参考文献及鸣谢
[1] Chen, Y.; Sang, Y.; Li, S. et al. The ERK inhibitor GDC-0994 selectively inhibits growth of BRAF mutant cancer cells. Translational oncology 2024, 45, 101991.
[2] Blaheta, R. A. Han, J. Oppermann, E. et al. Transglutaminase 2 promotes epithelial-to-mesenchymal transition by regulating the expression of matrix metalloproteinase 7 in colorectal cancer cells via the MEK/ERK signaling pathway. Biochimica et biophysica acta. Molecular basis of disease 2025, 1871 (1), 167538.
[3] Huang, T. Ge, S. Huang, W. et al. AIBP promotes cell proliferation and migration through the ERK1/2-MAPK signaling pathway in hepatocellular carcinoma. Translational cancer research 2024, 13 (8), 4028-4041.
[4] Li, X. Wang, T. Liu, N. et al. Focal cortical dysplasia II caused by brain somatic mutation of IRS-1 is associated with ERK signaling pathway activation. Cerebral cortex (New York, N.Y. : 1991) 2024, 34 (6).
[5] Kirouac, D. C. Schaefer, G. Chan, J. et al. Clinical responses to ERK inhibition in BRAF(V600E)-mutant colorectal cancer predicted using a computational model. NPJ systems biology and applications 2017, 3, 14.
细胞系:RAW ISG cells
方法:RAW ISG cells were pretreated with ERK inhibitors ravoxertinib (5 μM) and ulixertinib (5 μM) for 2 h and then treated with 1 μg/mL LPS or 100 μM c-di-GMP for 6 h
浓度:5 μM
处理时间:6 h
参考文献:ACS Chem Biol. 2021 Sep 17;16(9):1663-1670.
* 上述方法来自公开文献,仅供相同目的实验参考。如实验目的、材料、方法不同,请参考其他文献。
动物实验参考
动物模型:Nude mice
配制:Not mentioned
剂量:10 mg/kg
给药处理:Intratibially injected
参考文献:Mol Med. 2021 Dec 4;27(1):152.
体内实验的工作液,建议现用现配,当天使用;如在配制过程中出现沉淀、析出现象,可以通过超声和(或)加热的方式助溶。
切勿一次性将产品全部溶解。
建议制定动物给药及实验方案时,尽量参考已发表的相关实验文献(溶剂种类及配比众多,简单地溶解目的化合物,并不能解决动物给药依从性、体内生物利用度、组织分布等相关问题,未必能保证目的化合物在动物体内充分发挥生物学效用)。
