其它各类仪器
Beamon光束质量分析仪
Beamon光束质量分析仪
进口
duma
Beamon
 秒动科技供应BeamOn系列光束质量分析仪,组成:CCD相机、滤光片(NG4、NG9、NG10)、USB2.0通讯、CD软件、操作手册、包装箱子,该系列光束质量分析仪用于连续或脉冲激光器的光束质量的分析,包含:强度分布、光束宽度、光束形状、光束位置、激光功率。
Model
Descriptions
BeamOn-VIS-NIR
CCD camera (VIS 350-1310nm), a post, a set of 3×NG Schott filters (NG4,NG9,NG10) in housing on a filter wheel, a USB2.0 interface, CD disk, carrying case
BeamOn-UV-NIR
CCD camera (UV 190-1310nm), a post, a set of 3×NG Schott filters (NG4,NG9,NG10) in housing on a filter wheel, a USB2.0 interface, CD disk, carrying case
BeamOn-IR1550-USB
CCD camera (VIS 350-1310nm AND IR1550 +/-50nm), a post, a set of 3×NG Schott filters (NG4,NG9,NG10) in housing on a filter wheel, a USB2.0 attachment, CD disk, carrying case
BeamOn HR
Complete system with a camera, a USB2.0 cable, a post, a set of 3×ND filters in housing on a filter wheel (manual), software on CD disk, carrying case
BeamOn HR-AFW
Complete system with a camera, a USB2.0 cable, a post, a set of 3×ND filters in housing on motorized  Automatic Filter Wheel, software on CD disk, carrying case
BeamOn 2/3
2/3˝ CCD camera (VIS 350-1100nm), a post, a set of 3×NG Schott filters (1/8, 2x1/16) in housing, USB2.0 interface, CD disk, carrying case
BeamOn LB
USB2.0 type system for remote measurements, with a camera, USB2.0 cable, power supply 12V DC, 3×filters 1/8, software on CD disk
Optional accessories
NG4 Filter
1.6mm thick Schott NG4 filter in housing
NG9 Filter
1.6mm thick Schott NG9 filter in housing
NG10 Filter
1.6mm thick Schott NG10 filter in housing
SAM1
Attachment for high power lasers attenuation (up to 2 exe (-3))
SAM2
Attachment for high power lasers attenuation (up to 2 exe (-6))
SAM3-A
Reflective beam sampler, sampling reduction factor  0.0016, with mounting adapter for BeamOn / BeamOn HR
RDC×2
Attachment for viewing larger beams, factor of ×2
RDC FILT
Filter mounted on beam reducer, ×8 type
MOUNTB
Mounting base for BeamOn HR and accessories
ACC-SET
Full set of accessories, including: SAM1, SAM2, RDC×2, MOUNTB, 3×NG filters & adaptor
www.NewOpto.com
杭州新势力光电技术有限公司(www.NewOpto.com) 是2011年公司创建,主要从事光电产品及应用市场开发,包括氦氖激光器、微型激光器,应用领域包括精密测量、生物光子学、激光医疗。我们秉持简单有效的合作模式,提供标准化产品、OEM服务、ODM服务。此外我们还提供光电设备的进出口服务。
新势力光电www.NewOpto.com)面向光电领域的工业开发和科学研究,供应如下产品与服务:激光器半导体激光器固体激光器气体激光器光纤激光器窄线宽激光器可调谐激光器飞秒激光器Cobolt激光器Roithner激光器光学测量光束质量分析仪位敏探测系统光束准直系统光谱分析仪器激光功率计激光波长计红外观察仪透镜分析系统光学元器件激光防护眼镜光电探测器压力传感器滤光片可饱和吸收镜光源/LED光纤光学透镜SERS拉曼芯片单光子计数器体布拉格光栅激光显示卡太赫兹系统Rainbow太赫兹晶体及系统Batop太赫兹组件及系统Tydex太赫兹元件化学分析仪器Wilks化学分析仪器InfraSpec VFA-IR光谱仪InfraCal油脂分析仪InfraRan气体分析仪InfraCal Soot Meter烟尘仪)、Scientech电子分析天平
电话:0571-85152711
传真:0571-85152722
手机:153-5505-7810
企业QQ:1390164554
邮箱:Sales@NewOpto.com
中国浙江省杭州市西湖区西溪世纪中心2号楼828室
