IM B-3217UP SpecificationSpecification SpecificationSpecificationSpecification SpecificationSpecification SpecificationSpecificationSpecification Features(IM Features(IMFeatures(IMFeatures(IMFeatures(IMFeatures(IMFeatures(IMFeatures(IMFeatures(IMB-3217UP)
Image Sensor TypeImage Sensor Type Image Sensor TypeImage Sensor TypeImage Sensor TypeImage Sensor TypeImage Sensor TypeImage Sensor TypeImage Sensor TypeImage Sensor TypeImage Sensor TypeImage Sensor Type Image Sensor TypeImage Sensor Type
Mono Mono Mono 1/ ” CMOS ( ” CMOS ( ” CMOS ( ” CMOS ( ” CMOS ( ” CMOS ( ” CMOS ( PYTHON PYTHON PYTHON PYTHON PYTHON 00 )
Effective pixelsEffective pixelsEffective pixelsEffective pixelsEffective pixelsEffective pixelsEffective pixels Effective pixelsEffective pixelsEffective pixelsEffective pixelsEffective pixelsEffective pixelsEffective pixels
1, 310 ,72 0 pixelspixelspixelspixelspixels
Picture SizePicture Size Picture SizePicture SizePicture SizePicture SizePicture SizePicture SizePicture Size Picture Size
1280 (H) x 1024 (V)(V)(V)
Cell Size(um)Cell Size(um)Cell Size(um) Cell Size(um)Cell Size(um)Cell Size(um)Cell Size(um)Cell Size(um)Cell Size(um)Cell Size(um)Cell Size(um)
4.84.84.8 um xum xum xum x4.84.84.8 um
Real Frame RateReal Frame RateReal Frame RateReal Frame Rate Real Frame Rate Real Frame RateReal Frame Rate Real Frame RateReal Frame RateReal Frame RateReal Frame Rate
128 fpsfpsfps (1280 x1024 , Mono8), Mono8), Mono8) , Mono8), Mono8), Mono8)
70 fpsfpsfps (1280 x1024 , Mono Mono12 )
Lens MountLens MountLens MountLens MountLens MountLens Mount Lens MountLens Mount
C/C S-Mount MountMount
ShutterShutterShutterShutterShutterShutterShutter
Global GlobalGlobalGlobal ShutterShutterShutterShutterShutterShutterShutter
ROI
Partial ScanPartial ScanPartial ScanPartial ScanPartial Scan Partial ScanPartial ScanPartial ScanPartial Scan (Unit: 4x4)
Trigger Mode
Mode 0, 15 (Photo-coupler)
Strobe
Support Normal Mode (Photo-coupler)
Memory Save/Load
9 Channels(0:factory, 1~4:feature, 5~8:mode/feature)
Control Functions
Brightness, Sharpness, Gamma, Auto-Exposure, Shutter, Gain,
User Defined LUTUser Defined LUTUser Defined LUTUser Defined LUTUser Defined LUTUser Defined LUTUser Defined LUTUser Defined LUTUser Defined LUT User Defined LUTUser Defined LUTUser Defined LUTUser Defined LUTUser Defined LUT,
Digital Interface / Transfer Rate
USB3.0USB3.0USB3.0USB3.0USB3.0USB3.0 / 5Gbps
Gain
0 ~ 30 dB (Manual or Auto control)
Shutter Speed
1 usec ~ 1000 msec (Manual or Auto control)
Data Depth
10 bit
Supply Voltage& Power
Supplied via the camera’s USB 3.0 port
~ 3 W max. @ 5 VDC
External Dimension / Weight
44(W) x 44 (H) x34.5(D) mm / Approx 55g
Operation Temp/ Storage TempStorage TempStorage TempStorage TempStorage TempStorage TempStorage TempStorage TempStorage Temp Storage Temp
-5°C to 45°C / -30°C to 60°C
Camera Specification
Mono Camera Spectral Response
IMB-3217UP Spectral Response (From Sensor Data Sheet)
General Description of the Camera Connections
The camera is interfaced to external circuitry via connectors located on the back of the camera:
A 4-pin socket connector used to provide access to the camera’s I/O lines
A USB 3.0 Micro-B port used to provide a nominal 5 Gbit/s SuperSpeed data transfer connection.
There is also a LED indicator located on the back of the camera.
Camera Connector and LED Indicator Camera Connector and LED IndicatorCamera Connector and LED IndicatorCamera Connector and LED IndicatorCamera Connector and LED IndicatorCamera Connector and LED Indicator Camera Connector and LED IndicatorCamera Connector and LED IndicatorCamera Connector and LED IndicatorCamera Connector and LED Indicator Camera Connector and LED IndicatorCamera Connector and LED Indicator Camera Connector and LED IndicatorCamera Connector and LED Indicator Camera Connector and LED Indicator Camera Connector and LED IndicatorCamera Connector and LED Indicator
Camera Connector Types, Connection Numbering,
and Assignments
I/O Connector
The I/O connector on the camera is a 4-pin socket connector.
It is used to access the physical input and output lines on the camera.
Pinout for the I/O Connector and Related Designations
LED Indicator
USB 3.0 Connector
I/O Connector
1
2
3
4
