V8 protease
Sequencing Grade V8 Protease
Catalog Number:V813
CAS:66676-43-5
EC:3.4.21.19
Full Name:Sequencing grade recombinant V8 protease;Staphylococcus aureus strain V8
Synonyms:V8 protease;Endoproteinase Glu-C;Endoproteinase Asp-C
Storage temperature: 2-8°C
Source: Recombinant V8 protease is a genetically engineered protein expressed in E.coli
1. DESCRIPTION
Recombinant V8 protease is the serine protease family and can specifically hydrolyzing glutamic acid or aspartic acid residues carboxy side peptide bonds. The Glu carboxy terminal peptide bond can be identified and cleaved in CH4COONH4 buffer (pH 7.8) and NH4HCO3 (pH 4.0 ).Identify and cleave the Glu or Asp carboxy terminal peptide bond in phosphate buffer (pH 7.8),and the hydrolysis rate of Glu was higher than that of Glu Asp. Recombinant V8 protease has activity between pH 4.0-10.0, and the optimum pH is 8.0-8.5. It can be used alone or in combination with other proteases when used in protein digestion, peptide profiling and peptide mass fingerprinting analysis. The inhibitors of V8 protease are diisopropylfluorophosphate (DFP), α2-macroglobulin and Nα-P-tosyl-L-lysine chloromethyl ketone (TLCK).
2. MAIN FEATURES
Source |
Recombinant E. coli |
Appearance |
White or off white, or yellowish powder |
Specific activity |
≥ 5.0 U /mg pro. |
Purity(SDS-PAGE) |
Single major band |
Molecular Weight(SDS-PAGE) |
24.0±2.4 kDa |
UNIT DEFINITION: One unit is defined as the amount of enzyme required to catalytic substrate Z-Phe-Leu-Glu-4-nitranilide produced 1 μmol of 4-nitroaniline per minute at 25°C and pH 7.8 .
3. STABILITY OF STORAGE AND TRANSPORT
(1)Stability of storage: Recombinant V8 protease should be stored under 2-8°C in sealed container.It is stable within 6 months after dissolved with1mM HCl and 50mM HAC at -20°C or below. It is stable within 2 months after dissolved with 1mM HCl and 50mM HAC at 4°C.85% activity above can be kept after dissolved with 1mM HCl and 50mM HAC at 25°C or 37°C 12h. It is no activity loss after 10 times repeated freezing and thawing.
(2)Stability of transport: The product is stable by blue ice insulation transport.
4. RECOMMEND USAGE
Note that before using
1) Divide the material in according to usage quantity to avoid pollution or self-cutting.
2) Dissolve target protein.
The target protein is dissolved by cleavage buffer, for example 25-50 mM NH4HCO3 pH 7.8, if the solubility of target protein is not good, the target protein will be denatured by adding urea, SDS, DTT or heating.
3) digest
The recommended ratio of V8 protease and target protein is 1:20-1:100 (W/W).At 25 °C or 37 °C digest the protein 2-18h.
5.PRODUCT ADVANTAGE
(1)Sequence grade recombinant protein: high specificity,good stability.
(2)Animal origin free: Recombinant V8 Protease is no exogenous virus contamination,and any animal origin material is not used in the production process.
(3)Stable quality: Mass production can ensure stable and continuous batch production.It is no difference between the batch and the product quality is stable.
(4)High purity: Higher specific activity.Host protein residues is less than the limits of biological products.
(5)Lyophilized powder: The product is lyophilized powder and is easy to store and transport.
(6)Compliance with regulatory requirements: Production equipment and production environment comply with relevant regulatory requirements, and the production process is in full compliance with NSF ISO 9001: 2008 quality system and GMP guidelines.
(7)Complete quality documents: we can provide relevant regular support files in according to customers’ requirement.
6.RELATED PRODUCTS
Recombinant enterokinase
Sequencing grade trypsin
Sequencing grade chymotrypsin
Sequencing grade carboxypeptidase B
上海雅心生物技术有限公司主要从事基因工程蛋白酶的研发和生产,目前的主要品种为基因工程羧肽酶B和基因工程胰蛋白酶;为本公司自主研发,拥有自主知识产权。公司拥有自组研发团队,拥有世界先进的重组生物技术;自主研发的重组生物用酶为世界上生物用酶的首创!基因工程羧肽酶B和基因工程胰蛋白酶是由基因工程方法生产,纯度高,不含杂酶,无羧肽酶A、糜蛋白酶等其他蛋白酶活性;无动物源性,出口产品无需进行终产品的动物源性检验。制品中不含蛋白酶抑制剂,产品安全。 公司秉承“科技致胜”的理念,坚持“提供高纯度重组蛋白酶”,并愿与广大同行交流,有需求的客户提供优质的服务! 产品经多家医药公司检验和试用,认为符合重组人胰岛素生产的要求(5L和50L重组人胰岛素的生产),在纯度上高于sigma公司的产品(HPLC法);在比活上与sigma公司的产品类似。
| 单位名称: |
上海市徐汇区银都路466号1号楼101室
| 联系电话: |
| Email: |
