其它自动化设备
高级稀释系统 ADS 2 智能自动稀释器
Advanced Dilution System ADS 2
进口
安捷伦 Agilent
Advanced Dilution S
The Agilent Advanced Dilution System 2 (ADS 2) is an integrated auto dilution system. The ADS 2 can simplify your laboratory workflow by automating several laborious and error-prone tasks, such as preparing calibration standards, diluting samples before analysis, and preparing reactive dilutions for over-range samples and QC solution failures. Automating these tasks frees up analyst time, removes the risk of human error, and improves sample throughput.
The ADS 2 is designed to work seamlessly with Agilent ICP-OES and ICP-MS spectrometers and is fully integrated into the ICP Expert and ICP-MS MassHunter instrument control software, giving you complete control. Designed with productivity and simplicity in mind, discover how the ADS 2 could transform your laboratory workflows.
Features
  • Autocalibration Assistant can recommend calibration standards and calculate the dilution factors required to accurately create each standard at the required concentration
  • Optimized sample analysis times as samples not requiring dilution bypass the dilutor, ensuring maximum throughput
  • Customized Analyte Dilution Lists allow you to exclude elements from triggering over-range dilution, as required, avoiding unnecessary dilutions
  • Results summary that selects the optimal results for a set of sample measurements, simplifying data analysis and reporting
  • Simplified method setup with parameter settings optimized for tubing and sample loop length ensuring you are up and running as soon as possible
  • Small footprint for close coupling with the ICP and autosampler, allowing you to minimize tubing lengths and maximize sample throughput
  • Real-time flow-path animation shows the direction of flow for sample, internal standard, rinse, diluent, and carrier solutions, giving you total visibility during setup, maintenance, and troubleshooting
  • Comprehensive Help and Learning Center to aid quick setup, simplify user training, and troubleshooting
  • Early Maintenance Feedback that automatically indicates when cleaning and maintenance is required, with traffic light color-coding of counters to quickly show which activities need attention
  • Instrument tests verify operational status giving you total confidence in the operation of your hardware
Automatic Standard Preparation
Automatically prepare calibration standards for your sample analysis from purchased or lab-prepared stock solutions. Utilize the autocalibration assistant to specify the calibration range and desired number of standards. The ADS 2 autodilutor can prepare up to 400-fold dilutions, minimizing reagent handling, enhancing safety, and reducing contamination.
Automatic Prescriptive Dilution
Streamlining sample preparation is crucial in analytical labs. Pre-analysis dilutions of common samples (such as soil, seawater, and chemicals) consume significant analyst hours. Prescriptive autodilution automates this process, freeing up time for more valuable tasks. The ADS 2 ensures precise sample delivery to the ICP at a user-defined dilution factor, enhancing result quality and reducing labware usage.
Automatic Reactive Dilution
In less predictable samples like groundwater and wastewater, analyte concentrations often surpass the method’s calibration or linear range. At the same time, unexpectedly high matrix samples can lead to internal standard failure, necessitating time-wasting, post-analysis dilution, and re-analysis. Agilent’s ADS 2 intelligently calculates the required dilution factor to ensure samples fall within the valid calibration range. The results summary report then selects and displays optimal results for each element, streamlining data review.
安捷伦科技公司是生命科学和分析仪器系统的主要供应商,向全世界的生命科学、医药、环保和化工领域的科学工作者提供服务。安捷伦科技公司为科学提供成功采集并解释遗传基因和化学信息所需范围广泛的仪器、系统和服务。包括样品处理、分析及数据管理报告。我们致力于提供高标准的技术,提供最高的生产率、最大限度地节约成本并易于遵循法规要求。
官方服务热线:400 820 3278(手机拨打),800 820 3278(座机拨打)
北京市朝阳区望京北路3号
