美国cirs403多普勒超声模体
美国 CIRS 多普勒 403 模体
验证超声系统和换能器的性能。多普勒403TM和Mini-Doppler 1430TM Flow Phantoms使用精确流速和专有的血液模拟液帮助评估系统速度。
对多普勒超声系统进行精确的流量测量可以优化输出,为接受无创检测的患者提供有意义的结果。
扫描倾斜的容器显示颜色流动灵敏度深度。
DopplerFlow_113020
精密的脉动流模式,允许您可靠地测试系统速度
•HE(高等效性)GelTM已获得专利并经过验证
-帮助确保所有传感器和系统设置在整个频率范围内从2到18 MHz进行充分测试
-衰减对频率的响应
超过8 MHz支持精确的轴向分辨率和穿透深度代表人体组织
Doppler 403 Flow Phantom
The reference standard in Doppler Ultrasound QA
Laminar and parabolic flows are available (velocity
dependent)
Includes the Sono Transducer Holder
New blood mimicking fluid formulation
No need to ever purchase or store blood mimicking fluid
Increased viscosity and decreased Reynolds number Mini-Doppler 1430 Flow Phantom
Ideal for cardiology and musculoskeletal (MSK) applications
Portable and lightweight (<10 lbs / 4.6 kg) Common Highlights
Patented multi-frequency HE GelTM
Constant and pulsatile flow modes
Rugged, self-contained, battery-operated
The Sono Transducer Holder Accessory fits any Gammex phantom including the Sono Family and Doppler Flow phantoms.
Place a transducer in a precise location in the holder for reproducible tests over time
Support the transducer cable with the cable hook
Securely holds a transducer in a precise location to help you perform reproducible QC tests
Volume flow settings on the phantom support reliable system velocity testing.
“The tissue-like properties in Sun Nuclear ultrasound phantoms make them ideal for testing the performance of scanners.“
| 单位名称: |
北京市朝阳区裕民路12号E1座1038
| 联系电话: |
| Email: |
