Nutlin-3a(Rebemadlin,AbMole,M2894)是一种MDM2拮抗剂,能通过特异性阻断MDM2与肿瘤抑制因子p53之间的相互作用,解除MDM2对p53的泛素化降解,从而稳定p53蛋白水平并激活其下游转录程序。在野生型TP53细胞中(如结肠癌HCT116),10 μM Nutlin-3a处理24小时可显著抑制增殖、诱导G1期细胞周期阻滞及凋亡,同时下调β-连环蛋白、并抑制上皮-间质转化(EMT)进程,以及减少细胞迁移[1]。
Nutlin-3a(Rebemadlin,AbMole,M2894)还具有非p53依赖性的细胞活性,在结肠癌细胞(包括p53突变型Caco-2、SW480)中,Nutlin-3a通过内质网应激激活CHOP(一种细胞应激与凋亡相关的蛋白),上调死亡受体DR5,并通过Caspase-8通路诱导细胞凋亡[2];Nutlin-3a(Rebemadlin,AbMole,M2894)还在H1299细胞(一种p53缺失细胞)中,与干扰素α(IFN-α) 联用后通过抑制cyclin D1/CDK4阻断细胞周期[3]。
Nutlin-3a(10 μM)可以抑制骨肉瘤细胞增殖并促进细胞凋亡[4]。Nutlin-3a(5 μM)还能通过诱导AMP激酶活化,激活急性白血病细胞的自噬[5]。在动物模型研究中,小鼠(包括SCID小鼠、裸鼠)异种移植实验表明,Nutlin-3a(Rebemadlin)可在细胞水平和动物实验(小鼠)中有效抑制NCI-H295R来源的肾上腺皮质癌、ECA-109来源的食管鳞癌、GBM10来源的胶质母细胞瘤(颅内模型)及黑色素瘤肿瘤的生长。此外,Nutlin-3a(25 mg/kg)还可以激活小鼠肺部p53基因的表达并逆转小鼠的肺动脉高压[6]。
参考文献及鸣谢
[1] Hui, W.; Liu, S.; Zheng, J.; et al. Nutlin-3a as a novel anticancer agent for adrenocortical carcinoma with CTNNB1 mutation.
Cancer medicine 2018,
7 (4), 1440-1449.
[2] Lu, M.; Ren, Y.; Feng, S.; et al. MDM2 inhibitor induces apoptosis in colon cancer cells through activation of the CHOP-DR5 pathway, independent of p53 phenotype.
Frontiers in pharmacology 2025,
16, 1508421.
[3] Shuvalov, O.; Kizenko, A.; Shakirova, A.; et al. Nutlin sensitizes lung carcinoma cells to interferon-alpha treatment in MDM2-dependent but p53-independent manner.
Biochemical and biophysical research communications 2018,
495 (1), 1233-1239.
[4] Wang, B.; Fang, L.; Zhao, H.; et al. MDM2 inhibitor Nutlin-3a suppresses proliferation and promotes apoptosis in osteosarcoma cells.
Acta Biochimica et Biophysica Sinica 2012,
44 (8), 685-691.
[5] Borthakur, G.; Duvvuri, S.; Ruvolo, V.; et al. MDM2 inhibitor, nutlin 3a, induces p53 dependent autophagy in acute leukemia by AMP kinase activation. 2015,
10 (10), e0139254.
[6] Mouraret, N.; Marcos, E.; Abid, S.; et al. Activation of lung p53 by Nutlin-3a prevents and reverses experimental pulmonary hypertension. 2013,
127 (16), 1664-1676.
细胞系:U-2 OS
方法:Cells were seeded in duplicate in 96-well plates (104 per well), incubated for 6 h, and treated with 10 μM Nutlin-3a for 24, 48, and 72 h, respectively, or exposed to 0–10 M Nutlin-3a for 48 h. Cell viability was determined using the Luminescent cell viability kit.
浓度:10 μM
处理时间:24, 48, and 72 h
参考文献:Acta Biochim Biophys Sin (Shanghai). 2012 Aug;44(8):685-91.
* 上述方法来自公开文献,仅供相同目的实验参考。如实验目的、材料、方法不同,请参考其他文献。
动物实验参考
动物模型:C57Bl/6j mice
配制:0.9% NaCl and 30% DMSO
剂量:6, 12, or 25 mg/Kg/d
给药处理:Intraperitoneal injection
参考文献:Circulation. 2013 Apr 23;127(16):1664-76.
体内实验的工作液,建议现用现配,当天使用;如在配制过程中出现沉淀、析出现象,可以通过超声和(或)加热的方式助溶。
切勿一次性将产品全部溶解。
建议制定动物给药及实验方案时,尽量参考已发表的相关实验文献(溶剂种类及配比众多,简单地溶解目的化合物,并不能解决动物给药依从性、体内生物利用度、组织分布等相关问题,未必能保证目的化合物在动物体内充分发挥生物学效用)。
