PlantScreen植物高通量XYZ表型成像分析平台
PlantScreen 植物高通量表型成像分析平台(XYZ三维扫描版)
PlantScreen植物表型成像系统由捷克PSI公司研制生产,整合了Robotic自动化控制系统、智能LEDs光照培养系统、叶绿素荧光成像测量分析、植物热成像分析、植物近红外成像分析、植物高光谱分析、自动条码识别管理、RGB真彩成像等多项先进技术,以最优化的方式实现大量植物样品——从拟南芥、玉米到各种其它植物的全方位生理生态与形态结构成像分析,用于高通量植物表型成像分析测量、植物胁迫响应成像分析测量、植物生长分析测量、生态毒理学研究、性状识别及植物生理生态分析研究等。XYZ三维扫描版PlantScreen的优势在于可以在一套系统中同时测量高度差异较大的不同植物样品,比如同时培养测量拟南芥和玉米。
PlantScreen系统包括如下成像分析功能:
1. 大型叶绿素荧光成像分析:单幅成像面积35x35cm,成像测量参数包括Fo, Fm, Fv, Fo’, Fm’, Fv’, Ft, Fv/Fm, Fv’/Fm’, Phi_PSII, NPQ, qN, qP, Rfd等几十个叶绿素荧光参数
2. RGB成像分析:成像测量参数包括:
1) 叶面积(Leaf Area: Useful for monitoring growth rate)
2) 植物紧实度/紧密度(Solidity/Compactness. Ratio between the area covered by the plant’s convex hull and the area covered by the actual plant)
3) 叶片周长(Leaf Perimeter: Particularly useful for the basic leaf shape and width evaluation (combined with leaf area))
4) 偏心率(Eccentricity: Plant shape estimation, scalar number, eccentricity of the ellipse with same second moments as the plant (0...circle, 1...line segment))
5) 叶圆度(Roundness: Based on evaluating the ratio between leaf area and perimeter. Gives information about leaf roundness)
6) 叶宽指数(Medium Leaf Width Index: Leaf area proportional to the plant skeleton (i.e. reduction of the leaf to line segment))
7) 叶片细长度SOL (Slenderness of Leaves)
8) 植物圆直径(Circle Diameter. Diameter of a circle with the same area as the plant)
9) 凸包面积(Convex Hull Area. Useful for compactness evaluation)
10) 植物质心(Centroid. Center of the plant mass position (particularly useful for the eccentricity evaluation))
11) 节间距(Internodal Distances)
12) 生长高度(Growth Height)
13) 植物三维最大高度和宽度(Maximum Height and Width of Plant in 3 Dimensions)
14) 相对生长速率(Relative growth rate)
15) 叶倾角(Leaf Angle)
16) 节叶片数量(Leaf Number at Nodes)
17) 其它参数如用于植物适合度估算的颜色定量分级、绿度指数(Other parameters such as color segmentation for plant fitness evaluation, greening index and others)
3. 高光谱成像分析(选配),可成像并分析如下参数:
1) 归一化指数(Normalized Difference Vegetation Index (NDVI))
2) 简单比值指数(Simple Ratio Index, Equation: SR = RNIR / RRED)
3) 改进的叶绿素吸收反射指数(Modified Chlorophyll Absorption in Reflectance Index (MCARI1),
Equation: MCARI1 = 1.2 * [2.5 * (R790- R670) - 1.3 * (R790- R550)])
4) 最优化土壤调整植被指数(Optimized Soil-Adjusted Vegetation Index (OSAVI)
, Equation: OSAVI = (1 + 0.16) * (R790- R670) / (R790- R670 + 0.16))
5) 绿度指数(Greenness Index (G), Equation: G = R554 / R677)
6) 改进的叶绿素吸收反射指数(Modified Chlorophyll Absorption in Reflectance Index (MCARI),
Equation: MCARI = [(R700- R670) - 0.2 * (R700- R550)] * (R700/ R670))
7) 转换类胡罗卜素指数(Transformed CAR Index (TCARI)
, Equation: TSARI = 3 * [(R700- R670) - 0.2 * (R700- R550) * (R700/ R670)])
8) 三角植被指数(Triangular Vegetation Index (TVI)
Equation: TVI = 0.5 * [120 * (R750- R550) - 200 * (R670- R550)])
9) ZMI指数(Zarco-Tejada & Miller Index (ZMI), Equation: ZMI = R750 / R710)
10) 简单比值色素指数(Simple Ratio Pigment Index (SRPI), Equation: SRPI = R430 / R680)
11) 归一化脱镁作用指数(Normalized Phaeophytinization Index (NPQI), Equation: NPQI = (R415- R435) / (R415+ R435))
12) 光化学植被反射指数(Photochemical Reflectance Index (PRI), Equation: PRI = (R531- R570) / (R531+ R570))
13) 归一化叶绿素指数(Normalized Pigment Chlorophyll Index (NPCI), NPCI = (R680- R430) / (R680+ R430))
14) Carter指数(Carter Indices
, Equation: Ctr1 = R695 / R420; Ctr2 = R695 / R760)
15) Lichtenthaler指数(Lichtenthaler Indices
, Equation: Lic1 = (R790 - R680) / (R790 + R680); Lic2 = R440 / R690)
16) SIPI指数(Structure Intensive Pigment Index (SIPI), Equation: SIPI = (R790- R450) / (R790+ R650))
17) Gitelson-Merzlyak指数 (Gitelson and Merzlyak Indices
Equation: GM1 = R750/ R550; GM2 = R750/ R700)
4. 热成像分析(选配):用于成像分析植物在光辐射情况下的二维发热分布,良好的散热可以使植物耐受较长时间的高光辐射或低水条件(干旱)
5. 近红外成像分析(选配):用于观测分析植物的水分状态及其在不同组织间的分布变异,处于良好浇灌状态的植物表现出对近红外光谱的高吸收性,而处于干旱状态的植物则表现出对近红外光谱的高反射性,通过分析软件可以监测分析从干旱胁迫到再浇灌过程中的整个过程动态及植物对干旱胁迫的响应和水分利用效率,并形成假彩图像,可以与植物的形态指数及叶绿素荧光指数进行相关分析研究。
系统配置与工作原理:
技术指标:
产地:欧洲
北京易科泰生态技术有限公司成立于2002年,为中关村高新技术企业,致力于生态-农业-健康研究监测技术推广、研发与服务,特别是在光谱成像技术(高光谱成像技术、叶绿素荧光成像技术、红外热成像技术、无人机遥感等)、植物表型分析技术、呼吸与能量代谢测量技术等方面,与国际领先企业PSI、Specim、Sable等合作,致力于植物科学、土壤与地球科学、动物能量代谢、水体与藻类及生态环境领域先进仪器技术的引进推广和技术研发集成,为植物/作物表型分析、生态修复及生态保护、能量代谢测量等提供规划设计、技术方案与系统集成、技术咨询与科技服务。公司技术团队80%以上具备硕士或硕士以上学位,并与中国科学院研究生院、中科院植物研究所、中科院动物所、中科院地理科学与资源研究所、中国农科院、中国林科院、中国环科院、中国水科院、清华大学、中国农业大学、北京林业大学、北京大学、中国海洋大学、陕西师范大学、内蒙古大学等建立了长期的技术合作交流关系。
公司下设有叶绿素荧光技术与植物表型业务部、EcoTech®实验室、光谱成像与无人机遥感事业部及无人机遥感研究中心(与陕西师范大学合作建立)、动物能量代谢实验室、内蒙古阿拉善蒙古牛生态牧业研究院及青岛分公司。实验室拥有叶绿素荧光成像、叶绿素荧光仪、水体藻类荧光仪、SPECIM高光谱仪、WORKSWELL红外热成像仪、EasyChem全自动化学分析仪、MicroMac1000水质在线监测系统、ACE土壤呼吸自动监测系统、SoilBox便携式土壤气体通量测量系统、动物呼吸测量系统、LCpro+光合作用测量仪、Hood土壤入渗仪、年轮分析仪等各种仪器设备,可以进行实验研究分析、实验培训等,欢迎与易科泰生态研究室开展合作研究。
易科泰公司与欧洲PSI公司(叶绿素荧光技术与表型分析技术)、美国SABLE公司(动物能量代谢技术)、欧洲SPECIM公司(高光谱成像技术)、欧洲WORKSWELL公司(红外热成像技术)、欧洲Lightigo公司(LIBS元素分析技术)、欧洲BCN无人机遥感中心、欧洲ITRAX公司(样芯密度扫描与元素分析)、美国VERIS公司、英国ADC公司、德国UGT公司、欧洲SYSTEA公司等国际著名生态仪器技术领域的研发机构和厂商建立了密切的合作关系,在FluorCam叶绿素荧光成像与荧光测量技术、PlantScreen植物表型分析技术、高光谱成像技术、红外热成像技术、光合作用与植物生理生态研究监测、土壤呼吸与碳通量研究监测、动物呼吸代谢测量、水质分析与藻类研究监测、CoreScanner样芯密度CT与元素分析技术、LIBS元素分析技术、无人机生态遥感技术等生态仪器技术及其系统方案集成有着丰富的经验,成为我国农业、林业、地球科学、生态环境研究等领域科技进步的重要研究技术支持力量。由公司研制生产的EcoDrone®无人机遥感平台、SoilTron®多功能小型蒸渗仪技术、SoilBox®土壤呼吸测量技术、PhenoPlot®轻便型作物表型分析系统、SCG-N土壤剖面CO2/O2梯度监测系统、植物生理生态监测技术、动物能量代谢测量技术等,在中科院修购项目、农业部学科群项目、CERN网络(生态系统监测网络)等项目中发挥重要作用。
“工欲善其事,必先利其器”,易科泰公司将秉承“利其器,善其事”的经营理念,为国内生态-农业-健康研究与发展提供最优的技术方案和服务。
单位名称: |
北京市海淀区高里掌路3号院6号楼1单元101B
联系电话: |
Email: |
