BioBank智能化超低温储存系统
Automated -80°C sample library for microplates and cryotube racks in SBS format; for integration into automated processes.
The BioBank is the only automated -80C sample library with all robotics outside of the cold area (for maximum reliability.)
• Samples are stored at -80C.• The cold storage area is based on a proven chest freezer design that keeps temperatures uniformly cold.• The unique rack storage system minimizes exposure of the samples to ambient temperatures, and allows easy sample access.• Frost buildup never compromises the sample or interferes with the sample management process, with chamber air being maintained at < 5% relative humidity at all times.
The BioBank is ideal for the storage and retrieval of sensitive biological samples :
Store more samples - The BioBank is an automated sample storage and retrieval system with a capacity of nearly 1000 microplates.
Protect the samples from the effects of heat - Storage temperature of -80C keeps cells and tissues viable in applications such as biorepositories, cell libraries, and libraries of very thermosensitive molecules.
Protect the samples in case of unexpected problems - Based on a high quality -80C chest freezer, the Biobank is fitted with safety assurance systems such as CO2 backup and remote alarm. Robot maintenance can be performed without opening the cold area.
Fast and reliable storage and retrieval – The BioBank has a patented rack and robotic system that optimizes automated storage and retrieval of samples. The relative humidity in the robotics enclosure is always < 5%, minimizing frost buildup at all times. Samples are always easily accessible.
Capacity : | 984 standard microplates
510 half deep-well microplates 354 full deep-well microplates 312 cryotube racks (SBS format) |
Storage Volume, Nominal : | 440 liters |
Sample Access Time : | < 40 seconds in direct control mode |
Temperature Control : | -86C (ambient operating environment between +5C and +25C) |
Automated Operations : | Rack-based storage and handling. All robotics in ambient temperature environment for problem-free, low cost operation |
Communications Interfaces : | RS 232, RS 485 |
Electrical Characteristics : | 208-230V/50-60Hz (set at installation) 1800 W max. power consumption |
Humidity Control : | <5% relative humidity, no frost buildup (operating environment max. 70% RH at +25C) |
Dimensions (H x W x D) : | 199 cm x 217 cm x 115 cm (78 x 85 x 45 in) |
Weight : | 450 kg (990 lbs) |
Options and Accessories : | CO2 Backup Kit for BioBank |
赛默飞中国实验室产品事业部是赛默飞世尔科技(中国)有限公司的业务之一,由实验室设备、实验室耗材、实验室化学品和第三方产品业务合并而成。根据用户需求提供涵盖赛默飞和第三方品牌的实验室产品和实验室建设整体解决方案,客户遍布生物制药、学术研究、健康医学和工业与应用科学等领域。
销售联系:16710496996
售后支持:400 650 5118 转1
单位名称: |
上海浦东新金桥路27号7号楼
联系电话: |
Email: |
