流式细胞仪
CyTOF 2质谱流式细胞仪
CyTOF 2质谱流式细胞仪
进口
Fluidigm 富鲁达
CyTOF 2
The CyTOF® 2 system, the world’s most advanced mass cytometry platform, brings high-parameter capabilities to protein research, providing an unparalleled capacity to generate high-resolution phenotypic and functional profiles of cells from normal and diseased states.
The CyTOF 2 mass cytometer analyzes individual cells labeled with stable metal isotopes using state-of-the-art inductively coupled plasma time-of-flight technology. With more than 120 detection channels, the CyTOF 2 has the capability to simultaneously resolve multiple elemental probes per cell at high acquisition rates, thereby maximizing the per-cell information obtained from a single sample.
Mass cytometry employs elemental tags that are uncommon in biological systems. Cells stained with metal-conjugated probes in a single-cell suspension are introduced into the CyTOF 2 and undergo a multistep process within the instrument to detect these metal tags and record the identity and amount of each probe on each cell.
CyTOF 2
Specification
Channels 121
Mass Range 89–209 amu
Abundance Sensitivity 0.3% for 159Tb
Instrument Response 400,000 counts/pg 159Tb
Detection Limit 500 antibodies/cell
Dynamic Range 4.5 orders of magnitude
Calibration Automatic
Operating System Windows® 7 Pro 64-bit
Data Storage 720GB RAID (mirrored)
Sample Introduction Dual loop, syringe
Peak Throughput 1,000 events/sec
Flow Rate 45 μL/min
Replicate Sample CV (normalized) <3%
Width 97 cm (38 in)
Height 132 cm (52 in)
Depth 79 cm (31 in)
Weight 285 kg (628 lb)
Chiller
Specification​
Width 38 cm (15 in)
Height 64 cm (25 in)
Depth 67 cm (27 in)
Weight 81 kg (178 lb)
Workstation
Specification
Operating System Windows 7 Pro 64-bit
CPU Intel® Core™ i7 3930K
RAM 8 GB 2,400 MHz DDR3
Hard Drives 1.44 TB (6 x 240 GB SSD Corsair®
Force Series™ GS SATA3) in RAID 10 configuration
Data Storage 720 GB RAID (mirrored)
Video NVIDIA® NVS™ 310 x16 512 MB
Power Supply 650 W Antec® TruePower®
Serial Adapter Board 8 Port Native PCI Express RS232
Monitor ViewSonic® 24 in LED
Keyboard/Mouse Logitech® MK120 Wired
DVD/Blu-ray LG® SATA
Motherboard ASUS® P9X79 WS PRO
Enclosure Antec Titan 650
Data File Size imd    0.3 MB/sec/channel
fcs     12.4 bytes/event/channel
txt      2.4 bytes/event/channel
Width 20 cm (8 in)
Height 46 cm (18 in)
Depth 58 cm (23 in)
Weight 35 kg (77 lb)
Autosampler (optional)
Specification​
Sample Volume 50–900 μL
Sample Format 3 x 96-well plate, up to 2 mL deep well
Sample Resuspension Probe pipet motion
Reagent Reservoirs Carrier (DIW)       250 mL
Wash Solution    250 mL
Rinse (DIW)         250 mL
Flow Rate 45 μL/min
Width 39 cm (16 in)
Height 24 cm (10 in)
Depth 36 cm (14 in)
Weight 20 kg (44 lb)
Site Requirements​
Argon Gas Source Liquid or compressed gas
Pressure 522 ±7 kPa (80 ±1 psi)
Flow Rate 20 L/m
Purity ≥99.996%
Oxygen <5 ppm
Hydrogen <1 ppm
Nitrogen <20 ppm
Water <4 ppm
Exhaust Flow Rate 280 L/s (600 cfm)
Heat Dissipation 3,000 W (10,090 BTU/hr)
Electrical CyTOF 2 Two dedicated 30 A single-phase 220–240 V AC,50–60 Hz
Power Consumption 2 x 4,500 VA
Chiller Powered through instrument
Power Consumption 2,300 VA (via instrument)
Workstation 6 A, 100–240 V AC, 50–60Hz
Power Consumption 1,050 VA
Monitor 6 A, 110–230 V AC, 50–60 Hz
Power Consumption 100 VA
Autosampler 4.2 A, 100–240 V AC, 50–60 Hz
 思百拓(上海)仪器科技有限公司是美国Standard BioTools Inc在中国的全资子公司,负责面向中国市场的产品销售、技术支持及Standard BioTools 品牌的运营和推广。公司成立于2012年,总部位于上海市徐汇区。
         Standard BioTools一直以来致力于生命科学领域新技术、新仪器的研究和开发。拥有微流控芯片以及质谱流式等多项技术,产品线覆盖基因、蛋白和细胞水平的诸多研究领域,广泛用于肿瘤、免疫、单细胞及高通量基因分析的研究。我们的客户广泛分布于全球各地区,涵盖了学术组织、政府部门、制药厂商、生物技术公司、动植物研究实验室和其他相关机构。
         除了持续的技术开发以外,Standard BioTools 在全球范围内还有完善的客户支持服务,特别是在中国有一支业务过硬的销售、技术支持和工程师团队,为中国客户提供优质服务,帮助每个客户成功地运用我们的技术,并取得优异的研究成果。
上海徐汇区中山西路1600号宏汇国际广场A1709室
