其他离心机
卧式螺旋卸料沉降离心机系列
卧式螺旋卸料沉降离心机系列
Solid-bwol Centrifuge Series
上海浦东天本离心机械有限公司
LW系列
结构和工作原理:
  本系列离心机主要由锥形转鼓,螺旋推料器,行星差速器,机壳和机座等零部件组成。转鼓通过主轴承水平安装在机座上,并通过联接盘与差速器外壳相连。螺旋推料器通过轴承同心安装在转鼓内,并通过外花键与差速器输出轴内花键相连。
在电机拖动下,转鼓带动差速器外壳旋转,由于差速器的变速作用,螺旋推料器以一定的差速(超前或滞后)与转鼓同向旋转。待分离的悬浮液从加料管进入螺旋推料器的料仓内,经初步加速后经料仓出口进入转鼓。由于离心力的作用,转鼓内的悬浮液很快分成两相:较重的固相沉积在转鼓外层。在螺旋推料器的作用下,沉渣和分离液向相反的方向运动,沉渣被推送到锥段进一步脱水后经出渣口排出,分离液从大端溢流孔排出。
Construction Working Principle:
This machine is primarily composed of an awl-like bowl, a carrier, a planetary differential device, a case and a chassis base, etc. The bowl is installed holrizontally on the chassis base through shaft, and is connected to the outer case of the differential edvice. The scroll-carrier is installed inside the bowl through the bearing, which is then connected through outer spline to the spline inside of output bearing of the differential device. Led by motor, the bowl rotates together with the outer case of the differential device, due to the speed charnge function of the differential device, the scrool-carrier rotates in the same diretion with the bowl. The suspended liquid is fed into the material calin through the inlet, then enters the bowl after initial speeding. Under the centrifugal force, the suspended liquid inside the bowl is soon split into two parts, the solid is left onto the walls of the bowl to form a layer of sediments, while theliquid form a layer of separated liquid. They go in opposite directions under the centrifugal force. The sediments are sent back to the awl-like bowl for further dewatering and then discharge through solid outlet, the separated liquid discharges through liquid outlet.
主要技术参数 Main Specifcations :
型号
型号
转鼓直径:(mm)
最高转速:(r/min)
转鼓长度:(mm)
长径比:
分离因素:
生产能力:(m3/h)
最大排渣能力:(m3/h)
主电机功率:(kw)
重量:(kg)
外形尺寸(LxWxH)(mm)
LW220X600
220
5100
660
3
3200
0.3~1.5
0.2
7.5~11
700
1520x1080x640
LW220x930
220
4800
930
4.2
2800
0.5~3
0.25
11~15
900
1790x1080x640
LW350x1050
350
4000
1050
3
3100
1~10
0.6
11~15
1200
2330x1300x880
LW350x1550
350
3700
1550
4.4
2600
1~15
0.8
15~18.5
1800
2790x1300x880
LW400x1200
400
3400
1200
3
2590
1.5~15
1
18.5~22
1800
2400x1400x850
LW400x1750
400
3200
1750
4.4
2290
1.5~20
1.4
18.5~30
2200
2950x1400x850
LW450x1350
450
3100
1350
3
2420
3~20
1.6
15~22
2200
2750x1500x920
lw450x1940
450
2800
1940
4.3
2030
3~30
1.8
22~30
2500
3300x1500x920
上海浦东天本离心机械有限公司位于上海浦东新区东海之滨的机场镇(近浦东机场)。公司从事离心机研发和制造,始于1995年(上海云帆离心机设备有限公司),是生产离心机的专业企业,是制药机械和化工装备行业定点企业。本公司对离心机械的研制、开发、制造已有10年历史,生产5大系列20多个品种。产品严格按照行业标准设计制造,对产品质量和生产的整个过程实施全过程跟踪管理。
“天本”将奉行“以人为本,科技兴企,质量第一,用户满意”的经营理念,贯彻ISO9001全面质量保证体系和用户满意机制,为制药、食品、化工、污水处理等行业的新老客户提供高科技含量、低运营成本的分离技术装备。
“天本”愿以“以诚为天,以信为本”的企业精神与各界朋友携手并进,共创未来。
上海浦东新区川六公路2699号
021-58599339、58599398-803
