R280型手持式Xγ环境剂量率辐射仪用户手册
2011-05-28     来源:本站     点击次数:6574
德国R280型手持式环境剂量率辐射仪用户手册
版本號:J280-2
目录
一、介绍..........................................................................................................3
二、面板..........................................................................................................5
三、操作使用说明..........................................................................................6
指示当前的辐射剂量率:...........................................................................6
Sv/h、Rem/h、CPS、CPM 显示单位转换...............................................6
剂量累加计数...............................................................................................6
脉冲计数.......................................................................................................8
菜单设置.......................................................................................................9
校正因子.......................................................................................................9
数据存储.....................................................................................................11
数据传输.....................................................................................................12
开机/关机....................................................................................................12
电源指示.....................................................................................................12
四、Radiation Scanner软件........................................................................13
系统要求.....................................................................................................14
软件安装.....................................................................................................14
辐射计软件安装失败的解决办法.............................................................15
连接辐射计.................................................................................................16
联机测量.....................................................................................................17
显示间隔设定.............................................................................................20
报警设定.....................................................................................................20
保存联机测量数据.....................................................................................21
读辐射计存储数据.....................................................................................22
保存辐射计存储数据.................................................................................24
擦除辐射计数据.........................................................................................25
选项说明.....................................................................................................26
五、技术参数................................................................................................30
六、保修........................................................................................................32
七、附录........................................................................................................33
单位转换公式.............................................................................................33
sievert的含义:..........................................................................................35
校正因子计算方法.....................................................................................36
II 一 、 介 绍
一、介绍
恭喜您使用R280系列多功能数字核辐射计,此产品是完全基于新的标准所设计的,在以往产品的基础上改进,性能得到提升,操作使用上更加方便,并提供了出色的功能选项:
产品具有剂量累加计数Sv,最大值保持,手动存储,与电脑即时通讯显示,数据分析等功能
        1. 使用凸起按键:只需要按一下按键就可以开始工作,并可以马上得到丰富的测量数据。
        2. 经过严格测试的精确仪表:每个R280系列多功能数字核辐射计都经过德国核辐射保护学会的监控和测试。
        3. 可以测量多种核辐射:不但可以测量γ,还可以测量β和Χ射线
        4. R280系列多功能数字核辐射计增加了电源开关按键,最大程度上增加电池的使用寿命。
        5. 超低电能消耗:仪表本身消耗很少的电能,加之使用一节9V电池,客户可以很方便的更换。
            6. 大屏幕显示:所有的数值和未找到引文目录项。设定都可以显示在一个超大屏幕上。
7. 数据存储: R280型多功能数字核辐射计本身带有大容量内存,可以把数据直接存储到仪表内,随后传输到电脑。不需要手工记录。并且支持掉电后保持存储数据1分钟的
            8. 可通过电脑分析数据:随机附带的Radiation Scanner软件可以在电脑中显示辐射计的即时数据,做到远传监视,分析测量的数据.并可任意设定时间间隔存储数据。
            9. 便携式设计:由于该仪表非常小巧,便于携带,完全可以放入口袋里。
            10. 效验: R280系列多功能数字核辐射计通过德国TUV安全设备测试,而且符合所有欧洲CE标准和美国FCC 15标准。您在空中旅途时可以携带辐射计,并监测飞机上的宇宙辐射。
            11. R280型具有超限报警,存储,最大值记录,与电脑即时通讯显示等功能。
功能,用户不用担心在更换电池后数据会丢失。
II 二 、 面 板
二、面板
R280型辐射计面板:
三、操作使用说明
指示当前的辐射剂量率:
按键,进入标准模式,它显示的是当前测量值,默认用μSv/h 单位表示。R280系列多功能数字核辐射计不但可以用数值表示,还可以用弧形棒图来显示。屏幕下方的棒图随着显示的数值大小而变化,棒图带有刻度,分别是0.1,1,10,100,呈指数分布。注意:如果测量值很小,棒图的显示为一条线。
Sv/hRem/hCPSCPM 显示单位转换
按键,显示单位在μSv/h、过去24小时内的平均值、CPS、CPM和mR/h之间切换。单位的转换拆参考公式如下:
10μSv/h=1mRem/h
剂量累加计数
R280系列多功能数字核辐射计也可以当作剂量仪,记录当前环境中一段时间内的的累计辐射剂量。初始单位为μSv,当剂量达到一定数值后自动转换为mSv或者Sv记录显示。
剂量累加计数按键
II 三 、 操 作 使 用 说 明
按键一次,进入剂量了累加计数模式,然后屏幕上显示剂量图标(μSv),并闪烁。再按一次键,剂量累加计数测量结束,同时指示图标停止闪烁,屏幕上显示当前已经累计到的剂量值。
或长按键2秒,进入设定测量时间,屏幕上显示剂量图标(μSv),和时间单位“min”图标。此时显示器中显示有三位数字,默认状态为060,表示60分钟,最大可计数到999分钟,此时通过操作上翻键()或下翻键()调整您想要的时间。当您长按上翻键或下翻键达2s时,数值将会迅速增加或减小。 设定好时间后按下回车键(),时间设定完成,并停止闪烁,再次按下回车键开始进入定时剂量累加工作状态,并且显示器中显示剂量累加工作状态标志:“Sv”,同时“TIME”标志开始闪烁,表示当前是在定时测量工作状态。如果测量时间被设定,在测量结束时,仪表蜂鸣器会短响一声提示,这时,显示的是这个时间段的累计剂量值,同时“TIME”显示在当前界面,并停止闪烁。如果定时时间还没有到就短按该键时,将进入非定时累加或记录状态;若长按将重新进入定时设置状态。
能够用如下三个方法停止测量。
- 非定时测量情况下,第二次短按键,累加测量结束,测量结果被显示在屏幕上;定时测量过程中,短按该键,进入不定时累加状态。
- 长按键,进入定时设置,并把定时时间设置为000,确认后即可,测量结果消失,进入默认的剂量率测试状态。
- 选择其他操作模式,测量结果消失。
脉冲计数
R280系列多功能数字核辐射计也可以当作普通盖革计数器使用,在这种设定下,它只记录接收到的脉冲,只进行脉冲计量,不转换为Sv(剂量当量单位, 1Sv=100Rem)。多功能数字核辐射计把接收到的脉冲累计量显示到LCD中。
脉冲计数按键
按键一次,进入脉冲记数模式,然后屏幕上显示脉冲图标。并闪烁。再按一次该键,剂量累加计数测量结束,同时指示图标停止闪烁,屏幕上显示当前已经累计到的剂量值。
或长按键2秒,进入设定测量时间,并且屏幕上显示脉冲图标。此时显示器中显示有三位数字,默认状态为060,表示60分钟,最大可计数到999分钟。
时间设定的操作方法与前面剂量累加的操作一样。
如果测量时间被设定,在测量结束时,仪表蜂鸣器会短响一声提示,这时,显示的是这个时间段的累计计数值,同时“TIME”显示在当前界面,并停止闪烁。
同样,能够用如下三个方法停止测量。
II 三 、 操 作 使 用 说 明
加状态。
- 选择其他操作模式,测量结果消失。
菜单设置
按键,进入菜单设置界面。可以设置时间(TIME),日期(DATA),校正因子(CAL),报警阈值(ALM),平均时间设置(T),脉冲声响()。
时间格式:时/分/秒
日期格式:月/日/年
校正因子:仪表出厂默认校正因子为2.10。(注意:R280辐射仪的标定源以Co60源为标准,校正因子为2.1。如果使用Cs-137源,由于两种核素能量不同通过GM管输出的脉冲幅度不同从而造成差异,数据会有所不同,校正因子必须重新修正,建议校正因子经验值为1.4。)所有操作,均通过上翻键()或下翻键()修改数值,回车键()确认。
校正因子(CAL)不能随意修改,否则会造成测量数据不准确现象。如果确实需要修改,必须由专业的核防护工作人员对该仪表进行正规标定并计算出当前的校正因子后方可修改。修改时必须输入密码,首先进入校正因子界面:“CAL”标志闪烁,显示器正中间显示“----”字样,回车确认后,第一个“-”闪烁,然后输入,第一个“-”变成“c”,第二个“-”闪烁,然后依次输入键盘上面的按键:,,显示器上显示为“ccc-”,同时“-”闪烁,再输入按键,显示器上将显示当前的校正因子(如2.10),并且闪烁,此时就可以和前面的操作一样修改该数值。当校正因子增加时,导致计算的辐射值减少。当校正因子减少时,导致计算的辐射值增加。
报警阈值:1—99μSv/h,默认为10(只有R280型号有报警功能)
平均时间:该设置可以改变仪表对放射源的处理反应时间,设置范围8s到60s。随着辐射剂量率的增加,会根据所设置的当前平均时间,自动按照比例减少平均时间。当设置为8s时,在辐射强度大于5μSv/h时,最快反应时间可以达到2s。仪表出厂默认时间为60s
脉冲声响:ON和OFF两种状态选择
II 三 、 操 作 使 用 说 明
数据存储
按键一次,仪表即存储当前的测量剂量率的值到仪表的存储器里(手动单次存储,同时记录时间和辐射值)。
长按键2秒,进入定时存储的设置。并且屏幕上显示“MEM”图标。此时显示器中显示有三位数字,默认状态为001(表示每间隔1分钟自动存储一次,最大可设置间隔时间到999分钟),时间设定操作同前所述。按下回车键开始进入定时剂量累加工作状态,并且显示器中显示存储工作状态标志—“MEM”,同时“TIME”标志开始闪烁,表示当前是在定时测量工作状态。
如果测量时间被设定,在测量结束时,仪表蜂鸣器会短响一声提示,这时,显示的是这个时间段的最大剂量率值,同时“TIME”显示在当前界面,并停止闪烁。在定时存储的过程中,仍然可以即时手动单次存储当前看到的某个值。若长按将重新进入定时设置状态。
可用如下方法停止自动存储功能。
- 长按键2s,进入定时设置,并把定时时间设置为000,确认后即可。
- 选择除剂量率以外的其他操作模式,即可停止自动存储功能。
注意:如果内置存储器数据空间已经存满,显示器上会显示“F-OU”,同时伴随“MEM”标志闪烁。可以与上位机联机,下载存储器内的数据后,通过上位机的擦除操作清楚当前存储器区内的数据,然后才可继续存储。
数据传输
(注意:简化版R280型辐射计不具备此功能)
该型号辐射计采用即插即拔的USB通讯模式,连接好仪器后,直接通过上位机联机进行各项操作,无需再操作仪表本身。
在USB通讯状态下,显示器上会显示“----”,如果需要此时也能从仪器上看到当前测量数据,可按下键显示当前剂量率,建议通过上位机正常中断连接后再断开物理连接。
开机/关机
长按键2s,开机或者关机。
每次正常关机,再次开机后,内存里存储的数据将仍然存在。非正常关机时,将不能保证存储数据仍然被保留。
电源指示
R280系列辐射计电源采用一节9V电池供电,可以选择普通碱性电池,也可以选择充电电池。
仪表内部有电源电压检测功能,电池电量不足时,显示器上电池指示标志会闪烁,建议当电池标志闪烁时即时更换电池,在换电池时,内存数据可以保持一分钟。电量严重不足时,仪表会自动关机,存储数据将会丢失
II 四 、 Radiation Scanner 软 件
使用“R280型辐射计”和Radiation Scanner计算机软件可以将辐射计中的数据读取出到计算机上并转换为图像化数据以方便进一步的数据处理。除此之外,Radiation Scanner计算机软件还可以将辐射计的检测数值实时远传到电脑中,进行显示和分析。
连接辐射计和电脑的USB线
电脑和辐射计连接示意图
R280型辐射计,通过专用的USB连接线与电脑连接,可以方便地实现远程监视和存储功能。这一功能对现场辐射较大,并不得不随时监控的场合,提供了最佳解决方案。
专用USB连接线长度:一般提供1米长的连接线,必要时可以提供5米长的连接线。可以通过USB延长器,最多延长到100米。
系统要求
          1、 CD-ROM或者DVD-ROM主要用于安装软件
          2、 WIN 2000、WIN XP、WIN VISTA
软件安装
          1、打开光盘中“中文版本,进入Radiation Scanner运行“
点击“Install”按钮开始安装,然后按照提示, 安装程序默认释放到“c:\SiLabs\MCU_3”文件夹中。 释放完毕后,选中“Launch the CP210X VCP Driver Installer”选项,再点击 “FINISH”选项,弹出如下菜单:
点击“Install”,继续完成安装。 如果没有弹出此菜单,请到“c:\SiLabs\MCU_3”文件夹中找到CP210xVCPInstaller.exe, 双击后运行此程序。
  2、 运行: 安装完成后,在“开始→程序→coliy”下可以找到Radiation Scanner项,点击即可以启动软件。也可点击桌面快捷方式启动软件。
  3、 软件卸载: 点击“开始→程序→coliy→Uninstall Radiation”,根据提示信息即可将软件从计算机中移除。
辐射计软件安装失败的解决办法
软件和驱动程序安装完成,但是联机失败可进行下列检查:
          1、是否按下辐射计的“USB”按键,如果没有请按下该键。
          2、打开系统属性(具体方法是:右键点击“我的电脑”点击“属性”),进入到“设备管理器”中检查端口一栏是否显示正常,如果不正常则显示一个黄色三角形(中间一个感叹号)。这时需要更
          新驱动程序,具体方法是:在系统安装盘(一般是C盘)找到“SiLabs”文件夹,依次打开“C:\SiLabs\MCU\CP210x\Windows_2K_XP_S2K3_Vista”文件夹,运行“CP210xVCPInstaller”文件,可以自动更新驱动程序,更新过程中请勿运行其它应用程序。更新完成到“设备管理器”中检查端口一栏中黄色三角形是否消失,如果消失则表示端口正常可以使用,否则需要重复上述操作。
连接辐射计
第一步:将辐射计与计算机用USB连接线连接起来、。
第二步:自动连接:点击菜单“操作→自动联机”或者点击工具栏上的自动联机图标,系统即可以进行自动连接辐射计。
联机成功:手动设置联机或者自动联机,联机成功后系统会给出提示。
工具栏上自动联机图标,点击此图标
联机失败:手动设置联机或者自动联机,联机失败后系统会给出提示。
联机失败的原因除了上面提示的两个外还有很多种的,下面再给出几种供参考:
            1、 驱动程序没有安装完全,可通过更新驱动程序来完成。
            2、 USB连接线故障。
如果上述问题都不存在,可以关闭软件再启动,多试几次,一般可以连接成功。
联机测量
连机成功后,可以进行联机测量。点击菜单“操作→联机测量”快捷键CtrlT或者点击工具栏上“联机测量”图标。
如果需要暂停,点击菜单“操作→暂停测量”或者点击工具栏暂停测量图标,系统进入暂停联机测量状态。
联机测量主界面:
工具栏上联机测量图标,点击此图标
Y轴是剂量率刻度值,会自动调整;X轴是记测量的数据量。显示区域内最多可以显示目前20个即时测量的数据。
如果想观察以前的数据,请点击工具栏上“当前趋势图”图标。在这个趋势图中可以看到一次连续(中间没有断开或者暂停)测试的所有数据信息。拖动滚动条可以查看所有测试数据的测试信息。
当前趋势图中只能看到当前的测量数据的趋势变化图,如果想要查看以前的测量趋势图,则可以通过历史趋势图来实现。方法是点击工具栏上“历史趋势图”图标打开以前测量的所有数据的趋势图。在历史趋势图中可以查看所有未删除的历史测量数据的趋势图。
点击图标后,选择“采集日期”,再选择“采集时间”,在采集时间中会显示这一天所有采集数据的起始时间点。如果选择的日期上没有任何采集数据则会显示“No Data”,显示趋势图的主界面上显示“无数据”。拖动滚动条可以查看所有测试数据的测试信息。
显示间隔设定
点击菜单“设置→显示间隔设定...”或者点击工具栏显示间隔设定图标打开显示间隔设定界面。
点击可以改变时间间隔值,时间间隔值的范围是2~60秒,默认为2秒。设定显示间隔值在再次启动软件时依然有效。
显示间隔是指联机测量时每次采集的数据的间隔时间。
报警设定
点击菜单“设置→报警设定...”或者点击工具栏上报警设定图标打开报警设定界面。
选中“报警”则报警开,这时可以设定“报警阈值”。报警默认为关,报警阈值默认为5μSv/h。报警值设定范围是1~1000μSv/h,增量是1μSv/h。
打开报警设定后,当采集到的剂量率数值超过了设定的报警阈值后,即开始报警。报警的方式是记录超限的剂量率值和时间,并显示在软件左侧,同时发出报警音。报警记录最多可以同时显示255个报警值,超过则删除前面的报警值。
保存联机测量数据
联机测量采集的数据可以保存为EXCEL格式文件或者TEXT文本文件供测试者进一步分析使用。
点击菜单“文件→保存在线数据...”或者点击工具栏保存在线数据图标弹出保存数据对话框。
功能是将当前连续采集的数据保存到文件中。支持的文件类型有Excel文件(.xls)和Text文件(.txt)两种。
读辐射计存储数据
联机成功后点击菜单“操作→读辐射计存储数据”或者点击工具栏图标,即开始进行读辐射计存储数据。如果系统是在联机测量状态中,则会给出提示:
点击按钮“是(Y)”开始读取辐射计存储数据,点“否(N)”则
默认保存文件名
默认保存文件类型
放弃读取辐射计存储数据。如果系统不在联机测量状态则会直接进入到读取辐射计存储数据状态中。
读取过程中要等一段时间,这个时间与辐射计中存储的数据量多少有关,存储的数据越多需要的时间则越多。这个过程中软件会出现不能操作的状态,这是软件延时造成的,并不是死机。
上方显示的是“单次采集数据”,下方显示的是“自动采集数据”。如果辐射计中的存储数据只有 “单次采集数据”或者“自动采集数据”一种,则界面上只显示这一种数据的信息而不会显示另一种。
每一个黄色立体代表一次采集的数据点,在其上方有该数据点的详细信息:采集日期、采集时间、剂量率信息。拖动滚动条可以查看所有数据。
保存辐射计存储数据
辐射计中的存储数据读取到软件中可以保存到Excel文件或者Text文件中供使用者分析数据。
点击菜单“文件→保存辐射计存储数据...”或者工具栏保存辐射计存储数据图标弹出保存对话框。这个功能是将读取的辐射计中的所有数据保存到文件中。如果只想保存其中的一种数据可以点击菜单“文件→保存辐射计单次存储数据...”或者“文件→保存辐射计自动存储数据...”来完成,保存方式与上述一致,不再赘述。
如果读取的辐射计存储数据没有保存,在退出软件时会给出提示,询问是否要保存辐射计存储数据,如果点选“是(Y)”则保存数据,保存方式同上,选择“否(N)”则放弃保存并退出程序。
擦除辐射计数据
辐射计中的存储空间有限,需要将已存储的数据删除来存放新的存储数据。辐射计中的存储数据被擦除后将无法复原,因此这个操作要谨慎进行。
点击菜单“操作→擦除辐射计存储数据”或者工具栏擦除辐射计存储数据图标,系统会弹出一个提示框询问是否要擦除辐射计数据
点击按钮“是(Y)”则擦除辐射计中存储数据,点“否(N)”则不进行擦除。擦除成功后会给出提示“存储数据擦除完成!”
选项说明
点击菜单“设置→选项...”打开选项配置子界面。选项中有三个设置模块:保存设置、数据管理、联机设置。
1、保存设置
手动保存的模式是在关闭软件时给出提示询问是否需要保存联机测量数据;自动保存的模式是在关闭软件时自动保存联机测量的数据。
点击单选按钮“自动保存”时弹出对话框提示选择自动保存的文件夹:
点击“确定”软件将记录选择的自动保存数据的文件夹,“取消”则视为放弃选择自动保存。这个设定的文件目录也是其他数据保存的默认文件目录。
默认文件类型:保存数据时提供的默认保存文件类型,系统默认为Excel文件,在保存数据时可以通过选择文件类型来改变保存的文件类型。自动保存模式下将把数据保存为设定的文件类型。
2、数据管理
采集日期栏会将有记录数据的日期全部显示出来。点击要查看的日期后,在采集时间栏会显示该日期内所有采集数据的起始时刻,并在采集信息栏显示该时刻采集的信息的详细信息:起始采集时间、终止采集时间、采集的数据中的最大值与最小值、数据量。
点击要保存采集数据的采集时间,“保存”按钮可用,点击“保存”按钮弹出保存对话框,保存方法与上述保存一致。
点击要删除数据的采集时间,然后点击“删除”按钮弹出删除确认
“确定”删除数据,“取消”放弃删除数据。
清理的功能是释放磁盘空间,联机测量采集的的数据保存在磁盘上,删除这些采集的数据后,这些占用的磁盘空间并没有被完全释放,这就需要通过点击“清理”按钮手动释放这些空间。点击“清理”按钮后,软件开始自动清理和释放磁盘空间,清理完成弹出完成信息:
3、联机设置
联机设置是指辐射计联机成功后的操作,有三个操作选项:
无操作:联机成功后不进行任何操作,等待用户的操作。
启动联机测量:联机成功后,立即启动联机测量。
读取存储数据:联机成功后,立刻开始读辐射计中存储数据。
II 四 、 Radiation Scanner 软 件 Page29
五、技术参数
测量射线种类
β、γ和Χ射线
测量量程
辐射剂量率:0.01μSv/h - 1000μSv/h
脉冲计量率:0-300,000cpm (0-5000cps)
辐射剂量累计值:0.001μSv – 999999Sv
脉冲计量累计值:0-999999个
灵敏度
能量为1μSv/h的Cobalt-60射线环境背景下,108个脉冲或1000 cpm/mR/hr
贝塔射线- 从0.2 兆伏特
伽玛射线- 从0.02 兆伏特
X射线- 从0.02 兆伏特
探测器
卤素填装探测器
输出端口
USB电脑连接口(有专用USB线延长线可选,可延长到100米)
显示
大屏幕4位数字LCD, 可显示各种检测数值,带棒图显示
报警功能
可自由设定报警值,缺省设置为5μSv/hr
精度
<10%(500μSv/h以下) <20%(500μSv/h以上)
存储功能
可存储2000个数据,可手动或自动存储
探测器工作温度
-40℃ 到 75℃
II 五 、 技 术 参 数 Page31
重量
500克
尺寸
L 190mm, W 88mm, H 40 mm
电源
1节9V层叠碱性电池
质量认证
European CE, US FCC 15
质量保证期
主机一年
六、保修
德国柯雷技术有限公司保证它制造的每一个仪表在材料和工艺上没有缺陷。
所有产品在运送给原始消费者后保修一年。
德国柯雷技术有限公司保留在任何时间改变设计的权利。
此中文使用手册由德国柯雷技术有限公司翻译并提供。
II 七 、 附 录
七、附录
单位转换公式
UNITS OF RADIATION MEASUREMENT
The curie is the number of particles per second from 1 gram of Radium = 3.7 x 10 E10 counts/second = 37 billion cps = 37 billion Becquerel.
1 Becquerel (Bq) = 1 count per second = 1 event per second
1 microcurie = 1 uCi = 37,000 Bq = 37,000 cps.
1 microcurie = 2.22 x 10E6 disintegrations / minute = 2,220,000 cpm.
1 nanocurie = 1 billionth of a curie = 2,220 disintegrations / minute.
1 picocurie = 2.2 disintegrations / min.
Dosage units:
Gray (Gy) = 1 Joule/kg
Sievert (Sv) = Gray x QF, where QF is a "quality factor" based on the type
of particle. The Sievert is a measure of biological effect.
QF for electrons, positrons, and xrays = 1 QF = 3 to 10 for neutrons,
protons dependent upon the energy transferred by these heavier particles.
QF = 20 for alpha particles and fission fragments.
Converting older units:
1 rad = 1 centigray = 10 milligrays ( 1 rad = 1cGy = 10 mGy )
1 rem = 1 centisievert = 10 millisieverts ( 1 rem = 1cSv = 10 mSv )
1 mrad = 10 μGy
Nominal background radiation absorbed dose of 100 mrad/year = 1 mGy/yr.
Nominal background radiation dose biological equivalent of 1mrem/year = 10μSv/yr.
Occupational whole body limit is 5 rem/yr = 50 μsv/yr. ( Recently proposed that levels be reduced to 2 rem/yr.)
2.5 mrem/hr or 25 μSv/hr is maximum average working level in industry.
Exposure rate from Naturally Occurring Radioactive Material (NORM) ; an
empirically derived conversion factor for Ra-226 decay series: 1.82 microR/hour = 1 picoCurie/gram.
mR/h=10μSv/h
mR=10μSv
II 七 、 附 录
sievert的含义:
在物理学上,我们已经知道三种射线α、β、γ (Χ射线属于低能γ射线范围),它们不但有不同的物理特性,而且作用于人体的效果也不一样。为了让这三种射线在作用于人体时可以比较,一个数值被建立起来,这个数值基于射线作用于生物体的效果。
sievert西弗特 (符号Sv, 剂量当量单位, 1 Sv=100 rem)
rem roentgen equivalent man) 雷姆, 人体伦琴当量
校正因子计算方法
假如标定三个数据点:7.5uSv/h,75uSv/h,750uSv/h。在这三个剂量率测量点上测到实时数据取样分别如下(此时仪器的校正因子S0):
7.5uSv/h:
7.27
7.3
7.57
7.12
6.79
6.97
6.49
7.27
7.98
7.63
8.04
7.74
7.33
7.33
7.09
6.91
6.67
7.39
7.21
75uSv/h:
70.99
71.3
72.34
73.38
73.56
74.48
72.95
73.87
73.99
73.75
73.26
73.26
69.71
68.49
68.49
68.73
70.32
69.89
70.81
750uSv/h:
747.3
754.52
758.02
751.57
751.49
746.3
742.89
752.66
754.99
745.99
745.99
750.41
748.86
742.5
759.5
765.42
759.5
769.95
775.34
计算三个点的平均值分别为:V1 = 7.268421 uSv/h
V2 = 71.76684 uSv/h
V3 = 753.8526 uSv/h。
根据这三个数据可计算新的校准因子S:
S = (V1×S0/7.5 V2×S0/75 V3×S0/750)/ 3
例如:S0 = 2.1,则根据上面3组测量数据修正后校正因子后,
S = (7.268421×2.1/7.5 71.76684×2.1/75 753.8526×2.1/750)/ 3
= 2.051806
≈2.05
中国总代理:北京华瑞森科技发展有限公司
北京通州张家湾开发区光华路16号方和正圆写字楼A座209-211
Tel/Fax:010-51266093(总机)010-57118919(直线) 13501267210
QQ:1275041125          邮编:101113
E-mail:huarui51266093@163.com
http://
