代码分享:基于TCGA甲基化数据挖掘验证分子表型代码分享(第三期)
2026-03-10     来源:本站     点击次数:490
DNA甲基化作为表观遗传调控的重要机制,在肿瘤发生、发展及预后中发挥关键作用。前两期已经完成了甲基化数据挖掘的基础分析,这一期将立足于解释具体的生物学问题来展开。
8.每个基因的甲基化信号值的比较 --------------------------------------------------------
# 8.每个基因的甲基化信号值的比较 --------------------------------------------------------
##对膀胱癌中差异上调的cg进行绘制均值的折线图
load('./00.data//pangguangai_21paired_meLoad_data_412481.Rdata')
# exp_count_gene_name =myLoad$beta
sample= pd
normalized_counts =myNorm
# exp_count_gene_name = exp_count_gene_name[,c(1:10,13:18,21:24,27:30,33:42)]
sample=sample[c(1:10,13:18,21:24,27:30,33:42),]
normalized_counts=normalized_counts[,c(1:10,13:18,21:24,27:30,33:42)]
colnames(marker_plot)
marker_1 = marker[,c(1,8,9,15,25)]
marker_plot <- reshape2::melt(marker_1, id.vars=c("rowname","gene",'change'), variable.name="group",value.name="AVG")
color <- c("#E63863","#0228A5")
gene <- "IFFO1"
marker_plot_sub = marker_plot[marker_plot$gene %in% gene,]
ggplot(marker_plot_sub, aes(x = rowname, y = AVG, group = group, colour=group, shape= group, fill = group)) +
  geom_line(size=0.5)+
  geom_point(size=3)+
  geom_text(aes(label=AVG),position = position_dodge(.9),vjust =-1,hjust=1.3)+
  scale_shape_manual(values = c(24,22)) +
  scale_fill_manual(values =color)+
  scale_color_manual(values = color)+
  labs(x="",y="β value", title = "IFFO1", subtitle = "Padj < 0.00001 & |logFC| >= 0.4") +
  # ylim(0,3200) +
  theme(
    #legend.position="none",
    axis.text.x = element_text(size = 12,colour="black"),
    #axis.text.x = element_text(size = 12,colour="black", angle = 45,hjust = 1),
    axis.text.y = element_text(size = 12,colour="black"),
    axis.title.x = element_text(size = 14),
    axis.title.y = element_text(size = 12),
    #axis.ticks = element_blank(),
    plot.title = element_text(hjust = 0.5, vjust=1),
    #panel.background = element_rect(fill="white",color = "black"),
    panel.background = element_blank(),
    panel.grid.major = element_blank(),
    panel.grid.minor = element_blank(),
    axis.line = element_line(colour = "black"),
    panel.border = element_rect(colour = "black", fill=NA))
ggsave(paste0("../03.plot/", "line_βval_IFFO1",".pdf"), width = 6*1.5, height = 6*1.5)
ggsave(paste0("../03.plot/", "line_βval_IFFO1",".png"), width = 6*1.5, height = 6*1.5)
结果如下:
gene <- "TMEM106A"
  geom_point(size=3)+
  labs(x="",y="β value", title = "TMEM106A", subtitle = "Padj < 0.00001 & |logFC| >= 0.4") +
  # ylim(0,3200) +
  theme(
ggsave(paste0("../03.plot/", "line_βval_TMEM106A",".pdf"), width = 6*1.5, height = 6*1.5)
ggsave(paste0("../03.plot/", "line_βval_TMEM106A",".png"), width = 6*1.5, height = 6*1.5)
结果如下:
gene <- "SHANK2"
  geom_point(size=3)+
  labs(x="",y="β value", title = "SHANK2", subtitle = "Padj < 0.00001 & |logFC| >= 0.4") +
  # ylim(0,3200) +
  theme(
ggsave(paste0("../03.plot/", "line_βval_SHANK2",".pdf"), width = 6*1.5, height = 6*1.5)
ggsave(paste0("../03.plot/", "line_βval_SHANK2",".png"), width = 6*1.5, height = 6*1.5)
结果如下:
gene <- "IFFO1"
  geom_bar(stat="identity", color="black",
           position=position_dodge()) +
  # ylim(0,3200) +
  theme(
ggsave(paste0("../03.plot/", "barplot_βval_IFFO1",".pdf"), width = 6*1.5, height = 6*1.5)
ggsave(paste0("../03.plot/", "barplot_βval_IFFO1",".png"), width = 6*1.5, height = 6*1.5)
结果如下:
gene <- "TMEM106A"
  # ylim(0,3200) +
  theme(
ggsave(paste0("../03.plot/", "barplot_βval_TMEM106A",".pdf"), width = 6*1.5, height = 6*1.5)
ggsave(paste0("../03.plot/", "barplot_βval_TMEM106A",".png"), width = 6*1.5, height = 6*1.5)
结果如下:
gene <- "SHANK2"
  # ylim(0,3200) +
  theme(
ggsave(paste0("../03.plot/", "barplot_βval_SHANK2",".pdf"), width = 6*1.5, height = 6*1.5)
ggsave(paste0("../03.plot/", "barplot_βval_SHANK2",".png"), width = 6*1.5, height = 6*1.5)
结果如下:
gene <- c("IFFO1","TMEM106A","SHANK2")
marker_plot_sub
marker_plot_sub$rowname <- factor(marker_plot_sub$rowname, levels = c("cg08875705","cg01979888", "cg01493517", "cg00983904",  "cg23737737" ,
        "cg18222083", "cg19548479" ,
        "cg20170028"
  geom_point(size=3)+
  labs(x="",y="β value", title = "TCGA BLCA", subtitle = "Padj < 0.00001 & |logFC| >= 0.4") +
  # ylim(0,3200) +
  theme(
ggsave(paste0("../03.plot/", "line_βval_all",".pdf"), width = 6*1.5, height = 6*1.5)
ggsave(paste0("../03.plot/", "line_βval_all",".png"), width = 6*1.5, height = 6*1.5)
结果如下:
color <- c("#EE9B7E","#D9D7BC")
  # ylim(0,3200) +
  theme(
ggsave(paste0("../03.plot/", "barplot_βval_all",".pdf"), width = 6*1.5, height = 6*1.5)
ggsave(paste0("../03.plot/", "barplot_βval_all",".png"), width = 6*1.5, height = 6*1.5)
结果如下:
#上面的结果再加上对应的igv的图这里我选择hg19
9.补充生存分析以及AUC分析 ----------------------------------------------
# 输入文件
dd =read.delim('../00.data/clinical.tsv')
# clinical.tsv,包含生存数据和临床亚组信息。
# dd <- data.table::fread("easy_input.csv",data.table = F)
dd[1:3,]
#处理数据为生存分析需要的格式
meta = dd
# 生存时间需要为月份
# meta[meta==""]=NA
meta$time = ifelse(meta$vital_status == 'Alive',meta$days_to_last_follow_up,meta$days_to_death)
meta$time = as.numeric(meta$time)/30
# 1.2生死定义
meta$event = ifelse(meta$vital_status== 'Alive',0,1)
table(meta$event)
# 区分年龄
meta$age = ceiling(abs(as.numeric(meta$days_to_birth))/365)
meta$age_group=ifelse(meta$age>median(meta$age,na.rm = T),'older','younger')
table(meta$age_group)
## 自定义颜色
orange <- "#EB736B"
blue <- "#57B5AB"
library(stringr)
# 1.4提取分期信息
b= meta$ajcc_pathologic_stage
a= str_extract_all(meta$ajcc_pathologic_stage,"I|V");head(a)#提取分期信息
b= sapply(a,paste,collapse = '')
head(b)
meta$stage = b
#去掉生存信息不全或者生存时间小于0.1(月)的病人,样本纳排标准不唯一,且差别很大
# k1 = meta$time>=0.1;table(k1)
# # 8
# k2 =!(is.na(meta$time)|is.na(meta$event));table(k2)
# 6
##只先看目前的数据
#注意生存分析只需要肿瘤的病人
head(normalized_counts)
# nm_tumor = normalized_counts[]
sample$sample_type_fix[sample$sample_type_fix=='Primary Tumor']='Tumor'
colnames(sample)
exp = normalized_counts[,sample$sample_type_fix %in% "Tumor"]
dim(exp)#412481     17 只存贮这17个
meta$case_submitter_id<- str_replace_all(meta$case_submitter_id ,"-", ".")
# meta$case_submitter_id =
# meta = meta[meta$case_submitter_id %in% str_sub(colnames(exp),1,12),]
meta = meta[meta$case_id %in% sample_tumor$case_id,]
sample_tumor = sample[sample$sample_type_fix %in% c("Tumor"),]
dim(sample_tumor)  #34 215
dim(meta)  #34 215
meta <- meta[!duplicated(meta$case_id), ]
dim(meta)  #17 215
# exp = exp[,k1&k2]
# meta = meta[k1&k2,]
# rownames(meta)
# colnames(meta)
save(meta,exp,sample_tumor,file = './/surve_model_tumor.Rdata')
# load('./00.data//surve_model_tumor.Rdata')
## 提取数据
# rt <- meta
# colnames(rt)
## 生存分析
# rt$days_to_death =as.numeric(rt$days_to_death)
fit <- survfit(Surv(time,event) ~age_group, data = meta)
## 作图
ggsurvplot(fit,
           pval = TRUE,
           palette = c(orange, blue),
           title="age_group",
           xlab="Time")
orange <- "#EB736B"
blue <- "#57B5AB"
ggsurvplot(fit,
           palette =c("#E7B800","#2E9FDF"),
           risk.table =TRUE,pVal =TRUE,
           conf.int =TRUE,xlab ="Time in months",
           ggtheme =theme_light(),
           ncensor.plot = TRUE)
ggsurvplot(fit,
           palette =c("#EB736B","#57B5AB"),
#性别年龄
sfit1=survfit(Surv(time, event)~gender, data=meta)
sfit2=survfit(Surv(time, event)~age_group, data=meta)
splots<- list()
splots[[1]]<- ggsurvplot(sfit1,pval =TRUE,data = meta,risk.table = TRUE)
splots[[2]]<- ggsurvplot(sfit2,pval =TRUE,data = meta,risk.table = TRUE)
arrange_ggsurvplots(splots, print = TRUE,
                    ncol=2,nrow=1,risk.table.height=0.4)
dev.off()
#单个基因(选择对应的cg展示他们的风险)
g=rownames(exp)[1]
meta$gene = ifelse(exp[g,]> median(exp[g,]),'high','low')
sfit1=survfit(Surv(time, event)~gene, data=meta)
ggsurvplot(sfit1,pval =TRUE, data = meta, risk.table = TRUE)
#多个基因
gs=rownames(exp)[1:4]
splots <- lapply(gs,function(g){
  sfit1=survfit(Surv(time, event)~gene,data=meta)
arrange_ggsurvplots(splots, print = TRUE,ncol=2,nrow=2,risk.table.height=0.4)
##log_rank_p
#加上KM生存曲线即可
mySurv <- with(meta, Surv(time, event == "1"))  # 创建生存对象,event == 1表示“1为结局时间发生“
log_rank_p <- pbapply(exp, 1, function(gene){
  # gene <- exp[1,]
  meta$group <- ifelse(gene > median(gene), "high", "low")
  data.survdiff <- survdiff(mySurv ~ group, data = meta)
  # survdiff()用于检验两条或多条生存曲线之间是否存在差异,
  # 或者针对已知替代项检验单条曲线,也适用于分组资料以及多组间生存曲线的比较;
  p.val <- 1 - pchisq(data.survdiff$chisq, length(data.survdiff$n) - 1)  # 计算log-rank检验的p值
  return(p.val)
log_rank_p <- sort(log_rank_p)  # 取出每一个基因生存分析的P值,形成表
table(log_rank_p < 0.01)  # 哪些是P<0.01的
table(log_rank_p < 0.05)  # 哪些是P<0.05的
log_rank <- names(log_rank_p)[log_rank_p < 0.05]  # log-rank检验筛选的差异基因 0.05
log_rank_p
# Cox比例风险回归(HR)
mySurv <- with(meta, Surv(time, event == "1"))  # 创建生存对象,event = 1表示“1为结局事件发生”
unicox_results <- pbapply(exp, 1, function(gene){  # 对表达矩阵exp中的每一行(基因)执行函数function
  # gene = as.numeric(exp[1,]) # 举个例子
  group <- ifelse(gene > median(gene), "high","low")  # 标记不同样本中该基因的上下调,将表达量转换为二分类变量
  survival_dat <- data.frame(group = group,
                             stage = meta$stage,
                             age = meta$age,
                             gender = meta$gender,
                             gene = gene,  # 基因表达量
                             stringsAsFactors = F)  # 选择用于生存分析的数据
  # 拟合Cox比例风险回归模型 m :
  m <- coxph(mySurv ~ gender + age + stage + group, data = survival_dat)  # 表达量用二分类变量group
  # m <- coxph(mySurv ~ group, data = survival_dat)  # 表达量用二分类变量group
  # m <- coxph(mySurv ~ gene, data =  survival_dat)  # 表达量也可直接使用连续型变量gene
  # sm <- summary(m)  # 看拟合出的Cox比例风险回归模型的参数
  # n:总人数。
  # number of events:发生结局事件的人数,即死亡人数
  # coef(coefficients,回归系数):结果为正(负),表示男性(genderMALE)死亡风险高(低)于女性,或者说有较低(高)的生存概率。
  # exp(coef):也称为风险比(HR)。HR = 1: 无影响,HR < 1: 降低风险,HR > 1: 增加风险。
  # se(coef):coef的标准误
  # z:Wald检验的统计量,z = coef/se(coef),是否具有统计学意义看p值
  # Pr(>|z|):p值
  # low.95与upper.95表示HR值的95%置信度区间CI,如果95%CI跨越了1,一般就不认为该因素对生存有显著影响。
  beta <- coef(m)
  se <- sqrt(diag(vcov(m)))
  tmp <- round(cbind(coef = beta,  # 模型的偏回归系数β
                     se = se,  # 偏回归系数β的标准误
                     z = beta/se,  # Wald检验的统计量
                     p = 1 - pchisq((beta/se)^2, 1),  # p值,差异的统计学意义
                     HR = exp(beta),  # 风险值,计算公式为exp(coef)
                     HRCILL = exp(beta - qnorm(.975, 0, 1) * se),  # HR的95%置信区间低点
                     HRCIUL = exp(beta + qnorm(.975, 0, 1) * se)), 3)  # HR的95%置信区间高点
  return(tmp["grouplow",])  # 分类变量
  # return(tmp["gene",])  # 连续型变量
unicox_results <- as.data.frame(t(unicox_results))
table(unicox_results[,4] < 0.01)  # p值<0.01的有多少
table(unicox_results[,4] < 0.05)  # p值<0.05的有多少
unicox <- rownames(unicox_results)[unicox_results[,4] < 0.05]  # Cox单因素分析筛选的差异基因
save(log_rank_p,unicox_results,file = './/surve_cox_log_rank_p.Rdata')
#多个基因
#  c("cg08875705","cg01979888", "cg01493517", "cg00983904",  "cg23737737" ,"cg18222083", "cg19548479" ,"cg20170028"
gs=c("cg08875705","cg01979888", "cg01493517", "cg00983904",  "cg23737737" ,"cg18222083", "cg19548479" ,"cg20170028")
arrange_ggsurvplots(splots, print = TRUE,ncol=4,nrow=2,risk.table.height=0.4)
load('./00.data//surve_cox_log_rank_p.Rdata')
# 取交集
cd =intersect(log_rank,gs)  #0
cd =intersect(unicox,gs)  #0
  meta$gene = ifelse(exp[g,]> mean(exp[g,]),'high','low')
#ggsave(paste0("../03.plot/", "volcano","_logFC_0.4_P.Value_10_5.pdf"), width = 6*1.2, height = 6*1)
##log_rank_p
# KM生存曲线即可
  # gene <- exp[1,]
  meta$group <- ifelse(gene > mean(gene), "high", "low")
  return(p.val)
log_rank_p
# Cox比例风险回归(HR)
  group <- ifelse(gene > mean(gene), "high","low")  # 标记不同样本中该基因的上下调,将表达量转换为二分类变量
                             stage = meta$stage,
                             age = meta$age,
  # 拟合Cox比例风险回归模型 m :
  # n:总人数。
  # se(coef):coef的标准误
  # Pr(>|z|):p值
  beta <- coef(m)
save(log_rank_p,unicox_results,file = './00.data//surve_cox_log_rank_p_mean.Rdata')
#输出均值的结果
# cg19548479
write.csv(log_rank_p,'./00.data//log_rank_p_mean.csv')
write.csv(unicox_results,'./00.data//unicox_results_mean.csv')
# cg19548479符合后面的几个检验
# gs=c("cg08875705","cg01979888", "cg01493517", "cg00983904",  "cg23737737" ,"cg18222083", "cg19548479" ,"cg20170028")
g='cg19548479'
最后出图结果如下:
Fig1样本质控
Fig2样本筛选
Fig3-标志物筛选
本文所使用的数据均已公开,欢迎各位老师获取数据下载链接。
