs的输送推力。
± 0.5% 的稳定精度
± 0.1% 的可重复性精度
可编程操作 – 具有通过键盘进行编程的先进特性
经久耐用 - 结实的结构可保证终生工作稳定
只能使用Harvard的不锈钢注射器
两年质保
High Capacity
This NEW PHD 22/2000 Hpsi Syringe Pump provides the highest capacity output of all of Harvard Apparatus’ microprocessor syringe pumps. This pump can hold up to four syringes from 20 to 200 ml. By combining the output from four 200 ml syringes, this pump is able to infuse up to 800 ml of fluid without refilling.
Ultra High Pressure
This NEW PHD 22/2000 Hpsi Syringe Pump over 400 pounds of force against the syringe plungers, higher than any other pump we manufacture. For applications with viscous fluids or requiring high pressure, this is the pump to handle the job.
Versatility
This Programmable PHD 22/2000 Hpsi syringe pump provides advanced capabilities directly from the keypad. No external computer is required. The pump can store up to four programs of 10 sequences each. Programs are stored in non-volatile memory. No other pump can provide this level of control and flexibility with the accuracy of the PHD 22/2000 syringe pump series. Like all of Harvard Apparatus’ other pumps, this new high capacity pump is easy to use.
Built-to-Last
This pump uses high quality, industrial grade components that will deliver years of smooth operation.
To Accommodate Almost Every Workbench
This pump is provided with a standard 5 foot cable that connects the control box to the pumping mechanism box. If additional distance is required between the controller and pump, a 30 foot remote extension cable is offered as an accessory.
Stainless Steel Syringes
Only Harvard Apparatus’ stainless steel syringes can be used with this pump. They can withstand high pressure applications and provide years of service, see page A70.
自然基因有限公司
NatureGene Corp.
CREATE, INVENT, INNOVATE
自然基因有限公司成立于1998年,是一家长期致力于研究,生产及销售生命科学仪器的一流企业。我们主要提供生化,医学,生物工程,分子生物学及其他科研项目如生物化学,农业,环保及质量控制等方面的产品。多年来,凭借强大的技术力量,完善的软硬件配置,自然基因有限公司为世界各地的大学,医院,科学研究机构提供世界最先进的科研仪器,满足各种研究领域的应用需求,并专业地提供完美的售后服务给客户。自然基因有限公司用户遍布全球,不少产品已在业界具有绝对的市场占有率,并享有很高的知名度。
自然基因有限公司于2005年进入中国市场,其北京代表处初期由原安莱公司北京代表处员工组成,为中国区域的管理机构。并先后在武汉、上海、成都、沈阳、西安、福州以及呼和浩特设立了分支机构。我们拥有经国外专业培训的有较好专业背景知识、熟悉市场的销售及技术服务人员,长期以来积累了丰富的经验和专业知识,为您提供完善周到的售前和售后服务,并提供全方位的产品及一体化的解决方案。我们还拥有一只经过专业培训的技术服务队伍,建立了一套十分完善的客户服务体系,能够确实帮助客户解决实际工作中的各种问题,并可以为客户提供各种需求的最佳解决方案。
我们在全国范围内诚征代理商,欢迎您们加入我们的队伍!详情请参见 http://www.naturegene.cn (中文)或致电0105150520/21
我们目前中国区域内的销售网络包括:
北京总部      马经理
上海联络处 徐经理
沈阳联络处 汪经理
大连联络处 孙经理
哈尔滨联络处 候经理
武汉联络处 李经理
成都联络处 王经理
昆明联络处 李经理
重庆联络处 周经理
北京市海淀区芙蓉里南街6号百环大厦1905
51650521
