实体/体视显微镜
KEWLAB SM-101 体视显微镜
KEWLAB SM-101 体视显微镜
Stereo Microscope
KEWLAB
SM-101
请电话咨询15168427495
产品概述:
SM-101是一款放大倍率为7X-45X、变焦范围为0.7X-4.5X的体视显微镜。
它将方便性和性能结合在一个紧凑的装置中。SM-101操作简单,成像清晰。工作距离长,视野大。此外还提供了多种配件,扩展了显微镜的功能性。
产品特点:
  • 0.7X-4.5X大变焦范围,可通过附加物镜达到0.35X-9X
  • 反射光源可调亮度
  • 可采用环形LED照明器或环形荧光照明器实现额外照明
  • 双目(SM-101-B),三目(SM-101-T)目镜筒
  • 可调视角
  • 与外部摄像机兼容
  • 大量配件可供选择,提高功能性和灵活性
  • 不同的底板和支架可以混合搭配,实现更优化的组合
产品参数:
目镜 WF10X(φ20mm)
总放大倍率 7X-45X
视场 φ28.5-φ4.5
照明 透射光源:12V/10W卤素灯,带反射器
反射光源:12V/10W卤素灯,亮度可调
工作距离 88mm
垂直有效行程 35mm<=h<215mm
底座尺寸 260×290×55mm
​更多体视显微镜产品,请移步KEWLAB中国官网
KEWLAB主营产品有离心机、显微镜、磁力搅拌器、顶置式电子搅拌器移液器、天平、混匀器、超声波清洗机、冷水机、水分仪、高速均质器、蠕动泵、恒流泵等系列实验室通用仪器和微型光谱仪、照度计、激光光束分析仪、光源、积分球、光学系统、光学棱镜、光学透镜、晶体光学、平面光学窗口和反射镜基底等系列光学仪器和元件。KEWLAB致力于推进科学事业,做您身边的仪器专家。
官网: www.kewlab.com.cn
电话: 0571-28121709
KEWLAB is dedicated to advancing the cause of science, and we do that by supplying optics, photonics and scientific laboratory instruments to both the scientific and the industrial community. It's surprisingly uncommon to find your perfect job nowadays, and despite the odds, that is precisely what we have done! Everyone here is an energetic, brilliant science supporter.
In the beginning humans developed tools, language, agriculture, and leisure; we then had the time to figure out how most of the gross mechanisms on our planet worked. We traced our origins, what had preceded us, and found clues and hints about what the future held in store. Humanity embraced knowledge, shedding ancient superstitions, in favour of experiments, study, and replicable results.
Our amazing KEWLAB crew has decades of accumulated experience in this field; we're ready to meet your toughest technical challenges worldwide. You really need to experience our premium optics and scientific products because the simple truth is that if you cannot measure and/or observe something, it is extremely difficult to learn very much from it.
Describe your optical, illumination, photonic or any scientific needs and let us craft your solution. You show us the path to the future, so let our dedicated staff provide you with the tools that you need to light the way.
KEWLAB Pty Ltd
513/370 St Kilda Road
Melbourne, VIC 3004
Australia
info@kewlab.com
浙江省杭州市上城区民心路100号万银国际2406室
