其他离心机
GQ高速管式离心机
GQ高速管式离心机
上海浦东天本离心机械有限公司
GQ系列
工作原理:
  分离机由机身、传动装置、转鼓、集液盘、进液轴承座组成。转鼓上部是挠性主轴,下部是阻尼浮动轴承,主轴由联接座缓冲器与被动轮联接,电动机通过传送带,张紧轮将动力传递给被动轮,从而使转鼓绕自身轴线高速旋转,形成强大的离心力场。物料由底部进液口射入,离心力迫使料液沿转鼓内壁向上流动,且因料液不同组分的密度差而分层。
  GF型,密度大的液相形成外环,密度轻的液相形成内环,流动到转鼓上部各自的排液口排出,微量固体沉积在转鼓壁上,待停机后人工卸出。GQ型,密度较大的固体微粒逐渐沉积在转鼓内壁形成沉渣层,待停机后人工卸出,澄清后的液体流动到转鼓上部的排液口排出。
Working Principle
This separator is consisted of main body, driving device, bowl collecting pan and liquid-in bearing. The upper of the bowl is fiexible mainshaft and thelower of it is damp floating bearing. The mainshaft is connected through and with a buffer of connecting seat and a vdriven wheel. The driven wheel is driven by a motor through driving wheel and tension gear to make the bowl rotate around its own ax is at a extra speed and form a strong centrifuge force field. The stock flows into the liquid inlet from the bottom and is forced by centrifuge force to flow upto and along theinner wall of the bowl and then is separated the different layer according to density difference of the different liquid components. GFtype: Liquid phase with great density forms an outer loop and liquid phase with light density forms an inner loop, and flows to the upper of the bowl out of their respective liquid outlet. The little solid is settled on the inner wall of the bowl and then is discharged manually after the machine stops.
GQtype: Fine solid phase particles with great density are settled on the inner wall of the bowl gradually to form residne layer then to be discharged manually, after the machine stops. The liquid phase flows out of the liquid outlet at the bowl''s upper after clarification.
主要用途:
  高速管式分离机主要用于生物医学、中药制剂、保健食品、饮料、化工等行业的液固或液液固三相分离。是目前用离心法进行分离的理想设备。最小分离颗粒为1微米,特别对一些液固相比重差异小,固体粒径细、含量低,介质腐蚀性强等物料的提取、浓缩、澄清较为适用。
*特殊物料的分离可带料来本公司做选型分离实验,公司也可根据客户要求定制特殊材质的管式机。
Main Purposes
High speed tubular centrifuge is an ideal instrument in biology, traditional medicine preparation, health food, chemistry for liquid separating and solid liquid separating. The minimun diameter of dissociative granule is 1 micron. It is especially separated for low differential proportion, small granularity, low solid content, strong medium corrosion, fuel distilled, and concentration and clarify. If you want to separate special material, please bring it to out company to do the separating test. We can also make the special material tubular centrifuge Instrument requested by customer.
各型号主要技术参数 Main Specifcations
型号
Model
分离筒内径
Cylinder
Diameter (mm)
分离筒容积
Cylinder
Cubage (l)
分离筒转速
Cylinder
Speed(r/min)
最大离心力
R.C.F.
(xg)
通水能力
Throughput
Capacity(t/h)
电机功率
Motor
Power(kw)
电源
Operating
Voltage(v)
重量
Weight(kg)
外形尺寸
Dimension
(mm)
GQ145(J)
145
11
14000
15900
1.5
3
AC380
800
890×580×1670
GQ105
105
6
16000
15050
1.2
3
AC380
400
700×450×1600
GQ105B(J)
105
6
16000
15050
1.2
3
AC380
400
700×450×1600
GF105
105
6
16000
15050
1.2
3
AC380
400
700×450×1600
GQ75
75
2
20000
16700
0.2
1.5
AC380
200
660×390×1200
GQ75B
75
2
20000
16700
0.2
1.5
AC380
200
660×390×1200
重要说明:1)管式离心机的实际生产能力视分离介质和分离效果而定。2)如需在低温下分离介质,厂方可根据用户要求安装冷却管道,冷源自配。
3)GQ-液固分离;GF-液液固分离;145、105、75-转筒内径(mm);B-机身全不锈钢;J-机身外包不锈钢。
上海浦东天本离心机械有限公司位于上海浦东新区东海之滨的机场镇(近浦东机场)。公司从事离心机研发和制造,始于1995年(上海云帆离心机设备有限公司),是生产离心机的专业企业,是制药机械和化工装备行业定点企业。本公司对离心机械的研制、开发、制造已有10年历史,生产5大系列20多个品种。产品严格按照行业标准设计制造,对产品质量和生产的整个过程实施全过程跟踪管理。
“天本”将奉行“以人为本,科技兴企,质量第一,用户满意”的经营理念,贯彻ISO9001全面质量保证体系和用户满意机制,为制药、食品、化工、污水处理等行业的新老客户提供高科技含量、低运营成本的分离技术装备。
“天本”愿以“以诚为天,以信为本”的企业精神与各界朋友携手并进,共创未来。
上海浦东新区川六公路2699号
021-58599339、58599398-803
