普通PCR
KEWLAB Pro96C PCR扩增仪
KEWLAB
Pro96C
请电话咨询15168427495
Pro96C PCR扩增仪是进行聚合酶链式反应(PCR)实验的理想仪器。精准的温度控制、快速加热和优越的热均匀性使Pro96C性能出众。Pro96C还可与多种PCR容器兼容,满足不同的需求。直观的界面可以让用户很容易操作仪器和编程热循环程序备用。
产品特点:
优越性能
  • 高精度珀耳帖效应元件确保精准控温
  • 边界温度补偿机制实现优越的热均匀性
  • 快速加热和冷却,节省运行时间
  • 断电保护功能,性能可靠
灵活操作
  • 兼容降落PCR和长PCR实验
  • 可与普通PCR管、PCR条和不同高度的PCR板兼容
丰富而直观的用户控制
  • 彩色触摸屏,操作简单
  • 双击轻松建立热循环程序
  • 大容量内存,可存储>200个程序
  • 高分辨率OLED屏幕实时显示速度
  • 配备触屏笔,防止交叉污染
技术参数:
 型号
 Pro96C
 样品容量
 96 x 0.2 ml PCR 管, 96 孔板or 8 x 12 PCR 板
 模块控温范围
 4-105 ºC
 盖子温度范围
 30-110 ºC
 温度显示精度
 ±0.1 ºC
 控温精度 (at 55 ºC)
 ±0.3 ºC
 模块热均匀性 (at 55ºC)
 <0.3 ºC
 升温速率
 5 ºC/sec
 加热模块材质
 铝
 显示屏
 7英寸LCD触摸屏
 程序内存
 >200个程序,每个程序可包含多达30个步骤和99个循环
 电源
 100-120 V/200-240 V, 50/60 Hz
 外观尺寸
 280 × 370 × 250 mm
 净重
 11 kg
KEWLAB主营产品有离心机、显微镜、磁力搅拌器、顶置式电子搅拌器移液器、天平、混匀器、超声波清洗机、冷水机、水分仪、高速均质器、蠕动泵、恒流泵等系列实验室通用仪器和微型光谱仪、照度计、激光光束分析仪、光源、积分球、光学系统、光学棱镜、光学透镜、晶体光学、平面光学窗口和反射镜基底等系列光学仪器和元件。KEWLAB致力于推进科学事业,做您身边的仪器专家。
官网: www.kewlab.com.cn
电话: 0571-28121709
KEWLAB is dedicated to advancing the cause of science, and we do that by supplying optics, photonics and scientific laboratory instruments to both the scientific and the industrial community. It's surprisingly uncommon to find your perfect job nowadays, and despite the odds, that is precisely what we have done! Everyone here is an energetic, brilliant science supporter.
In the beginning humans developed tools, language, agriculture, and leisure; we then had the time to figure out how most of the gross mechanisms on our planet worked. We traced our origins, what had preceded us, and found clues and hints about what the future held in store. Humanity embraced knowledge, shedding ancient superstitions, in favour of experiments, study, and replicable results.
Our amazing KEWLAB crew has decades of accumulated experience in this field; we're ready to meet your toughest technical challenges worldwide. You really need to experience our premium optics and scientific products because the simple truth is that if you cannot measure and/or observe something, it is extremely difficult to learn very much from it.
Describe your optical, illumination, photonic or any scientific needs and let us craft your solution. You show us the path to the future, so let our dedicated staff provide you with the tools that you need to light the way.
KEWLAB Pty Ltd
513/370 St Kilda Road
Melbourne, VIC 3004
Australia
info@kewlab.com
浙江省杭州市上城区民心路100号万银国际2406室
