四川成都DOP液槽高效过滤器\四川成都制药厂液槽高效过滤网
侧液槽高效空气过滤器
HEPA filter sump
特点Features
●效率高、阻力低
●重量轻、安装方便
●适用于制药、医院、食品卫生、微生物等高等级密封空气净化末端
●High efficiency, low resistance
●Light weight, convenient installation
●For pharmaceutical, hospital, food hygiene, microbiology and other high-grade air purification at the end sealed
构成材料及运行条件四川成都DOP液槽高效过滤器\四川成都制药厂液槽高效过滤网
Materials and operating conditions
●框材:铝合金外框
●External frane:Aluminum alloy frame
●密封物:聚胺脂胶
●Sealant:Gel-glue
●分隔物:热熔胶
●Filter media:Hot-melt
●密封条:蓝色液槽密封果冻胶
●Gasket:Blue jelly rubber seal sump
●滤料:玻纤滤纸
●Filter media:Glass fiber
●使用温度、湿度:80℃、80%以内
●Use the highest temperature, humidity:80℃、80%
型号尺寸及其他参数
Standard specification
型号 model |
外形尺寸 Outside dimensions (mm) |
额定风量 Rated air flow (m3/h) |
初阻力 Imitial resistance (Pa) |
效率(比色法) Efficiency (%) |
容尘量 Dust capacity (g) |
CJ-H1-B1 |
305×305×70 |
200 |
≤220或≤140(HV) |
≥99.99 |
120 |
CJ-H1-B2 |
610×305×70 |
400 |
≤220或≤140(HV) |
≥99.99 |
240 |
CJ-H1-B3 |
610×610×70 |
900 |
≤220或≤140(HV) |
≥99.99 |
510 |
CJ-H1-B4 |
915×610×70 |
1400 |
≤220或≤140(HV) |
≥99.99 |
810 |
CJ-H1-B5 |
305×305×80 |
250 |
≤220或≤140(HV) |
≥99.99 |
150 |
CJ-H1-B6 |
610×305×80 |
500 |
≤220或≤140(HV) |
≥99.99 |
300 |
CJ-H1-B7 |
915×305×80 |
750 |
≤220或≤140(HV) |
≥99.99 |
450 |
CJ-H1-B8 |
610×610×80 |
1000 |
≤220或≤140(HV) |
≥99.99 |
600 |
CJ-H1-B9 |
915×610×80 |
1500 |
≤220或≤140(HV) |
≥99.99 |
900 |
CJ-H1-B10 |
305×305×90 |
300 |
≤220或≤140(HV) |
≥99.99 |
180 |
CJ-H1-B11 |
610×305×90 |
600 |
≤220或≤140(HV) |
≥99.99 |
360 |
CJ-H1-B12 |
915×305×90 |
900 |
≤220或≤140(HV) |
≥99.99 |
540 |
CJ-H1-B13 |
610×610×90 |
1200 |
≤220或≤140(HV) |
≥99.99 |
720 |
CJ-H1-B14 |
915×610×90 |
1800 |
≤220或≤140(HV) |
≥99.99 |
1080 |
*可要据用户要求定制不同规格型号的过滤器
According to user requirements to customize different specifications and types of filters詹经理 手机:15928853231 18108224282
电话:028-87849573
传真:028-87849573
QQ:2541564050
邮箱:2541564050@qq.com 2685383469@qq.com
网址:http://www.cdffu.com
http://www.scffu.com
专业生产空气过滤器、高效空气过滤器、FFU风机过滤单元、初效空气过滤器、中效空气过滤器、高效空气过滤器、洁净工作台、离子风机、洁净棚、风淋室、净化设备、净化工程、等产品专业生产加工的有限责任公司,本公司集“研发、设计、生产、销售、服务”为一体,为广大客户提供优质的洁净技术服务与质量稳定、物美价廉的空气净化设备,在空气净化方面,我们涵盖了各尺寸、各种类的袋式、板式、密褶式、箱式等过滤器,产品能提供初效到高效级别(G2-H14)的过滤产品。适用于各类空调净化设备,除尘环保设备,组合式空调机组,新风机组,空调净化产品.
公司已通过并严格按照ISO9001:2000质量体系认证,所生产的产品广泛用于电子技术、半导体业、汽车制造、工业涂装、生物制药工业(FGMP、GMP)、医院、医药卫生、重工业、化学工业、食品工业、机电设备、商场大厦等场所的净化过滤。
公司主要生产销售产品有:
初效空气过滤器(板式过滤器、纸框过滤器、全金属过滤器、空调尼龙过滤网、平板式过滤器、漆雾过滤器、初效袋式过滤器
中效空气过滤器(合成纤维袋式过滤器、无纺布袋式过滤器、中效箱式过滤器);
高效空气过滤器(无隔板过滤器、有隔板过滤器、V型组合式高效过滤器、耐高温高效过滤器、高效送风口、FFU);
活性炭过滤器(空气净化机用蜂窝状活性炭滤网、袋式活性炭过滤器、板式活性炭过滤器、中效活性炭袋式过滤器、活性炭化学过滤器);
单位名称: |
成都高新西区科技园168
官网: |
联系电话: |
Email: |
