流式抗体FITC Anti-Human CD2 Antibody(TS1/8)
产品介绍
| 产品名称 | FITC Anti-Human CD2 Antibody(TS1/8) |
| 货号 | SNFA-1799 |
| 规格 | 20T/100T |
| 偶联物 | Sunncell Violet 450 |
| 激发及发射波长 | Sunncell® Violet 450 is designed to be excited by the violet laser (405 nm) and detected using an optical filter centered near 450 nm (e.g., a 450/45 nm bandpass filter). |
| 抗体类型 | Monoclonal |
| 克隆性 | G034E3 |
| 抗体亚型 | IgG2b, κ |
| 反应性 | Human |
| 应用范围 | FC |
| 抗原名称 | Human CD196/CCR6 |
| 基因ID | 1235 |
| 克隆性 | P51684 |
| 抗原别名 | CMKBR6|GPR29|STRL22|CKRL3|GPRCY4|CCR6 |
| 抗原背景 | CCR6, also known as CD196/CCR6, is a chemokine receptor that is expressed on immature dendritic cells, B lymphocytes, and memory T cells. CCR6 binds CCL20, although members of the β defensin family also bind CCR6 with a lower affinity. CCR6 positive cells, and its ligand CCL20, have been detected in numerous organs, especially the secondary lymphoid organ. CCL20 is selectively made by the follicle-associated epithelium (FAE) overlying Peyers Patches (PPs) and isolated lymphoid follicles (ILFs). CCL20 contributes to the recruitment of CCR6-expressing B cells to these structures. In humans, CCR6 can function to mediate arrest of T cells on dermal endothelial cells and is highly expressed on T cells resident in both normal and psoriatic skin. CCR6 and/or CCL20 have been implicated in the pathogenesis of rheumatoid arthritis and inflammatory bowel disease. Human T cells that are able to produce IL-17 express CCR6. It suggests that CCL20 and CCR6 have a role in inflammatory diseases by recruiting Th17 cells to target tissues. |
| 状态 | liquid |
| 储存 | PBS with 0. 1% sodium azide, 1%BSA, pH 7.3, 2-8℃ for 12 months (Avoid repeated freeze / thaw cycles.) |
| 使用方法 | Volume per test: 5μL. Each lot of this antibody is quality control tested by flow cytometric analysis. The amount of the reagent is suggested to be used 5 µL of antibody per test (million cells in 100 µL staining volume or per 100 µL of whole blood). Please check your vial before the experiment. Since applications vary, the appropriate dilutions must be determined for individual use. | 注意事项 | FITC Anti-Human CD2 Antibody(TS1/8)仅供科研使用 |
流式抗体是一类专门用于流式细胞术的抗体,通过与荧光标记物结合,从而实现对细胞表面或内部的特定蛋白质进行精确检测和定量分析。流式抗体广泛应用于生物医学研究、临床诊断、药物开发和生物工程等领域。尚恩推出亲和力高,特异性好的经典克隆细胞株纯化抗体,产品涵盖人、大鼠、小鼠等,指标丰富,可选择性多。同时尚恩生物提供免费的配色,实验指导和数据分析服务,为您提供整体流式解决方案。
染料标记类型
现有超过十种染料类型,满足多色流式实验配色需求。
数据展示
| 单位名称: |
武汉东湖新技术开发区高新二路388号武汉光谷国际生物医药企业加速器1.2期C22栋二层
| 联系电话: |
| Email: |
