代码分享:基于TCGA甲基化数据挖掘验证分子表型代码分享
2026-03-02     来源:本站     点击次数:438
DNA甲基化作为表观遗传调控的重要机制,在肿瘤发生、发展及预后中发挥关键作用。TCGA(The Cancer Genome Atlas)数据库作为全球最大的肿瘤数据库,包含了全基因组甲基化芯片数据,主要涵盖Illumina 450K(HM450)、850K(EPIC)及最新935K(EPICv2)甲基化芯片数据,不同平台在覆盖范围、检测精度及临床应用上各有优势,为癌症表观遗传学研究提供了宝贵资源。基于TCGA甲基化数据,系统分析不同芯片平台(450K/850K/935K)的分子表型特征,能够获取课题研究思路、筛选目的基因或者验证关键表观遗传标志物。在这里,易基因分享开源代码,旨在为相关课题的甲基化数据分析思路提供一定的参考意见。
1.加载R包 ----------------------------------------------------------------
#DNA甲基化的探针数据-必要的R包下载
#BiocManager::install(c("minfi","ChAMPdata","Illumina450ProbeVariants.db","sva","IlluminaHumanMethylation450kmanifest","limma","RPMM","DNAcopy","preprocessCore","impute","marray","wateRmelon","goseq","plyr","GenomicRanges","RefFreeEWAS","qvalue","isva","doParallel","bumphunter","quadprog","shiny","shinythemes","plotly","RColorBrewer","DMRcate","dendextend","IlluminaHumanMethylationEPICmanifest","FEM","matrixStats","missMethyl","combinat"))
rm(list = ls())
options(stringsAsFactors = F)
library(ChAMP)
library(dplyr)
library(tibble)
library(openxlsx)
library(stringr)
library(data.table)
library(impute)
set.seed(123)#设置随机数种子,保证结果可重复,自己喜欢的数字即可
getwd()
2.读取必要数据 ----------------------------------------------------------------
clinical_data =read.delim('./00.data/clinical.tsv')#临床表型
sample =read.xlsx('./00.data/副本sample.xlsx')#样本信息
OSCC_21paired =read.csv('./00.data/OSCC_21paired.csv')#探针文件
head(OSCC_21paired)#行为cg岛的编号,列为样本
Promoter_methylation_candidate =read.xlsx('./00.data/副本Promoter_methylation_candidate(1)(1).xlsx')#筛选的基因集(课题感兴趣的)
#实验验证的有A-B-C,所以需要明确这三个基因的甲基化情况
head(Promoter_methylation_candidate)
human_me =read.csv('./00.data/humanmethylation450_15017482_v1-2 - 副本.csv')#
head(human_me,10)
3.数据预处理 ---------------------------------------------------------------
# 查看数据集的大小和列名
dim(sample) #1240 39
colnames(sample)
# 只保留特定列,即 "case_id", "case_submitter_id", "sample_submitter_id", "sample_type"
sample_1 <- sample[, c("case_id", "case_submitter_id", "sample_submitter_id", "sample_type")]
# 统计样本类型
table(sample_1$sample_type)
# 只保留 "Primary Tumor" 和 "Solid Tissue Normal" 两种类型
tissue <- c("Primary Tumor", "Solid Tissue Normal")
sample_tissue <- sample_1[sample_1$sample_type %in% tissue, ]
# 统计保留后的样本类型
table(sample_tissue$sample_type)
# 对样品进行过滤,因为有些肿瘤样品的取样多于1次,需要去除
table(sample_tissue$sample_submitter_id)
deleteuniquelines <- function(x) {
  stand.col <- x$case_submitter_id
  count <- table(stand.col)
  if (all(count < 2)) stop("no repeated records")
  else {
    ind <- sapply(stand.col, function(t) ifelse(count[as.character(t)] > 1, TRUE, FALSE))
    return(x[ind,])
sample_tissue_filter =deleteuniquelines(sample_tissue)
dim(sample_tissue_filter) #815
nt = sample_tissue_filter[sample_tissue_filter$sample_type =="Solid Tissue Normal",]
tt = sample_tissue_filter[sample_tissue_filter$sample_type =="Primary Tumor",]
#对于正常组织,由于都只取了一次样品,所以不进行过滤
#对于肿瘤样品:只取tt里sample_submitter id编码最后一位是"A"的样品,因为B是福尔马林固定石蜡包埋组织
tt <- tt[substr(tt$sample_submitter_id,16,16) =="A",]
tt <- tt[tt$case_submitter_id %in% nt$case_submitter_id,]
dim(tt) #37
dim(nt) #37
paired_tissue <- rbind(nt,tt)
dim(paired_tissue) #74个配对的  37对
# 读取"clinical.tsv"文件,提取肿瘤位置信息
tumor_site <- clinical_data
# 取膀胱癌
colnames(tumor_site)
tumor_site$tissue_or_organ_of_origin
tumor_site <- tumor_site[, c("case_id", "case_submitter_id", "tissue_or_organ_of_origin")]
# 统计样本类型
table(tumor_site$tissue_or_organ_of_origin)
tumor_site[,c('ans','takeout')]=str_split_fixed(tumor_site$tissue_or_organ_of_origin,',',2)
# tumor_site <- tumor_site[tumor_site$ %in% oscc,]
# 取样位置"取样位置"和"肿瘤发生位置",取"肿瘤发生的位置"
tumor_site <- tumor_site[,c(1,2,4)]
table(tumor_site$ans)#
dim(tumor_site)#824样品都是在膀胱的
tumor_site_unique = as.data.frame(unique(tumor_site$case_submitter_id))
colnames(tumor_site_unique)= 'case_submitter_id'
merge_info = paired_tissue[paired_tissue$case_submitter_id %in% tumor_site_unique$case_submitter_id,]
dim(merge_info) #74 4  37对
head(me_data)
merge_info$sample_submitter_id =substr(merge_info$sample_submitter_id,1,15)
#输出过滤文件
write.table(merge_info,'./00.data/paired_sample_clinial_filter.txt',quote = F,row.names = F,col.names = F)
nt_paired = merge_info[merge_info$sample_type =="Solid Tissue Normal",]
tt_paired = merge_info[merge_info$sample_type =="Primary Tumor",]
#读取上面的数据
me_data =OSCC_21paired
rownames(me_data)=me_data[,1]
me_data=me_data[,-1]
# colnames(me_data) <- str_replace(colnames(me_data),".", "-")
nt_paired$sample_submitter_id <- str_replace_all(nt_paired$sample_submitter_id ,"-", ".")
tt_paired$sample_submitter_id <- str_replace_all(nt_paired$sample_submitter_id ,"-", ".")
me_data_nt = me_data[,colnames(me_data) %in% nt_paired$sample_submitter_id]
me_data_tt = me_data[,colnames(me_data) %in% tt_paired$sample_submitter_id]
me_data_paired = cbind(me_data_nt,me_data_tt)
#重新保留
merge_info$sample_submitter_id <- str_replace_all(merge_info$sample_submitter_id ,"-", ".")
write.table(merge_info,'./00.data//paired_sample_clinial_filter.txt',quote = F,row.names = F,col.names = F)
write.csv(me_data_paired,'./00.data//pangguangai_21paired_me_data_412481.csv')
write.csv(me_data,'./00.data//pangguangai_me_data_412481.csv')
write.csv(merge_info,'./00.data//merge_info.csv')
本篇我们重点探讨了甲基化数据分析的预处理。在下一期中,我们将深入分析:
  • CHAMP对象的生成以及可视化
  • 差异基因和功能富集分析
